702,019
Grove Crane RT530E-2 280145 Parts Manual 2015
Brand: Grove
Model: Grove RT530E-2 Crane
Serial Number: 280145
Publication Date: 2015
Number of Pages: 906 Pages
Boom Assembly Complete (95')
Boom Assembly 95'
Pointer Assembly
Sheave Assembly - 5/8" Rope
Light Installation - Boom
Light Assembly - Modified
Socket Assy 5/8"
Cable Reel Lwg508 - Iflex 5
Roller Guide Assembly
Box Assembly - Junction
Flag Assembly - A2b Retainer
Kit-Lmi Auxiliary Boom Nose
Tele-Off Boom Extension Kit
Lmi Aux Boom Nose Kit Install
Kit - Lmi S/S Iflex 5
Nose Installation - Auxiliary
Mast Assembly
Bottle Jack Assy (Modified)
Lmi Cab Kit Installation -Iflex2
Lmi Cab Kit, Iflex2, Expert
Boom Mount Installation
Turntable & Drive Installation (Rotek)
16mm Dia Hoisting Wire Rope -
Lock Installation - 360 Swing
Counterweight Installation
Slip Ring Assy 20 Cond W/Slew
Control Valve Installation
Directional Control Val(4sect)
Accessory Manifold
T/T Pin Lock Control Installation
Hydraulic Lines Installation Main & Auxiliary Hoist
Hoist Assembly - Hp15c/17g With 3rd Wrap
Roller Assy. Idler Group
Bolt Installation - Bearing
Mirror Installation - Hoist
Cylinder Installation - Lift
Lift Cylinder Assembly
Valve - Lift Cyl Pilot Hold
Binder Installation
Air Cond Lines Kit - S/S
A/C Condenser-Vert. Mtg. 24v.
Valve Cover Installation
Esi-Superstructure
Harness Assembly -Ss
Diode (Modified)
360 Swing Lock Pedal Install
Pedal Assembly - Foot (Complete Assembly)
Light Installation - Strobe
Washer Bottle Installation
Cab Assembly -24v Brazil
Cab Sub- Assembly - (Sg-24v)
Glass Door Assembly
Window Assembly - Side Rh
Kit - Skylight Wiper (24 Volt)
Kit - Front Wiper (24 Volt)
Heater & A/C Installation - Superstructure Cab
24v Heater/Cool Kit
Acoustics Installation (Sg)
Cab Misc Components
Cab Brackets Installation
Pedal Group Installation
Swing Brake Pedal-5v
Pedal, Throttle 5v
Cab Crane Star Installation
Protective Tape Strip Install
Control Seat Installation -Dual Axis With Auxiliary Hoist
Control Seat Assembly -Dual Axis With Auxiliary Hoist
Controller Assembly - 8-32 Volt Right Hand Armrest
Harness Assembly -Seat
Heater & Air Condition Control Panel Installation
Heat/Ac Control 12v/24v Grove
Plastic Covers Installation
Pedal Assembly - Electronic Telescope (Complete Assembly)
Drive Controls Installation
Steering Column W/ Cluster
Boom Light Switch
Esi-Cab
Fuse & Relay Panel Assembly
Fuse & Relay Harness Assy
Overhead Console Assembly
Harness Assembly -Overhead Cab Panel
Panel Assy-Front Console
Harness Assembly -Front Panel Cab
Harness Assembly -Superstructure Cab
Receptacle Harness
Rear Cab Cover Installation
3rd Wrap Indicator Installation
Fire Extinguisher Installation
Fire Extinguisher Assembly
Harness-Swing Brake Jumper
Rework-Brake Pedal
Roller Assembly
Cab Installation -Components
Tcu And Sat Antenna Kit
Carrier Frame Complete
Frame Assembly
Outrigger Beam Install-Br
Outrigger Beam Assembly -Br
O/R Ext Cyl-Complete Assy Br
Decking Installation -Fender
Ladder Assembly
Engine Hood Installation
O/R Float Installation
Outrigger Float Assembly
Battery Box Cover Installation
Outrigger Controller Installation
Outrigger Controller Assembly
Cable Assembly
Hardware Kit - Decal
Esi-Carrier
Hydraulic Tank Installation
Hydraulic Reservior Assembly
Filter Assy. Hyd. Return
Hydraulic Valve Installation
Park Brake Range Shift Valve
Valve-Axle Lockout
O/R Rear Steer Valve
Solenoid Valve Assembly
Rear Axle Installation W/O Differential Lock
Drive Steer Axle
Diff. Carrier Group
Axle Housing Group
Hub & Shaft Group
Brake Group
Brake Assembly ,Group
Cyl Assembly -2.50 Steer Br
Cylinder - Lockout Br
Front Axle Installation Without Differential Lock
Driveline Installation
Engine Installation -Brazil
Engine Assembly -Brazil
Transmission-T20000
Converter Housing Group
Case & Rear Cover Group
Turbine Shaft Group
Drive Plate Group
Torque Converter Group
Gear Group
Auxiliary Pump Drive Group
Pump Drive Group
Forward Shaft Group
Reverse & 2nd. Shaft Group
Reverse Idler Group
Low Speed Shaft Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Charging Pump Group
Control Valve Mounting Group 24 Volt
Control Valve Assy.Group 24v.
Pump Ass'y With Flow Divider
Esi-Engine
Wiring Harness-Engine T3
Brake-Park Assy W/Spacer
Radiator Installation -Brazil
Radiator Assembly -Brazil
Fuel Tank Installation -T3
Mounting Kit - Oil Cooler
Battery Box Installation
Battery Box Assembly
Fuse Panel Assembly
Harness Assembly -Engine Relay Panel
Battery Cable Kit
Exhaust System Installation
Air Cleaner Installation -Brz
Air Cleaner Assembly
Hydraulic Oil Cooler Install
Air Condition Installation -Carrier
A/C Hose Kit-Carrier
Block Heater Installation -Qsb 120v
Step Installation -Hoist Access
Oil Cooler Installation
Oil Cooler-Transmission
Decal Installation -Standard
Decal Installation -Standard Cab
Decal Installation -Standard Carrier
Decal Installation -Standard Ss
Decal Installation -Rt530e-2 Nomenclature
Alphabetical Index
Recommended Spare Parts List
Belt And Filter Maintenance List
