Grove Crane RT530E-2 258010 Parts Manual 2008
Brand: Grove
Model: Grove RT530E-2 Crane
Serial Number: 258010
Publication Date: 2008
Number of Pages: 705 Pages
Cable Reel Lwg508 - Iflex 5
Box Assembly - Junction
Flag Assembly - A2b Retainer
Kit Installation - Iflex 5 Lmi Boom (For Reference Only)
Extension Installation - Jib Boom
Socket Assy 5/8"
Pointer Assembly
26-45’ O/S Boom Ext Install
26’-45’ Boom Ext Assembly
Sheave Assembly
Mast Assembly
Sheave Assembly - 5/8" Rope
Bottle Jack (Modified)
Cab Installation
Cab Assembly
Cab Weld
Window Assembly - Right Hand (Complete Assembly)
Controller Assembly - 8-32 Volt Right Hand Armrest
Acoustics Installation
Console Installation - Front (Rt540e/Rt530e2)
Console Assembly - Front (Rt540e/Rt530e2)
Harness Assembly - Front Console (Complete Assembly)
Panel Assembly - Fuse And Relay (Superstructure Cab)
Harness Assembly - Fuse And Relay Panel (Superstructure Cab)
Lever Installation - 360 Degree Swing Brake
Heater/Cooler Installation - Cab
Screen Installation - Sun
Binder Installation
Kit, Lmi S/S Iflex 5
Harness Assembly - Superstructure (Complete Assembly)
Cover Installation - Rear Cab
Valve Installation - Control Main And Future Auxiliary Hoist
Valve Assembly - Directional Control 4 Section
Hydraulic Lines Installation - Main And Future Auxiliary Hoist
16mm Dia Hoisting Wire Rope -
Hoist Installation - Main
Mirror Installation - Hoist
Turntable Section
Lock Installation - 360 Swing
Bolt Installation - Bearing
Cylinder Installation - Lift
Cover Installation - Valve
Counterweight Installation
Cooler Installation - Hydraulic Oil
Cooler Assembly - Hydraulic Oil (Complete Assembly)
Hood Installation - Engine
Engine Installation
Transmission Assembly - 6 Speed 12 Volt
Converter Housing Group
Case & Rear Cover Group
Turbine Shaft Group
Drive Plate Group
Torque Converter Group
Gear Group
Auxiliary Pump Drive Group
Pump Drive Group
Forward Shaft Group
Reverse & 2nd. Shaft Group
Reverse Idler Group
Low Speed Shaft Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Charge Pump & Filter Group
Control Valve Mounting Group
Control Valve Assy. Group
Radiator Installation
Radiator Assembly (Not Available As Assembly)
System Installation - Exhaust
Cleaner Installation - Air
Fan Installation - Non Ce
Axle Installation - Front
Tire And Wheel Installation - 20.5 X 25 General
Tire And Wheel Assembly - 20.5 X 25 General
Wheel Assembly - 17.00" X 25" (Complete Assembly)
Driveline Installation
Decal Installation Rt540e Standard-Cab
Fender & Decking Installation
Decal Installation - Rt530e2 (Nomenclature)
Step Installation
Hardware Kit - Decal
Tank Installation - Hydraulic
Filter Assy. Hyd. Return
Ladder Assembly (Complete Assembly)
Valve Installation - Hydraulic (Carrier)
Valve Assembly - Axle Lockout (Complete Assembly)
Valve Assembly - Outrigger Selector Rear Steer
Tray Installation - Storage
Tank Installation - Fuel
Mounting Kit - Oil Cooler
Kit - Cable (Batteries) Rt535
Hydraulic Lines Installation - Carrier
Brand: Grove
Socket Assy 5/8"
Pointer Assembly
Sheave Assembly
Mast Assembly
Cab Installation
Cab Assembly
Cab Weld
Binder Installation
Turntable Section
Engine Installation
Turbine Shaft Group
Drive Plate Group
Gear Group
Pump Drive Group
Forward Shaft Group
Reverse Idler Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Step Installation
