702,019
Great Plains Air Drill Cart ADC2350 ADC2350B Parts Manual
Brand: Great Plains
Type of Machine: Air Drill Cart
Model: ADC2350 ADC2350B
Part Number: 167-085P
Date: 2022
Number of Pages: 124 Pages
Section 1: Introduction
Using This Manual
Manual Replacement Information
Manual Revisions
Touch-up Paint
Hardware Legend
Replacement Hardware
Serial Numbers
Part Number Service Coding
Frame and Bins
Tongue to Frame Pull Behind Air Cart
Tongue to Frame Pull Between Air Cart
Tongue Pull Behind Air Cart
Tongue Pull Between Air Cart
Rotating Square Hammerblow Jack (890-610C)
Bin to Frame
Bin Assembly
Handrail and Step
Hub and Wheel
Rear Hitch
Rear Hitch Pull Between Cart
Hose Connection
Rear Hose Connection Pull Between Cart
Fan and Air System
Fan and Transition Pull Behind Air Cart (S/N A1157T-)
Fan and Transition Pull Behind Air Cart (S/N A1158T+)
Fan and Transition Pull Between Air Cart (S/N A1157T-)
Fan and Transition Pull Between Air Cart (S/N A1158T+)
Meter Box Assembly
4 Outlet Meter Shaft Assembly
5 Outlet Meter Shaft Assembly
6 Outlet Meter Shaft Assembly
6 Outlet Meter Shaft, Small Seeds Assembly
Drive
Wheel Drive Pull Behind Air Cart
Wheel Drive Pull Between Air Cart
Caster Wheel and Hub
Zero-Max Gearbox Assembly
Zero-Max Gearbox Linear Actuator
Drive and Gearbox Chain Routing
Drive Components
Auger
Auger Assembly (S/N A1159T-)
Auger Assembly (S/N A1160T to A1172T) and ADC2350E
Auger Assembly Pull Between (S/N A1173T+)
Auger Assembly Pull Behind (S/N A1173T+)
Auger Hydraulic Drive (S/N A1172T-)
Auger Hydraulic Drive (S/N A1173T+)
Auger Front Support Rest
Hydraulics
Fan Hydraulic Pull Behind Cart (S/N A1157T-)
Fan Hydraulic Pull Behind Cart (S/N A1158T+)
Fan Hydraulics Pull Between Cart (S/N A1157T-)
Fan Hydraulics Pull Between Cart (S/N A1158T+)
Hydraulic System Pull Behind Cart (S/N A1157T-)
Hydraulic System Pull Behind Cart (S/N A1158T+)
Hydraulic System Pull Between Cart (S/N A1157T-)
Hydraulic System Pull Between Cart (S/N A1158T+)
Double Selector Valve (810-274C)
Selector Valve (810-152C)
Valve 4Way (810-268C)
Monitor
TopCon Console and In Cab Kit (S/N A1449T+)
Monitor
Lights and Harness
Pull Between Cart Light
Lights and Harness Pull Behind Cart
Decals Pull Behind Cart
Decals Pull Between Cart
Part Number Index
