Great Plains Air Drill Cart Implement 1150 Operator Manual
Brand: Great Plains
Type of Machine: Air Drill Cart Implement
Model: 1150
Part Number: 167-058M
Date: 1995-1997
Number of Pages: 90 Pages
Important Safety Information
Introduction
Description of Unit
Intended Usage
Using This Manual
Owner Assistance
Section 1 Cart Assembly and Setup
Pre-Assembly Checklist
General Description
Shipping information
Top Steps & Rear Handrail
Spindles, Hubs, Wheels, & Drive Chain
Hitch, Safety Chain, & Jack
Lower Ladder Weldment & Support Weldment
Slow Moving Vehicle Bracket & Emblem
Section 2 Implement Assembly and Setup
Flex Limiter Bars
Implement Lift Cylinder Hydraulic Hoses
Bleeding the Hydraulic Lifting System
Fold Cylinders
34’ and 45’ Drills
45’ Drills
Bleeding the Folding System
Side-to Side Frame Leveling
45’ Drill Frame Leveling
34’ Drill Frame Leveling
Distribution Towers and Hoses
Primary 2 1/2” Distribution Hoses
1” Secondary Hoses
Light Harness and Brackets
Section 3 Operating Instructions
General Description
Attaching the Drill to the Tractor
Recommended Minimum Tractor Size
Safety Lights
Attaching 1150 Air Drill Cart to Implement
Hydraulic Hose Hook-up
Filling the Drill
Field Operations
Implement Lifting System
Folding the Drill
Unfolding the Drill
Opener Operation
Unloading the Drill
Transporting
Parking
Section 4 Adjustments
Setting the Drill Seeding Rate
Setting Seeding Depth/Leveling Front-to-Rear
Individual Opener Adjustments
Shear Bolt &Spring Reset Opener Depth
Reset Opener Down Pressure
Hoe Tip Angle
Drive System Adjustment
Main Drive Chain from Wheel to Clutch
Chain from Speed Change to Gearbox
Drive Chain from Clutch to Speed Change
Chain from Gearbox Output to Jackshaft
Chain from Jackshaft to Meter
Electric Clutch Height Switch
Section 5 Troubleshooting
Section 6 Maintenance and Lubrication
Maintenance
Storage
Lubrication
Main Drive Chain
Clutch Output Chain
Gearbox Input Chain
Gearbox Output Chain
Jackshaft Output Chain
Clutch Shaft Bearings
Jackshaft Bearings
Gauge Wheel Pivots
Castor Wheel Shafts
Lift Assist Pivots
Press Wheel Gang Bearings
Press Wheel Pivot Bearings
Implement Hinge Pivots
Cart Pull Link Pivots
Parallel Arm Pivots
Press Wheel Screw Adjustments
Auger Pivot Arms
Floating Hoe Opener Pivots
Auger Pivot Arms
Meter Lid Clamp Pivots
Bin Lid Pivot Bar and Latch
Gearbox
Wheel or Axle Bearings
Section 7 Options
Loading/Unloading Auger
Vansco Electronis Monitor
Section 8 Specifications and Capacities
Section 9 Appendix
Torque Values Chart for Common Bolt Sizes
Tire Inflation Chart
Warranty
