Great Plains Front Fold Boom Sprayer TSF-1060 TSF-1260 Parts Manual
Brand: Great Plains
Type of Machine: Front Fold Boom Sprayer
Model: TSF-1060 & TSF-1260
Part Number: 500-642P
Date: 2019
Number of Pages: 220 Pages
Section 1: Introduction
Using This Manual
Manual Replacement Information
Manual Revisions
Touch-up Paint
Hardware Legend
Replacement Hardware
Serial Numbers
Part Number Service Coding
Frame
Hitch Assembly
Hitch Assembly for Ace PTO Pump
Tongue Assembly
Left Hand Walkboard Assembly (1000 Gallon)
Left Hand Walkboard Assembly (1250 Gallon)
Boom Supports (S/N A1053F-) (S/N A1002G-)
Boom Supports (S/N A1054F+) (S/N A1003G+)
Axle Assembly
Single Axle Hub and Tire (1000 Gallon)
Single Axle Hub and Tire (1250 Gallon)
13.6-38 6 Ply Tire and Wheel Assembly
320/85R38 Tire and Wheel Assembly
14.9R46 10 Ply Tire and Wheel Assembly
Tank and Saddle Assembly (1000 Gallon)
Tank and Saddle Assembly (1250 Gallon)
Sight Gauges
Boom
Elevator to Frame (S/N A1053F-) (S/N A1002G-)
Elevator to Frame (S/N A1054F+) (S/N A1003G+)
Elevator Assembly (S/N A1054F+) (S/N A1003G+)
Elevator Assembly (S/N A1053F-) (S/N A1002G-)
Elevator to Center Frame
Spring Lock Assembly
Boom to Center Frame
Center Boom Assembly
Outer Arm Boom Assembly
Lights (S/N A1237F-) (S/N A1019G-)
Lights (S/N A1238F+) (S/N 1020G+)
Wet Boom
Center Section Spray Kit (S/N A1053F-) (S/N A1002G-)
Center Section 30" Spray Kit (S/N A1054F+) (S/N
A1003G+)
Center Section 20" Spray Kit (S/N A1054F+) (S/N
A1003G+)
Center Frame to Inner Boom Spray Kit (S/N A1053F-) (S/N
A1002G-)
Inner Boom 30" Spray Kit (S/N A1053F-) (S/N A1002G-)
Inner Boom 30" Spray Kit (S/N A1054F+) (S/N
A1003G+)
Inner Boom 20" Spray Kit (S/N A1053F-) (S/N A1053F-)
Inner Boom 20" Spray Kit (S/N A1054F+) (S/N
A1003G+)
Outer Boom 30" Spray Kit
Outer Boom 20" Spray Kit
Sprayer Nozzle Body 3-Way (829-108C)
Sprayer Nozzle Body 3-way (829-122C)
Nozzle Assembly
Calibration Kit (502-108A)
Cylinders
Inner Boom Fold Cylinder 3.0 x 12.0 x 1.25 Rod
(810-312C)
Outer Boom Fold Cylinder 2.0 x 12.0 x 1.12 Rod
(810-433C)
Wing Lift Cylinder 2.5 x 11.0 x 1.25 Rod (810-591C)
Wing Lift Cylinder 2.5 x 10.0 x 1.06 Rods (810-018C and
810-022C)
Elevator Lift Cylinder 2.0 x 36.0 x 1.25 Rod (810-388C) (S/N
A1053F-)
Elevator Lift Cylinder 2.5 x 42.0 x 1.5 Rod (810-504) (S/N
A1054F+)
Fasse Valve Assembly (2006-)
Fasse Valve Assembly (2007+)
Fasse Valve (833-305C) (2006-)
Fasse Valve (833-424C) (2007+)
Plumbing
Plumbing Assembly
Manifold Valve
Quick Fill and Tank Plumbing
Control Panel Assembly
Control Panel Plumbing
Agitation and Flush Plumbing
Quick Fill Plumbing Assembly
Agitation Assembly
Single Union 1/2" Ball Valve
Cam Lock Ball Valve (829-048C)
Union Ball Valve
Ball Valves
Whirlfilter Assembly
2" Line Strainer Assembly
Pumps
Pump Mounting Assembly
High Volume Hydraulic Pump Assembly (S/N A1031F-) (S//N A1000G-)
High Volume Hydraulic Pump Assembly (S/N A1032F+) (S/N A1001G+)
Scot Hydraulic Pump (S/N A1031F-) (S/N A1000G-)
Scot Hydraulic Pump Assembly (S/N A1031F-) (S/N A1000G-)
Ace Hydraulic Pump (S/N A1032F+) (S/N A1001G+)
Ace PTO Pump
Ace PTO Pump Assembly
Driveline Bearing Mount Assembly
Eurocardan Driveline 540 RPM (826-238C)
Eurocardan Driveline 1000 RPM (826-239C)
Flow Control
Raven 440 Control Assembly (823-228C)
Raven 440 with Wheel Sensor (1000 Gallon)
Raven 440 with Wheel Sensor (1250 Gallon)
Raven 440 with Radar Gun (509-289A)
Raven Wheel Drive Sensor
Raven Valve (823-235C)
Raven 1 1/2" Poly Control Valve
Raven RFM 60 Flowmeter
Electric Hydraulic Control (833-306C) (2006-)
Electric Hydraulic Control (833-423C) (2007+)
Fasse Control Box (2006-)
Fasse Control Box (2007+)
Trailer Decals
Boom Decals (S/N A1237F-) (S/N A1019G-)
Boom Decals (S/N A1238F+) (S/N A1020G+)
Rinse and Flush Tank
Rinse, Flush Tank, and Mounting Assembly
Rinse and Flush Tank Plumbing Assembly
Tank Rinse Assembly
Options
Chemical Inductor Kit Assembly (Option)
Chemical Inductor Assembly (Option)
Foam Marker Mount (Option)
Foam Marker Components (Option)
Control Module
Raven G1 Autoboom Control Kit
Raven G1 Autoboom Install Kit
Part Number Index
Brand: Great Plains
Date: 2019
Using This Manual
Manual Revisions
Touch-up Paint
Hardware Legend
Serial Numbers
Frame
Hitch Assembly
Tongue Assembly
Axle Assembly
Sight Gauges
Boom
Wet Boom
A1003G+)
A1003G+)
A1002G-)
A1003G+)
A1003G+)
Nozzle Assembly
Cylinders
(810-312C)
(810-433C)
810-022C)
A1053F-)
A1054F+)
Plumbing
Plumbing Assembly
Manifold Valve
Agitation Assembly
Union Ball Valve
Ball Valves
Pumps
Ace PTO Pump
Flow Control
Trailer Decals
Tank Rinse Assembly
Options
Control Module
Part Number Index
- Great Plains Flat Fold Marker John Deere 7500 15' 20' Operator Parts Manual
- Great Plains Cross Fold Sprayer Boom CF50 CF60 Parts Manual
- Great Plains Finishing Attachment Verti-Till 5300 7225 7300 9225 Operator Parts Manual
- Great Plains Multi Flex Drill After August 1990 Operator Manual
- Great Plains Front Fold Sprayer 3P-FF600 3P-FF800 3P-FF900 Operator Manual
- Great Plains End Wheel No Till Drill 1206NT Operator Manual
- Great Plains Cart Rake RA108CR to RA212CR Parts Manual
- Great Plains 40' Folding Drill BD7600 Parts Manual
- Great Plains 3 Point Drill 3PD12 to 3PD30 Parts Manual
- Great Plains Combination Drill Hitch Operator Parts Manual 1983
- Great Plains 24' 30' 2 Section Drill 2SF24 2SF30 Parts Manual
- Great Plains Flat Fold Marker John Deere 30' Dual 750 Operator Parts Manual
- Great Plains No Till Air Drill Cart 3010 3510 Pre-Delivery Manual
- Great Plains Centurion Cultivator Drill CDA600 MK1 Parts Manual
- Great Plains 26' Folding Drill BD7600 Parts Manual
