702,169
Grove Crane RT530E-2 236920 Parts Manual 2020
Brand: Grove
Model: Grove RT530E-2 Crane
Serial Number: 236920
Publication Date: 2020
Number of Pages: 863 Pages
Boom Assy Complete (95')
Boom Assembly -95'
Cylinder Assy.Tele 6.31" Bore
Piston Assy. #1
Piston Assy. #2
Head Assy. #1
Cover Assy. #1
Cover Assy. #2
Head Assy. #2
Pointer Assembly
Sheave Install - 2 Over 3
Sheave Assembly - 5/8" Rope
Boom Kit 2 Over 3
Light Installation - Boom
Boom Light Rework
Light Assy - Cab Std 24v
Work Light Ha - Jumper
Rcl Boom Kit Ccs
Cable Reel Lwg509 - Ccs
Box Assembly - Junction
A2b Flag Assy
Kit-Lmi Auxiliary Boom Nose
Rcl Boom Kit Install
Wiring Harness-Boom
Lmi Aux Boom Nose Kit Install
Nose Installation - Auxiliary
Ball Assembly - Overhaul(7.5 Ton)
Boom Mount Installation
Lift Cylinder Install
Lock Installation - 360 Swing
Lock Assembly - Swing(Complete Assembly)
Swivel Assy-14 Port Hyd Assy.
Slip Ring Assy 20 Cond W/Slew
Control Valve Installation
Accessory Manifold W/Swing
Dual Accum Charge Valve
T/T Pin Lock Ctrl Install
Hyd Lines S/S Main&Aux Hoist
Boom Tele Pedal Installation
Hoist Install-Main&Aux (Std)
Hoist Assy. Ccs
Hoist Common Parts Group
Brake Cylinder, Parts Group
Clutch Sprag Assy. Group
Roller Assy. Idler Group
Cable Roller Assy. Group
Bolt Installation - Bearing
Hoist Mirror Installation
Air Cond Lines Kit - S/S
A/C Condenser-Vertical Mount
Binder Installation
Esi - S/S Ccs
Wiring Harness-S/S Ccs
Diode (Modified)
Valve Cover Installation
Light Installation - Strobe
Light Assembly - Modified Strobe(Complete Assembly)
Washer Bottle Installation
Non-Skid Tape Installation
Supply Module Installation
Pump, Def Supply Module,24v
Counterweight Installation
Cab Assy 24v-Ccs
Heat & A/C Install-Ss Cab 24v
Kit - 24v Heater/Cool
Acoustics Installation
Misc Cab Components Install
Brackets Install-Ccs Cab
Pedal Group Installation
Swing Brake Pedal
Valve Assembly - Brake Treadle(Complete Assembly)
Plug Installation
Seat Installation -Dual Axis
Seat Assy-Dual Axis
Riser Assy
Mounting Plate Assembly
Harness Assembly -Seat
Seat With Headrest
Plastic Covers Installation
Ccs Steer Install
Steering Column (W/3 Speeds)
Boom Light Switch
Foot Pedal
Esi-Cab
Fuse & Relay Panel Assembly
Wiring Harness-Fuse & Relay
Panel Assy-Overhead Console
Harness Assy-Ovrhd Panel Ccs
Cab Display Installation
Cab Display Assembly
Display Console
Electr Parts Display Console
Harness Assembly -Cab
Switch Installation (Auxiliary Hoist)
Rear Cab Cover Installation
Tier 4 Regen Switch Install
Cab Installation -Components
Carrier Frame Complete
Frame Weldment & Assembly
Outrigger Beam Installation
Outrigger Beam Assembly
Cyl Hyd - Extension Complete
Cyl Assembly -4.00 Jack
Fender & Decking Installation
Ladder Assembly
Install-Engine Hood
Install, O/R Float
Outrigger Float Assembly
Battery Cover Install
Esi-Carrier
Wiring Harness, Carrier
Extension Carrier Installation
Hardware Kit - Decal
Hydraulic Tank Installation
Hyd Reservior Assembly
Hyd Valve Install Ca
Park Brake Range Shift Valve
Valve-Axle Lockout
O/R Rear Steer Valve
Solenoid Valve Assembly
Axle Install Rear W/O D Lock
Axle,Drive Steer
Diff Carr. Assy. Parts Group
Axle Housing Parts Group
Hub & Shaft Assy. Parts Group
Brake Assy.Parts Group (2-Set)
Cylinder Assembly - 2 1/2" Steer(Complete Assembly)
Cylinder Assembly - 5" Lockout(Complete Assembly)
Axle Installation -Front
T&W 20.5x25 Install-Titan
Wheel & Disc Assy
T & W Assy Parts (Ref 80098157
Driveline Installation
Driveline Assembly with Center Bearing
Engine Install Qsb6.7 160hp
Eng Assembly Qsb6.7 160hp
Converter Housing Group
Case & Rear Cover Group
Turbine Shaft Group
Drive Plate Group
Torque Converter Group
Gear Group
Auxiliary Pump Drive Group
Pump Drive Group
Forward Shaft Group
Reverse & 2nd. Shaft Group
Reverse Idler Group
Low Speed Shaft Group
3rd. Shaft Group
Idler Shaft Group
Output Shaft Group
High & Low Range Shift Group
Disc Brake Group
Control Valve Assy. Group 24 V
Pump Ass'y With Flow Divider
Brake-Park Assy W/O Spacer
Esi, Engine
Wiring Harness-Engine
Alternator Installation
Coolant Lines Install
Fan Install
Install-Radiator
Radiator Assembly
Hydraulic Oil Cooler Install
Fuel Tank Installation
Battery Box Install
Battery Box Assembly
Exhaust Installation
Air Intake Install-T4f
Air Cleaner Assembly
A/C Install, Carrier
Install-Blck Heatr Qsb 120v 10'c
Oil Cooler Installation
Oil Cooler-Transmission
Oms Install
Oms Installation
Def Tank Install
Reservoir, Def 5gal
Def Lines Installation
Scr Coolant Lines Installation
Esi - Exhaust
Wiring Harness-Exh Ccs
24v Warning Light-Modified
Esi - Fuse Box
Wiring Harness-Fb T4
Block Heater Install W/Cord
16mm Dia Hoisting Wire Rope -
Weight-Lmi A2b
Miscellaneous Decals
Decal Installation -Std
Decal Install-Std Cab
Decal Install-Std-Carrier
Decal Install-Std-S/S
Decal Install-Std-Boom
Decal Install-Nomeclature
