Grove Crane RT530E-2 258260 Parts Manual 2019
Brand: Grove
Model: Grove RT530E-2 Crane
Serial Number: 258260
Publication Date: 2019
Number of Pages: 737 Pages
Boom Assembly 95'
Cylinder Assembly - Telescope(Complete Assembly)
Valve Assembly -Counterbalance
Cable Reel Lwg508 - Iflex 5
Roller Guide Assembly
Box Assembly - Junction
Flag Assembly - A2bretainer
Hook Block Assembly - 33 Ton (30 Mt)(Complete Assembly)
Socket Assy 5/8"
Pointer Assembly
Sheave Assembly - 5/8" Rope
Counterweight Installation -(C.E. Conformity)
Swivel Installation -Electric, Water And Hydraulic
Swivel Assembly -Electric, Water And Hydraulic
Swivel Assy-14 Port Hyd Assy.
Ring Assembly - Slip15 Conductor
Control Valve Installation -Main And Future Auxiliary Hoist
Valve Assembly - Directional Control4 Section
Valve Assy. Inlet Section
Hydraulic Lines Installation main And Future Auxiliary Hoist
Hoist Installation - Main
Hoist Assembly - Hp15c/17g(Complete Assembly)
Cable Roller Assy. Group
Bolt Installation - Bearing
Mirror Installation - Hoist
Cylinder Installation - Lift
Lift Cylinder Assembly
Valve - Lift Cyl Pilot Hold
Binder Installation
Kit - Lmi S/S Iflex 5
Cover Installation - Valve
Electrical System Installation -Ss
Lube Installation - Turntable Bearingmanual
Cab Installation
Cab Assembly
Door Installation - Cab(Not Available As Assembly)
Kit - Skylight Wiper(Complete Assembly)
Kit - Front Wiper(Complete Assembly)
Skylight Assembly - Sliding(Complete Assembly)
Window Assembly - Rear(Complete Assembly)
Window Assembly - Right Hand(Complete Assembly)
Fan Assembly - 12 Volt Cab(Complete Assembly)
Seat Installation without Auxiliary Hoist
Seat Assembly without Auxiliary Hoist
Switch Assembly - Proximity(Normally Open)
Controller Assembly - 12voltright Hand Armrest
Handle Assy. W/Thumper
Harness Assembly - Seat(Complete Assembly)
Acoustics Installation
Front Console Installation
Front Console Assembly
Gauge, 12 Volt Tachometer(With Hourmeter)
Panel Assembly - Fuse And Relay(Superstructure Cab)
Harness Assembly - Fuse And Relay Panel(Superstructure Cab)
Heater/Cooler Installation - Cab
Kit - Cab Heater And Air Conditioner(Complete Assembly)
Screen Installation - Sun
Kit - Iflex2 Lmi Cab(Complete Assembly)
Cover Installation - Rear Cab
Pedals Installation -Without Auxiliary Hoist
Valve Assembly - Brake Treadle(Complete Assembly)
Column Assembly - Modified Tilt Steering(Complete Assembly)
Column Assembly - Tilt Steering(Complete Assembly)
Harness Assembly - Turn Signal/Washer(Complete Assembly)
Harness Assembly - Shifter(Complete Assembly)
Step Installation hoist Access
Carrier Frame Complete
Carrier Frame Installation
Carrier Frame Assembly
Outrigger Beam Installation
Ourtrigger Beam Assembly
Cylinder Assembly - 4" Outrigger Jack(Complete Assembly)
Cylinder Assembly Modified
Fender And Deck Installation hoist Access
Hood Installation - Engine
Float Assembly - Outrigger(Complete Assembly)
Lights Installation - Exterior(Domestic)
Step Installation
Hardware Kit - Decal
Electrical System Installation - Carrier(Rt540e/Rt530e2)
Harness Assembly - Carrier(Complete Assembly)
Panel Assembly - Engine Relays(Complete Assembly)
Harness Assembly - Engine Relay Panel(Complete Assembly)
Tank Installation - Hydraulic
Reservoir Assembly - Hydraulic(Complete Assembly)
Filter Assy. Hyd. Return
Ladder Assembly (Complete Assembly)
Axle Installation - Rearwithout Differential Lock
Axle Assembly - Drive/Steer(Complete Assembly)
Diff.Carr. Group @ 4.67 Ratio
Housing & Hub Group
Planetary Hub Group
Steer Cylinder Group
Brake Group
Cylinder Assembly - 5" Lockout(Complete Assembly)
Axle Installation - Front
Tire And Wheel Installation jiangsu 16x25
Tire And Wheel Assembly jiangsu 16x25
Driveline Installation
Driveline Assembly with Center Bearing
Engine Installation
Engine Assembly - Cummins Qsb6.7(Not Available As Assembly)
Transmission Assembly - 3 Speed12 Volt
Converter Housing Group
Case & Rear Cover Group
Turbine Shaft Group
Drive Plate Group
Torque Converter Group
Gear Group
Auxiliary Pump Drive Group
Pump Drive Group
Forward Shaft Group
Reverse & 2nd. Shaft Group
Reverse Idler Group
Low Speed Shaft Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Charge Pump & Filter Group
Control Valve Mounting Group
Control Valve Assy. Group
Brake Assembly - Parking(Complete Assembly)
Harness Assembly - Engine(Complete Assembly)
Kit - Cable (Engine)(Complete Assembly)
Brake-Park Assy W/Spacer
Radiator Installation
Radiator Assembly (Not Available As Assembly)
Cooler Assembly - Radiator/Charge Air(Complete Assembly)
Tank Assembly - Surge(Not Available As Assembly)
Tank Installation - Fuel
Tank Assembly - 58 Gallon Fuel(Complete Assembly)
Mounting Kit - Oil Cooler
Kit - Cable (Batteries)Rt535
System Installation - Exhaust
Air Cleaner Installation
Cleaner Assembly - Air(Complete Assembly)
Oil Cooler Installation -Hydraulic
Hydraulic Cooler
Fenders Kit-Hoist Access
Block Heater Assembly - 120v
Fan Installation - Non Ce
16mm Dia Hoisting Wire Rope -
Miscellaneous Decals
Decal Installation -Rt540estandard Cab
Decal Installation - Rt535e(Standard Carrier)
Decal Installation - Rt535e(Standard Superstructure)
Decal Installation - Rt535e(Standard Boom)
Decal Installation - Rt530e2(Nomenclature)
Brand: Grove
Boom Assembly 95'
Socket Assy 5/8"
Pointer Assembly
Binder Installation
Cab Installation
Cab Assembly
Step Installation
Housing & Hub Group
Planetary Hub Group
Brake Group
Engine Installation
Turbine Shaft Group
Drive Plate Group
Gear Group
Pump Drive Group
Forward Shaft Group
Reverse Idler Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Hydraulic Cooler
