118
6,911
Grove Crane RT9130E Parts Manual 2011
Brand: Grove
Model: Grove RT9130E Crane
Serial Number: 226581
Publication Date: 2011
Number of Pages: 1129 Pages
Boom Assembly
Sheave Installation - 2 Over 7
Sheave Assembly
Cylinder Assembly - 9 1/4" Telescope (Dual Rods)
Cylinder Assembly - 7 1/2" Telescope (Complete Assembly)
Cable Guide Assy
Upper Lift Pin Installation
Luffing Ext 11-18
Swing-Away Boom 11-18m
Jib Comp Parts 18m
Hook Block Assembly - 80 Ton Quick Reeve
Ball Assembly - Overhaul 10 Ton Swivel
Hook Block Tie-Down Installation
Boom Lights Install
Switch Install-Boom Lights
Socket, 3/4’’ Open Wedge
Lmi Boom Kit - Iflex 5 (Bcs)
Cable Reel Assy. Iflex 5 176’
Slip Ring Assembly - 11 Cond.
Cable Reel Assy. Iflex 5 87’
Roller Guide Assembly
Flag Assembly - A2b Retainer
Lmi Boom Kit Installation -Iflex5 Bcs
Wedge Socket Adapter Kit
Boom Removal Kit
Removal Assembly
Cylinder Assembly - 2" Pin Removal (Complete Assembly)
Hydr Pipe Diagram Bolt Dwg Dev
Switch Assembly - Limit
Lmi Bi-Fold Boom Ext Install Kit
Kit Installation - Lmi System (Superstructure)
Lmi Aux Nose Kit
Kit Installation - Auxiliary Nose Lmi
Turntable Section
Lock Assembly - Swing
Hose Reel Installation
Reel Assembly - Hose
Brake Assembly
Motor Assembly - Hydraulic (Complete Assembly)
Swivel Assembly - 11 Port Hydraulic (Complete Assembly)
Lever Installation -Counterweight Removal
Valve Installation - Control (Superstructure)
Valve Assembly - Control
Valve Assembly - Counterweight (Complete Assembly)
Valve Assembly - Selector
Valve Assy - Pressure Reducing Sequence (Complete Assembly)
Valve Assembly - Directional Control
Accumulator Assembly - Hydraulic Oil
Valve Assembly -Dual Pilot Operated Check (Complete Assembly)
Valve-Manual Bleed Off Pressur
Lift Hyd Lines Install-S/S
Main & Aux Hoist Hyd Lines Ins
Cylinder Installation - Lift
Cylinder Assembly - 14" Lift (Complete Assembly)
19mm Hoisting Rope 35x7x214m
Bolt Installation - Bearing
Switch Assembly - Pressure (Modified)
Valve Assembly - Shuttle
Swing Hyd Lines Install-S/S
Lmi Hyd Lines Install-S/S
Binder Installation
Hydraulic Lines Installation - Counterweight Removal
Counterweight Install-24000 Lb
Cylinder Assembly - 4" Counterweight Removal
Hoist Assembly - Hp35 - 26g (Complete Assembly)
Cylinder Assembly - 3" Hoist Pin Removal
Heavy Counterweight Install
Mirror Installation - Hoist
M. & Aux Hoist Hyd Lines Install
Lift Hyd Lines Install-Cab
Steer Hyd Lines Install-Cab
Brake Hyd Lines Install-Cab
Valve Cover Install
T/T Lock Pin Install
Hose Retainer Installation
Lines Installation - Motor Case Drain Air Conditioner
Cab Installation
Cab (With Door Installation)
Skylight Assembly - Sliding
Valve Assembly With Treadle Pedal
Ctrl Seat Install W/Main & Aux
Ctrl Seat Assy W/Main & Aux
Acoustics Install - Rt"E"
Rt"E" Series Acoustics Kit
Spotlight Installation
Light Installation - Strobe
Console Installation - Front
Console Assembly - Front (Complete Assembly)
Panel Assembly - Front Console (Complete Assembly)
Harness Assembly - Front Console (Complete Assembly)
360 Lever Install
Screen Installation - Sun
Cab Tilt Installation
Cylinder Assembly - 2 1/2" Steer (Complete Assembly)
Cover Installation - Cab Rear
Lmi Internal Light Bar Kit
Esi-S/S
Ha-Superstructure
Kit - Lmi Iflex 5 Cab (For Bcs Machines)
Centeral Unit - Iflex 5
Pedal Installation - Brake
Steer Valve Installation
Steering Control Valve
Pole Installation -Jib Release
Frame - Complete
Box Installation - Outrigger
Cylinder Assembly -6 1/2" Outrigger Jack (Complete Assembly)
Box Assembly - Outrigger (Complete Assembly)
Cylinder Assembly - 4" Power Pin (Complete Assembly)
Harness Assembly - Outrigger Box
Fender Installation
Kit, Hardware Fender Installation
Hood Installation - Engine
Front Sub Assembly - Hood
Exterior Lts & Alarm Install
Cover Installation - Battery Box
Stand Installation - Counterweight
Cooler Installation - Hydraulic And Transmission Oil
Cooler Assembly - Hydraulic And Transmission Oil
Storage Tray Mat Inst’l
Box Assembly - Outrigger Pin Controls (Complete Assembly)
Cable Assy - Lh Remote O/R Rem
Lift Cyl Travel Support Install
Lift Cyl Travel Support Ass’y
Bottle Jack (Modified)
Hydraulic Reservoir Install
Hydraulic Reservoir Assembly
Hydraulic Reservoir
Filter Assembly
Hydraulic Valve Installation Without Differential-Carrier
Valve Assembly - Integrated Outrigger/ Rear Steer
Valve Assy-Axle Dis & Park Bra
Sling Assembly
O/R Hyd Lines-Carr
Solenoid Valve 2 Way N.O.
Hydraulic Lines Installation - Rear Axle Lockout
Serv Brake Hyd Lines-Disc
Axle Disc & Park Brake Lines
Axle Assembly - Rear Drive Steer Standard Differential
Diff.Carr.Group
Housing Group
Hub & Shaft Group
Brake Group, 4 Set
Brake Assy.Group
Cylinder Assembly - 7" Lockout (Complete Assembly)
Axle Assembly - Front Drive Steer Standard Differential
Driveline Installation
Tire And Wheel Installation
Tire And Wheel Assembly
Wheel Assembly
Engine Installation - Cummins
Engine Assembly - Cummins (Not Available As Assembly)
Converter Assembly - Torque (Complete Assembly)
Torque Convertor Group
Charge Pump And Regulating Valve Group
Pump Assy. Charging
Dual Pump Disconnect Group
Pump Assembly - 2 Section Gear (Complete Assembly)
Pump Assembly - Gear With Flow Control
Hydraulic Lines Installation - Engine
Heater Installation - Block (Not Available As Assembly)
Transmission Installation
Transmission Assembly
Input Shaft And Cover Group
Case And Rear Cover Group
Drive Group - Low Speed
Forward Clutch And Shaft Group
Shaft Group - Reverse And Second
Shaft Group - First Clutch
Idler Group - Forward High
Shaft Group - Forward High And Third
Idler Shaft Group
Shaft Group - Output
Control Valve Mounting Group
Flange Group
Transmission Filter/Lines Installation
Radiator Installation
Radiator Assembly (Not Available As Assembly)
Tank Installation - Fuel
Tank Assembly - Fuel
Tank Assembly - Fuel 100 Gallon
Mounting Kit - Oil Cooler
Cable Kit-Rt9000e Batteries
System Installation - Exhaust
Cleaner Installation - Air
Strainer Installation - Coolant
Disconnect Installation - Pump
Hook Installation - Pintle
Rt9000e Decal Installation
Decal Installation - Rt9000e Series
Decal Installation - Rt9000e Foreign Standard
Decal Installation - Rt9000e (Standard)
Decal Installation - Rt9000e (Standard Cab)
Decal Installation - Rt9000e (Standard Carrier)
Decal Installation - Rt9000e (Standard Superstructure)
Decal Installation - Rt9000e (Standard Boom)
Decal Installation - Rt9130e (Nomenclature)
Decal Installation - Rt9130e (Spanish)
Hardware Kit - Decal
