Grove Crane RT530E-2 258285 Parts Manual 2021
Brand: Grove
Model: Grove RT530E-2 Crane
Serial Number: 258285
Publication Date: 2021
Number of Pages: 747 Pages
Boom Assembly - 4 Section(Complete Assembly)
Cylinder Assembly - Telescope(Complete Assembly)
Valve Assembly -Counterbalance
Cable Reel Lwg508 - Iflex 5
Roller Guide Assembly
Box Assembly - Junction
A2b Flag Assy
Kit Installation - Iflex 5 Lmi Boom(For Reference Only)
Hook Block Assembly - 33 Ton (30 Mt)(Complete Assembly)
Socket Assy 5/8"
Pointer Assembly
Sheave Assembly - 5/8" Rope
Counterweight Installation -(C.E. Conformity)
Swivel Installation -Electric, Water And Hydraulic
Swivel Assembly -Electric, Water And Hydraulic
Swivel Assy-14 Port Hyd Assy.
Ring Assembly - Slip15 Conductor
Control Valve Installation -Main And Future Auxiliary Hoist
Valve Assembly - Directional Control4 Section
Valve Assy. Inlet Section
Hydraulic Lines Installation -Main And Future Auxiliary Hoist
Hoist Installation - Main
Hoist Assembly - Hp15c/17g(Complete Assembly)
Cable Roller Assy. Group
Bolt Installation - Bearing
Mirror Installation - Hoist
Cylinder Installation - Lift
Lift Cylinder Assembly
Valve - Lift Cyl Pilot Hold
Binder Installation
Kit - Lmi S/S Iflex 5
Cover Installation - Valve
Lube Installation - Turntable Bearingmanual
Cab Installation
Cab Assembly
Door Installation - Cab(Not Available As Assembly)
Kit - Skylight Wiper(Complete Assembly)
Kit - Front Wiper(Complete Assembly)
Skylight Assembly - Sliding(Complete Assembly)
Rear Window Assembly
Window Assembly -Rh
Fan Assembly -12v (Cab)
Cab Light Assembly -12v
Seat Installation without Auxiliary Hoist
Seat Assembly without Auxiliary Hoist
Switch Assembly - Proximity(Normally Open)
Controller Assembly - 12voltright Hand Armrest
Handle Assy. W/Thumper
Harness Assembly - Seat(Complete Assembly)
Acoustics Installation
Console Installation - Front(Rt540e/Rt530e2)
Console Assembly - Front(Rt540e/Rt530e2)
Harness Assembly - Front Console(Complete Assembly)
Gauge, 12 Volt Tachometer(With Hourmeter)
Panel Assembly - Fuse And Relay(Superstructure Cab)
Harness Assembly - Fuse And Relay Panel(Superstructure Cab)
Heater/Cooler Installation - Cab
Kit - Cab Heater And Air Conditioner(Complete Assembly)
Screen Installation - Sun
Kit - Iflex2 Lmi Cab(Complete Assembly)
Console Assembly - Graphic (Color)(Complete Assembly)
Harness Assembly - Superstructure(Complete Assembly)
Cover Installation - Rear Cab
Pedals Installation -Without Auxiliary Hoist
Valve Assembly - Brake Treadle(Complete Assembly)
Column Assembly - Modified Tilt Steering(Complete Assembly)
Column Assembly - Tilt Steering(Complete Assembly)
Harness Assembly - Turn Signal/Washer(Complete Assembly)
Harness Assembly - Shifter(Complete Assembly)
Step Installation hoist Access
Carrier Frame Complete
Carrier Frame
Carrier Frame Assembly
Outrigger Beam Installation (Complete Assembly)
Outrigger Beam Assembly
Cylinder Assembly - 4" Outrigger Jack(Complete Assembly)
Cylinder Assembly - Outrigger Extension(Complete Assembly)
Fender And Deck Installation hoist Access
Hood Installation - Engine
Float Assembly - Outrigger(Complete Assembly)
Lights Installation - Exterior(Domestic)
Step Installation
Hardware Kit - Decal
Electrical System Installation - Carrier(Rt540e/Rt530e2)
Harness Assembly - Carrier(Complete Assembly)
Panel Assembly - Engine Relays(Complete Assembly)
Harness Assembly - Engine Relay Panel(Complete Assembly)
Tank Installation - Hydraulic
Reservoir Assembly - Hydraulic(Complete Assembly)
Filter Assy. Hyd. Return
Ladder Assembly (Complete Assembly)
Valve Installation - Hydraulic(Carrier)
Valve Assembly - Park Brake Range Shift(Complete Assembly)
Valve Assembly - Axle Lockout(Complete Assembly)
Valve Assembly - Outrigger Selector Rear Steer
Tray Installation - Storage
Axle Installation - Rearwithout Differential Lock
Axle Assembly - Drive/Steer(Complete Assembly)
Diff.Carr. Group @ 4.67 Ratio
Housing & Hub Group
Planetary Hub Group
Steer Cylinder Group
Brake Group
Cylinder Assembly - 5" Lockout(Complete Assembly)
Axle Installation - Front
Tire And Wheel Installation -General 16.00 X 25
Tire And Wheel Assembly -General 16.00 X 25
Wheel Assembly - 11.25" X 25"(Complete Assembly)
Driveline Installation
Driveline Assembly with Center Bearing
Engine Installation
Engine Assembly - Cummins Qsb6.7(Not Available As Assembly)
Transmission Assembly - 3 Speed12 Volt
Converter Housing Group
Case & Rear Cover Group
Turbine Shaft Group
Drive Plate Group
Torque Converter Group
Gear Group
Auxiliary Pump Drive Group
Pump Drive Group
Forward Shaft Group
Reverse & 2nd. Shaft Group
Reverse Idler Group
Low Speed Shaft Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Charge Pump & Filter Group
Control Valve Mounting Group
Control Valve Assy. Group
Brake Assembly - Parking(Complete Assembly)
Harness Assembly - Engine(Complete Assembly)
Kit - Cable (Engine)(Complete Assembly)
Brake-Park Assy W/Spacer
Radiator Installation
Radiator Assembly (Not Available As Assembly)
Cooler Assembly - Radiator/Charge Air(Complete Assembly)
Tank Assembly - Surge(Not Available As Assembly)
Tank Installation - Fuel
Tank Assembly - 58 Gallon Fuel(Complete Assembly)
Mounting Kit - Oil Cooler
Kit - Cable (Batteries)Rt535
System Installation - Exhaust
Air Cleaner Installation
Cleaner Assembly - Air(Complete Assembly)
Oil Cooler Installation -Hydraulic
Hydraulic Cooler
Fenders Kit-Hoist Access
Block Heater Assembly - 120v
Fan Installation - Non Ce
16mm Dia Hoisting Wire Rope -
Miscellaneous Decals
Decal Installation -Rt540estandard Cab
Decal Installation - Rt535e(Standard Carrier)
Decal Installation - Rt535e(Standard Superstructure)
Decal Installation - Rt535e(Standard Boom)
Decal Installation - Rt530e2(Nomenclature)
