Grove Crane RT9130E Parts Manual 2016
Brand: Grove
Model: Grove RT9130E Crane
Serial Number: 229296
Publication Date: 2016
Number of Pages: 1145 Pages
Boom Assembly - 5 Section (Complete Assembly)
Sheave Installation - 2 Over 7
Sheave Assembly
Cylinder Assembly - 9 1/4" Telescope (Dual Rods)
Cylinder Assembly - 7 1/2" Telescope (Complete Assembly)
Cable Guide Assy
Upper Lift Pin Installation
Luffing Ext 11-18
Swing-Away Boom 11-18m
Mtg.Parts 1.3m, 11-18m
Sheave Holder
Mtg.Parts 10m, 11-18m
E-Parts Terminal Box
Jib Mtg.Parts 11m
Jib Mtg.Parts 7m, 11-18m
Jib Mtg.Parts 7m
Jib Comp Parts 18m
Insert 8m (26ft) Gmk5100
Hook Block Assembly - 80 Ton Quick Reeve
Ball Assembly - Overhaul 10 Ton Swivel
Hook Block Tie-Down Installation
Boom Lights Install
Switch Install-Boom Lights
Lmi Boom Kit - Iflex 5 (Bcs)
Cable Reel Lwg521-Iflex5 (Bcs)
Slip Ring Assembly - 11 Cond.
Cable Reel-Iflex5 (Bcs)
Roller Guide Assembly
Flag Assembly - A2b Retainer
Lmi Boom Kit Installation -Iflex5 Bcs
Wedge Socket Adapter Kit
Boom Removal Kit
Removal Assembly
Cylinder Assembly - 2" Pin Removal (Complete Assembly)
Hydr Pipe Diagram Bolt Dwg Dev
Hose Assys
Sheave Holder Gmk 5100
Switch Assembly - Limit
Lmi Bi-Fold Boom Ext Install Kit
Kit Installation - Lmi System (Superstructure)
Harness Assembly - Jib Extension
Lmi Aux Nose Kit
Kit Installation - Auxiliary Nose Lmi
Turntable Section
Hose Reel Installation
Reel Assembly - Hose
Brake Assembly
Motor Assembly - Hydraulic (Complete Assembly)
Swivel Assembly - 11 Port Hydraulic (Complete Assembly)
Lever Installation -Counterweight Removal
Valve Installation - Control (Superstructure)
Valve Assembly - Control
Valve Assembly - Counterweight (Complete Assembly)
Valve Assembly - Selector
Valve Assy - Pressure Reducing Sequence (Complete Assembly)
Valve Assembly - Directional Control
Accumulator Assembly - Hydraulic Oil
Valve Assembly -Dual Pilot Operated Check (Complete Assembly)
Valve-Manual Bleed Off Pressur
Solenoid Valve - 4 Wheel Dr
Lift Hyd Lines Install-S/S
Rope-Hoisting 19mm 35x7 290m
Cylinder Installation - Lift
Cylinder Assembly - 14" Lift (Complete Assembly)
19mm Hoisting Rope 35x7x214m
Bolt Installation - Bearing
Switch Assembly - Pressure (Modified)
Valve Assembly - Shuttle
Socket, 3/4'' Open Wedge
Swing Hyd Lines Install-S/S
Lmi Hyd Lines Install-S/S
Binder Installation
Hydraulic Lines Installation - Counterweight Removal
Counterweight Install-24000 Lb
Cylinder Assembly - 4" Counterweight Removal
Hoist Assembly - Hp35 - 26g (Complete Assembly)
Clutch Assy.
Cylinder Assembly - 3" Hoist Pin Removal
Heavy Counterweight Install
Mirror Installation - Hoist
M. & Aux Hoist Hyd Lines Install
Lift Hyd Lines Install-Cab
Steer Hyd Lines Install-Cab
Brake Hyd Lines Install-Cab
Valve Cover Install
Esi-S/S
Ha-Superstructure
T/T Lock Pin Install
Hose Retainer Installation
Lines Installation - Motor Case Drain Air Conditioner
Lock Installation - Swing 360 Degree
Cab Installation
Cab (With Door Installation)
Skylight Assembly - Sliding
Valve Assembly With Treadle Pedal
Ctrl Seat Install W/Main & Aux
Ctrl Seat Assy W/Main & Aux
Acoustics Install - Rt"E"
Rt"E" Series Acoustics Kit
Spotlight Installation
Light Installation - Strobe
Front Console Installation
Console Assembly - Front (Complete Assembly)
Panel Assembly - Front Console (Complete Assembly)
360 Lever Install
Screen Installation - Sun
Cab Tilt Installation
Cylinder Assembly - 2 1/2" Steer (Complete Assembly)
Cover Installation - Cab Rear
Lmi Internal Light Bar Kit
Kit - Lmi Iflex 5 Cab (For Bcs Machines)
Centeral Unit - Iflex 5
Pedal Installation - Brake
Steer Valve Installation
Steering Control Valve
Pole Installation -Jib Release
Frame - Complete
Box Installation - Outrigger
Cylinder Assembly -6 1/2" Outrigger Jack (Complete Assembly)
Box Assembly - Outrigger (Complete Assembly)
Cylinder Assembly - 4" Power Pin (Complete Assembly)
Harness Assembly - Outrigger Box
Fender Installation
Hood Installation - Engine
Front Sub Assembly - Hood
Exterior Lights And Alarm Installation
Cover Installation - Battery Box
Stand Installation - Counterweight
Cooler Installation - Hydraulic And Transmission Oil
Cooler Assembly - Hydraulic And Transmission Oil
Storage Tray Mat Inst'l
Box Assembly - Outrigger Pin Controls (Complete Assembly)
Cable Assy - Lh Remote O/R Rem
Lift Cyl Travel Support Install
Lift Cyl Travel Support Ass'y
Bottle Jack (Modified)
Hydraulic Reservoir Install
Hydraulic Reservoir Assembly
Hydraulic Reservoir
Filter Assembly
Hydraulic Valve Installation Without Differential-Carrier
Valve Assembly - Integrated Outrigger/ Rear Steer
Valve Assy-Axle Dis & Park Bra
Sling Assembly
O/R Hyd Lines-Carr
Solenoid Valve 2 Way N.O.
Hydraulic Lines Installation - Rear Axle Lockout
Serv Brake Hyd Lines-Disc
Axle Disc & Park Brake Lines
Axle Assembly - Rear Drive Steer Standard Differential
Diff.Carr.Group
Housing Group
Hub & Shaft Group
Brake Group, 4 Set
Brake Assy.Group
Cylinder Assembly - 7" Lockout (Complete Assembly)
Axle Assembly - Front Drive Steer Standard Differential
Driveline Installation
Tire And Wheel Installation
Tire And Wheel Assembly
Wheel Assembly
Engine Installation - Cummins Qsc (With Air Conditioning)
Engine Assembly - Cummins Qsc (With Air Conditioning)
Converter Assembly - Torque (Complete Assembly)
Torque Convertor Group
Charge Pump And Regulating Valve Group
Pump Assy. Charging
Dual Pump Disconnect Group
Pump Assembly - 2 Section Gear (Complete Assembly)
Pump Assembly - Gear With Flow Control
Hydraulic Lines Installation - Engine
Transmission Installation
Transmission Assembly
Input Shaft And Cover Group
Case And Rear Cover Group
Drive Group - Low Speed
Forward Clutch And Shaft Group
Shaft Group - Reverse And Second
Shaft Group - First Clutch
Idler Group - Forward High
Shaft Group - Forward High And Third
Idler Shaft Group
Shaft Group - Output
Control Valve Mounting Group
Flange Group
Transmission Filter/Lines Installation
Radiator Installation
Radiator Assembly (Not Available As Assembly)
Tank Installation - Fuel
Tank Assembly - Fuel
Tank Assembly - Fuel 100 Gallon
Mounting Kit - Oil Cooler
Cable Kit-Rt9000e Batteries
System Installation - Exhaust
Cleaner Installation - Air
Strainer Installation - Coolant
Disconnect Installation - Pump
Miscellaneous Decals
Decal Installation - Rt9000e Series Standard
Decal Installation - Rt9000e Standard Cab
Decal Installation - Rt9000e (Standard Carrier)
Decal Installation - Rt9000e (Standard Superstructure)
Decal Installation - Rt9000e (Standard Boom)
Decal Installation - Rt9130e (Nomenclature)
Hardware Kit - Decal
Brand: Grove
Sheave Assembly
Cable Guide Assy
Luffing Ext 11-18
Sheave Holder
Jib Mtg.Parts 11m
Jib Mtg.Parts 7m
Jib Comp Parts 18m
Boom Lights Install
Boom Removal Kit
Removal Assembly
Hose Assys
Lmi Aux Nose Kit
Turntable Section
Brake Assembly
Binder Installation
Clutch Assy.
Valve Cover Install
Esi-S/S
Ha-Superstructure
Cab Installation
360 Lever Install
Frame - Complete
Fender Installation
Hydraulic Reservoir
Filter Assembly
Sling Assembly
O/R Hyd Lines-Carr
Diff.Carr.Group
Housing Group
Hub & Shaft Group
Brake Group, 4 Set
Brake Assy.Group
Wheel Assembly
Pump Assy. Charging
Idler Shaft Group
Flange Group
