Gradall Excavator XL4310III Operators Parts Service Manual
Brand: Gradall
Type of Machine: Telescopic Hydraulic Excavator
Type of Manual: Electrical Schematic, Hydraulic Schematic, Illustrated Parts Manual, Parts Manual, Service Manual
Model: Gradall XL4310III Telescopic Hydraulic Excavator
List of Files:
XL3300III XL4300III XL5300III XL3310III XL4310III to XL5320III Illustrated Parts Manual 80644001 2026.pdf (760 Pages)
Section 1 - Frame & Attaching Parts
Frame & Cover Plate Installation
Tool Boxes & Steps Installation
Skid Plate Installation
Upperstructure Mirror Installation (old-style)
Upperstructure Mirror Installation (new-style)
Upperstructure Covers Installation
Covers Installation, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III (optional steel covers)
Valve Cover
Valve Cover, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III, (optional steel covers)
Left Front Door
Left Rear Door
Fuel Tank & Reservoir Installation
Fuel Tank & Reservoir Assembly, XL3300III, XL3320III, XL4300III, XL4320III & XL5300III
Fuel Tank & Reservoir Assembly, XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Swing Bearing Installation Components
Swing Lock Installation
Counterweight & Swing Light Installation, XL3300III, XL3310III & XL3320III
Counterweight & Swing Light Installation, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Counterweight Bumpers Installation, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Boom Installation Components
Cab Installation Components, XL3300III, XL4300III & XL5300III
Cab Installation Components, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Power Unit Installation
Center Pin Installation
Section 2 - Boom
Boom Cradle, XL3300III & XL4300III
Boom Cradle, XL5300III
Boom Cradle, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Main Boom Assembly, XL3300III & XL4300III
Main Boom Assembly, XL5300III
Main Boom Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Telescope Boom Assembly, XL3300III, XL4300III & XL5300III
Telescope Boom Assembly, XL3310III, XL3320III, XL4310III, XL4320III & XL5310III
Telescope Boom Assembly, XL5320III
Boom Roller Assemblies
Bucket Linkage, XL3300III, XL4300III & XL5300III
Bucket Linkage, XL3310III, XL3320III, XL4310III, XL4320III & XL5310III
Bucket Linkage, XL5320III
Section 3 - Attachments
24” & 30” Excavating Buckets
30” Excavating Bucket (Pin-On)
36” Excavating Buckets
42” Excavating Bucket
48” Excavating Bucket
15” Trenching Bucket
18” & 28” Pavement Removal Buckets
24” & 40” Pavement Removal Buckets
24” Ditching Bucket w/o Teeth & 48” Ditching Bucket
30” & 60” Ditching Buckets
60” Ditching Bucket w/Bolt-on Cutting Edge
66” Ditching Bucket
66” Ditching Bucket w/Bolt-on Cutting Edge
72” Ditching Bucket
72” Ditching Bucket (Pin-On)
72” & 108” Dredging Buckets
Alamo 48” Flail Mower Installation
Alamo 50” Rotary Mower Assembly
Alamo 60” Rotary Mower Assembly
4’, 6’, 8’ & 12’ Boom Extension
Auxiliary Hydraulics, 4’, 6’, 8’ & 12’ Boom Extension
Telestick Installation, XL4300III
Telestick Installation, XL5300III
Guardrail Back Scraper
2184MM & 2800MM Conveyor Buckets
8’ Grading Blade & Single Tooth Ripper
Tree Limb Shear Assembly
Fixed Thumb Grapple Assembly
Hydraulic Thumb Grapple Assembly
Single & Double Tooth Scaling Hooks (Pin-On)
Hammer (Rammer S27) w/Hammer Bracket Installation
Hammer (Rammer S29) w/Hammer Bracket Installation
Hammer (Rammer S27 & S29) Bracket Assemblies
Air Hammer (Kent 999) Installation, XL3310III, XL4310III & XL5310III
Section 4 - Engine & Attaching Parts
Power Unit Assembly
Muffler Support Components
Air Cleaner Installation
Air Cleaner Assembly
Cooling Unit Installation
Double Gear Pump Installation
Section 5 - Drive Train
Transmission, Drive Motor and Drive Shafts Installation
Axle Installation, XL3300III, XL3310III & XL3320III
Axle Installation, XL4300III & XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Tire & Wheel Assembly
Tire & Wheel Assembly (w/Rail Gear; optional)
Transmission - Input Housing
Transmission - Housing
Transmission - Disc Brake
Transmission - Coupling
Transmission - Planetary Drive
Transmission - Output
Transmission - Shift Sensor
Transmission - Oil Pipe
Front Steer Axle - Input, XL3300III, XL3310III & XL3320III
Front Steer Axle - Differential, XL3300III, XL3310III & XL3320III
Front Steer Axle - Axle Casing, XL3300III, XL3310III & XL3320III
Front Steer Axle - Joint Housing, XL3300III, XL3310III & XL3320III
Front Steer Axle - Steering Cylinder, XL3300III, XL3310III & XL3320III
Front Steer Axle - Output, XL3300III, XL3310III & XL3320III
Front Steer Axle - Input, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Differential, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Axle Casing, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Joint Housing, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Steering Cylinder, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Front Steer Axle - Output, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Input, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Differential, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Axle Casing, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Hub Carrier, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Output, XL3300III, XL3310III & XL3320III
Rear Drive Axle - Input, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Differential, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Axle Casing, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Hub Carrier, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Rear Drive Axle - Output, XL4300III, XL4310III, XL4320III, XL5300III, XL5310III & XL5320III
Section 6 - Cab
Operators Cab Assembly, XL3300III, XL4300III & XL5300III
Operators Cab Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Operators Cab, XL3300III, XL4300III & XL5300III
Operators Cab, XL3310III, XL3320III, XL4310III & XL5310III
Operators Cab (SI Mine Cab), XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Operators Cab Door, XL3300III, XL4300III & XL5300III
Operators Cab Door, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Operators Cab Console
Pod Panel Assemblies
Operators Cab Seat Assembly
Operators Cab Seat
Pilot Cut-off Assembly
Evaporator & Heater Assembly
Air Conditioning Installation
Cab Guard Frame Installation, XL3310III, XL4310III & XL5310III
Cab Guard Frame Installation (SI Mine Cab), XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Cab Heat Shield Installation, XL3310III, XL4310III & XL5310III
Cab Heat Shield Installation (SI Mine Cab), XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Cab Guard Installation, XL3310III, XL4310III & XL5310III
Cab Guard Installation (SI Mine Cab), XL3310III, XL4310III, XL4320III, XL5310III & XL5320III
Section 7 - Controls
Foot Pedal Plate Assembly
Section 8 - Hydraulic Circuits
Hydraulic Pressure to Control Valves
Main Valve to Pilot Manifold, XL3300III, XL4300III & XL5300III
Main Valve to Pilot Manifold, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Dump Circuit
Hoist Cylinder Hydraulic Circuit
Hoist Tubes Replacement Kit
Boom Cylinder Hydraulic Circuit, XL3300III, XL4300III & XL5300III
Boom Cylinder Hydraulic Circuit, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tool Cylinder Hydraulic Circuit, XL3300III, XL4300III & XL5300III
Tool Cylinder Hydraulic Circuit, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tilt Motor Hydraulic Circuit, XL3300III, XL4300III & XL5300III
Tilt Motor Hydraulic Circuit, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Swing Motor Hydraulic Circuit
Swing Tubes Replacement Kit
Upper Propelling Hydraulic Circuit
Chassis Supply Hydraulic Circuit
Steering Control and Brake Pedal Valve Hydraulic Circuit
Oscillation Circuit
Outrigger & Blade Circuit
Steering & Brake Circuit
Drive Motor & Transmission Circuit
Section 9 - Hydraulic Components
Hoist Cylinder Assembly, XL3300III, XL3310III & XL3320III
Hoist Cylinder Assembly, XL4300III, XL4310III, XL4320III & XL5320III
Hoist Cylinder Assembly, XL5300III & XL5310III
Boom Cylinder Assembly, XL3300III, XL3310III & XL3320III
Boom Cylinder Assembly, XL4300III, XL4310III & XL4320III
Boom Cylinder Assembly, XL5300III, XL5310III & XL5320III
Tool Cylinder Assembly, XL3300III
Tool Cylinder Assembly, XL4300III, XL5300III & XL5320III
Tool Cylinder Assembly, XL3310III, XL3320III, XL4310III, XL4320III & XL5310III
Axle Oscillation Cylinder Assembly
Drive Motor
Main Hydraulic Pump
Main Hydraulic Control Valve Assembly
Main Hydraulic Control Valve - End Caps
Main Hydraulic Control Valve - Valve Section, Swing
Main Hydraulic Control Valve - Valve Section, Chassis Supply & Auxiliary
Pilot Manifold Valve Tray Components, XL3300III, XL4300III & XL5300III
Pilot Manifold Valve Tray Components, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Pilot Manifold Assembly
Swing Transmission Assembly
Swing Motor Assembly
Swing Drive Assembly
Swing Brake Assembly
Tilt Transmission Assembly, XL3300III, XL4300III & XL5300III
Tilt Transmission Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tilt Drive Assembly, XL3300III, XL4300III & XL5300III
Tilt Transmission, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tilt Motor Assembly, XL3300III, XL4300III & XL5300III
Tilt Motor Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Tilt Brake Assembly, XL3300III, XL4300III & XL5300III
Tilt Brake Assembly, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Center Pin Assembly
Center Pin
Steering Control Unit
Transmission Control Valve Assembly
Rear Outrigger Valve Assembly
Front Outrigger Valve Assembly
Outrigger Selector Valve
Oscillation Lock Valve Assembly
Section 10 - Electrical
Electrical Components
Service Panel Assembly
Cab Console Circuit Board
Undercarriage Harness Installation
Work Lights Installation
Section 11 - Decals
Decals Installation, XL3300III, XL4300III & XL5300III
Decals Installation, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
Section 12 - Options
Air Block Installation
Air Hammer (Kent 999) Supply Plumbing Installation, XL3310III, XL4310III & XL5310III
Air Hammer (Kent 999) Air Line Oiler Installation, XL3210III, XL4210III & XL5210III
Auxiliary Cab Fan Installation
Auxiliary Hydraulic Plumbing Installation, XL3300III, XL4300III & XL5300III
Auxiliary Hydraulic Plumbing Installation, XL3310III, XL4310III & XL5310III
Auxiliary Hydraulic Quick Disconnects Installation
Blade Installation
Blade Installation, (less cylinders)
Block Heater Installation
Bolt-On Lifting Yoke Installation, XL3310III, XL4310III & XL5310III
Bolt-On Folding Lifting Yoke Installation, XL3310III, XL4310III & XL5310III
Boom Top Guard Installation, XL3310III, XL4310III & XL5310III
Cab Air Filter Installation, XL3310III, XL4310III & XL5310III
Camera Kit Installation
Engine Shutdown Installation
Escape Hammer Installation
Fire Extinguisher Installation
Fire Extinguisher (in cab) Installation
Fire Extinguisher Installation, XL3310III, XL4310III & XL5310III
Fire Supression System Installation
First Aid Kit Installation
Frame Head Lights Installation, XL3310III, XL4310III & XL5310III
Front Window Guard Installation, XL3300III, XL4300III & XL5300III
Grid Heater Installation
“Headlights On” Relay Installation
Hoist Lock Installation, XL3300III & XL3310III
Hoist Lock Installation, XL4300III, XL4310III, XL5300III & XL5310III
Hydraulic Fluid Installation, Quintolubric 888-68
Hydraulic Fluid Installation, Ecosafe FR-68
Hydraulic Supressor Installation
Low Pressure Aux Return Installation
Outrigger Installation
Radio Power Supply Installation
Rail Gear Units - Brake Tee Installation
Rail Gear Units - Front & Rear Cylinders Installation
Search Light Installation
Seat Belt Installations
Seat Belt Installation, 3-Point
Speaker Installation
Strobe Light Installation, XL3300III, XL4300III & XL5300III
Strobe Light w/Branch Guard Installation, XL3300III, XL4300III & XL5300III
Strobe Light (Super-LED) Installation, XL3300III, XL4300III & XL5300III
Strobe Light (roof guard mount) Installation, XL3310III, XL4310III & XL5310III
Sun Visor Installation
Swing Motor Port Jumper Circuit Installation
Tire Shield Installation
Tool Open Lock Installations
Two-Point Lift Ring Installation
Vandal Covers Installation, XL3300III, XL4300III & XL5300III
Windshield Wiper Installation
Work Light (HID) Installation
Work Light Installation, XL3310III, XL4310III & XL5310III
Recommended Spare Parts
Part Number Index
XL3300III XL4300III XL5300III XL3310III to XL4320III XL5320III Operators Safety Manual 80644002 2024.pdf (122 Pages)
Section 1 - General Safety Practices
1.1 Hazard Classification System
1.2 General Precautions
1.3 Operation Safety
1.4 Personal Protection Equipment
Section 2 - Pre-Operation and Controls
2.1 Pre-Operation Checks & Inspection
2.2 Walk-Around Inspection
2.3 Safety Decals - XL3300III, XL4300III & XL5300III
2.4 Safety Decals - XL3300III, XL4300III & XL5300III (CE)
2.5 Safety Decals - XL3310III, XL4310III, XL5310III, XL3320III, 4320III & XL5320III
2.6 Safety Decals - XL3310III, XL4310III, XL5310III XL3320III, XL4320III & XL5320III (CE)
2.7 Cab Components
2.8 Cab Controls & Indicators
Section 3 - Operation
3.1 Engine Operation
3.2 Checks Before Operation
3.3 Brake System
3.4 Travel Modes
3.5 Typical Dig Cycle
3.6 Lifting & Placing a Load - XL3300III, XL4300III & XL5300III
3.7 Lift Capacity - XL3300III, XL4300III & XL5300III
3.8 Engine Shutdown
3.9 Parking the Excavator
3.10 Preservation & Storage
3.11 Rail Gear Operation (Optional)
Section 4 - Attachments
4.1 Approved Attachments
4.2 Unapproved Attachments
4.3 Attachment Operation
4.4 Adapter Attachment Installation
Section 5 - Lubrication & Maintenance
5.1 Introduction
5.2 General Maintenance Instructions
5.3 Service & Maintenance Schedules
5.4 Lubrication Schedules
Section 6 - Emergency Procedures
6.1 Loss Of Power
6.2 If You Get Stuck
6.3 Towing the machine
Section 7 - Specifications
7.1 Product Specifications
7.2 Torque Chart
7.3 Fuses
Pre-Operation Inspection Checklist
Index
XL3300III XL4300III XL5300III XL3310III XL4310III to XL4320III XL5320III Service Manual 80644003 2024.pdf (441 Pages)
Section 2 - Pre-Operation & Controls
Pre-Op Inspection Checklist
Alphabetical Index
Hand Signals
Hydraulic Section
Gradall Series III System Operation
Crawler & Rough Terrain Hydraulic Pressure Adjustment Procedures
80799009 Final Test Report
Product Support - Fire Resistent Hydraulic Fluids
Product Support - Series III Boom Circuit Speed
80799001 (C) Hydraulic Schematic, XL3300III, XL4300III, XL5300III (equipped with center pin 80333102 or 80733031 only)
80799023 (-) Hydraulic Schematic, XL3300III, XL4300III, XL5300III (equipped with center pin 80733056 only)
80799012 (B) Hydraulic Schematic, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III, XL5320III (equipped with center pin 80333102 or 80733031 only)
80799024 (-) Hydraulic Schematic, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III, XL5320III (equipped with center pin 80733056 only)
80609016 Torque Chart
Electrical Section
Gradall Bodas-Service Installation & Operation
Gradall Series III RT & Crawler Electrical Manual
80799002 (F) Electrical Schematic, XL3300III, XL4300III & XL5300III
80799011 (C) Electrical Schematic, XL3310III, XL3320III, XL4310III, XL4320III, XL5310III & XL5320III
80763011 (I) Upper Harness
Mechanical Section
Gradall Crawler & Rough Terrain Series III Mechanical Adjustments
Product Support - Engine Oil Pan Drain Plugs
Product Support - Swing Transmission Lube Check and Refill
Product Support - Fan Clutch Maintenance
Product Support - Drive Belt Routing
Bolt Torque Chart
Climate Control Section
Climate Control Systems - Series III Crawler & Wheeled Models
Product Support - AC System Receiver ADryers
Product Support - R134a AC Systems & Compressed Air
Product Support - AC System Moisture Contamination
XL3300 XL4300 XL5300 to XL5310 XL4320 Series III V Rough Terrain Chassis Lube Chart 80644009.pdf (1 Pages)
XL3310 XL3310III XL4310 XL4310III XL5310 XL5310III Electrical Schematic 80799011.pdf (7 Pages)
XL3310 XL4310 XL5300 XL3310III XL4310III XL5310III Hydraulic Schematic 80799024.pdf (1 Pages)
Brand: Gradall
List of Files:
Valve Cover
Left Front Door
Left Rear Door
Section 2 - Boom
66” Ditching Bucket
72” Ditching Bucket
Power Unit Assembly
Section 6 - Cab
Operators Cab Seat
Dump Circuit
Oscillation Circuit
Drive Motor
Main Hydraulic Pump
Center Pin Assembly
Center Pin
Section 11 - Decals
Blade Installation
Part Number Index
2.7 Cab Components
3.3 Brake System
3.4 Travel Modes
3.8 Engine Shutdown
5.1 Introduction
6.1 Loss Of Power
7.2 Torque Chart
7.3 Fuses
Index
Alphabetical Index
Hand Signals
Hydraulic Section
Electrical Section
Mechanical Section
Bolt Torque Chart
- Gradall Excavator XL2200 Operators Parts Service Manual
- Gradall Excavator XL2210 Operators Parts Service Manual
- Gradall Excavator XL2210SI Operators Service Manual
- Gradall Excavator XL2300 Operators Parts Service Manual
- Gradall Excavator XL3100 Operators Parts Service Manual
- Gradall Excavator XL3100EPA Technical Service Manual
- Gradall Excavator XL3100III Operators Parts Service Manual
- Gradall Excavator XL3100IV Operators Service Manual EN ES KO
- Gradall Excavator XL3100V Operators Parts Service Manual
- Gradall Excavator XL3200 Operators Parts Service Manual
- Gradall Excavator XL3200HP Operators Parts Service Manual
- Gradall Excavator XL3200III Operators Parts Service Manual
- Gradall Excavator XL3200LC Operators Parts Service Manual
- Gradall Excavator XL3200V Operators Parts Service Manual EN FR
- Gradall Excavator XL3210 Operators Parts Service Manual
