Gleaner Combine R60 R70 Parts Catalog 79008108
Brand: Gleaner
Type of Machine: Combine
Model:
Gleaner R60 Combine
Gleaner R70 Combine
Part Number: 79008108
Number of Pages: 507 Pages
Parts Catalog Information
Engine Attaching - Engine Mount & Oil Drain
Engine Attaching - P.T.O., Engine
Engine Attaching - Filter, Spin-On, Oil Bypass
Engine Attaching - Air Cleaner
Engine Attaching - Exhaust
Engine Attaching - Rotary Screen, And Cooling Shroud
Engine Attaching - Fuel Filter & Lines
Engine Attaching - Fuel Tank & Lines
Engine Attaching - Ether Starting Aid
Electrical & Instruments - Engine & Battery Wiring
Electrical & Instruments - Instruments & Gauges
Electrical & Instruments - Starting Motor, Nippondenso
Electrical & Instruments - Starting Motor, Delco- Remy
Electrical & Instruments - Alternator, 105 Amp
Electrical & Instruments - Fuse Panel, Breakers, Fuses & Relay
Electrical & Instruments - Electro-Hydraulics, R60 Eff. S N 16101 & R70 Eff. S N 12001
Electrical & Instruments - Electro-Hydraulics, Eff. R60 S N 16101 And R70 S N 12001
Electrical & Instruments - Efficiency Monitoring, Pacer
Electrical & Instruments - Warning Systems, Tattletale V And, Unloader Swing
Electrical & Instruments - Monitoring Systems, Digital Tachometer & Tattletale Iii
Electrical & Instruments - Upper Instruments, Console, Left Hand
Electrical & Instruments - Upper Instruments, Console, Right Hand
Electrical & Instruments - Lighting
Electrical & Instruments - Windshield Wiper
Electrical & Instruments - Cigarette Lighter
Electrical & Instruments - Radio
Feeder - Housing
Feeder - Latch, Header
Feeder - Conveyor, Front
Feeder - Countershaft, Feeder House
Feeder - Idler, Variable Speed Header Drive
Feeder - Idler, Rh Pivot Drive, R60 Eff. S N 16501, R70 Eff. S N 12501
Feeder - Idler, Constant Speed Header Drive
Separator - Housing
Separator - Pivot Shaft
Separator - Rear Conveyor Floor
Separator - Conveyor, Rear
Separator - Rear Feed Conveyor, Drive Shaft & Idler, R60
Separator - Rear Feed Conveyor, Drive Shaft & Idler, R60 Eff. S N 16501, R70 Eff. S N 12501
Separator - Feed Reverser
Separator - Main Clutch Shaft
Separator - Main Clutch Shaft, Left Hand Drive, Separator Clutch
Separator - Main Clutch Shaft, Right Hand Drive, Vari-Speed Cylinder, R60 Eff. S N 16501; R70 Eff. S N 12501
Separator - Main Drive Idler
Separator - Pivot Shaft Idler, Left Hand
Separator - Fan, Idler & Drive
Separator - Fan, Housing
Separator - Cleaner Shoe, Housing
Separator - Cleaner Shoe Drive, Idler & Hangers
Separator - Tailings Return To Cylinder, Return Conveyor &
Separator - Tailings Conveyor
Processor - Housing, P1 Processor
Processor - Housing, P3 Processor
Processor - Cage, Thresher, Separator & Fingers, P1 Processor
Processor - Cage, P3 Processor
Processor - Concave, P1 Processor
Processor - Concave, P3 Processor
Processor - Concave, Safety Door, P1 Processor
Processor - Concave, Safety Door, P3 Processor
Processor - Cylinder, P1 Processor
Processor - Cylinder, P3 Processor
Processor - Gearbox, Input Shaft, Input Sheave & Cam
Processor - Gearbox, Output Shaft, Intermediate Shaft, Shift
Processor - Cage Sweep, Carriage, Rails, Tines & Beams, P1
Processor - Cage Sweep, Ribs & Tines, P3 Processor
Processor - Cage Sweep, Drives & Idler, P1 Processor
Processor - Cage Sweep, Drives & Idler, P3 Processor
Processor - Overfeed Auger & Related Drives, Overfeed Auger & Accelerator Roll Drives, Cage Sweep & Clean Grain Elevator Drives
Processor - Tailings Return, Overfeed Auger Shaft & Related Drives
Processor - Front & Rear Augers, Cylinder Distribution
Processor - Accelerator Rolls & Drives, R60 Prior S N 16501, R70 Prior S N 12501
Processor - Accelerator Rolls & Drives, R60 Eff S N 16501, R70 Eff S N 12501
Processor - Jackshaft, Drive & Idler, R60 Prior S N 16501, R70 Prior S N 12501
Processor - Jackshaft, Drive & Idler, R60 Eff S N 16501, R70 Eff S N 12501
Processor - Impeller & Shaft, R60 Prior S N 16501, R70 Prior S N 12501
Processor - Impeller & Shaft, R60 Eff S N 16501, R70 Eff S N 12501
Processor - Impeller & Spreader, Drives
Processor - Straw Chopper & Spreader, Drives
Processor - Discharge Raddle
Grain Bin & Elevator - Grain Bin, Bolted
Grain Bin & Elevator - Grain Bin Extension, R70 Combine
Grain Bin & Elevator - Bin Unloader, Conveyor
Grain Bin & Elevator - Idler, Bin Unloader, Electric Clutch
Grain Bin & Elevator - Jackshaft, Bin Unloader
Grain Bin & Elevator - Bin Loader
Grain Bin & Elevator - Grain Elevator
Grain Bin & Elevator - Idler, Clean Grain Drive
Shields - Shields, Left Hand
Shields - Shields, Right Hand
Shields - Leaf Screen
Rear Hood & Ladder - Rear Hood, Right Hand
Rear Hood & Ladder - Rear Hood, Left Hand
Rear Hood & Ladder - Rear Hood Frame
Rear Hood & Ladder - Engine Hood
Rear Hood & Ladder - Rear Door & Ladder
Rear Hood & Ladder - Straw Spreader Shield, Prior To R60, S N 16101, Prior To R70, S N 12001
Rear Hood & Ladder - Straw Spreader Shield, R60 Eff S N 16101, R70 Eff S N 12001
Rear Hood & Ladder - Shafts & Housings
Rear Hood & Ladder - Paddles & Guards
Rear Hood & Ladder - Jackshaft
Rear Hood & Ladder - Drives
Rear Hood & Ladder - Shoe Spreader
Control Deck & Ladder - Platform & Front Ladder
Control Deck & Ladder - Console
Control Deck & Ladder - Control, Brake
Control Deck & Ladder - Control, Throttle
Control Deck & Ladder - Control, Fan
Control Deck & Ladder - Control, Hydrostatic
Control Deck & Ladder - Control, Gearshift
Control Deck & Ladder - Control, Bin Unloader, R60 Prior S N 15801, R70 Prior S N 11801
Control Deck & Ladder - Powerfold Ladder
Control Deck & Ladder - Steering Column
Control Deck & Ladder - Seat, R60 Prior S N 16101, R70 Prior S N 12001
Control Deck & Ladder - Seat, Adjustment, R60 Prior S N 16101, R70 Prior S N 12001
Control Deck & Ladder - Seat, Suspension, R60 Eff, S N 16101, R70 Eff, S N 12001
Control Deck & Ladder - Steering Column, Control Pump, R60 Eff S N 16101, R70 Eff S N 12001
Control Deck & Ladder - Steering Column, Control Pump, R60 Prior S N 16101, R70 Prior S N 12001
Control Deck & Ladder - Accumulator, Header & Reel Lift, R60 Prior S N 16501, R70 Prior S N 12501
Control Deck & Ladder - Header Lift, R60 Prior S N 16501, R70 Prior S N 12501
Control Deck & Ladder - Variable Speed Header & Reel Lift, Eff. R60 S N 16101 And R70 S N 12001
Control Deck & Ladder - Vari-Speed Cylinder Drive, R60 Eff S N 16501, R70 Eff S N 12501
Control Deck & Ladder - Vari-Speed Header & Cylinder Drive, Separator Clutch, R60 Prior S N 16501, R70 Prior S N 12501
Control Deck & Ladder - Conveyor Swing
Hydraulics - Lines & Fittings, Power Steering, Prior S N R60 16101 And R70 12001
Hydraulics - Lines & Fittings, Power Steering, Eff. R60 S N
Hydraulics - Lines & Fittings, Reservoir & Cooler, R60 Prior S N 16501, R70 Prior S N 12501
Hydraulics - Lines & Fittings, Reservoir & Cooler, R60 Eff S N 16501, R70 Eff S N 12501
Hydraulics - Lines & Fittings, Transmission & Auxiliary Steering
Hydraulics - Lines & Fittings, Transmission & Reel Speed, Separator Clutch, Eff. S N R60 16101 & R70 12001
Hydraulics - Lines & Fittings, Rear Wheel Assist W Denison Hydro, R60, Prior S N 14801, R70, Prior S N 10801
Hydraulics - Lines & Fittings, Transmission & Reel Speed, Separator Clutch, R60 Eff S N 16501, R70 Eff S N 12501
Hydraulics - Lines & Fittings, Rear Wheel Assist, R60 Eff S N 16501, R70 Eff S N 12501
Hydraulics - Lines & Fittings, Rear Wheel Assist W Denison, Or Sundstrand Hydro, R60 Prior S N 16501;R70 Prior S N 12501
Hydraulics - Lines & Fittings, Rear Wheel Assist Valve, R60 Eff S N 16501-16800, R70 Eff S N 12501-12800
Hydraulics - Lines & Fittings, Rear Wheel Assist Valve, R60, Eff. S N 14801-16500, R70, Eff. S N 10801-12500
Hydraulics - Lines & Fittings, Rear Wheel Assist, Single Cylinder, R60, Prior S N 14801, R70, Prior S N 10801
Hydraulics - Lines & Fittings, Rear Wheel Assist, Dual Cylinder, R60, Eff. S N 14801-16800, R70, Eff. S N 10801-12800
Hydraulics - Rear Wheel Assist Valve, R60 Eff S N 16101-16800, R70 Eff S N 12001-12800
Hydraulics - Rear Wheel Assist Valve, R60 Prior S N 16101, R70 Prior S N 12001
Hydraulics - Lines & Fittings, Hydraulic Pump, R60 Proir S N 16101, R70 Prior S N 12001
Hydraulics - Lines & Fittings, Hydraulic Pump, R60 Eff S N 16101, R70 Eff S N 12001
Hydraulics - Lines & Fittings, Feed Reverser
Hydraulics - Pump, Pressure Flow Compensator, R60 Prior S N 16101, R70 Prior S N 12001
Hydraulics - Pump, R60 Eff. S N 16101, R70 Eff. S N 12001
Hydraulics - Mounting, Stack Asy., R60 Prior S N 16101, R70 Prior S N 12001
Hydraulics - Valve, Master, Eff. S N R60 16101 & R70 12001
Hydraulics - Valve, Master, Prior S N R60 16101 & R70 12001
Hydraulics - Valve, Hydro Charge & Clutch, R60 Prior S N 16101, R70 Prior S N 12001
Hydraulics - Valve, Rear Wheel Assist, R60 Prior To S N 16801, R70 Prior To S N 12801
Hydraulics - Valve, Seperator Clutch And, Rear Wheel Assist, R60 Eff. S N 16101-16501, R70 Eff. S N 12001-12501
Hydraulics - Valve, Header Lift
Hydraulics - Valve, Demand Priority, Type I
Hydraulics - Valve, Demand Priority, R60 Eff S N 16101, R70 Eff S N 12001
Hydraulics - Valve, Auger Swing And Power Bin Unloader
Hydraulics - Valve, Vari-Speed Header & Cylinder, Reel Lift
Hydraulics - Valve, Reel Speed, R60 Eff. S N 16101, R70 Eff.
Hydraulics - Valve, Feed Reverser, R60 Eff. S N 16101, R70 Eff. S N 12001
Hydraulics - Valve, Feed Reverser, R60 Prior S N 16101, R70 Prior S N 12001
Hydraulics - Valve, Rear Wheel Assist, R60 Prior S N 14801, R70 Prior S N 10801
Hydraulics - Valve, Rear Wheel Assist, R60 Eff. S N 14801, R70 Eff. S N 10801
Hydraulics - Reservoir, R60 Prior S N 16101, R70 Prior S N 12001
Hydraulics - Reservoir, Eff. R60 S N 16101 And R70 S N 12001
Hydraulics - Cylinder, Conveyor Swing
Hydraulics - Cylinder Power Steering, Dual Cylinder Axle, R60
Hydraulics - Cylinder, Power Steering, Rice, R60 Eff S N 16501, R70 Eff S N 12501
Hydraulics - Cylinder, Power Steering-Rwa, Eaton #42200-Kab, R60 Eff S N 16501, R70 Eff S N 12501
Hydraulics - Cylinder, Header Lift
Hydraulics - Motor, Rear Wheel Assist, R60, Prior S N 14801, R70, Prior S N 10801
Hydraulics - Motor, Rear Wheel Assist, R60, Eff. S N 14801 & Up, R70, Eff. S N 10801 & Up
Hydraulics - Feed Reverser, Clutch Assy
Hydraulics - Feed Reverser, Clutch Assy, Feed Reverser, Torque Motor Asy
Hydraulics - Feed Reverser, Motor Asy
Hydraulics - Feed Reverser, Clutch Asy
Transmission, Axles & Wheels - Beam & Wheels
Transmission, Axles & Wheels - Final Drive
Transmission, Axles & Wheels - Brake, Disk
Transmission, Axles & Wheels - Transmission, Gear & Hydro, Transmission & Drive, For Combine Equipped With Denison Hydro
Transmission, Axles & Wheels - Transmission, Gear & Hydro, Transmission & Drive, For Combine Equipped, With Sundstrand Hydro
Transmission, Axles & Wheels - Transmission, Gear, Pressure Lube & Parking Brake
Transmission, Axles & Wheels - Transmission, Gear, Input Shaft & Gears
Transmission, Axles & Wheels - Transmission, Gear, Intermediate Shaft & Main Shaft
Transmission, Axles & Wheels - Transmission, Gear, Differential
Transmission, Axles & Wheels - Transmission, Hydro, Drive &
Transmission, Axles & Wheels - Transmission, Hydro, R60, Eff.
Transmission, Axles & Wheels - Transmission, Hydro, Input Control Asy., Combine With Denison Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Compensator, Combine With Denison Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Port Block, Combine With Denison Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Ring Check Block, Combine With Denison Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Hydro Pump Asy., Combine With Denison Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Hydro Motor Asy., Combine With Denison Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Pump Cam Asy., Combine With Denison Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Pump Housing & Control Valve, Combine With Sundstrand Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Motor & Cylinder Block, Combine With Sundstrand Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Center Section & Cylinder Block, Combine With Sundstrand Hydro
Transmission, Axles & Wheels - Transmission, Hydro, Servo, Swashplate & Front Cover, Combine With Sundstrand Hydro
Transmission, Axles & Wheels - Rear Axle & Wheels
Transmission, Axles & Wheels - Rear Axle & Wheels, Adjustable Tread
Transmission, Axles & Wheels - Rear Axle & Wheels, Rear Wheel
Transmission, Axles & Wheels - Rear Axle & Wheels, Rear Wheel Assist, Hub, R60, Prior S N 14801, R70, Prior S N 10801
Transmission, Axles & Wheels - Rear Axle & Wheels, Rear Wheel Assist Adjustable, Rice, R60 Eff. S N 16801, And R70 S N 12801
Transmission, Axles & Wheels - Rear Axle And Wheels, Rear Wheel Assist, Rice, R60 Eff. S N 16801, And R70 S N 12801
Transmission, Axles & Wheels - Rear Axle & Wheels, Rear Wheel Assist, Wheel Motor, Rice, R60 Eff. S N 16801, And R70 S N 12801
Cab - Frame, Exterior
Cab - Frame, Interior
Cab - Interior, Air Duct, Filter & Stack
Cab - Door
Cab - Windows, Glass, Gaskets & Hardware
Cab - Roof & Mirrors
Cab - Pressurizer, Housing
Cab - Pressurizer, Blower Asy.
Cab - Air Conditioner, Evaporator
Cab - Air Conditioner, Compressor
Cab - Air Conditioner, Condenser & Dryer
Cab - Heater
Options - Fuel Fired Heater, Lines, Hoses & Fittings
Drives
Drives - Recommended Dealer Stock
Brand: Gleaner
Model:
Gleaner R60 Combine
Gleaner R70 Combine
Feeder - Housing
Separator - Housing
Cab - Door
Cab - Heater
Drives
- Gleaner Crop 2015 Reference Manual
- Gleaner 9325 9330 9335 9340 DynaFlex Draper Header Service Manual_79037415A
- Gleaner NA Harvesting S96 S97 S98 Combine Service Manual_7903681B
- Gleaner 9255 DynaFlex Draper Header Service Manual_79036985A
- Gleaner NA Harvesting S67 S77 Combine Service Manual_79034327D
- Gleaner NA Harvesting A86 Combine Service Manual_79032990A
- Gleaner NA Harvesting A86 Combine Repair Time Schedule_79033167A
- Gleaner NA Harvesting R65 R75 Rotary Combine Service Manual_79028577A
- Gleaner NA Harvesting S67 S77 Combine Repair Time Schedule_79034730D
- Gleaner NA Harvesting 9300 Dynaflex Draper Header Workshop Service Manual
- Gleaner NA Harvesting R65 R75 Combine Repair Time Schedule_79033163A
- Gleaner NA Harvesting A85 Combine Service Manual_79024353A
- Gleaner NA Harvesting 9250 Dynaflex Draper Header Service Manual_79034308B
- Gleaner NA Harvesting R66 R76 Rotary Combine Service Manual_79032996A
- Gleaner NA Harvesting R66 R76 Combine Repair Time Schedule_79033166A
