Great Plains Air Drill Cart ADC2350 to ADC2350BE Operator Manual
Brand: Great Plains
Type of Machine: Air Drill Cart
Model: ADC2350 ADC2350E ADC2350B ADC2350BE
Part Number: 167-085M
Date: 2018
Number of Pages: 116 Pages
Important Safety Information
Safety Decals
Introduction
Air Cart Document Family
Description of Unit
Intended Usage
Using This Manual
Definitions
Preparation and Setup
Pre-Setup Checklist
Installing Seed Monitor Terminal
Cart Drive System
Cart Sprocket Setup
Hitching
ADC2350 Hitching
ADC2350B/E Hitching
ADC2350 “Pull Between” Hitching
Hitching ADC2350B/E to Leading Drill
Set Up the Implement
Setup Seed Monitor for Air Drill
Row Setup Data
Operating Instructions
General Description
Pre-Start Checklist
Walkboard Ladders
Ladder Operation
Removing the Right Ladder
Hopper Lids
Lid Opening
Lid Closing
Strainer
Meter Doors
Meter Door Opening
Meter Door Closing
Meter Hand Crank
Installing Crank
Operating the Hand Crank
Drive Chain Lockout
Locking Out for Transport
Disengaging Lockout
Auger Operations
Deploying Auger
Auger Hydraulic Controls
Storing Auger
Auger Swing Arm
Transport
Minimum Towing Vehicle
Pre-Transport Checklist
Monitor Material Configuration
Loading Material
Cart Diverter Valve
Unloading the Cart
Unloading Front Hopper
Unloading Rear Hopper
Unloading Closeout
Field Operations
Single Hopper Operation
Fan Speed
Final Field Checklist
Planting Sequence
Planting
Parking
Storage
Adjustments
Setting Material Rates
Check Drive System
Check Flute Shaft Type
Find Your Chart and Rate
Meter Rate Adjustment
Changing Meter Flutes
Fan Speed Adjustment
Hydraulic Fan Start-Up
Implement Lift Switch Adjustment S/N A1423T-
Lift Switch Location
Lift Switch Wiring
Implement Lift Switch Adjustment S/N A1424T+
Clutch Lock-Up
Troubleshooting
Maintenance and Lubrication
Chain Slack
Hub Chain
Clutch Input Chain
Gearbox Input Chains
Chain Maintenance
Problem Clean-Outs
Removing Meter Box
Hopper Entry
Lubrication and Scheduled Maintenance
Options
Appendix
Specifications and Capacities
Tire Inflation Chart
Torque Values Chart
Chain Routing
Hydraulic Diagrams
ADC2350 Hydraulic Diagram (S/N A1157T-)
ADC2350 Hydraulic Circuits
ADC2350 Hydraulic Fan (S/N A1157T-)
ADC2350B/E Hydraulic Diagram (S/N A1157T-)
ADC2350B/E Hydraulic Diagram (S/N A1158T+)
ADC2350B/E Hydraulic Fan (S/N A1157T-)
ADC2350B/E Hydraulic Fan (S/N A1158T+)
Brand: Great Plains
Date: 2018
Safety Decals
Introduction
Description of Unit
Intended Usage
Using This Manual
Definitions
Pre-Setup Checklist
Cart Drive System
Cart Sprocket Setup
Hitching
ADC2350 Hitching
ADC2350B/E Hitching
Row Setup Data
General Description
Pre-Start Checklist
Walkboard Ladders
Ladder Operation
Hopper Lids
Lid Opening
Lid Closing
Strainer
Meter Doors
Meter Door Opening
Meter Door Closing
Meter Hand Crank
Installing Crank
Drive Chain Lockout
Disengaging Lockout
Auger Operations
Deploying Auger
Storing Auger
Auger Swing Arm
Transport
Loading Material
Cart Diverter Valve
Unloading the Cart
Unloading Closeout
Field Operations
Fan Speed
Planting Sequence
Planting
Parking
Storage
Adjustments
Check Drive System
Lift Switch Wiring
Clutch Lock-Up
Troubleshooting
Chain Slack
Hub Chain
Clutch Input Chain
Chain Maintenance
Problem Clean-Outs
Removing Meter Box
Hopper Entry
Options
Appendix
Torque Values Chart
Chain Routing
Hydraulic Diagrams
- Great Plains Flat Fold Marker John Deere 7500 15' 20' Operator Parts Manual
- Great Plains Cross Fold Sprayer Boom CF50 CF60 Parts Manual
- Great Plains Finishing Attachment Verti-Till 5300 7225 7300 9225 Operator Parts Manual
- Great Plains Multi Flex Drill After August 1990 Operator Manual
- Great Plains Front Fold Sprayer 3P-FF600 3P-FF800 3P-FF900 Operator Manual
- Great Plains End Wheel No Till Drill 1206NT Operator Manual
- Great Plains Cart Rake RA108CR to RA212CR Parts Manual
- Great Plains 40' Folding Drill BD7600 Parts Manual
- Great Plains 3 Point Drill 3PD12 to 3PD30 Parts Manual
- Great Plains Combination Drill Hitch Operator Parts Manual 1983
- Great Plains 24' 30' 2 Section Drill 2SF24 2SF30 Parts Manual
- Great Plains Flat Fold Marker John Deere 30' Dual 750 Operator Parts Manual
- Great Plains No Till Air Drill Cart 3010 3510 Pre-Delivery Manual
- Great Plains Centurion Cultivator Drill CDA600 MK1 Parts Manual
- Great Plains 26' Folding Drill BD7600 Parts Manual
