Great Plains Front Fold Planter PL5500 Operator Manual
Brand: Great Plains
Type of Machine: Front Fold Planter
Model: PL5500
Serial Number:
Part Number: 411-633M
Date: 2021
Number of Pages: 111 Pages
Introduction
Intended Use Statement
Prohibited Use
Machine Identification
Target Group for Operator Manual
Training and Instruction
Safety Information
Safety Symbols and Signal Words
Observe Safety and Informational Symbols
Be Aware of Signal Words
Before Getting Started
Read Machine Information
Wear Appropriate Clothing and Equipment
Inspect Machine Before Use
Machine Use
Operate Responsibly
Handle Hydraulics with Care
Avoid Potential Collision Damage
Chemicals and Waste
Dispose of Waste Properly
Machine Maintenance
Follow Tire Recommendations
Prepare for Performing Maintenance
PTO
Machine Transport
Use Safety Lights and Devices
Shutdown and Storage
Safety Decals
Preparation and Setup
Hitch Planter to Tractor
Planter Hitches
Hydraulic Hose Connection
Fan Hydraulic Connections
Electrical Connection
Planter Leveling
Wheel Adjustment for Leveling
Speed Calibration
Speed Sensor
Console Installation
PTO (Option)
PTO Tractor Requirements
PTO Pump Clearance
Set-Up PTO Pump
Operation
Pre-Start Checklist
Field Operation
Before Planting Checklist
Begin Planting
End Planting
Seed Monitoring System
Dickey-john PM300 (Option)
Dickey-john IntelliAg ISO6 (Option)
Cylinder Locks
Raising/Lowering the Planter
Raising/Lowering Planter without IRC
Raising Planter without IRC
Raising/Lowering Planter with IRC
Raising Planter with IRC
Rephase Lift System
Unfolding/Folding Planter
Unfolding the Planter
Folding the Planter
Unfolding Wings without IRC
Folding Wings without IRC
Unfolding Wings with IRC (S/N D1054X-)
Folding Wings with IRC (S/N D1054X-)
Unfolding Wings with IRC (S/N D1055X+)
Folding Wings with IRC (S/N D1055X+)
Tongue Stop Adjustment
Height Switch
Air System Operation
Fan Hydraulics
Fan Operation
Fan Adjustment
Adjusting for Skips
Doubles
Alternate Skip/Doubles Check
Furrow Check
Fine-Tune Meter Pressurization
Butterfly Valve (Dry Fertilizer)
Loading Hoppers
Seed Lubricants
Seed Meter Setup and Adjustments
Seed Meter Rain Cover
Seed Disk Installation
Seed Disk Removal
Seed Inlet Gate Adjustment
Seed Pool Slopes
Seed Meter Refill
Seed Meter Operation
Planting Rate
Seed Monitoring System Setup
Ground Drive Setup
Transmission Sprockets (S/N D1053X-)
Check Planting Rate
Transmission Sprockets (S/N D1054X+)
Check Planting Rate
5000 Series Row Unit
Row Unit Down Pressure
Down-Pressure Adjustment
Opener Disks
Setting Planting Depth
Disk Contact Adjustment
Side Depth Wheel Adjustments
Depth Wheel Scrapers (Option)
Press Wheel Adjustments
Down Pressure
Press Wheel Stagger
Press Wheel Centering
Unit Mount Coulters
Coulter Row Alignment
Seed Firmer
Keeton® Seed Firmer
Liquid Fertilizer
Tank Loading Preparation
Tank Loading Procedure
Tank Hatch Loading
Liquid Fertilizer Operation
Vantage I Liquid Fertilizer Coulters
Dry Fertilizer
Dry Fertilizer Hopper Loading
Dry Fertilizer Operation
Dry Fertilizer Ground Drive Setup
Dry Fertilizer Coulters
Markers
Marker Operation without IRC
Marker Operation with IRC
Transport
Parking
Storage
Maintenance
Maintenance Schedule
Regular Maintenance
Hydraulic System Inspection
Rephase Lift System
PTO Hydraulic System
Check Oil Reservoir Level
Inspect Hoses and Fittings
Oil and Filter Change
Flow Control Valve Adjustment
Setting Meter Pressurization
Seed Clean-Out
Meter Clean-Out
Alternate Meter Clean-Out
Seed Tube Clean-Out
Seed Meter Brushes
Seed Meter Brush Replacement
Seed Disks
Cleaning and Storing Seed Disks
Side Depth Wheels Maintenance
Disk Spreaders and Scrapers
Seed Flap Replacement
Chain Maintenance
Chain Lubrication
Chain Slack
Chain Clips
Meter Drive Chain
Markers
Shear Bolt Replacement
Marker Disk Lubrication
Liquid Fertilizer Maintenance
Tank Clean-Out
Liquid Fertilizer Strainer
Dry Fertilizer Clean-Out
Lubrication
Grease Fittings
Bearing
PTO Pump System
Hydraulic Diagrams
Lift Hydraulics
IRC Lift Hydraulics
Fold/Marker Hydraulics with Dry Fertilizer
Fold/Marker Hydraulics with Liquid Fertilizer 71
Fold Hydraulics with Dry Fertilizer
Fold Hydraulics with Liquid Fertilizer
Fan Hydraulics
PTO Pump System Hydraulics
Troubleshooting
Planting Rate Problems
IRC Fuse Block Decal
Seed Pool Troubleshooting
Seed Pool Recovery
Pressure Gauge Troubleshooting
Seed Population Troubleshooting
Seed Population Too Low
Seed Population Too High
Planter Troubleshooting
Liquid Fertilizer Troubleshooting
Dry Fertilizer Troubleshooting
PTO Troubleshooting
Specifications
Torque Value Chart
Tire Information
Options
Hitches
Row Unit Press Wheels
Liquid Fertilizer System
Fertilizer Orifice Plates
VisaGage II
Vantage I Coulter
High-Rate Dribblers
Dry Fertilizer System
Adjustable Dry Fertilizer Coulter
Markers
Seed Lubricant
Unit-Mount Coulter
Coulter Mounted Row Cleaner
Inside Disk Scrapers
Side Depth Wheel Scrapers
Gauge Wheel Scrapers
Seed Meter Disks
Seed Firmer
PTO Pump
Dickey-john PM300
Topcon Console System
SureForce Hydraulic Option
Installation
Tongue Installation
Press Wheel Installation
Marker Installation
Scraper Installation
Warranty
