Great Plains 3m Drill Hitch FCP1000 Operator Manual
Brand: Great Plains
Type of Machine: 3m Drill Hitch
Model: FCP1000
Part Number: 148-693M-A Rev. C
Date: 2005
Number of Pages: 44 Pages
Important Safety Information
Introduction
Description of Unit
Intended Usage
Using This Manual
Definitions
Owner Assistance
Section 1 Preparation and Setup
Prestart Checklist
Wiring Drill
Hitching Tractor to Implement
Hydraulic Hook-up
Bleeding Hydraulic Systems
Bleeding Tongue Cylinder
Bleeding Transport Lift Cylinders
Bleeding Marker Hydraulics
Section 2 Operating Instructions
Prestart Checklist
Field Operation
Opener Operation
Pivot Lock Tubes
Marker Operation
Fertilizer Operation
Transporting
Parking
Section 3 Adjustments
Seeding Depth
Coulters
Openers
Coulter Depth
Hydraulic Control
Coulter Mounting Height
Coulter Down Pressure
Added Weight
Coulter Springs
Opener Depth
Press Wheel Adjustment
Opener Mounting Height
Opener Down Pressure
Disk Scraper Adjustment
Harrow Adjustment
Leaf Spring Adjustment
Marker Adjustments
Folding Speed
Disk Adjustments
Pivot Lock Tube Adjustment
Seed-Lok Lock Up
Setting the Seeding Rate
Changing Drive Sprockets
Setting Seed-Rate Handle
Positioning Seed-Cup Doors
Checking Seeding Rate
Seed Rate Charts
Fertilizer Rate Calibration
Fertilizer Meter Rate Charts
Density Conversion Chart
Small Seeds Attachment
Small Seed Rate Charts
Section 4 Troubleshooting
Section 5 Maintenance and Lubrication
Maintenance
Fertilizer Clean Out
Transport Cylinder Support Brace
Storage
Lubrication
Vertical Pivot Bushings, Top and Bottom
Coulter Swing Arm Pivot
Coulter Hub Bearings
Seed-Cup-Drive Sprocket
Tongue to Main Frame Pivot
Transport Wheel Bearings
Optional Folding Markers
Additional Lubrication, Fertilizer Drills
Section 6 Options
Harrow Attachment
Markers
Mud Guard
Acremeter
Seed-Cup Plugs
Seed-Lok Firming Wheels
Section 7 Specifications and Capacities
Appendix
Tire Inflation Chart
Torque Values Chart
Warranty
