Gradall Wheeled Excavator XL3300 Operators Parts Service Technical Manual
Brand: Gradall
Type of Machine: Rough-terrain Wheeled Excavator
Type of Manual: Combined Service Manual, Electrical Schematic, Hydraulic Schematic, Illustrated Parts Manual, Lubrication Chart, Operator Safety Manual, Operators Manual, Parts Manual, Service Manual, Service Supplement, Technical Manual, Upper Electrical Schematic
Model: Gradall XL3300 Rough-terrain Wheeled Excavator
List of Files:
XL3200 XL3300 Technical Manual 32004004 2011.pdf (656 Pages)
ELECTRICAL
XL3200 Electrical System Manual
XL3300 Electrical System Manual
BB-3 Control Panel
HYDRAULIC
XL3200 Hydraulic System Manual
XL3300 Hydraulic System Manual
XL3200 & XL3300 Hydraulic System Operation Supplement
XL3200 Pressure Setting Guide (Troubleshooting)
XL3300 Pressure Setting Manual
XL3200 Final Test Report
XL3300 Final Test Report
MECHANICAL
Rough Terrain Excavator Maintenance Manual (XL3300)
Crawler Excavator Maintenance Manual (XL3200)
XL3300 Transmission Service Manual
XL3300 Axle Service Manual
XL3300 Torque Specs (80319006)
Hydraulic Fitting Torque Chart (80609016)
Loctite Chart (80319007)
Product Support Information - Swing Transmission Lube Check & Refill
Product Support Information - A/C System Reciever Dryers
Product Support Information - A/C System Moisture Contamination
Product Support Information - A/C Systems & Compressed Air
SCHEMATICS
XL3300 Hydraulic Schematic (80339005)
XL3300 Upper Electrical Schematic (80339006)
XL3200 Hydraulic Schematic (80319008)
XL3200 Upper Electrical Schematic (80319001)
XL3300 Illustrated Parts Manual 3300-4001 2025.pdf (436 Pages)
Service Kits
Section 1 Frame & Attaching Parts
Figure 1-1 Frame Assembly
Figure 1-2 Frame & Plumbing
Figure 1-3 L.H. Rotating Platform
Figure 1-4 R.H. Rotating Platform
Figure 1-5 Swing Bearing, Cradle & Hoist Cylinder Mounting & Lube System
Figure 1-6 Engine Cover
Figure 1-7 Valve Cover
Section 2 Boom
Figure 2-1 Boom Cradle Assembly
Figure 2-2 Main Boom Assembly
Figure 2-3 Roller Assemblies
Figure 2-4 Telescope Boom Assembly
Figure 2-5 Bucket Linkage
Section 3 Attachments
Figure 3-1 24” & 30” Excavating Buckets
Figure 3-2 36” Excavating & 30” Pavement Removal Buckets
Figure 3-3 60” & 66” Ditching Buckets
Figure 3-4 8’ Grading Blade
Figure 3-5 Single Tooth Ripper
Figure 3-6 4’ Boom Extension
Figure 3-7 Fixed Thumb Grapple Assembly
Figure 3-8 Limb Lopper
Figure 3-9 Telestick Adapter Installation
Section 4 Engine & Attaching Parts
Figure 4-1 Engine Assembly
Figure 4-2 Deere Engine Assembly
Figure 4-3 Air Cleaner & Installation
Figure 4-4 Air Cleaner Assembly
Figure 4-5 Exhaust System
Figure 4-6 Fuel Tank Assembly
Figure 4-7 Oil Cooler, Radiator & Hoses
Section 5 Drive Train
Figure 5-1 Transmission - Input Housing
Figure 5-2 Transmission - Input
Figure 5-3 Transmission - Housing
Figure 5-4 Transmission - Oil Pipe
Figure 5-5 Transmission - Coupling
Figure 5-6 Transmission - Disc Brake
Figure 5-7 Transmission - Planetary Drive
Figure 5-8 Transmission - Disconnection
Figure 5-9 Transmission - Spurred Gear Drive
Figure 5-10 Transmission - Shift Sensor
Figure 5-11 Transmission - Output
Figure 5-12 Steer Axle - Axle Housing
Figure 5-13 Steer Axle - Differential Spider, Cage & Nest
Figure 5-14 Steer Axle - Differential Carrier
Figure 5-15 Steer Axle - Wheel End
Figure 5-16 Steer Axle - Gearbox & Brake
Figure 5-17 Steer Axle - Steering Gear
Figure 5-18 Drive Axle - Housing & Cover
Figure 5-19 Drive Axle - Differential
Figure 5-20 Drive Axle - Hub Carrier & Wheel End
Figure 5-21 Drive Axle - Gearbox & Brake
Section 6 Cab
Figure 6-1 Operators Cab
Figure 6-2 Operators Cab
Figure 6-3 Cab Door
Figure 6-4 Cab Interior Components
Figure 6-5 Cab Console
Figure 6-6 Cab Seat
Figure 6-7 Cab Heater & Installation
Figure 6-8 Cab Wiper/Washer Installation
Figure 6-9 Pilot Cut-off Assembly
Section 7 Controls
Figure 7-1 Joystick
Figure 7-2 Steering Column, Foot Pedals & Installation
Figure 7-3 Steering Control
Section 8 Hydraulic Circuits
Figure 8-1 Oil Supply to Pumps
Figure 8-2 Hydraulic Pressure to Control Valves
Figure 8-3 Main Valve to Pilot Manifold Hydraulic Hosing
Figure 8-4 Hydraulic Hosing to Joysticks & Propel
Figure 8-5 Dump Circuit
Figure 8-6 Hoist Pilot
Figure 8-7 Boom Pilot
Figure 8-8 Tool Pilot
Figure 8-9 Swing & Swing Brake Pilot
Figure 8-10 Hoist Cylinder
Figure 8-11 Boom Cylinder
Figure 8-12 Tool Cylinder
Figure 8-13 Swing Motor
Figure 8-14 Tilt Motor
Figure 8-15 Upper Propelling
Figure 8-16 Chassis Supply
Figure 8-17 Chassis Supply Pilot
Figure 8-18 Tilt & Auxiliary Pilot
Section 9 Hydraulic Components
Figure 9-1 Hoist Cylinder Assembly
Figure 9-2 Boom Cylinder Assembly
Figure 9-3 Tool Cylinder Assembly
Figure 9-4 Outrigger Cylinder Assembly
Figure 9-5 Oscillation Cylinder Assembly
Figure 9-6 Swing Lock Cylinder
Figure 9-7 Blade Cylinder Assembly
Figure 9-8 Main Pump - Front
Figure 9-9 Main Pump - Rear
Figure 9-10 Pilot Manifold Valve Tray Hydraulic Components
Figure 9-11 Pilot Propel Valve Tray Hydraulic Components
Figure 9-12 Pilot Manifold
Figure 9-13 Main Hydraulic Control Valve Assembly
Figure 9-14 Main Hydraulic Control Valve & w/Auxiliary
Figure 9-15 Main Hydraulic Control Valve - Spools & End Caps
Figure 9-16 Main Hydraulic Control Valve - Swing Section
Figure 9-17 Main Hydraulic Control Valve - Seal Kits
Figure 9-18 Hydraulic Reservoir Assembly
Figure 9-19 Swing Transmission Assembly
Figure 9-20 Swing Drive Assembly
Figure 9-21 Swing Motor Assembly
Figure 9-22 Swing Brake
Figure 9-23 Tilt Transmission Assembly
Figure 9-24 Tilt Drive Assembly
Figure 9-25 Tilt Brake Assembly
Figure 9-26 Tilt Motor
Figure 9-27 Drive Motor
Figure 9-28 Center Pin
Figure 9-29 Gear Pump
Figure 9-30 Foot Operated Pedal Valve & Brake Valve
Figure 9-31 Transmission Control Valve
Figure 9-32 Outrigger Selector Valve
Figure 9-33 Six-Way Diverter Valve
Figure 9-34 Duel Solenoid Valve
Figure 9-35 Oscillation/Cylinder Anti-Drift Valve
Figure 9-36 Outrigger Valve Block
Figure 9-37 Thermal By-Pass Valve
Figure 9-38 Propel Pilot Valve
Figure 9-39 Blade Selector Valve
Figure 9-40 Blade Valve Block
Section 10 Electrical
Figure 10-1 Batteries & Misc. Electrical Components
Figure 10-2 Circuit Board
Section 11 Decals
Figure 11-1 Decals
Figure 11-2 CE Decals
Section 12 Options
Figure 12-1 Air Condition Kit Installation Components
Figure 12-2 Air Conditioning Evaporator Kit
Figure 12-3 Additional Battery Installation Components
Figure 12-4 Engine Block Heater Installation Components
Figure 12-5 Cold Start Installation Components
Figure 12-6 Floodlight Installation Components
Figure 12-7 HID Floodlight Installation Components
Figure 12-8 Seat Belt Installation Components
Figure 12-9 AM/FM Radio & Antenna Installation Components
Figure 12-10 Chassis Mounted Blade Installation Components
Figure 12-11 Front Outrigger Assembly Installation Components
Figure 12-12 Front Outrigger Installation Components
Figure 12-13 Wiper-Washer Installation Components
Figure 12-14 Auxiliary Hydraulic Field Installation Components
Recommended Spare Parts
Part Number Index
3300-4005 XL3300 NA Operators Manual 2004.pdf (68 Pages)
Introduction
General
Related Manuals & Decals
Operator Qualifications
Orientation
Serial Number Location (Product Identification No.)
Nomenclature
Tools
Safety
Serial Number Plates
Operator’s Cab
Seat Adjustment
Control & Instrument Identification
Electronic Monitor
Engine Operation
Checks & Services Before Starting Engine
Starting Engine
Cold Weather Starting Aids
Normal Engine Operation
Auto Idle
Stopping Engine
Warm Up & Operational Checks
Adapter Attachment Installation
Travel
Outriggers
Steering
Drive Train
Operator Control Patterns
Typical Digging Cycle
Lifting & Positioning A Load
Maintenance & Lubrication Diagram
Recommended Lubricants & Capacities
Torque Chart
Emergency Towing
Loading & Securing For Transport
Preservation & Storage
If You Get Stuck
Basic Machine Dimensions
Excavator Hand Signals
XL3300 NA Combined Service Manual 3300-4006 2006.pdf (945 Pages)
3300-4006 XL3300 NA Combined Service Manual
OPERATOR INSTRUCTION
20020 3300-4005 XL3300NA OWNER/OPERATOR
SCHEDULED MAINTENANCE
XL3300 Lubrication & Maintenance Chart
8090-9017 Critical Item Checklist
HYDRAULIC SYSTEM OPERATION
8033-9005 Hydraulic Schematic
8033-9001 Start-Up Procedure
RA64-555 Rexroth Joystick
HYDRAULIC TEST & ADJUSTMENT
8033-9003 Final Test Report
MECHANICAL ADJUSTMENTS
1512-003 Parker Low Speed, High Torque Hydraulic Motors
75580 Ausco Brake Technical Page
29712 Boom Extension Installation Manual
ELECTRICAL
1M-128 Delco Remy 28-MT Cranking Motor Service Manual
8033-9006 Electrical Schematic
8036-3115 Upper Harness
8036-3079 Engine Harness
8036-3114 Cab Harness
8036-5024 Console Assembly Circuit
DCMB Trojan Deep Cycle Battery Maintenance
BCI-II edition Trojan Battery Service Manual
125-189 Leece-Neville Alternators for Electronic Charging Systems
DRIVE AXLE
AP(L)-B 765/775 ZF-Planetary Axle w/Wet-Type Multiple-Disk Brakes Service
APL-B 765 ZF-Planetary Steering Axle Parts Manual
AP-B 765 ZF-Rear Axle Parts Manual
2 HL 100 ZF-Transfer Case Service Manual
2 HL 100 ZF-Hydrostatic Powershift Transmission Technical Manual
2 HL 100 ZF-Axle Transfer Case Parts Manual
WHEEL & RIM
0009 Rim & Wheel Safety Manual
MISCELLANEOUS
20013 Gradall Safety Manual
HE92-2 EMI Hydraulic Excavator Safety Manual
8031-9006 Torque Specs
8031-9007 Loctite Chart
8060-9016 Hydraulic Fitting Torque Chart
XL3300 Hydraulic Schematic 80339005.pdf (1 Pages)
XL3300 Upper Electrical Schematic 80339006.pdf (5 Pages)
XL3300III XL4300III XL5300III XL3310III XL4310III to XL5320III Illustrated Parts Manual 80644001 2026.pdf (760 Pages)
Understanding Your Manual
Section 1 - Frame & Attaching Parts
Frame & Cover Plate Installation
Tool Boxes & Steps Installation
Skid Plate Installation
Upperstructure Mirror Installation (old-style)
Upperstructure Mirror Installation (new-style)
Upperstructure Covers Installation
Covers Installation, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III (optional steel covers)
Valve Cover
Valve Cover, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III, (optional steel covers)
Left Front Door
Left Rear Door
Fuel Tank & Reservoir Installation
Fuel Tank & Reservoir Assembly, XL3300III, XL3320III, XL4300III, XL4320III & XL5300III
Fuel Tank & Reservoir Assembly, XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Swing Bearing Installation Components
Swing Lock Installation
Counterweight & Swing Light Installation, XL3300III, XL3310III & XL3320III
Counterweight & Swing Light Installation, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Counterweight Bumpers Installation, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Boom Installation Components
Cab Installation Components, XL3300III, XL4300III & XL5300III
Cab Installation Components, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Power Unit Installation
Center Pin Installation
Section 2 - Boom
Boom Cradle, XL3300III & XL4300III
Boom Cradle, XL5300III
Boom Cradle, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Main Boom Assembly, XL3300III & XL4300III
Main Boom Assembly, XL5300III
Main Boom Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Telescope Boom Assembly, XL3300III, XL4300III & XL5300III
Telescope Boom Assembly, XL3310III, XL3320III, XL4310III, XL4320III & XL5310III
Telescope Boom Assembly, XL5320III
Boom Roller Assemblies
Bucket Linkage, XL3300III, XL4300III & XL5300III
Bucket Linkage, XL3310III, XL3320III, XL4310III, XL4320III & XL5310III
Bucket Linkage, XL5320III
Section 3 - Attachments
30” Excavating Bucket (Pin-On)
36” Excavating Buckets
42” Excavating Bucket
48” Excavating Bucket
15” Trenching Bucket
18” & 28” Pavement Removal Buckets
24” & 40” Pavement Removal Buckets
24” Ditching Bucket w/o Teeth & 48” Ditching Bucket
30” & 60” Ditching Buckets
60” Ditching Bucket w/Bolt-on Cutting Edge
66” Ditching Bucket
66” Ditching Bucket w/Bolt-on Cutting Edge
72” Ditching Bucket
72” Ditching Bucket (Pin-On)
72” & 108” Dredging Buckets
Alamo 48” Flail Mower Installation
Alamo 50” Rotary Mower Assembly
Alamo 60” Rotary Mower Assembly
4’, 6’, 8’ & 12’ Boom Extension
Auxiliary Hydraulics, 4’, 6’, 8’ & 12’ Boom Extension
Telestick Installation, XL4300III
Telestick Installation, XL5300III
Guardrail Back Scraper
2184MM & 2800MM Conveyor Buckets
8’ Grading Blade & Single Tooth Ripper
Tree Limb Shear Assembly
Hydraulic Thumb Grapple Assembly
Single & Double Tooth Scaling Hooks (Pin-On)
Hammer (Rammer S27) w/Hammer Bracket Installation
Hammer (Rammer S29) w/Hammer Bracket Installation
Hammer (Rammer S27 & S29) Bracket Assemblies
Air Hammer (Kent 999) Installation, XL3310III, XL4310III & XL5310III
Section 4 - Engine & Attaching Parts
Power Unit Assembly
Muffler Support Components
Air Cleaner Installation
Cooling Unit Installation
Double Gear Pump Installation
Section 5 - Drive Train
Transmission, Drive Motor and Drive Shafts Installation
Axle Installation, XL3300III, XL3310III & XL3320III
Axle Installation, XL4300III & XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Tire & Wheel Assembly
Tire & Wheel Assembly (w/Rail Gear; optional)
Front Steer Axle - Input, XL3300III, XL3310III & XL3320III
Front Steer Axle - Differential, XL3300III, XL3310III & XL3320III
Front Steer Axle - Axle Casing, XL3300III, XL3310III & XL3320III
Front Steer Axle - Joint Housing, XL3300III, XL3310III & XL3320III
Front Steer Axle - Steering Cylinder, XL3300III, XL3310III & XL3320III
Front Steer Axle - Output, XL3300III, XL3310III & XL3320III
Front Steer Axle - Input, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Differential, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Axle Casing, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Joint Housing, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Steering Cylinder, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Output, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Input, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Differential, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Axle Casing, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Hub Carrier, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Output, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Input, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Differential, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Axle Casing, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Hub Carrier, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Output, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Section 6 - Cab
Operators Cab Assembly, XL3300III, XL4300III & XL5300III
Operators Cab Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Operators Cab, XL3300III, XL4300III & XL5300III
Operators Cab, XL3310III, XL3320III, XL4310III & XL5310III
Operators Cab (SI Mine Cab), XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Operators Cab Door, XL3300III, XL4300III & XL5300III
Operators Cab Door, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Operators Cab Console
Pod Panel Assemblies
Operators Cab Seat Assembly
Operators Cab Seat
Evaporator & Heater Assembly
Air Conditioning Installation
Cab Guard Frame Installation, XL3310III, XL4310III & XL5310III
Cab Guard Frame Installation (SI Mine Cab), XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Cab Heat Shield Installation, XL3310III, XL4310III & XL5310III
Cab Heat Shield Installation (SI Mine Cab), XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Cab Guard Installation, XL3310III, XL4310III & XL5310III
Cab Guard Installation (SI Mine Cab), XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Section 7 - Controls
Foot Pedal Plate Assembly
Section 8 - Hydraulic Circuits
Main Valve to Pilot Manifold, XL3300III, XL4300III & XL5300III
Main Valve to Pilot Manifold, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Dump Circuit
Hoist Cylinder Hydraulic Circuit
Hoist Tubes Replacement Kit
Boom Cylinder Hydraulic Circuit, XL3300III, XL4300III & XL5300III
Boom Cylinder Hydraulic Circuit, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tool Cylinder Hydraulic Circuit, XL3300III, XL4300III & XL5300III
Tool Cylinder Hydraulic Circuit, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tilt Motor Hydraulic Circuit, XL3300III, XL4300III & XL5300III
Tilt Motor Hydraulic Circuit, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Swing Motor Hydraulic Circuit
Swing Tubes Replacement Kit
Upper Propelling Hydraulic Circuit
Chassis Supply Hydraulic Circuit
Steering Control and Brake Pedal Valve Hydraulic Circuit
Oscillation Circuit
Outrigger & Blade Circuit
Steering & Brake Circuit
Drive Motor & Transmission Circuit
Section 9 - Hydraulic Components
Hoist Cylinder Assembly, XL3300III, XL3310III & XL3320III
Hoist Cylinder Assembly, XL4300III, XL4310III, XL4320III & XL5320III
Hoist Cylinder Assembly, XL5300III & XL5310III
Boom Cylinder Assembly, XL3300III, XL3310III & XL3320III
Boom Cylinder Assembly, XL4300III, XL4310III & XL4320III
Boom Cylinder Assembly, XL5300III, XL5310III & XL5320III
Tool Cylinder Assembly, XL3300III
Tool Cylinder Assembly, XL4300III, XL5300III & XL5320III
Tool Cylinder Assembly, XL3310III, XL3320III, XL4310III, XL4320III & XL5310III
Axle Oscillation Cylinder Assembly
Drive Motor
Main Hydraulic Pump
Main Hydraulic Control Valve - End Caps
Main Hydraulic Control Valve - Valve Section, Swing
Main Hydraulic Control Valve - Valve Section, Chassis Supply & Auxiliary
Pilot Manifold Valve Tray Components, XL3300III, XL4300III & XL5300III
Pilot Manifold Valve Tray Components, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Pilot Manifold Assembly
Swing Brake Assembly
Tilt Transmission Assembly, XL3300III, XL4300III & XL5300III
Tilt Transmission Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tilt Drive Assembly, XL3300III, XL4300III & XL5300III
Tilt Transmission, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tilt Motor Assembly, XL3300III, XL4300III & XL5300III
Tilt Motor Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tilt Brake Assembly, XL3300III, XL4300III & XL5300III
Tilt Brake Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Center Pin Assembly
Center Pin
Steering Control Unit
Transmission Control Valve Assembly
Rear Outrigger Valve Assembly
Front Outrigger Valve Assembly
Oscillation Lock Valve Assembly
Section 10 - Electrical
Service Panel Assembly
Cab Console Circuit Board
Undercarriage Harness Installation
Work Lights Installation
Section 11 - Decals
Decals Installation, XL3300III, XL4300III & XL5300III
Decals Installation, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Section 12 - Options
Air Block Installation
Air Hammer (Kent 999) Supply Plumbing Installation, XL3310III, XL4310III & XL5310III
Air Hammer (Kent 999) Air Line Oiler Installation, XL3210III, XL4210III & XL5210III
Auxiliary Cab Fan Installation
Auxiliary Hydraulic Plumbing Installation, XL3300III, XL4300III & XL5300III
Auxiliary Hydraulic Plumbing Installation, XL3310III, XL4310III & XL5310III
Auxiliary Hydraulic Quick Disconnects Installation
Blade Installation
Blade Installation, (less cylinders)
Bolt-On Lifting Yoke Installation, XL3310III, XL4310III & XL5310III
Bolt-On Folding Lifting Yoke Installation, XL3310III, XL4310III & XL5310III
Boom Top Guard Installation, XL3310III, XL4310III & XL5310III
Cab Air Filter Installation, XL3310III, XL4310III & XL5310III
Camera Kit Installation
Engine Shutdown Installation
Escape Hammer Installation
Fire Extinguisher Installation
Fire Extinguisher (in cab) Installation
Fire Extinguisher Installation, XL3310III, XL4310III & XL5310III
Fire Supression System Installation
First Aid Kit Installation
Frame Head Lights Installation, XL3310III, XL4310III & XL5310III
Front Window Guard Installation, XL3300III, XL4300III & XL5300III
Grid Heater Installation
“Headlights On” Relay Installation
Hoist Lock Installation, XL3300III & XL3310III
Hoist Lock Installation, XL4300III, XL4310III, XL5300III & XL5310III
Hydraulic Fluid Installation, Quintolubric 888-68
Hydraulic Fluid Installation, Ecosafe FR-68
Hydraulic Supressor Installation
Low Pressure Aux Return Installation
Radio Power Supply Installation
Rail Gear Units - Brake Tee Installation
Rail Gear Units - Front & Rear Cylinders Installation
Search Light Installation
Seat Belt Installations
Seat Belt Installation, 3-Point
Speaker Installation
Strobe Light Installation, XL3300III, XL4300III & XL5300III
Strobe Light w/Branch Guard Installation, XL3300III, XL4300III & XL5300III
Strobe Light (Super-LED) Installation, XL3300III, XL4300III & XL5300III
Strobe Light (roof guard mount) Installation, XL3310III, XL4310III & XL5310III
Sun Visor Installation
Swing Motor Port Jumper Circuit Installation
Tire Shield Installation
Tool Open Lock Installations
Two-Point Lift Ring Installation
Vandal Covers Installation, XL3300III, XL4300III & XL5300III
Windshield Wiper Installation
Work Light (HID) Installation
Work Light Installation, XL3310III, XL4310III & XL5310III
Part Number Index
XL3300III XL4300III XL5300III XL3310III to XL4320III XL5320III Operators Safety Manual 80644002 2024.pdf (122 Pages)
Section 1 - General Safety Practices
1.1 Hazard Classification System
1.2 General Precautions
1.3 Operation Safety
1.4 Personal Protection Equipment
Section 2 - Pre-Operation and Controls
2.1 Pre-Operation Checks & Inspection
2.2 Walk-Around Inspection
2.3 Safety Decals - XL3300III, XL4300III & XL5300III
2.4 Safety Decals - XL3300III, XL4300III & XL5300III (CE)
2.5 Safety Decals - XL3310III, XL4310III, XL5310III, XL3320III, 4320III & XL5320III
2.6 Safety Decals - XL3310III, XL4310III, XL5310III XL3320III, XL4320III & XL5320III (CE)
2.7 Cab Components
2.8 Cab Controls & Indicators
Section 3 - Operation
3.1 Engine Operation
3.2 Checks Before Operation
3.3 Brake System
3.4 Travel Modes
3.5 Typical Dig Cycle
3.6 Lifting & Placing a Load - XL3300III, XL4300III & XL5300III
3.7 Lift Capacity - XL3300III, XL4300III & XL5300III
3.8 Engine Shutdown
3.9 Parking the Excavator
3.10 Preservation & Storage
3.11 Rail Gear Operation (Optional)
Section 4 - Attachments
4.1 Approved Attachments
4.2 Unapproved Attachments
4.3 Attachment Operation
4.4 Adapter Attachment Installation
Section 5 - Lubrication & Maintenance
5.1 Introduction
5.2 General Maintenance Instructions
5.3 Service & Maintenance Schedules
5.4 Lubrication Schedules
Section 6 - Emergency Procedures
6.1 Loss Of Power
6.2 If You Get Stuck
6.3 Towing the machine
Section 7 - Specifications
7.1 Product Specifications
7.2 Torque Chart
7.3 Fuses
Pre-Operation Inspection Checklist
Index
XL3300III XL4300III XL5300III XL3310III XL4310III to XL4320III XL5320III Service Manual 80644003 2024.pdf (441 Pages)
Operator & Safety Manual
Revision Log
Read This First
Table of Contents
Section 2 - Pre-Operation & Controls
Pre-Op Inspection Checklist
Alphabetical Index
Hand Signals
Hydraulic Section
Gradall Series III System Operation
Crawler & Rough Terrain Hydraulic Pressure Adjustment Procedures
80799009 Final Test Report
Product Support - Fire Resistent Hydraulic Fluids
Product Support - Series III Boom Circuit Speed
80799001 (C) Hydraulic Schematic, XL3300III, XL4300III, XL5300III (equipped with center pin 80333102 or 80733031 only)
80799023 (-) Hydraulic Schematic, XL3300III, XL4300III, XL5300III (equipped with center pin 80733056 only)
80799012 (B) Hydraulic Schematic, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III, XL5320III (equipped with center pin 80333102 or 80733031 only)
80799024 (-) Hydraulic Schematic, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III, XL5320III (equipped with center pin 80733056 only)
80609016 Torque Chart
Electrical Section
Gradall Bodas-Service Installation & Operation
Gradall Series III RT & Crawler Electrical Manual
80799002 (F) Electrical Schematic, XL3300III, XL4300III & XL5300III
80799011 (C) Electrical Schematic, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
80763011 (I) Upper Harness
Mechanical Section
Gradall Crawler & Rough Terrain Series III Mechanical Adjustments
Product Support - Engine Oil Pan Drain Plugs
Product Support - Swing Transmission Lube Check and Refill
Product Support - Fan Clutch Maintenance
Product Support - Drive Belt Routing
Bolt Torque Chart
Climate Control Section
Climate Control Systems - Series III Crawler & Wheeled Models
Product Support - AC System Receiver ADryers
Product Support - R134a AC Systems & Compressed Air
Product Support - AC System Moisture Contamination
XL3300 XL4300 XL5300 to XL4330 XL5330 Upper Lubrication Chart Series III V Rough Terrain 80644004.pdf (1 Pages)
XL3300V XL3310V XL3330V to XL5300V XL5310V XL5330V Illustrated Parts Manual 80644006 2025.pdf (794 Pages)
Upperstructure Mirror Installation (Steel Mirrors)
Upperstructure Covers Installation (Tier 4F Engine)
Upperstructure Covers Installation (CE) (Tier 4F Engine)
Upperstructure Covers Installation (Tier 3 Engine)
Upperstructure Covers Installation (Tier V Engine)
Valve Cover
Valve Cover (CE)
Fuel Tank & Reservoir Assembly (Plastic Fuel Tank)
Fuel Tank & Reservoir Assembly (Steel Fuel Tank)
Reservoir Breather Installation
Counterweight & Swing Light Installation, XL3000’s
Counterweight & Swing Light Installation, XL4000’s & XL5000’s
Counterweight Bumpers Installation, XL3310V, XL4310V, XL4320V & XL5310V
Counterweight Plates Installation (optional)
Cab Installation Components, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Cab Installation Components, XL3310V, XL4310V, XL4320V & XL5310V
Section 2 - Boom
Boom Cradle, XL3300V, XL3330V, XL4300V & XL4330V
Boom Cradle, XL4320V
Boom Cradle, XL5300V & XL5330V
Boom Cradle, XL3310V, XL4310V & XL5310V
Main Boom Assembly, XL3300V, XL3330V, XL4300V & XL4330V
Main Boom Assembly, XL5300V & XL5330V
Main Boom Assembly, XL3310V, XL4310V, XL4320V & XL5310V
Telescope Boom Assembly, XL3300V, XL3330V, XL4300V, XL4320V, XL4330V, XL5300V & XL5330V
Telescope Boom Assembly, XL3310V, XL4310V & XL5310V
Bucket Linkage, XL3300V, XL3330V, XL4300V, XL4320V, XL4330V, XL5300V & XL5330V
Bucket Linkage, XL3310V, XL4310V & XL5310V
42” Ditching Bucket w/o Teeth
48” Ditching Bucket w/Bolt-on Cutting Edge
66” Ditching Bucket
72” Ditching Bucket
Telestick Installation, XL4300V
Telestick Installation, XL5300V
2184MM & 2800MM Conveyor Buckets (Pin-On)
Single & Double Tooth Scaling Hook (Pin-On)
Air Hammer (Kent 999) Installation (Pin-On), XL3310V, XL4310V & XL5310V
Hammer (Rammer 999) w/Quick Switch Adapter Installation
Rock Saw Installation, XL3300V, XL4300V, XL3330V, XL4330V & XL5330V
Power Unit Assembly (Tier 4F Engine)
Power Unit Assembly (Tier 3 Engine)
Power Unit Assembly (Stage V Engine)
Exhaust System Installation (Tier 4F Engine)
Exhaust System Installation (Tier 3 Engine)
Exhaust System Installation (Stage V Engine)
Air Cleaner Installation (Tier 4F Engine)
Air Cleaner Installation (Tier 3 Engine)
Air Cleaner Installation (Stage V Engine)
Cooling Unit Installation (Tier 4F Engine)
Cooling Unit Installation (Tier 3 Engine)
Cooling Unit Installation (Stage V Engine)
DEF Tank Installation (Tier 4F Engine)
DEF Tank Installation (Stage V Engine)
Axle Installation, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Axle Installation, XL4300V & XL4310V, XL4320V, XL5300V & XL5310V
Front Steer Axle - Input, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Front Steer Axle - Differential, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Front Steer Axle - Axle Casing, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Front Steer Axle - Joint Housing, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Front Steer Axle - Steering Cylinder, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Front Steer Axle - Output, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Front Steer Axle - Input, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Front Steer Axle - Differential, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Front Steer Axle - Axle Casing, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Front Steer Axle - Joint Housing, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Front Steer Axle - Steering Cylinder, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Front Steer Axle - Output, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Rear Drive Axle - Input, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Rear Drive Axle - Differential, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Rear Drive Axle - Axle Casing, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Rear Drive Axle - Hub Carrier, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Rear Drive Axle - Output, XL3300V, XL3330V, XL3310V, XL4330V & XL5330V
Rear Drive Axle - Input, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Rear Drive Axle - Differential, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Rear Drive Axle - Axle Casing, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Rear Drive Axle - Hub Carrier, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Rear Drive Axle - Output, XL4300V, XL4310V, XL4320V, XL5300V & XL5310V
Rail Gear Components Installation
Railgear Pintle Hitch Installation, XL3330V, XL4330V & XL5330V (optional)
Section 6 - Cab
Operators Cab Assembly, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Operators Cab Assembly, XL3310V, XL4310V, XL4320V & XL5310V
Operators Cab, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Operators Cab, XL3310V, XL4310V & XL5310V
Operators Cab, XL4320V
Operators Cab Door, XL3300V, XL3330V, XL4300V, XL4320V, XL4330V, XL5300V & XL5330V
Operators Cab Door, XL3310V, XL4310V & XL5310V
Operators Cab Seat
Evaporator & Heater Assembly (Pro-Air Units)
Evaporator & Heater Assembly (Victory Units)
Foot Operated Switch for Aux Hydraulics (bidirectional flow), (optional)
Foot Operated Switch for Aux Hydraulics (unidirectional flow), (optional)
Radio Remote Control Installation, With Cab (optional)
Radio Remote Controller Installation (optional)
Remote Control Transmitter/Receiver Components (optional)
Oil Supply to Main Pump & Control Valve
Main Valve to Pilot Manifold, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Main Valve to Pilot Manifold, XL3310V, XL4310V, XL4320V & XL5310V
Dump Circuit
Boom Cylinder Hydraulic Circuit, XL3300V, XL3330V, XL4300V, XL4320V, XL4330V, XL5300V & XL5330V
Boom Cylinder Hydraulic Circuit, XL3310V, XL4310V & XL5310V
Tool Cylinder Hydraulic Circuit, XL3300V, XL3330V, XL4300V, XL4320V, XL4330V, XL5300V & XL5330V
Tool Cylinder Hydraulic Circuit, XL3310V, XL4310V & XL5310V
Case Drain Circuit, XL3300V, XL3330V, XL4300V, XL4320V, XL4330V, XL5300 & XL5330V (optional)
Tilt Motor Hydraulic Circuit, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Tilt Motor Hydraulic Circuit, XL4320V
Tilt Motor Hydraulic Circuit, XL3310V, XL4310V & XL5310V
Oscillation Circuit
Hoist Cylinder Assembly, XL3300V, XL3330V & XL3310V
Hoist Cylinder Assembly, XL4300V, XL4320V, XL4330V & XL4310V
Hoist Cylinder Assembly, XL5300V, XL5310V & XL5330V
Boom Cylinder Assembly, XL3300V, XL3330V & XL3310V
Boom Cylinder Assembly, XL4300V, XL4320V, XL4330V & XL4310V
Boom Cylinder Assembly, XL5300V, XL5310V & XL5330V
Tool Cylinder Assembly, XL3300V & XL3330V
Tool Cylinder Assembly, XL4300V, XL4320V, XL4330V, XL5300V & XL5330V
Tool Cylinder Assembly, XL3310V, XL4310V & XL5310V
Drive Motor
Main Hydraulic Pump
Pilot Manifold Valve Tray Components, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Pilot Manifold Valve Tray Components, XL3310V, XL4310V, XL4320V & XL5310V
Swing Transmission Assembly, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Swing Transmission Assembly, XL3310V, XL4310V, XL4320V & XL5310V
Swing Drive Assembly, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Swing Drive Assembly, XL3310V, XL4310V, XL4320V & XL5310V
Tilt Transmission Assembly, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Tilt Transmission Assembly, XL3310V, XL4310V, XL4320V & XL5310V
Tilt Drive Assembly, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Tilt Transmission, XL3310V, XL4310V, XL4320V & XL5310V
Tilt Motor Assembly, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Tilt Motor Assembly, XL3310V, XL4310V, XL4320V & XL5310V
Tilt Brake Assembly, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Tilt Brake Assembly, XL3310V, XL4310V, XL4320V & XL5310V
Center Pin Assembly
Center Pin
Rail Gear Units - Travel Lights (FRA) Installation (optional)
Section 11 - Decals
Decals Installation, XL3300V, XL4300V & XL5300V
Decals Installation, XL3310V, XL3330V, XL4310V, XL4320V, XL4330V, XL5310V & XL5330V
Lube Chart Installation, XL3330V, XL4330V & XL5330V (optional)
Lube Chart Installation, XL3300V, XL4300V, XL5300V, XL3310V, XL4310V, XL5310V & XL4320V (optional)
Machine Weight Plate Installation, XL3330V, XL4330V & XL5330V (optional)
Fuel & Hydraulic Oil Decals Installation, XL3330V, XL4330V & XL5330V (optional)
Air Hammer (Kent 999) Supply Plumbing Installation, XL3310V, XL4310V & XL5310V
Air Hammer (Kent 999) Air Line Oiler Installation, XL3310V, XL4310V & XL5310V
Auxiliary Hydraulic Plumbing Installation, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Auxiliary Hydraulic Plumbing Installation, XL3310V, XL4310V & XL5310V
Auxiliary Tube Adapter Installation
Blade Installation
Bolt-On Lifting Yoke Installation, XL3310V, XL4310V & XL5310V
Bolt-On Folding Lifting Yoke Installation, XL3310V, XL4310V & XL5310V
Boom Hole Covers (main boom) Installation, XL3310V, XL4310V, XL4320V & XL5310V
Boom Hole Covers (telescope boom) Installation, XL4310V, XL4320V & XL5310V
Boom Top Guard Installation, XL3310V, XL4310V & XL5310V
Boom Top Guard Installation, XL4320V
Cab Air Filter Installation, XL3300V, XL3330V, XL4300V, XL4330V & XL5300V
Cab Air Filter Installation, XL3310V, XL4310V, XL4320V & XL5310V
Cab Guard Installation (ROPS Certified)
Cab Guard Installation (non - ROPS Certified)
Cab Roof Guard Installation (solid peaked)
Cab Roof Guard Installation (bars)
Cab Roof Guard Installation (mesh)
Camera (Split-Screen) Kit Installation
Camera (Quad-Screen) Kit Installation
Dual Air Horn Installation
Dual Air Horn (rear-facing) Installation
Emergency Hydraulics Installation
Engine Block Heater Installation (110v)
Engine Block Heater Installation (220v)
Extended Steps Installation, XL3330V, XL4330V & XL5330V
Fire Extinguisher Installation, XL3310V, XL4310V & XL5310V
Front Cab Guard (bottom) Installation (solid)
Front Cab Guard (bottom) Installation (slotted)
Front Window Guard Installation (solid bars)
Front Window Guard Installation (mesh)
Front Window Guard Installation (hinged wire mesh)
Front Window Guard Installation (hinged), XL3300V, XL3330V, XL4300V, XL4330V & XL5300V
Front Window Guard Installation (fixed), XL3300V, XL3330V, XL4300V, XL4330V & XL5300V
Front Window (Heat Resistant) Installation
Hand Rail Installation
Hydraulic Fluid Installation, Ecosafe FR-46
Low Pressure Aux Return Installation (left hand)
Low Pressure Aux Return Installation (right hand)
Power Supply (12-volt) Installation
Roller Bracket Guards Installation, XL3310V, XL4310V & XL5310V
Steering Wheel Lock Installation
Strobe Light (counterweight-mounted) Installation
Strobe Light (LED) Installation, XL3300V, XL4300V & XL5300V
Strobe Light (LED) Installation, XL3310V, XL4310V, XL4320V & XL5310V
Strobe Light (LED) Installation, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Strobe Light Branch Guard Installation, XL3300V, XL3330V, XL4300V, XL4330V & XL5300V
Utility Cable (5th line) Installation, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Utility Hose (5th line) Installation, XL3300V, XL3330V, XL4300V, XL4330V, XL5300V & XL5330V
Vandal Covers Installation, XL3300V, XL3330V, XL4300V, XL4330V & XL5300V
Work Light (LED) Installation
Work Light (Hi-Temp) Installation, XL3310V, XL4310V & XL5310V
Work Light Guards Installation
Work Lights (Sides & Rear) Installation
Zone Lights (Red Stripe LED) Installation
Part Number Index
XL3300V XL4300V XL5300V XL4310V to XL5330V XL4320V Operator Safety Manual 80644007 2026.pdf (148 Pages)
2.3 Safety Decals - XL3300V, XL4300V, XL5300V
2.4 Safety Decals - XL3310V, XL4310V, XL4320V, XL3330V, XL4330V, XL5310V & XL5330V
2.5 Cab Components
2.6 Cab Controls & Indicators
3.3 Brake System
3.4 Travel Modes
3.6 Lifting & Placing a Load - XL3300V, XL4300V & XL5300V
3.7 Lift Capacity - XL3300V, XL3330V, XL4300V, XL4330, XL5300V & XL5330V
3.8 Engine Shutdown
3.12 Parked Regeneration (Stage V Engines)
5.1 Introduction
5.5 Boom Adjustments & Maintenance
6.1 Loss Of Power
7.2 Torque Chart
7.3 Fuses
Index
XL3300V XL4300V XL5300V XL3310V to XL5330V XL4320V Service Supplement 80644008 2026.pdf (558 Pages)
OPERATOR INSTRUCTIONS
80644007_K_SV Rough Terrain Excavator Op & Safety Manual_4-2026
Revision Log
Read This First
Table of Contents
Index
ELECTRICAL
41200184_D_Bodas System Training_3-5-2026.pdf
Slide 1: BODAS Use & Operation Guide
Slide 2: BODAS – Program Notes
Slide 3: Program Notes (Continued)
Slide 4: Processor & Software
Slide 5: BODAS Software
Slide 6: Serial Communications Cable
Slide 7: This Doesn’t Work!
Slide 8: CAN Communication Port
Slide 9: Program Setup
Slide 10: Program Setup (Continued)
Slide 11: Program Setup (Continued)
Slide 12: Program Setup (Continued)
Slide 13
Slide 14: Using Bodas
Slide 15: Using Bodas (Continued)
Slide 16: Using Bodas (Continued)
Slide 17: Using Bodas (Continued)
Slide 18: Using Bodas (Continued)
Slide 19
Slide 20: Bodas Menus
Slide 21
Slide 22: Parameter-Calibration
Slide 23: Parameter-Calibration
Slide 24: Parameter-Calibration
Slide 25: Parameter-Calibration Expanded
Slide 26: Parameter-Calibrations
Slide 27: Parameter-Calibrations
Slide 28: Parameter- Machine and Truck type
Slide 29: Parameter- Unlocking
Slide 30: Parameter- Unlocked Parameters
Slide 31: Parameter- Unlocked Parameters
Slide 32: Parameter Settings
Slide 33: Parameter Menus Expanded
Slide 34: Parameter Menus Expanded
Slide 35: Parameter Menus Expanded
Slide 36: Parameter Menus Expanded
Slide 37: Parameter Menu Details
Slide 38: Parameter Menus Detail & Adjustments
Slide 39: Parameter Menus Detail & Adjustments
Slide 40
Slide 41: Error Messages
Slide 42: Error Messages (Continued)
Slide 43: Error Messages (Continued)
Slide 44
Slide 45: Processdata Menu
Slide 46: Processdata Menu (Continued)
Slide 47: Processdata Menu (Continued)
Slide 48: Processdata Menu (Continued)
Slide 49: Processdata Menu (Continued)
Slide 50: Processdata Menu (Continued)
Slide 51: Processdata Menu (Continued)
Slide 52: Processdata Menu (Continued)
Slide 53
Slide 54: How to Graph
Slide 55: Saving a Parfile
Slide 56: WARNING! WHAT NOT TO DO!
Slide 57
80799030 (D) Electrical Schematic
80763138 (A) Console Circuit Board
80763135 (H) Upper Harness
80763136 (B) Cab Harness
HYDRAULIC
80799031 (-) Hydraulic Schematic
DRIVE TRAIN
Front Axle Repair Manual
Front Axle Maintenance Instructions
Rear Axle Repair Manual
Rear Axle Maintenance Instructions
Transmission Repair Manual
Transmission Op & Maintenance
XL3300 XL4300 XL5300 to XL5310 XL4320 Series III V Rough Terrain Chassis Lube Chart 80644009.pdf (1 Pages)
XL3300 XL3300III XL4300 XL4300III Hydraulic Schematic 80799001.pdf (1 Pages)
XL3300 XL3300III XL4300 XL4300III XL5300III Electrical Schematic 80799002.pdf (7 Pages)
XL3300III XL4300III XL5300III XL3300 XL4300 Hydraulic Schematic 80799023.pdf (1 Pages)
XL3300 to XL5330V Railgear Electrical Schematic 80799030.pdf (9 Pages)
XL3300V XL3300 ALTERRAIN XL3300V to XL3310 XL4310 INDUSTRIAL XL5330V Railgear Hydraulic Schematic 80799031.pdf (1 Pages)
Brand: Gradall
List of Files:
ELECTRICAL
BB-3 Control Panel
HYDRAULIC
MECHANICAL
SCHEMATICS
Service Kits
Section 2 Boom
Section 6 Cab
Figure 6-3 Cab Door
Figure 6-6 Cab Seat
Section 7 Controls
Figure 7-1 Joystick
Section 11 Decals
Figure 11-1 Decals
Section 12 Options
Part Number Index
Introduction
General
Orientation
Nomenclature
Tools
Safety
Operator’s Cab
Seat Adjustment
Electronic Monitor
Engine Operation
Starting Engine
Auto Idle
Stopping Engine
Travel
Outriggers
Steering
Drive Train
Torque Chart
Emergency Towing
If You Get Stuck
ELECTRICAL
DRIVE AXLE
WHEEL & RIM
MISCELLANEOUS
Valve Cover
Left Front Door
Left Rear Door
Section 2 - Boom
66” Ditching Bucket
72” Ditching Bucket
Power Unit Assembly
Section 6 - Cab
Operators Cab Seat
Dump Circuit
Oscillation Circuit
Drive Motor
Main Hydraulic Pump
Center Pin Assembly
Center Pin
Section 11 - Decals
Blade Installation
Part Number Index
2.7 Cab Components
3.3 Brake System
3.4 Travel Modes
3.8 Engine Shutdown
5.1 Introduction
6.1 Loss Of Power
7.2 Torque Chart
7.3 Fuses
Index
Revision Log
Read This First
Table of Contents
Alphabetical Index
Hand Signals
Hydraulic Section
Electrical Section
Mechanical Section
Bolt Torque Chart
Valve Cover
Valve Cover (CE)
Section 2 - Boom
66” Ditching Bucket
72” Ditching Bucket
Section 6 - Cab
Operators Cab Seat
Dump Circuit
Oscillation Circuit
Drive Motor
Main Hydraulic Pump
Center Pin Assembly
Center Pin
Section 11 - Decals
Blade Installation
Part Number Index
2.5 Cab Components
3.3 Brake System
3.4 Travel Modes
3.8 Engine Shutdown
5.1 Introduction
6.1 Loss Of Power
7.2 Torque Chart
7.3 Fuses
Index
Revision Log
Read This First
Table of Contents
Index
ELECTRICAL
Slide 13
Slide 19
Slide 21
Slide 40
Slide 44
Slide 53
Slide 57
HYDRAULIC
DRIVE TRAIN
- Gradall Excavator XL2200 Operators Parts Service Manual
- Gradall Excavator XL2210 Operators Parts Service Manual
- Gradall Excavator XL2210SI Operators Service Manual
- Gradall Excavator XL2300 Operators Parts Service Manual
- Gradall Excavator XL3100 Operators Parts Service Manual
- Gradall Excavator XL3100EPA Technical Service Manual
- Gradall Excavator XL3100III Operators Parts Service Manual
- Gradall Excavator XL3100IV Operators Service Manual EN ES KO
- Gradall Excavator XL3100V Operators Parts Service Manual
- Gradall Excavator XL3200 Operators Parts Service Manual
- Gradall Excavator XL3200HP Operators Parts Service Manual
- Gradall Excavator XL3200III Operators Parts Service Manual
- Gradall Excavator XL3200LC Operators Parts Service Manual
- Gradall Excavator XL3200V Operators Parts Service Manual EN FR
- Gradall Excavator XL3210 Operators Parts Service Manual
