702,019
Great Plains Drill 3S-4000 3S-4000F 3S-4000HD 3S-4000HDF Operator Manual
Brand: Great Plains
Type of Machine: 3-Section 40 Foot Drills
Model: 3S-4000 3S-4000F 3S-4000HD 3S-4000HDF
Part Number: 195-442M
Number of Pages: 120 Pages
Date: 2020
Important Safety Information
Safety Decals
Introduction
Models Covered
Document Family
Description of Unit
Intended Usage
Definitions
Further Assistance
Preparation and Setup
Hitching
Electrical Connections
Hydraulic Hose Hookup
Check Drill Level
Setting the Bypass Valve
Scraper Installation
Press Wheel Scraper Installation
Marker Setup
Operating Instructions
General Description
Pre-Start Checklist
Raising and Lowering Openers
Opener Lock Up
Folding
Raising Drill (Transport Lift)
Transport Lift
Transport
Tractor Requirements
Marker Transportation
Transport Checklist
Lowering Drill (Transport Lift)
Transport Lower
Unfolding
Folding and Unfolding Quick Reference
Opener Operation
Active Hydraulic Systems
Priority Flow Hydraulic Systems
Non-Active Hydraulic Systems
Loading Materials
Loading Main Seed Box
Small Seeds Box Loading
Loading Fertilizer Compartment
Main Box Seed Rate Handle
Position Seed Cup Doors
Initial Seeding Depth
Fertilizer Box Operation
Seeding and applying fertilizer
Divided Capacities
Divider Removal
Using Fertilizer Compartment
Seeding with Both Compartments
Marker Operation
Single Marker Operations
Dual Marker Operations
Lift Selector Valve Operation
Point Row Operation
Shaft Monitor Operation
Acremeter Installation
Acremeter Operation
Field Operations
Final Field Checklist
Point Row Control Box (Option)
Parking
Parking with Drill Folded
Storage
Adjustments
Frame Level
Frame Weight
Opener Frame Down-Force
Setting Hydraulic Down-Pressure
Opener-Subframe Adjustment
00 Row Unit Adjustments
00HD Row Unit Adjustments
Opener Height
Row Unit Down Pressure (Spring)
Disk Blade Adjustments
Disk Scraper Adjustments
Seed Firmer Adjustments
Fertilizer Tube Adjustment
Opener Depth (Press Wheel Height)
Individual Opener Height
Marker Adjustments
Marker Extension
Marker Setup
Marker Disk Adjustment
Marker Chain Adjustment
Troubleshooting
Maintenance and Lubrication
In-Line Filters
Leveling The Drill
Center Box Frame Leveling
Opener Frames
Wing Box Alignment
Align Transfer Drive Shaft
Truss Tube Tension
Toolbar Height
Opener-Frame Clearance
Drive System
Marker Maintenance
Marker Transport Carrier
Marker Shear Bolt
Marker Disk
Materials Clean-Out
Main Box Seed Meter Clean-Out
Fertilizer Box Clean-Out
Small Seeds Box Clean-Out
Seed Flap Replacement
Lubrication and Scheduled Maintenance
Options
Calibration Tray
Digital Scale
Small Seeds Attachment
Seed Firmers
Seed-Lok® Seed Firmer
Acremeter
Appendix
Specifications and Capacities
Tire Inflation Chart
Torque Values Chart
Hydraulic Diagrams
Transport Lift
Fold
Dual Markers
Single Marker
Two Outlet Conversion
Opener Lift: Standard Closed-Center
Opener Lift: Optional Open-Center
Point-Row
Appendix B - Option Installation
Carbide Disc Scraper Installation
Warranty
