Grove Crane RT530E-2 258166 Parts Manual 2008
Brand: Grove
Model: Grove RT530E-2 Crane
Serial Number: 258166
Publication Date: 2008
Number of Pages: 713 Pages
Lights Installation - Boom (Domestic)
Cable Reel Lwg508 - Iflex 5
Box Assembly - Junction
Flag Assembly - A2b Retainer
Kit Installation - Iflex 5 Lmi Boom (For Reference Only)
Socket Assy 5/8"
Pointer Assembly
Sheave Assembly - 5/8" Rope
Cab Installation
Cab Assembly
Cab Weld
Window Assembly - Right Hand (Complete Assembly)
Controller Assembly - 8-32 Volt Right Hand Armrest
Acoustics Installation
Console Installation - Front (Rt540e/Rt530e2)
Console Assembly - Front (Rt540e/Rt530e2)
Harness Assembly - Front Console (Complete Assembly)
Panel Assembly - Fuse And Relay (Superstructure Cab)
Harness Assembly - Fuse And Relay Panel (Superstructure Cab)
Heater/Cooler Installation - Cab
Screen Installation - Sun
Binder Installation
Kit, Lmi S/S Iflex 5
Harness Assembly - Superstructure (Complete Assembly)
Cover Installation - Rear Cab
Switch Installation - Boom Lights
Hydraulic Lines Installation - Main And Future Auxiliary Hoist
16mm Dia Hoisting Wire Rope -
Hoist Installation - Main
Mirror Installation - Hoist
Control Valve Installation - Main And Future Auxiliary Hoist
Valve Assembly - Directional Control 4 Section
Bolt Installation - Bearing
Cylinder Installation - Lift
Cover Installation - Valve
Counterweight Installation
Light Installation - Strobe
Cooler Installation - Hydraulic Oil
Cooler Assembly - Hydraulic Oil (Complete Assembly)
Hood Installation - Engine
Engine Installation
Transmission Assembly - 6 Speed 12 Volt
Converter Housing Group
Case & Rear Cover Group
Turbine Shaft Group
Drive Plate Group
Torque Converter Group
Gear Group
Auxiliary Pump Drive Group
Pump Drive Group
Forward Shaft Group
Reverse & 2nd. Shaft Group
Reverse Idler Group
Low Speed Shaft Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Charge Pump & Filter Group
Control Valve Mounting Group
Control Valve Assy. Group
Radiator Installation
Radiator Assembly (Not Available As Assembly)
System Installation - Exhaust
Cleaner Installation - Air
Fan Installation - Non Ce
Driveline Installation
Axle Installation - Front
Tire And Wheel Installation - 20.5 X 25 General
Tire And Wheel Assembly - 20.5 X 25 General
Wheel Assembly - 17.00" X 25" (Complete Assembly)
Carrier Frame Complete
Carrier Frame
Carrier Frame Assembly
Outrigger Beam Installation (Complete Assembly)
Outrigger Beam Assembly
Cylinder Assembly - 4" Outrigger Jack (Complete Assembly)
Decal Installation Rt540e Standard-Cab
Decal Installation - Rt530e2 (Nomenclature)
Step Installation
Hardware Kit - Decal
Tank Installation - Hydraulic
Filter Assy. Hyd. Return
Ladder Assembly (Complete Assembly)
Valve Installation - Hydraulic (Carrier)
Valve Assembly - Axle Lockout (Complete Assembly)
Valve Assembly - Outrigger Selector Rear Steer
Tray Installation - Storage
Tank Installation - Fuel
Mounting Kit - Oil Cooler
Kit - Cable (Batteries) Rt535
Hydraulic Lines Installation - Carrier
