Great Plains Fluted Feed Drill 2020F to 2525F Operator Manual
Brand: Great Plains
Type of Machine: 3-Point Fluted Feed Drills
Model: 2020F, 2025F, 2520F and 2525F
Part Number: 118-232M
Number of Pages: 90 Pages
Date: 2018
Important Safety Information
Look for Safety Symbol
Be Aware of Signal Words
Prepare for Emergencies
Be Familiar with Safety Decals
Avoid High Pressure Fluids
Wear Protective Equipment
Handle Chemicals Properly
Keep Riders Off Machinery
Use Safety Lights and Devices
Transport Machinery Safely
Shutdown and Storage
Practice Safe Maintenance
Tire Safety
Safety At All Times
Safety Decals
To install new decals:
Safety Reflectors and Decals
Slow Moving Vehicle Reflector
Red Reflectors
Amber Reflectors
Daytime Reflectors
Caution: Tires Not A Step
Caution: Read Manual
Caution: Tire Pressure
Danger: Walkboard Falling Hazard
Warning: Excessive Speed Hazard
Warning: High Pressure Fluid Hazard
Warning: Marker Pinch/Crush Hazard
Danger: Hitch Crushing Hazard
Introduction
Covered Models
Preparation and Setup
Pre-Setup Checklist
Hitching Tractor to Drill
Making Hydraulic Connections
Making Electrical Connections
Leveling the Drill
20 Series Opener Height
25 Series Opener Height
Frame Height
Operating Instructions
Pre-Operation Checklist
Transporting
Check Tractor Capacity and Configuration
Unload Seed Box
Transporting with Markers
Acremeter Operation
Normal Operating Sequence
Field Operation
Marker Operation
Parking
Model 20F Only:
All Models:
Storage
Adjustments
Ground Drive Adjustments
Setting Drive Type
Setting Seed Rate Handle
Position Seed Cup Doors
Marker Adjustments
Marker Width
Marker Disk Adjustment
Marker Chain Adjustment
Marker Speed
Row Unit Adjustments
Row Unit Down Pressure
Row Unit Shutoff
25 Series Row Unit Lock-Up
25 Series Coulter Adjustments
Row-Unit Opener Disk Adjustments
Side Gauge Wheel Adjustment
Press Wheel Adjustment
Troubleshooting
Maintenance and Lubrication
Marker Maintenance
Marker Cylinder Bleeding
Marker Shear Bolt Replacement
Marker Transport Carrier
Drive System Maintenance
Chain Maintenance
Row Unit Maintenance
Seed Cup Clean-Out
Opener Side Wheel Maintenance
Opener Disc Maintenance
Seed Flap Replacement (2010+)
Seed Flap Replacement (2009-)
Lubrication
Gauge Wheels: Arm Pivots
Markers: Hinge Points
Seed Cup Drive Shaft Sprocket
Gauge Wheel Chains
Markers: Disk Hubs
Gauge Wheels: Wheel Bearings
Options
Hitch Setback Kit
Gauge Wheels
Markers
Seed Tube Plug
Weight Bracket Kit
Unit-Mounted Disk Coulters
Coulter Blades
Scrapers
20 Series Inside Scrapers
25 Series Gauge Wheel Scrapers
Seed-Lok® Seed Firmer
Keeton Seed Firmer
Row Unit Press Wheels
Acremeter
Appendix
Specifications and Capacities
Tire Inflation Chart
Torque Values Chart
Marker Extension
Reading a Marker Extension Diagram
Model 2020F Marker Extension
Model 2025F Marker Extension
Model 2520F Marker Extension
Model 2525F Marker Extension
Brand: Great Plains
Date: 2018
Tire Safety
Safety At All Times
Safety Decals
Red Reflectors
Amber Reflectors
Daytime Reflectors
Introduction
Covered Models
Pre-Setup Checklist
Leveling the Drill
Frame Height
Transporting
Unload Seed Box
Acremeter Operation
Field Operation
Marker Operation
Parking
Model 20F Only:
All Models:
Storage
Adjustments
Setting Drive Type
Marker Adjustments
Marker Width
Marker Speed
Row Unit Shutoff
Troubleshooting
Marker Maintenance
Chain Maintenance
Seed Cup Clean-Out
Lubrication
Gauge Wheel Chains
Markers: Disk Hubs
Options
Hitch Setback Kit
Gauge Wheels
Markers
Seed Tube Plug
Weight Bracket Kit
Coulter Blades
Scrapers
Keeton Seed Firmer
Acremeter
Appendix
Torque Values Chart
Marker Extension
- Great Plains Flat Fold Marker John Deere 7500 15' 20' Operator Parts Manual
- Great Plains Cross Fold Sprayer Boom CF50 CF60 Parts Manual
- Great Plains Finishing Attachment Verti-Till 5300 7225 7300 9225 Operator Parts Manual
- Great Plains Multi Flex Drill After August 1990 Operator Manual
- Great Plains Front Fold Sprayer 3P-FF600 3P-FF800 3P-FF900 Operator Manual
- Great Plains End Wheel No Till Drill 1206NT Operator Manual
- Great Plains Cart Rake RA108CR to RA212CR Parts Manual
- Great Plains 40' Folding Drill BD7600 Parts Manual
- Great Plains 3 Point Drill 3PD12 to 3PD30 Parts Manual
- Great Plains Combination Drill Hitch Operator Parts Manual 1983
- Great Plains 24' 30' 2 Section Drill 2SF24 2SF30 Parts Manual
- Great Plains Flat Fold Marker John Deere 30' Dual 750 Operator Parts Manual
- Great Plains No Till Air Drill Cart 3010 3510 Pre-Delivery Manual
- Great Plains Centurion Cultivator Drill CDA600 MK1 Parts Manual
- Great Plains 26' Folding Drill BD7600 Parts Manual
