Grove Crane RT530E-2 258002 Parts Manual 2019
Brand: Grove
Model: Grove RT530E-2 Crane
Serial Number: 258002
Publication Date: 2019
Number of Pages: 825 Pages
Boom Assembly 95'
Cylinder Assembly - Telescope(Complete Assembly)
Valve Assembly -Counterbalance
Alarm Installation - Lmi
Cable Assembly - Lmi Alarm(Complete Assembly)
Cable Reel Lwg508 - Iflex 5
Roller Guide Assembly
Box Assembly - Junction
A2b Flag Assy
Ball Assembly - Overhaul(7.5 Ton)
Hook Block Assembly - 33 Ton (30 Mt)(Complete Assembly)
Socket Assy 5/8"
Pointer Assembly
Cover Installation - Boom Hole
Sheave Assembly - 5/8" Rope
Swivel Installation -Electric, Water And Hydraulic
Swivel Assembly -Electric, Water And Hydraulic
Ring Assembly - Slip15 Conductor
Valve Installation - Control Main And Future Auxiliary Hoist
Valve Assembly - Directional Control4 Section
Valve Assy. Inlet Section
Accumulator Assembly -Hydraulic Oil
Hydraulic Lines Installation -Main And Future Auxiliary Hoist
Hoist Installation - Main(C.E. Conformity)
Hoist Assembly - Hp15c/17gwith 3rd Wrap
Bolt Installation - Bearing
Cylinder Installation - Lift
Cylinder Assembly - 9" Lift(Complete Assembly)
Valve Assembly - Holding(Complete Assembly)
Binder Installation
Kit - Lmi S/S Iflex 5
Cover Installation - Valve
Electrical System Installation -Ss
Mirror Installation - Turntable
Lube Installation - Turntable Bearingmanual
Counterweight Installation
Hoist Cover Installation - Main(C.E. Conformity)
Foam Kit-Hoist (M)
Mirror Installation - Hoist(Ce With Main Hoist Only)
Valve Foam Cover Installation
Cover Installation - Bottom
Foam Cover Installation -Bottom
Counterweight Foam Installation (Italian)
Counterweight Foam Kit
Lmi Override Installation -(C.E. Conformity)
Lmi Override Assy
Harness Assembly -Supplementalsuperstructure Cab Fuse & Relay
Canbus Crane Assembly (Retro)
Cab Installation (C.E. Conformity)
Cab Assembly (C.E. Conformity)
Door Installation - Cab(Not Available As Assembly)
Kit - Skylight Wiper(Complete Assembly)
Kit - Front Wiper(Complete Assembly)
Window Assembly - Rear(Complete Assembly)
Window Assembly - Right Hand(Complete Assembly)
Fan Assembly - 12 Volt Cab(Complete Assembly)
Seat Installation without Auxiliary Hoist
Seat Assembly without Auxiliary Hoist
Switch Assembly - Proximity(Normally Open)
Controller Assembly - 12voltright Hand Armrest
Handle Assy. W/Thumper
Harness Assembly - Seat(Complete Assembly)
Acoustics Installation
Front Console Installation
Front Console Assembly
Gauge, 12 Volt Tachometer(With Hourmeter)
Panel Assembly - Fuse And Relay(Superstructure Cab)
Harness Assembly - Fuse And Relay Panel(Superstructure Cab)
Heater/Cooler Installation - Cab
Kit - Cab Heater And Air Conditioner(Complete Assembly)
Screen Installation - Sun
Kit - Iflex2 Lmi Cab(Complete Assembly)
Cover Installation - Rear Cab
Switch And Lamp Installation -Cross Axle
Pedals Installation -Without Auxiliary Hoist
Valve Assembly - Brake Treadle(Complete Assembly)
Column Assembly - Modified Tilt Steering(Complete Assembly)
Column Assembly - Tilt Steering(Complete Assembly)
Harness Assembly - Turn Signal/Washer(Complete Assembly)
Harness Assembly - Shifter(Complete Assembly)
Indicator Installation - 3rd Wrap
Indicator Installation -Low Steer Pressure
Step Installation hoist Access
Carrier Frame Complete
Carrier Frame Installation
Carrier Frame Assembly
Outrigger Beam Installation
Ourtrigger Beam Assembly
Cylinder Assembly - 4" Outrigger Jack(Complete Assembly)
Cylinder Assembly Modified
Fender And Deck Installation hoist Access
Hood Installation - Engine
Counterweight Installation with C.E. Conformity Modified - Italy
Float Assembly - Outrigger(Complete Assembly)
Lights Installation - Exterior(C.E. Conformity)
Head/Turn Signal Signal Light Assembly - Left Hand
Head/Turn Signal Signal Light Assembly - Right Hand
Harness Assembly - Front Lightsc. E. Conformity
Harness Assembly - Marker Lightc. E. Conformity
Harness Assembly - Rear Lightsc. E. Conformity
Step Installation
Hardware Kit - Decal
Cover Installation - Outriggerbeam
Electrical System Installation - Carrier(Rt540e/Rt530e2)
Harness Assembly - Carrier(Complete Assembly)
Panel Assembly - Engine Relays(Complete Assembly)
Harness Assembly - Engine Relay Panel(Complete Assembly)
Tank Installation - Hydraulic
Reservoir Assembly - Hydraulic(Complete Assembly)
Filter Assy. Hyd. Return
Ladder Assembly (Complete Assembly)
Valve Installation - Hydrauliccarrier With Differential Lock
Valve Assembly - Park Brake Range Shift(Complete Assembly)
Valve Assembly - Outrigger Selector Rear Steer
Valve Assembly - Differential Lockout(Complete Assembly)
Valve Assembly - Differential Lockoutc. E. Conformity
Hydraulic Lines Installation -Carrierwith Differential Lock
Axle Installation - Rearwith Differential Lock
Axle Assembly - Drive/Steerwith Differential Lock
Diff. Carrier Group
Housing And Hub Group
Planetary Hub Group
Steer Cylinder Group
Brake Group
Harness Assembly - Axle Differential Supplemental
Cylinder Assembly - 5" Lockout(Complete Assembly)
Axle Installation - Front With Differential Lock
Tire And Wheel Installation jiangsu 16x25
Tire And Wheel Assembly jiangsu 16x25
Driveline Installation
Driveline Assembly with Center Bearing
Engine Installation
Engine Assembly - Cummins Qsb6.7(Not Available As Assembly)
Transmission Assembly - 3 Speed12 Volt
Converter Housing Group
Case & Rear Cover Group
Turbine Shaft Group
Drive Plate Group
Torque Converter Group
Gear Group
Auxiliary Pump Drive Group
Pump Drive Group
Forward Shaft Group
Reverse & 2nd. Shaft Group
Reverse Idler Group
Low Speed Shaft Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Charge Pump & Filter Group
Control Valve Mounting Group
Control Valve Assy. Group
Brake Assembly - Parking(Complete Assembly)
Harness Assembly - Engine(Complete Assembly)
Kit - Cable (Engine)(Complete Assembly)
Radiator Installation
Radiator Assembly (Not Available As Assembly)
Cooler Assembly - Radiator/Charge Air(Complete Assembly)
Tank Assembly - Surge(Not Available As Assembly)
Tank Installation - Fuel
Tank Assembly - 58 Gallon Fuel(Complete Assembly)
Mounting Kit - Oil Cooler
Kit - Cable (Batteries)Rt535
System Installation - Exhaust
Air Cleaner Installation
Cleaner Assembly - Air(Complete Assembly)
Oil Cooler Installation -Hydraulic
Hydraulic Cooler
Fenders Kit-Hoist Access
Grill Installation -Engine Hood
Foam Installation -Engine Hood
Heater Installation - Block
Fan Installation -Ce Configure
Foam Installation - Engine
Kit, Foam
Panel Install - Carrier Noise
16mm Dia Hoisting Wire Rope -
Miscellaneous Decals
Decal Installation - Rt535/540e(Foreign Standard)
Decal Installation - Rt530e2(Nomenclature)
Decal Installation - Rt530e-2(French)
Supplemental Decal Installation
Brand: Grove
Boom Assembly 95'
A2b Flag Assy
Socket Assy 5/8"
Pointer Assembly
Binder Installation
Foam Kit-Hoist (M)
Lmi Override Assy
Step Installation
Diff. Carrier Group
Planetary Hub Group
Brake Group
Engine Installation
Turbine Shaft Group
Drive Plate Group
Gear Group
Pump Drive Group
Forward Shaft Group
Reverse Idler Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
Disc Brake Group
Hydraulic Cooler
Kit, Foam
