Great Plains Front Fold Boom Sprayer TSF-1080 to TSF-1290 Parts Manual
Brand: Great Plains
Type of Machine: Front Fold Boom Sprayer
Model: TSF-1080 & TSF-1090, TSF-1280 & TSF-1290
Serial Number:
Part Number: 500-641P
Date: 2019
Number of Pages: 230 Pages
Section 1: Introduction
Using This Manual
Manual Replacement Information
Manual Revisions
Touch-up Paint
Hardware Legend
Replacement Hardware
Serial Numbers
Part Number Service Coding
Frame
Hitch Assembly
Hitch Assembly for Ace PTO Pump
Tongue Assembly
Axle Assembly
Boom Supports
Tank and Saddle Assembly (1000 Gallon)
Tank and Saddle Assembly (1250 Gallon)
Left Hand Walkboard Assembly (1000 Gallon)
Left Hand Walkboard Assembly (1250 Gallon)
Sight Gauges
Single Axle Hub and Tire (1000 Gallon)
Single Axle Hub and Tire (1250 Gallon)
13.6-38 6 Ply Tire and Wheel Assembly
14.9R46 10 Ply Tire and Wheel Assembly
320/85R38 Tire and Wheel Assembly
Boom
Elevator to Frame
Elevator Assembly
Elevator to Center Frame
Boom to Center Frame
Center Boom Assembly
Lights (S/N 1183RR-) (S/N 1109VV-)
Lights (S/N 1184RR+) (S/N 1110VV+)
Outer Arm Boom Assembly
Spring Lock Assembly
Wet Boom
Center Section Spray Kit (S/N 1013RR-) (S/N 1006VV-)
Center Section Spray Kit (S/N 1014RR+) (S/N
1006VV+)
Inner Boom 20" Spray Kit
Inner Boom 30" Spray Kit
Outer Boom 20" Spray Kit
Outer Boom 30" Spray Kit
Center Frame to Inner Boom Spray Kit
Sprayer Nozzle Body 3-Way (829-108C)
Sprayer Nozzle body 3-way (829-122C)
Nozzle Assembly
Calibration Kit (502-108A)
Cylinders
Fasse Valve Assembly (2006-)
Fasse Valve Assembly (2007+)
Fasse Valve (833-305C) (2006-)
Fasse Valve (833-424C) (2007+)
Elevator Lift Cylinder 2.5 x 42.0 x 1.5 Rod (810-504C)
Inner Boom Fold Cylinder 3.0 x 12.0 x 1.25 Rod
(810-312C)
Outer Boom Fold Cylinder 2.0 x 12.0 x 1.12 Rod
(810-433C)
Wing Lift Cylinder 2.5 x 11.0 x 1.25 Rod (810-591C)
Wing Lift Cylinder 2.5 x 10.0 x 1.06 Rods (810-018C and
810-022C)
Plumbing
Plumbing Assembly (2004-)
Plumbing Assembly (2005+)
Manifold Valve
Quick Fill and Tank Plumbing (2004-)
Quick Fill and Tank Plumbing (2005+)
Quick Fill Plumbing Assembly
Control Panel Assembly (2005+)
Control Panel Plumbing (2005+)
Agitation and Flush Plumbing (2005+)
Agitation Assembly
2" Line Strainer Assembly
3-Way Bottom Fill Valve
Ball Valve 1 1/4" and 1 1/2"
Ball Valve 1/2", 3/4", and 1"
Ball Valves
Cam Lock Ball Valve (829-048C)
Precision Ball Valve
Single Union 1/2" Ball Valve
Whirlfilter Assembly
Pumps
Pump Mounting Assembly
High Volume Hydraulic Pump Assembly (S/N 1037RR-) (S/N
A1029VV-)
High Volume Hydraulic Pump Assembly (S/N 1038RR+) (S/N
A1030VV+)
Scot Hydraulic Pump (S/N 1037RR-) (S/N A1029VV-)
Scot Hydraulic Pump Assembly (S/N 1037RR-) (S/N
A1029VV-)
Ace Hydraulic Pump (S/N 1038RR+) ( A1030VV+)
Ace PTO Pump
Ace PTO Pump Assembly
Driveline Bearing Mount Assembly
Eurocardan Driveline 1000 RPM (826-239C)
Eurocardan Driveline 540 RPM (826-238C)
Flow Control
Raven 450 Control Assembly (823-209C)
Raven 450 with Radar Gun (509-289A)
Raven 450 with Wheel Sensor (1000 Gallon)
Raven 450 with Wheel Sensor (1250 Gallon)
Raven Wheel Drive Sensor
Raven Valve (823-210C)
Raven 1 1/2" Poly Control Valve
Raven RFM 60 Flowmeter
Electric Hydraulic Control (833-306C) (2006-)
Electric Hydraulic Control (833-423C) (2007+)
Fasse Control Box (2006-)
Fasse Control Box (2007+)
Trailer Decals
Boom Decals (S/N 1183RR-) (S/N 1109VV-)
Boom Decals (S/N 1184RR+) (S/N 1110VV+)
Rinse and Flush Tank
Rinse, Flush Tank, and Mounting Assembly (2004-)
Rinse, Flush Tank, and Mounting Assembly (2005+)
Rinse and Flush Tank Plumbing Assembly (2004-)
Rinse and Flush Tank Plumbing Assembly (2005+)
Tank Rinse Assembly
Options
Chemical Inductor Assembly
Chemical Inductor Kit Assembly (2004-)
Chemical Inductor Kit Assembly (2005+)
Control Module (2004-)
Control Module (2005+)
Foam Marker Components (60' Spray Kit)
Foam Marker Components (90' Spray Kit) (2004-)
Foam Marker Components (90' Spray Kit) (2005+)
Foam Marker Mount (2004-)
Foam Marker Mount (2005+)
Raven G1 Autoboom Control Kit
Raven G1 Autoboom Install Kit
Part Number Index
