Grove Crane RT530E-2 258174 Parts Manual 2009
Brand: Grove
Model: Grove RT530E-2 Crane
Serial Number: 258174
Publication Date: 2009
Number of Pages: 745 Pages
Socket Assy 5/8"
Cable Reel Lwg508 - Iflex 5
Box Assembly - Junction
Flag Assembly - A2b Retainer
Kit - Lmi Auxiliary Boom Nose
Kit Installation - Iflex 5 Lmi Boom (For Reference Only)
Extension Installation - Jib Boom
Load Moment Indicator Kit Installation - Auxiliary Boom
Nose Installation - Auxiliary
Sheave Assembly - 5/8" Rope
Pointer Assembly
26-45' O/S Boom Ext Install
26'-45' Boom Ext Assembly
Sheave Assembly
Mast Assembly
Bottle Jack (Modified)
Cab Installation
Cab Assembly
Cab Weld
Window Assembly - Right Hand (Complete Assembly)
Extinguisher, Fire
Seat Installation - Dual Axis Control (With Auxiliary Hoist)
Seat Assembly - Dual Axis Control (With Auxiliary Hoist)
Controller Can 12v Lh W/Ar
Controller Can 12v Rh Armrest
Acoustics Installation
Console Installation - Front (Rt540e/Rt530e2)
Console Assembly - Front (Rt540e/Rt530e2)
Harness Assembly - Front Console (Complete Assembly)
Panel Assembly - Fuse And Relay (Superstructure Cab)
Harness Assembly - Fuse And Relay Panel (Superstructure Cab)
Heater/Cooler Installation - Cab
Screen Installation - Sun
Binder Installation
Kit, Lmi S/S Iflex 5
Harness Assembly - Superstructure (Complete Assembly)
Cover Installation - Rear Cab
Pedals Installation - With Auxiliary Hoist
Pedal Assembly - Electronic Telescope (Complete Assembly)
16mm Dia Hoisting Wire Rope -
Mirror Installation - Hoist
Control Valve Installation - Main And Auxiliary Hoist
Valve Assembly - Directional Control 4 Section
Bolt Installation - Bearing
Cylinder Installation - Lift
Kit - Air Conditioner Condenser (Complete Assembly)
Cover Installation - Valve
Cooler Installation - Hydraulic Oil
Cooler Assembly - Hydraulic Oil (Complete Assembly)
Hood Installation - Engine
Engine Installation
Radiator Installation
Radiator Assembly (Not Available As Assembly)
System Installation - Exhaust
Cleaner Installation - Air
Kit - Cummins Air Conditioner Compressor 12 Volt
Kit - Carrier A/C Hose
Fan Installation - Non Ce
Driveline Installation
Diff.Carr. Group @ 4.67 Ratio
Housing & Hub Group
Planetary Hub Group
Steer Cylinder Group
Brake Group
Axle Installation - Front
Tire And Wheel Installation - 20.5 X 25 General
Tire And Wheel Assembly - 20.5 X 25 General
Wheel Assembly - 17.00" X 25" (Complete Assembly)
Carrier Frame Complete
Carrier Frame
Carrier Frame Assembly
Outrigger Beam Installation (Complete Assembly)
Outrigger Beam Assembly
Cylinder Assembly - 4" Outrigger Jack (Complete Assembly)
Decal Installation Rt540e Standard-Cab
Decal Installation - Rt530e2 (Nomenclature)
Step Installation
Hardware Kit - Decal
Tank Installation - Hydraulic
Filter Assy. Hyd. Return
Ladder Assembly (Complete Assembly)
Valve Installation - Hydraulic (Carrier)
Valve Assembly - Axle Lockout (Complete Assembly)
Valve Assembly - Outrigger Selector Rear Steer
Tray Installation - Storage
Tank Installation - Fuel
Mounting Kit - Oil Cooler
Kit - Cable (Batteries) Rt535
Hydraulic Lines Installation - Carrier
Brand: Grove
Socket Assy 5/8"
Pointer Assembly
Sheave Assembly
Mast Assembly
Cab Installation
Cab Assembly
Cab Weld
Extinguisher, Fire
Binder Installation
Engine Installation
Housing & Hub Group
Planetary Hub Group
Brake Group
Carrier Frame
Step Installation
