Great Plains Heavy Duty Fluted Feed Drill 1510HDF to 2510HDF Operator Manual
Brand: Great Plains
Type of Machine: 15-, 20- and 25-Foot 3-Point Heavy Duty Fluted Feed Drills
Model: 1510HDF, 2010HDF & 2510HDF
Part Number: 288-340M
Date: 2018
Number of Pages: 84 Pages
Important Safety Information
Safety Reflectors and Decals
Introduction
Document Family
Description of Unit
Intended Usage
Models Covered
Using This Manual
Definitions
Owner Assistance
Preparation and Setup
Pre-Setup Checklist
Hitching
Electrical Connections
Hydraulic Hose Hookup
Leveling the Drill
Leveling: Single-Wheel
Leveling: Offset-Single Wheel
Leveling: Dual-Wheel
Options Setup
Acremeter Installation
Shaft Monitor Cab Module
Marker Setup
Marker Chain Adjustment
Marker Extension Setup
Marker Extension Adjustment
Operating Instructions
Pre-Start Checklist
Transporting
Loading Materials
Marker Operations
Independent Markers
Dual Auto-Sequenced Markers
Field Operation
Shaft Monitor Operation
Parking
Storage
Adjustments
Planting Depth
Marker Adjustments
Marker Disk Angle
Marker Speed
Material Rate Adjustments
Revolutions Per Acre
Non-Standard Configurations
Main Box Seed Rate
Small Seeds Attachment Rate
Fertilizer Rate
Row Unit Adjustments
Unit-Mounted Coulter Adjustments
Row Unit Down Pressure
Row Unit Shut-Off
Disk Blade Adjustments
Seed Firmer Adjustments
Press Wheel Adjustments
Troubleshooting
Maintenance and Lubrication
Marker Maintenance
Marker Shear Bolt
Marker Disk Grease Seal
Bleeding Marker Hydraulics
Marker Transport Carrier
Seed Box Maintenance
Main Box Cleanout
Small Seeds Cleanout
Fertilizer Cleanout
Row Unit Maintenance
Disk Spreader-Scraper
Seed Flap Replacement
Lubrication
Options
Accessory Hitches
Hitch Setback Kit
Gauge Wheels
Markers
Seed Tube Plugs
Fertilizer
Fertilizer Box
Shaft Monitor
Small Seeds
Row Unit Options
10HD Unit-Mounted Coulters
Seed Firmers
Keeton® Seed Firmer
Seed-Lok® Seed Firmer
Appendix
Specifications and Capacities
15-Foot Model Specifications
20-Foot Model Specifications
25-Foot Model Specifications
Tire Information
Torque Values Chart
Hydraulic Diagrams
Dual Independent Markers
Dual Marker Sequence Valve
Chain Routing
Ground Drive and Main Seed Box Chains
Option Box Drive Chains
