Great Plains Heavy Duty Precision Openers 1510HDP 2010HDP 2510HDP Operator Manual
Brand: Great Plains
Type of Machine: 15-, 20-, 25-Foot 3-Point Drills with 10 Series Heavy Duty Precision Openers
Model: 1510HDP, 2010HDP, and 2510HDP
Part Number: 118-245M
Date: 2019
Number of Pages: 180 Pages
Important Safety Information
Safety Reflectors and Decals
Introduction
Document Family
Description of Unit
Intended Usage
Models Covered
Using This Manual
Owner Assistance
Preparation and Setup
Pre-Setup Checklist
Hitching
20- and 25-foot Hitching
15-foot Hitching
Electrical Connections
Hydraulic Hose Hookup (Options)
Older Style Hoses with Color Ties
Leveling the Drill
Leveling: Single-Wheel
Leveling: Offset-Single Wheel
Leveling: Dual-Wheel
Options Setup
Acremeter Installation
Seed Monitor Cab Module
Speed Sensor Installation
Hydraulic Console Installation
Marker Setup
Marker Chain Adjustment
Marker Extension Setup
Marker Extension Adjustment
Operating Instructions
Pre-Start Checklist
Prepare for Planting
Transporting
Loading Materials
Seed Lubricants
Acremeter Operation
Normal Operating Sequence
Dormant Display
Field Operation
Marker Operations
Independent Markers
Dual Auto-Sequenced Markers
Parking
Storage
Adjustments
Planting Depth
Material Rate Adjustments
Main Box Seed Rate
Checking Main Box Seed Rate
Small Seeds Attachment Rate
Fertilizer Rate
Row Unit Adjustments
Unit-Mounted Coulter Adjustments
Row Unit Down-Force
Row Unit Shutoff
Disk Blade Adjustments
Meter Adjustments
Seed Firmer Adjustments
Press Wheel Adjustments
Marker Adjustments
Marker Disk Angle
Marker Speed
Hydraulic Drive Operation
Drive Operational Requirements
Hydraulic System:
Electrical System:
Tractor Hookup
Hydraulics:
Electrical:
Controller Menu
Console Functions
Calibration
Speed Calibration
Operations
Before going to the field
In Field
Hydraulic Drive Calibration
Varying Rates with Pre-set Function
GPS-Based Planting
FarmWorks SiteMate
GP Precision Population Settings
Troubleshooting with SiteMate
Ag Leader PF3000
Troubleshooting with PF3000
Hydraulic Drive Maintenance
To change the element:
Hydraulic Drive Troubleshooting
Drive will not rotate:
Drive rotates but not at desired speed:
Calibration Troubleshooting:
Hydraulic Drive Troubleshooting Flow Chart
Hydraulic Drive Electronics Troubleshooting
Troubleshooting
Maintenance and Lubrication
Materials Clean-Out
Main Seed Box Clean-Out
Small Seeds Box Clean-Out
Fertilizer Clean-Out
Meter Maintenance
Singulator Plus Meter Maintenance
Finger Meter Maintenance
Row Unit Maintenance
Seed Tube Maintenance
Grommet Maintenance
Disk Spreader-Scraper
Seed Flap Replacement
Chain Maintenance
Chain Slack
Idler Chain Tension
Marker Maintenance
Marker Shear Bolt
Marker Disk Grease Seal
Bleeding Marker Hydraulics
Marker Transport Carrier
Lubrication
Options
Accessory Hitches
Hitch Setback Kit
Seed Monitor
Speed Sensors
Hydraulic Meter Drive
Gauge Wheels
Weight Bracket Kit
Markers
Seed Lubricants
Main Seed Box Baffles
Fertilizer
Small Seeds
Small Seed Tube Plugs
Row Unit Options
10HD Series Seed Meters
Row Unit Press Wheels
Appendix
Specifications and Capacities
Tire Inflation Chart
Torque Values Chart
Row Spacing Data
Hydraulic Diagrams
Chain Routing
Warranty
