Momed80
150
35,046
Gradall Excavator XL3220III Operators Parts Service Manual
Brand: Gradall
Type of Machine: Mine Scaler Excavator
Type of Manual: Illustrated Parts Manual, Operator Manual, Safety Manual, Parts Manual, Service Literature, Service Manual, Hydraulic Schematic, Electrical Schematic
Model: Gradall XL3220III Mine Scaler Excavator
List of Files:
XL3200III XL4200III XL5200III XL3210III XL4210III to XL3220III Illustrated Parts Manual 80744001 2026.pdf (656 Pages)
Section 1 - Frame & Attaching Parts
Section 2 - Boom
Section 3 - Attachments
Section 4 - Engine & Attaching Parts
Section 5 - Drive Train
Section 6 - Cab
Section 7 - Controls
Section 8 - Hydraulic Circuits
Section 9 - Hydraulic Components
Section 10 - Electrical
Section 11 - Decals
Section 12 - Options
Recommended Spare Parts
Part Number Index
XL3200III XL4200III XL5200III XL3210III XL5210III to XL3220III Operator Safety Manual 80744002 2024.pdf (116 Pages)
Section 1 - General Safety Practices
1.1 Hazard Classification System
1.2 General Precautions
1.3 Operation Safety
1.4 Personal Protection Equipment
Section 2 - Pre-Operation and Controls
2.1 Pre-Operation Checks & Inspection
2.2 Walk-Around Inspection
2.3 Safety Decals - XL3200III, XL4200III & XL5200III
2.4 Safety Decals - XL3200III, XL4200III & XL5200III (CE)
2.5 Safety Decals - XL3210III, XL4210III & XL5210III
2.6 Safety Decals - XL3210III, XL4210III & XL5210III (CE)
2.7 Cab Components
2.8 Cab Controls & Indicators
Section 3 - Operation
3.1 Engine Operation
3.2 Checks Before Operation
3.3 Crawler Chassis
3.4 Typical Dig Cycle
3.5 Lifting & Placing a Load - XL3200III, XL4200III & XL5200III
3.6 Lift Capacity - XL3200III, XL4200III & XL5200III
3.7 Engine Shutdown
3.8 Parking the Excavator
3.9 Preservation & Storage
Section 4 - Attachments
4.1 Approved Attachments
4.2 Unapproved Attachments
4.3 Attachment Operation
4.4 Adapter Attachment Installation
Section 5 - Lubrication & Maintenance
5.1 Introduction
5.2 General Maintenance Instructions
5.3 Service & Maintenance Schedules
5.4 Lubrication Schedules
Section 6 - Emergency Procedures
6.1 Loss Of Power
6.2 If You Get Stuck
Section 7 - Specifications
7.1 Product Specifications
7.2 Torque Chart
7.3 Fuses
Pre-Operation Inspection Checklist
Index
XL3200III XL4200III XL5200III XL3210III XL4210III XL5210III XL3220III Service Manual 80744003 2024.pdf (469 Pages)
Operator & Safety Manual
Revision Log
Read This First
Section 2 - Pre-Operation Checks & Controls
Pre-Op Inspection Checklist
Alphabetical Index
Hydraulic Section
Gradall Series III Systems Operation
Crawler/Rough Terrain Hydraulic Pressure Adjustment Procedures
80719004 Final Test Report
Product Support - Fire Resistant Hydraulic Fluids
Product Support - Series III Boom Circuit Speed
80719001 (C) XL3200III, XL4200III & XL5200III Hydraulic Schematic
80719007 (B) XL3210III, XL4210III & XL5210III Hydraulic Schematic
80609016 Torque Chart
Electrical Section
Gradall Bodas-Service Installation & Operation
Gradall Series III RT & Crawler Electrical Manual
80719002 (G) XL3200III, XL4200III & XL5200III Electrical Schematic
80719006 (E) XL3210III, XL4210III & XL5210III Electrical Schematic
80763021 (I) Upper Harness
Mechanical Section
Gradall Crawler Series III Mechanical Adjustments
XL Series Crawler Maintenance Manual
Product Support - Engine Oil Pan Drain Plugs
Product Support - Swing Transmission Lube Check and Refill
Product Support - Fan Clutch Maintenance
Product Support - Drive Belt Routing
Bolt Torque Chart
Climate Control Section
Climate Control Systems - Series III Crawler & Rough Terrain Models
Product Support - AC System Receiver Dryers
Product Support - R134a AC Systems & Compressed Air
Product Support - AC System Moisture Contamination
SIII Crawler Mount Vendor XL3200 XL3200III to XL4210 XL5200 XL5200III XL5210 Service Literature 2010.pdf (188 Pages)
Crawler Undercarriage Maintenance Manual
Pressure Denotation
Introduction
Nomenclature
Track Adjustment
Travel Speed
Track Chain
Track Rollers
Idler Roller w/Track Tension & Adjuster
Drive Sprocket
Miscellaneous
Main Hydraulic Pump Repair Manual
Tilt Motor Service Procedure (XL3200III, XL4200III & XL5200III)
Tilt Brake Installation & Maintenance (XL3200III, XL4200III & XL5200III)
Tilt Brake Service Notes (XL3210III, XL4210III & XL5210III)
Swing Transmission Assembly-Disassembly Manual
Swing/Tilt Motor Repair Manual
Gear Pump Change of Rotation & Seal Replacement
Crawler Drive Service Manual
Air Cleaner Service Instructions
