Grove Crane RT530E-2 258600 Parts Manual 2019
Brand: Grove
Model: Grove RT530E-2 Crane
Serial Number: 258600
Publication Date: 2019
Number of Pages: 839 Pages
Boom Assembly 95'
Cylinder Assembly - Telescope(Complete Assembly)
Valve Assembly -Counterbalance
Lights Installation - Boom(Domestic)
Light Assembly - Modified Boom(Complete Assembly)
Cable Reel Lwg508 - Iflex 5
Roller Guide Assembly
Box Assembly - Junction
A2b Flag Assy
Ball Assembly - Overhaul(7.5 Ton)
Socket Assy 5/8"
Pointer Assembly
Sheave Assembly - 5/8" Rope
Counterweight Installation -(C.E. Conformity)
Swivel Installation -Electric, Water And Hydraulic
Swivel Assembly -Electric, Water And Hydraulic
Swivel Assy-14 Port Hyd Assy.
Ring Assembly - Slip15 Conductor
Control Valve Installation main & Future Auxiliary Hoist
Directional Control Val(4sect)
Valve Assy. Inlet Section
Valve Assy. Work Section
Solenoid & Cap Assy. 12v
Hydraulic Lines Installation main And Future Auxiliary Hoist
Hoist Installation - Main(C.E. Conformity)
Hoist Assembly - Hp15c/17gwith 3rd Wrap
Bolt Installation - Bearing
Mirror Installation - Hoist
Cylinder Installation - Lift
Lift Cylinder Assembly
Valve - Lift Cyl Pilot Hold
Binder Installation
Kit - Lmi S/S Iflex 5
Air Conditioning Installation -Superstructure
Kit - Air Conditioner Condenser(Complete Assembly)
Valve Cover Installation
Electrical System Installation -Ss
Lube Installation - Turntable Bearingmanual
Light Installation - Strobe
Light Assembly - Modified Strobe(Complete Assembly)
Cab Assembly
Door Installation - Cab(Not Available As Assembly)
Kit - Skylight Wiper(Complete Assembly)
Kit - Front Wiper(Complete Assembly)
Skylight Assembly - Sliding(Complete Assembly)
Window Assembly - Rear(Complete Assembly)
Window Assembly - Right Hand(Complete Assembly)
Fan Assembly - 12 Volt Cab(Complete Assembly)
Seat Installation without Auxiliary Hoist
Seat Assembly without Auxiliary Hoist
Switch Assembly - Proximity(Normally Open)
Controller Assembly - 12voltright Hand Armrest
Handle Assy. W/Thumper
Harness Assembly - Seat(Complete Assembly)
Acoustics Installation
Front Console Installation
Front Console Assembly
Gauge, 12 Volt Tachometer(With Hourmeter)
Panel Assembly - Fuse And Relay(Superstructure Cab)
Harness Assembly - Fuse And Relay Panel(Superstructure Cab)
Heater/Cooler Installation - Cab
Kit - Cab Heater And Air Conditioner(Complete Assembly)
Screen Installation - Sun
Kit - Iflex2 Lmi Cab(Complete Assembly)
Lines Installation - Air Conditioning(Cab)
Kit - Air Conditioner Hose(Complete Assembly)
Cover Installation - Rear Cab
Switch Installation - Boom Lights
Pedals Installation -Without Auxiliary Hoist
Valve Assembly - Brake Treadle(Complete Assembly)
Column Assembly - Modified Tilt Steering(Complete Assembly)
Column Assembly - Tilt Steering(Complete Assembly)
Harness Assembly - Turn Signal/Washer(Complete Assembly)
Harness Assembly - Shifter(Complete Assembly)
Indicator Installation - 3rd Wrap
Cab Crane Star Install Rt540e
Harness Assembly -Crane Star Tcu
Canbus Crane Assembly (Retro)
Harness Assembly -Supplementalsuperstructure Cab Fuse & Relay
Cab Installation Components
Step Installation hoist Access
Cab Crane Star Installation
Tcu And Sat Antenna Kit
Carrier Frame Complete
Carrier Frame
Carrier Frame Assembly
Outrigger Beam Installation
Outrigger Beam Assembly
Cylinder Assembly -4.00 Jack
Cylinder Assembly Modified
Fender And Deck Installation hoist Access
Hood Installation - Engine
Float Assembly - Outrigger(Complete Assembly)
Lights Installation - Exterior(Domestic)
Step Installation
Hardware Kit - Decal
Electrical System Installation - Carrier(Rt540e/Rt530e2)
Harness Assembly - Carrier(Complete Assembly)
Panel Assembly - Engine Relays(Complete Assembly)
Harness Assembly - Engine Relay Panel(Complete Assembly)
Hydraulic Tank Installation
Reservoir Assembly - Hydraulic(Complete Assembly)
Filter Assy. Hyd. Return
Hydraulic Valve Installation -Carrier
Valve Assembly - Park Brake Range Shift(Complete Assembly)
Valve Assembly - Axle Lockout(Complete Assembly)
O/R Rear Steer Valve
Tray Installation - Storage (With Mat)
Axle Installation - Rearwithout Differential Lock
Axle Assembly - Drive/Steer(Complete Assembly)
Diff.Carr. Group @ 4.67 Ratio
Housing & Hub Group
Planetary Hub Group
Steer Cylinder Group
Brake Group
Cylinder Assembly - 5" Lockout(Complete Assembly)
Axle Installation - Front
Tire & Wheel Installation -20.5 X 25jiangsu
Tire & Wheel Assembly -20.5 X 25jiangsu
Driveline Installation
Driveline Assembly with Center Bearing
Engine Installation
Engine Assembly - Cummins Qsb6.7(Not Available As Assembly)
Transmission Assembly - 3 Speed12 Volt
Converter Housing Group
Case & Rear Cover Group
Turbine Shaft Group
Drive Plate Group
Torque Converter Group
Gear Group
Auxiliary Pump Drive Group
Pump Drive Group
Forward Shaft Group
Reverse & 2nd. Shaft Group
Reverse Idler Group
Low Speed Shaft Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Charge Pump & Filter Group
Control Valve Mounting Group
Control Valve Assy. Group
Brake Assembly - Parking(Complete Assembly)
Harness Assembly - Engine(Complete Assembly)
Kit - Cable (Engine)(Complete Assembly)
Brake-Park Assy W/Spacer
Radiator Installation -Italy
Radiator Assembly -Italy
Radiator Cac Toc
Surge Tank Assembly
Fuel Tank Installation
Mounting Kit - Oil Cooler
Ladder Assembly
Kit - Cable (Batteries)Rt535
System Installation - Exhaust
Air Cleaner Installation
Cleaner Assembly - Air(Complete Assembly)
Hydraulic Oil Cooler Installation
Fenders Kit-Hoist Access
Kit - Cummins Air Conditioner Compressor12 Volt
Kit - Carrier A/C Hose
Block Heater Assembly - 120v
Fan Installation - Non Ce
Carrier Crane Star Installation
Harness Assembly -Carrier
16mm Dia Hoisting Wire Rope -
Miscellaneous Decals
Decal Installation -Rt540estandard Cab
Decal Installation - Rt535e(Standard Carrier)
Decal Installation - Rt535e(Standard Superstructure)
Decal Installation - Rt535e(Standard Boom)
Decal Installation -Rt530e-2nomenclature
