Momed80
150
35,046
Gradall Excavator XL4240V Operators Parts Service Manual
Brand: Gradall
Type of Machine: Telescopic Hydraulic Excavator
Type of Manual: Electrical Schematic, Hydraulic Schematic, Illustrated Parts Manual, Operator Manual, Safety Manual, Parts Manual, Service Supplement
Model: Gradall XL4240V Telescopic Hydraulic Excavator
List of Files:
XL4240V Skimmer Boom Illustrated Parts Manual 42404001 2025.pdf (280 Pages)
Section 1 - Frame & Attaching Parts
Frame Assembly
Upperstructure Mirror Installation
Upperstructure Covers Installation
Valve Cover
Fuel Tank & Reservoir Installation
Fuel Tank & Reservoir Assembly (Steel Fuel Tank)
Reservoir Breather Installation
Swing Bearing Installation Components
Counterweight & Swing Light Installation
Cab Installation Components
Section 2 - Boom
Boom Installation
First Boom Assembly
Second Boom Assembly
Third Boom Assembly
Skimmer Guards Installation
Winch & Cables Components Installation
Hydraulic Cable Winch Assembly
Section 3 - Attachments
Skimmer Tool Installation
Skimmer Tool Adapter Assembly
Section 4 - Engine & Attaching Parts
Power Unit Assembly
Exhaust System Installation
Air Cleaner Installation
Air Cleaner Assembly
Cooling Unit Installation
DEF Tank Installation
Gear Pump Installation
Section 5 - Drive Train
Track Chain & Shoes Assembly
Track Roller
Carrier Roller
Front Idler Track Adjuster
Crawler Drive Motor Assembly - Control
Crawler Drive Motor Assembly - Hydraulic Motor
Crawler Drive Motor Assembly - Gearbox
Section 6 - Cab
Operators Cab Assembly
Operators Cab
Operators Cab Door
Operators Cab Console
Pod Panel Assemblies
Operators Cab Seat Assembly
Operators Cab Seat
Pilot Cut-off Assembly
Evaporator & Heater Assembly (Pro-Air Units)
Evaporator & Heater Assembly (Victory Units)
Air Conditioning Installation
Section 7 - Controls
Foot Pedal Plate Assembly
Section 8 - Hydraulic Circuits
Oil Supply to Main Pump & Control Valve
Hoist Cylinder (Front of Boom) Hydraulic Circuit
Hoist Cylinder (Rear of Boom) Hydraulic Circuit
Main Valve to Cable Winch Circuit
Cable Tensioner Circuit
Main Valve to Pilot Manifold
Main Valve to Tilt Control Valve
Dump Circuit
Swing Motor Hydraulic Circuit
Upper Propelling Hydraulic Circuit
Crawler Drive Main Hydraulic Circuit
Crawler Drive Forward/Reverse Hydraulic Circuit
Section 9 - Hydraulic Components
Hoist Cylinder Assembly (Front of Boom)
Hoist Cylinder Assembly, (Rear of Boom)
Main Hydraulic Pump
Main Hydraulic Control Valve Assembly
Main Hydraulic Control Valve - End Caps
Main Hydraulic Control Valve - Valve Section, Swing
Main Hydraulic Control Valve - Valve Section, Tilt & Auxiliary
Pilot Manifold Valve Tray Hydraulic Components
Pilot Manifold Assembly
Swing Transmission Assembly
Swing Motor Assembly
Swing Drive Assembly
Swing Brake Assembly
Center Pin Assembly
Section 10 - Electrical
Electrical Components
Electrical Components (Skimmer Boom)
Service Panel Assembly
Cab Console Circuit Board
Work Lights Installation
Main Control Valve Jumper Harnesses
Section 11 - Decals
Decals Installation
Section 12 - Options
Cab Air Filter Installation
Cab Guard Installation (non - ROPS Certified)
Cab Roof Guard Installation (bars)
Camera Kit Installation
Dual Beacon (LED) Installation
Emergency Hydraulics Installation
Engine Block Heater Installation (110v)
Front Cab Guard (bottom) Installation (solid)
Front Window (Heat Resistant) Installation
Hydraulic Fluid Installation, Cosmolubric HF-122
Hydraulic Fluid Installation, Quintolubric 888-68
Power Supply (12-volt) Installation
Recommended Spare Parts
Part Number Index
XL4240V Skimmer Boom Operator Safety Manual 42404002 2021.pdf (90 Pages)
Section 1 - General Safety Practices
1.1 Hazard Classification System
1.2 General Precautions
1.3 Operation Safety
1.4 Personal Protection Equipment
Section 2 - Pre-Operation and Controls
2.1 Pre-Operation Checks & Inspection
2.2 Walk-Around Inspection
2.3 Safety Decals
2.4 Cab Components
2.5 Cab Controls & Indicators
Section 3 - Operation
3.1 Engine Operation
3.2 Checks Before Operation
3.3 Crawler Chassis
3.4 Engine Shutdown
3.5 Parking the Excavator
3.6 Preservation & Storage
Section 4 - Lubrication & Maintenance
4.1 Introduction
4.2 General Maintenance Instructions
4.3 Service & Maintenance Schedules
4.4 Lubrication Schedules
Section 5 - Specifications
5.1 Product Specifications
5.2 Torque Chart
5.3 Fuses
Section 6 - Emergency Procedures
6.1 Loss Of Power
6.2 Emergency Hydraulics (optional)
Index
XL4240V Skimmer Boom Service Supplement 42404003 2022.pdf (247 Pages)
42404003_D_XL4240V Skimmer Boom_Service Supplement_4-2022
OPERATOR INSTRUCTIONS
42404002_B_XL4240V Skimmer Boom_Op & Safety Manual_4-2021
ELECTRICAL
BODAS System Training
80719020_E_Electrical Schematic
80763138_A_Console Circuit Board
80763158_H_Upper Harness
80763156_B_Cab Harness
80723076_A_Skimmer Boom Cushion Harness (S/N 4240000001)
80723079_Skimmer Boom Cushion Harness (S/N 4240000002 & After)
HYDRAULIC
80719022_Hydraulic Schematic
CRAWLER
XL-Series Crawler Maintenance Manual
WINCH
Winch Service Manual
XL3200V XL3200 XL3200 to XL5210 XL5210V XL5210 XL5210V Electrical Schematic 80719020.pdf (8 Pages)
XL3200V XL3200V XL3200V to XL5210V XL5210V XL5210V Hydraulic Schematic 80719022.pdf (1 Pages)
