Great Plains Heavy Duty Drill 3S-4000HD 3S-4000HDF Operator Manual
Brand: Great Plains
Type of Machine: Heavy Duty Drill
Model: 3S-4000HD 3S-4000HDF
Part Number: 195-067M
Date: 2019
Number of Pages: 119 Pages
Important Safety Information
Safety Decals
Introduction
Document Family
Description of Unit
Intended Usage
Models Covered
Definitions
Preparation and Setup
Hitching
Electrical Connections
Hydraulic Hose Hookup
Check Drill Level
Setting the Bypass Valve
Scraper Installation
Marker Setup
Operating Instructions
General Description
Pre-Start Checklist
Raising and Lowering Openers
Opener Lock Up
Lock Up Openers
Unlock Openers
Folding
Raising Drill (Transport Lift)
Transport Lift
Transport
Tractor Requirements
Marker Transportation
Transport Checklist
Lowering Drill (Transport Lift)
Transport Lower
Unfolding
Folding and Unfolding Quick Reference
To Fold Drill for Transport
To Unfold Drill for Field
Opener Operation
Active Hydraulic Systems
Priority Flow Hydraulic Systems
Non-Active Hydraulic Systems
Loading Seed
Main Seed Box Loading
Small Seeds Box Loading
Initial Seeding Depth
Fertilizer Box Operation
Seeding and applying fertilizer
Divided Capacities
Divider Removal
Seeding with Both Compartments
Marker Operation
Single Marker Operations
Dual Marker Operations
Lift Selector Valve Operation
Point Row Operation
Shaft Monitor Operation
Acremeter Installation (S/N YY1736+)
Acremeter Operation (S/N YY1736+)
Normal Operating Sequence
Dormant Display
Digital Acremeter Operation (S/N YY1735-)
Field Operations
Final Field Checklist
Parking
Parking with Drill Folded
Storage
Adjustments
Seed and Fertilizer Rate
Planting Depth
Frame Level
Frame Weight
Opener Frame Down-Force
Setting Hydraulic Down-Pressure
Opener-Subframe Adjustment
00HD Row Unit Adjustments
Opener Height
Row Unit Down Pressure (Spring)
Disk Blade Adjustments
Adjusting Disk Contact
Disk Scraper Adjustments
Seed Firmer Adjustments
Keeton® Seed Firmer Adjustment
Seed-Lok® Seed Firmer Lock-Up
Opener Depth (Press Wheel Height)
Marker Adjustments
Marker Extension
Marker Disk Adjustment
Mark Width
Direction of Cut
Marker Chain Adjustment
