Gleaner Combines Rotary T81 TRANSVERSE COMBINE (2025-9999) Part Book
- Download this document, you need 8625 Gallons
Brand: Gleaner
Type of Machine: Combines Rotary
Type of Manual: Part Book
Model: Gleaner T81 TRANSVERSE COMBINE (2025-9999) Combines Rotary
Publication Date: 2025
Number of Pages: 699 Pages
TABLE OF CONTENT PAG 00-TOC Tech Spec Notes Ref
GENERAL INFORMATION PAG 01-000-TOC Tech Spec Notes Ref
FILTERS GUIDE PAG 01-0001
BELTS GUIDE PAG 01-0002
CHAINS GUIDE PAG 01-0003
SENSORS GUIDE PAG 01-0004
ENGINE ACX4464240 98 AWF-HLA PAG 02-000-TOC Tech Spec Notes Ref
ENGINE ASSEMBLIES PAG 02-0001
CYLINDER BLOCK - HYDRAULIC LASH ADJUSTMENT PAG 02-0002
TIMING GEARS & HOUSING PAG 02-0003
FLYWHEEL & HOUSING PAG 02-0004
CRANKSHAFT & PISTONS PAG 02-0005
CAMSHAFT & VALVE MECHANISM - HYDRAULIC LASH ADJUSTMENT PAG 02-0006
CYLINDER HEAD PAG 02-0007
VALVE ROCKER COVER PAG 02-0008
INTAKE MANIFOLD PAG 02-0009
EXHAUST MANIFOLD - M12 TURBO MOUNTING STUD BOLTS PAG 02-0010
HIGH PRESSURE TURBOCHARGER - M12 TURBO MOUNTING STUD BOLTS PAG 02-0011
LOW PRESSURE TURBOCHARGER & ICAC - M12 TURBO MOUNTING STUD BOLTS PAG 02-0012
EXHAUST GAS RECIRCULATION (EGR) PAG 02-0013
OIL PUMP & SUMP PAG 02-0014
OIL COOLER & OIL FILTER PAG 02-0015
CLOSED CRANKCASE VENTILATION (CCV) PAG 02-0016
COOLANT PIPING PAG 02-0017
COOLANT PUMP & THERMOSTAT PAG 02-0018
FUEL INJECTION SYSTEM PAG 02-0019
FUEL FILTERS PAG 02-0020
ELECTRONIC ENGINE MANAGEMENT PAG 02-0021
STARTER MOTOR PAG 02-0022
FAN DRIVE PAG 02-0023
EXHAUST AFTER-TREATMENT PAG 02-0024
SPECIAL OVERHAUL PARTS PAG 02-0026
ENGINE INSTALLATION PAG 03-000-TOC Tech Spec Notes Ref
ENGINE BRACKET PAG 03-0001
COOLING - FAN PAG 03-0002
COOLING - FAN (COMPONENTS) PAG 03-0003
COOLING - RADIATOR & FAN SHROUD PAG 03-0004
COOLING - AIR DEFLECTOR PAG 03-0005
COOLING - EXPANSION TANK & HOSES PAG 03-0006
COOLING - EXPANSION TANK & HOSES PAG 03-0007
COOLING - ROTARY SCREEN PAG 03-0008
COOLING - ROTARY SCREEN PAG 03-0009
ENGINE AIR FILTER & DUST ASPIRATOR PAG 03-0010
EXHAUST PAG 03-0011
EXHAUST PAG 03-0012
EXHAUST - LESS REGULATED COUNTRIES PAG 03-0013
EXHAUST - DEF TANK & LINES PAG 03-0014
EXHAUST - DEF TANK (COMPONENTS) PAG 03-0015
EXHAUST - SHIELDS PAG 03-0016
FUEL - TANK PAG 03-0017
DRIVE SYSTEM PAG 04-000-TOC Tech Spec Notes Ref
HYDROSTATIC PUMP & POWER TAKE-OFF - DRIVE PAG 04-0001
FEEDER CONVEYOR - BELT TENSIONER PAG 04-0002
FIXED SPEED HEADER DRIVE PAG 04-0003
FIXED SPEED HEADER DRIVE PAG 04-0004
FIXED SPEED HEADER DRIVE PAG 04-0005
VARIABLE SPEED HEADER DRIVE PAG 04-0006
VARIABLE SPEED HEADER DRIVE PAG 04-0007
VARIABLE SPEED HEADER DRIVE PAG 04-0008
ROTOR - DRIVE PAG 04-0009
ROTOR - GEARBOX (COMPONENTS) PAG 04-0010
ROTOR - DRIVE PAG 04-0011
ELEVATOR - DRIVE PAG 04-0012
ELEVATOR - DRIVE PAG 04-0013
REAR FEED SHAFT - DRIVE PAG 04-0014
PIVOT JACKSHAFT - DRIVE PAG 04-0015
MAIN - DRIVE PAG 04-0016
SHAKER SHOE - DRIVE PAG 04-0017
CLUTCH SHAFT - DRIVE PAG 04-0019
CLEANING SHOE - DRIVE PAG 04-0020
GRAIN BIN UNLOADING - DRIVE PAG 04-0021
GRAIN BIN UNLOADING - DRIVE PAG 04-0022
GRAIN BIN UNLOADING - DRIVE PAG 04-0023
GRAIN BIN UNLOADING - DRIVE PAG 04-0024
GRAIN BIN UNLOADING - DRIVE PAG 04-0025
IMPELLER - DRIVE PAG 04-0026
STRAW CHOPPER - DRIVE PAG 04-0027
AXLES PAG 05-000-TOC Tech Spec Notes Ref
FRONT AXLE PAG 05-0001
REAR AXLE - 2 WHEEL DRIVE PAG 05-0002
REAR AXLE - 2 WHEEL DRIVE - SPINDLE PAG 05-0003
REAR AXLE - LUBRICATION PAG 05-0004
REAR AXLE - 4 WHEEL DRIVE PAG 05-0005
REAR AXLE - LUBRICATION PAG 05-0006
REAR AXLE - 4 WHEEL DRIVE - CURTAIN PAG 05-0007
STABILIZER PADS PAG 05-0008
STEERING SYSTEM PAG 06-000-TOC Tech Spec Notes Ref
STEERING WHEEL & COLUMN PAG 06-0001
STEERING LINES PAG 06-0002
STEERING CYLINDER (COMPONENTS) PAG 06-0003
STEERING CYLINDER (COMPONENTS) PAG 06-0004
STEERING - ELECTRONIC PAG 06-0005
STEERING - ELECTRONIC PAG 06-0006
DRIVETRAIN SYSTEM PAG 07-000-TOC Tech Spec Notes Ref
TRANSMISSION PAG 07-0001
GEARBOX - HOUSING PAG 07-0002
GEARBOX - MAIN SHAFT PAG 07-0003
GEARBOX - INTERMEDIATE SHAFT PAG 07-0004
GEARBOX - BEVEL PINION SHAFT PAG 07-0005
GEARBOX - DIFFERENTIAL PAG 07-0006
GEARBOX - PIPING PAG 07-0007
GEARBOX - VALVE PAG 07-0008
GEARBOX - OIL FILLER & MEASUREMENT PAG 07-0009
GEARBOX - OIL COOLER PAG 07-0010
GEARBOX - HYDRAULIC PUMP PAG 07-0011
GEARBOX - SUCTION LINE PAG 07-0012
BRAKE SYSTEM PAG 08-000-TOC Tech Spec Notes Ref
BRAKE PEDALS PAG 08-0001
BRAKE LINES PAG 08-0002
DISC BRAKES PAG 08-0003
DISC BRAKES PAG 08-0004
PARKING BRAKE PAG 08-0005
HYDRAULIC SYSTEM PAG 09-000-TOC Tech Spec Notes Ref
HYDRAULIC TANK PAG 09-0001
HYDRAULIC TANK (COMPONENTS) PAG 09-0002
HYDRAULIC PUMP PAG 09-0003
HYDRAULIC PROPEL PAG 09-0004
HYDRAULIC PROPEL - HYDRAULIC LINES PAG 09-0005
HYDRAULIC PROPEL - HYDRAULIC LINES PAG 09-0006
HYDRAULIC PROPEL - HYDRAULIC HOSE CLAMPS PAG 09-0007
HYDRAULIC LINES - RIGHT SIDE & REAR PAG 09-0008
HYDRAULIC LINES - RIGHT SIDE PAG 09-0009
HYDRAULIC VALVE - MAIN PAG 09-0010
HYDRAULIC VALVE (COMPONENTS) PAG 09-0011
CUTTING HEADER - LIFTING PAG 09-0012
CUTTING HEADER - LIFTING - ACCUMULATOR PAG 09-0013
CUTTING HEADER - TILT PAG 09-0014
CUTTING HEADER - TILT - HYDRAULIC CYLINDER (COMPONENTS) PAG 09-0015
CUTTING HEADER - TILT - RELIEF VALVE PAG 09-0016
CUTTING HEADER - TILT PAG 09-0017
CUTTING HEADER - TILT - HYDRAULIC VALVE (COMPONENTS) PAG 09-0018
CUTTING HEADER - QUICK HYDRAULIC COUPLERS (MULTI-FASTER) PAG 09-0019
CUTTING HEADER - QUICK HYDRAULIC COUPLERS (MULTI-FASTER) PAG 09-0020
CUTTING HEADER - VARIABLE SPEED PAG 09-0021
FEEDER REVERSER PAG 09-0022
FEEDER REVERSER PAG 09-0023
FEEDER REVERSER PAG 09-0024
GRAIN BIN UNLOADING PAG 09-0025
CHAFF SPREADER PAG 09-0026
STRAW SPREADER PAG 09-0027
ELECTRICAL SYSTEM PAG 10-000-TOC Tech Spec Notes Ref
LIGHTING - ROAD LIGHTS PAG 10-0001
LIGHTING PAG 10-0002
LIGHTING - INTERIOR LIGHT PAG 10-0003
WORK LIGHTS - ROOF PAG 10-0004
WORK LIGHTS - DUAL BEAM PAG 10-0005
BATTERY & CABLES PAG 10-0006
BATTERY & CABLES PAG 10-0007
BATTERY & CABLES PAG 10-0008
WIRING HARNESS - ENGINE PAG 10-0009
WIRING HARNESS - TRANSMISSION PAG 10-0010
WIRING HARNESS - MAIN FRAME PAG 10-0011
WIRING HARNESS - MAIN FRAME PAG 10-0012
WIRING HARNESS - CAB PAG 10-0013
WIRING HARNESS - CAB PAG 10-0014
WIRING HARNESS - FEEDER CONVEYOR PAG 10-0015
WIRING HARNESS - THRESHING PAG 10-0016
WIRING HARNESS - GRAIN BIN PAG 10-0017
WIRING HARNESS - GRAIN BIN UNLOADING PAG 10-0018
ELECTRIC ADJUSTABLE SIEVES PAG 10-0019
ELECTRIC ADJUSTABLE SIEVES PAG 10-0020
FUSES & RELAYS PAG 10-0021
ELECTRONIC BOX & CONTROL MODULE PAG 10-0022
SENSOR - FEEDER CONVEYOR PAG 10-0023
SENSOR - FEEDER CONVEYOR PAG 10-0024
SENSORS - HYDRAULIC TANK & EXHAUST PAG 10-0025
SENSORS - DISCHARGE PAG 10-0026
SWITCH - HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) PAG 10-0027
MONITORING DISPLAY - NT01 PAG 10-0028
MONITORING DISPLAY - NT01 PAG 10-0029
MONITORING DISPLAY - NT01 PAG 10-0030
ARMREST PAG 10-0031
ARMREST PAG 10-0032
QUAD CAMERA DISPLAY MONITOR PAG 10-0033
QUAD CAMERA DISPLAY MONITOR PAG 10-0034
CAB PAG 11-000-TOC Tech Spec Notes Ref
CAB SUPPORT PAG 11-0001
CAB FRAME PAG 11-0002
CAB GLASS PAG 11-0003
ROOF - OUTER PAG 11-0004
ROOF - VISION CAB PAG 11-0005
WASHER & WIPER - WINDSHIELD PAG 11-0006
WASHER & WIPER - WINDSHIELD WASHER BOTTLE PAG 11-0007
TRIM - DOOR PAG 11-0008
TRIM - CAB PAG 11-0009
STORAGE BOX PAG 11-0010
COOL BOX PAG 11-0011
NOISE REDUCTION PAG 11-0012
OPERATOR SEAT - STANDARD PAG 11-0013
OPERATOR SEAT (COMPONENTS) - STANDARD PAG 11-0014
OPERATOR SEAT (COMPONENTS) - STANDARD PAG 11-0015
OPERATOR SEAT - DELUXE PAG 11-0016
OPERATOR SEAT (COMPONENTS) - DELUXE PAG 11-0017
OPERATOR SEAT (COMPONENTS) - DELUXE PAG 11-0018
OPERATOR SEAT & PASSENGER SEAT - VISION CAB PAG 11-0019
PASSENGER SEAT PAG 11-0020
RADIO - STANDARD PAG 11-0021
RADIO - DELUXE PAG 11-0022
RADIO - SPEAKERS & SUBWOOFER PAG 11-0023
MONITOR MOUNTING PAG 11-0024
MONITOR MOUNTING - CLAMP PAG 11-0025
SUN VISOR PAG 11-0026
REAR VIEW MIRROR PAG 11-0027
REAR VIEW MIRROR & ROTARY BEACON PAG 11-0028
PLATFORM - CAB SUPPORT PAG 11-0029
PLATFORM - EXTENSION PAG 11-0030
PLATFORM - HANDRAIL PAG 11-0031
PLATFORM EXTENSION - DUAL WHEELS PAG 11-0032
ACCESS LADDER - SWIVEL PAG 11-0033
ACCESS LADDER - SWIVEL PAG 11-0034
ACCESS LADDER - FOLDING PAG 11-0035
ACCESS LADDER - FOLDING PAG 11-0036
ACCESS LADDER - PIVOT PAG 11-0037
ACCESS LADDER - PIVOT PAG 11-0038
ACCESS LADDER - ACTUATOR PAG 11-0039
ACCESS LADDER - HANDRAIL PAG 11-0040
AIR CONDITIONING AND HEATING SYSTEM PAG 12-000-TOC Tech Spec Notes Ref
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) - VISION CAB PAG 12-0001
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) PAG 12-0002
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) PAG 12-0003
REFRIGERANT LINES PAG 12-0004
CHASSIS PAG 13-000-TOC Tech Spec Notes Ref
FRAME & PANEL PAG 13-0001
SEPARATOR DOOR PAG 13-0002
STONE TRAP PAG 13-0003
ENGINE DECK PAG 13-0004
ENGINE ACCESS - LADDER PAG 13-0005
ENGINE ACCESS - LADDER PAG 13-0006
ENGINE COVER PAG 13-0007
TRIM - REAR PAG 13-0008
SIDE PANELS - LEFT SIDE PAG 13-0009
SIDE PANELS - LEFT SIDE PAG 13-0010
SIDE PANELS - LEFT SIDE PAG 13-0011
SIDE PANELS - RIGHT SIDE PAG 13-0012
SIDE PANELS - RIGHT SIDE PAG 13-0013
SIDE PANELS - RIGHT SIDE PAG 13-0014
MUD SHIELDS - LEFT SIDE PAG 13-0015
MUD SHIELDS - RIGHT SIDE PAG 13-0016
DECALS PAG 14-000-TOC Tech Spec Notes Ref
EMBLEMS PAG 14-0001
SAFETY & WARNING PAG 14-0002
SAFETY & WARNING PAG 14-0003
SAFETY & WARNING - CAB PAG 14-0004
SAFETY & WARNING - CAB PAG 14-0005
WHEELS PAG 15-000-TOC Tech Spec Notes Ref
FRONT WHEELS - STANDARD - 900_60R32 PAG 15-0001
FRONT WHEELS - DUAL WHEELS - 520_85R42 PAG 15-0002
FRONT WHEELS - DUAL WHEELS - 620_70R42 PAG 15-0003
FLIGHTING PAG 15-0004
REAR WHEELS PAG 15-0005
FEEDING SYSTEM PAG 16-000-TOC Tech Spec Notes Ref
TILT FRAME PAG 16-0001
TILT FRAME - ANCHOR PAG 16-0002
TILT FRAME - ANCHOR PAG 16-0003
TILT FRAME PAG 16-0004
FEEDER FRAME PAG 16-0005
FEEDER FLOOR PAG 16-0006
FEEDER FLOOR - DOOR PAG 16-0007
UPPER SHAFT PAG 16-0008
UPPER SHAFT PAG 16-0009
LOWER SHAFT - FIXED SPEED PAG 16-0010
LOWER SHAFT - VARIABLE SPEED PAG 16-0011
FEED DRUM & CHAINS - FRONT PAG 16-0012
FEED DRUM & CHAINS - REAR PAG 16-0013
FEEDER CHAIN - FRONT PAG 16-0014
FEEDER CHAIN - REAR PAG 16-0015
SHIELDS - LEFT SIDE PAG 16-0016
SHIELDS - RIGHT SIDE PAG 16-0017
THRESHING SYSTEM PAG 17-000-TOC Tech Spec Notes Ref
SEPARATOR CAGE PAG 17-0001
CONCAVE PAG 17-0002
CONCAVE PAG 17-0003
CONCAVE ADJUSTMENT PAG 17-0004
CONCAVE - FILLER PLATES PAG 17-0005
CONCAVE - SMALL GRAIN PAG 17-0006
ACCELERATOR ROLLS PAG 17-0007
AUGER PAG 17-0008
ROTOR PAG 17-0009
ROTOR - BEARING BRACKET PAG 17-0010
SHIFTER PAG 17-0011
CLEANING SYSTEM PAG 18-000-TOC Tech Spec Notes Ref
SHAKER SHOE PAG 18-0001
SHAKER SHOE - SIEVE & CHAFFER PAG 18-0002
SHAKER SHOE - COVER PAG 18-0003
SHAKER SHOE - HOUSING PAG 18-0004
SHAKER SHOE - HOUSING PAG 18-0005
CLEANING FAN - HOUSING PAG 18-0006
CLEANING FAN - FANNING MILL PAG 18-0007
CLEANING FAN - FANNING MILL PAG 18-0008
CLEANING FAN - FAN PAG 18-0009
TAILINGS ELEVATOR - COVER PAG 18-0010
TAILINGS ELEVATOR - RETURN PAG 18-0011
TAILINGS ELEVATOR PAG 18-0012
GRAIN BIN AND ELEVATOR SYSTEM PAG 19-000-TOC Tech Spec Notes Ref
GRAIN BIN - LADDER PAG 19-0001
GRAIN BIN - SUPPORT PAG 19-0002
GRAIN BIN PAG 19-0003
GRAIN BIN PAG 19-0004
GRAIN BIN - EXTENSION PAG 19-0005
GRAIN BIN UNLOADING PAG 19-0006
GRAIN BIN UNLOADING - CRADLE PAG 19-0007
GRAIN ELEVATOR PAG 19-0008
GRAIN ELEVATOR - CHAIN PAG 19-0009
GRAIN ELEVATOR - FILLING AUGER PAG 19-0010
WITHOUT YIELD MONITOR SYSTEM PAG 19-0011
YIELD MONITOR SYSTEM - AGCO PAG 19-0012
YIELD MONITOR SYSTEM - AGCO PAG 19-0013
YIELD MONITOR SYSTEM - AG LEADER® PAG 19-0014
DISCHARGE SYSTEM PAG 20-000-TOC Tech Spec Notes Ref
IMPELLER PAG 20-0001
STRAW CHOPPER - FINE CUT 2 PAG 20-0002
CHAFF SPREADER PAG 20-0003
SINGLE STRAW SPREADER PAG 20-0004
PRECISION FARMING SYSTEMS PAG 21-000-TOC Tech Spec Notes Ref
TELEMETRY - 4 CHANNEL PAG 21-0001
ANTENNA - WITHOUT GUIDANCE PAG 21-0002
ANTENNA - NOVATEL PAG 21-0003
ANTENNA - TRIMBLE PAG 21-0004
ACCESSORIES PAG 22-000-TOC Tech Spec Notes Ref
WORK LIGHTS KIT - LED PAG 22-0001
HITCH EXTENSION KIT PAG 22-0002
VARIABLE SPEED HEADER DRIVE KIT PAG 22-0003
ELEVATOR SLOW DOWN KIT PAG 22-0004
HILLSIDE DIVIDER KIT PAG 22-0005
CASCADE PAN KIT PAG 22-0006
SMALL SEED KIT PAG 22-0007
CHAFFER KIT - CORN PAG 22-0008
CHAFFER KIT - CORN PAG 22-0009
CHAFFER KIT - CORN PAG 22-0010
STRAW CHOPPER (FINE CUT) KIT PAG 22-0011
STRAW CHOPPER (FINE CUT) KIT PAG 22-0012
CHAFF SPREADER KIT PAG 22-0013
CHAFF SPREADER KIT - HYDRAULIC PAG 22-0014
TRIMBLE KIT - RTK (REAL TIME KINEMATIC) PAG 22-0015
N-TRIP KIT - RTK (REAL TIME KINEMATIC) PAG 22-0016
Brand: Gleaner
EXHAUST PAG 03-0011
EXHAUST PAG 03-0012
ARMREST PAG 10-0031
ARMREST PAG 10-0032
EMBLEMS PAG 14-0001
CONCAVE PAG 17-0002
CONCAVE PAG 17-0003
AUGER PAG 17-0008
ROTOR PAG 17-0009
SHIFTER PAG 17-0011
- Gleaner Crop 2015 Reference Manual
- Gleaner 9325 9330 9335 9340 DynaFlex Draper Header Service Manual_79037415A
- Gleaner NA Harvesting S96 S97 S98 Combine Service Manual_7903681B
- Gleaner 9255 DynaFlex Draper Header Service Manual_79036985A
- Gleaner NA Harvesting S67 S77 Combine Service Manual_79034327D
- Gleaner NA Harvesting A86 Combine Service Manual_79032990A
- Gleaner NA Harvesting A86 Combine Repair Time Schedule_79033167A
- Gleaner NA Harvesting R65 R75 Rotary Combine Service Manual_79028577A
- Gleaner NA Harvesting S67 S77 Combine Repair Time Schedule_79034730D
- Gleaner NA Harvesting 9300 Dynaflex Draper Header Workshop Service Manual
- Gleaner NA Harvesting R65 R75 Combine Repair Time Schedule_79033163A
- Gleaner NA Harvesting A85 Combine Service Manual_79024353A
- Gleaner NA Harvesting 9250 Dynaflex Draper Header Service Manual_79034308B
- Gleaner NA Harvesting R66 R76 Rotary Combine Service Manual_79032996A
- Gleaner NA Harvesting R66 R76 Combine Repair Time Schedule_79033166A
