Great Plains Front Fold Boom Sprayer TSF-660 Parts Manual
Brand: Great Plains
Type of Machine: Front Fold Boom Sprayer
Model: TSF-660
Part Number: 23341 500-644P
Date: 2022
Number of Pages: 158 Pages
Section 1: Introduction
Using This Manual
Manual Replacement Information
Manual Revisions
Touch-up Paint
Hardware Legend
Replacement Hardware
Serial Numbers
Part Number Service Coding
Frame
Hitch Assembly
Walkboard Assembly
Boom Supports
Axle Assembly
Single Axle Hub and Tire
13.6-38 6 Ply Tire and Wheel Assembly
320/85R38 Tire and Wheel Assembly
Tank and Saddle Assembly (650 Gallon)
Sight Gauges
Boom
Elevator To Frame
Elevator Assembly ( S/N A1032N+)
Elevator To Center Frame
Spring Lock Assembly
Boom To Center Frame
Center Boom Assembly
Outer Arm Boom Assembly
Lights (S/N A1179N-)
Lights (S/N A1180N+)
Wet Boom
Center Section 30" Spray Kit (S/N A1032N+)
Center Section 20" Spray Kit ( S/N A1032N+)
Center Frame To Inner Boom Spray Kit
Inner Boom 30" Spray Kit (60FT) (S/N A1023N+)
Inner Boom 20" Spray Kit (60FT) (S/N A1031N+)
Outer Boom 30" Spray Kit
Outer Boom 20" Spray Kit
Sprayer Nozzle Body 3-Way (829-122C)
Nozzle Assembly
Calibration Kit (502-108A)
Cylinders
Wing Lift Cylinders 2.5 x 10 x 1.06 Rod (RH 810-018C & LH
810-022C)
Wing Lift Cylinder 2.5 x 11.0 x 1.25 Rod (810-591C)
Inner Boom Fold Cylinder 3 x 12 x 1.25 Rod (810-312C)
Outer Boom Fold Cylinder 2 x 12 x 1.12 Rod (810-433C).72
Elevator Lift Cylinder 2.5 X 42 X 1.5 Rod (810-504C) (S/N
A1032N+)
Fasse Valve Assembly (2006-)
Fasse Valve (833-305C) (2006-)
Plumbing
Plumbing Assembly
Manifold Valve
Quick Fill & Tank Plumbing
Control Panel Assembly
Control Panel Plumbing
Agitation & Flush Plumbing
Quick Fill Plumbing Assembly
Agitation Assembly
Single Union 1/2" Ball Valve
Cam Lock Ball Valve (829-048C)
Union Ball Valve
Ball Valves
Whirlfilter Assembly
2" Line Strainer Assembly (S/N A1031N-)
Pumps
High Volume Hydraulic Pump Assembly
Ace Hydraulic Pump Assembly
Flow Control
Raven 1 1/2" Poly Control Valve
Raven 440 Control Assembly (823-228C)
Raven 440 With Wheel Sensor 1000 Gallon (509-288A).116
Raven 440 With Radar Gun (509-289A)
Raven Wheel Drive Sensor
Raven Valve (823-235C)
Raven RFM 60 Flowmeter
Electric-Hydraulic Control (833-306C) (2006-)
Fasse Control Box (2006-)
Trailer Decals
Boom Decals (S/N A1179N-)
Boom Decals (S/N A1180N+)
Rinse and Flush Tank
Flush Tank & Mounting Assembly
Tank Rinse Assembly
Options
Chemical Inductor Kit Assembly (Option)
Chemical Inductor Assembly (Option)
Foam Marker Mount (Option)
Foam Marker Components (Option)
Control Module
Raven G1 Autoboom Control Kit
Raven G1 Autoboom Install Kit
Part Number Index
