Hyundai
86
176,684
Furukawa Crawler Drill HCR1200-ED II Adjustment and Test Manual 917200-D302010
Brand: Furukawa
Type of Machine: Crawler Drill
Type of Manual: Adjustment and Test Manual, Hydraulic and Pneumatic Diagram
Model: Furukawa HCR1200-ED II Crawler Drill
Part Number: 917200-D302010
Number of Pages: 212 Pages
Hydraulic Crawler Drill
Summary Section
Introduction
Labeling Symbols
Safety Warning Symbols
Tool Symbols
Precautions for Adjustment Tasks (for the Operator)
■ Follow Safety Warning Decals
■ The Workplace
■ Adjustment Tasks Should be Performed by 2 or More People
■ Warm the Hydraulic Oil
■ Clean the Crawler Drill
■ Wear Protective Gear
■ Risk of Falling
■ When Removing Hydraulic and Pneumatic Equipment
■ Risk of Burns
■ Care with Rotating and Moving Parts
■ Beware of Fire
■ Use Appropriate Tools
■ Seal Replacement
■ Handling Heavy Objects
■ Disposal of Waste Materials
Orientation of the Hydraulic Crawler Drill
Special Tools
1. Pressure Gauge
2. Revolution Counter
3. Hydraulic Hose Plugs and Union Caps
Tightening Torques
1. Regulation Tightening Torque Values for Bolts and Nuts (Metric)
2. Regulation Tightening Torques for Hydraulic Hose Pipe Joints
3. Tightening Torques for GPF Plugs
Hydraulic Device Adjustment
Locations of Hydraulic Devices and Hydraulic Pressure Measuring Ports
1. Locations of Hydraulic Devices
2. Locations of Hydraulic Pressure Measuring Ports
P1 Pump Cut-Off Pressure Adjustment
Before Adjusting
Adjustment Procedure
After Adjusting
P2 Pump Cut-Off Pressure Adjustment
Before Adjusting
After Adjusting
P3 Relief Pressure Adjustment
Before Adjusting
P4 Relief Pressure Adjustment
Before Adjusting
After Adjusting
P5 Relief Pressure Adjustment
Before Adjusting
After Adjusting
Pilot Pressure Adjustment
Before Adjusting
Percussion Pressure Adjustment
Collaring Percussion Pressure Adjustment
Forward Rotation Speed Adjustment (N-Mode)
Feed Forward Maximum Pressure Adjustment
Before Adjusting
After Adjusting
Feed Reverse Relief Pressure Adjustment
Before Adjusting
After Adjusting
Forward Rotation Relief Pressure Adjustment
Before Adjusting
After Adjusting
Reverse Rotation Relief Pressure Adjustment
Before Adjusting
After Adjusting
Forward Rotation H-Mode Relief Pressure Adjustment
Before Adjusting
After Adjusting
Boom and Rod Changer Relief Pressure Adjustment
Before Adjusting
Damper Maximum Pressure Adjustment
Before Adjusting
Damper Control Pressure Adjustment
Feed Slow Reverse Speed Adjustment
Before Adjusting
Forward Rotation Speed H-Mode Adjustment
Before Adjusting
Dust Collector Fan Rotation Speed Adjustment
Before Adjusting
Boom Speed Adjustment (Slow Mode)
Before Adjusting
Feed Pressure Control Adjustment
Percussion Pressure Control Adjustment
RP (Reverse Percussion) Pressure Adjustment
Before Adjusting
After Adjusting
Pneumatic Device Adjustment
Locations of Pneumatic Devices
Compressor Regulator Pressure Adjustment
Before Adjusting
Low Flushing Flow Rate Adjustment
Dust Collector Regulator Pressure Adjustment
Before Adjusting
Hydraulic Oil Tank Pressure Adjustment
Before Adjusting
Lubricator Hydraulic Oil Drop Adjustment
Before Adjusting
Rod Changer Adjustment
Rod Changer Part Names
Foot Pad Centering
Before Adjusting
Slide Arm Gap Adjustment
Before Adjusting
After Adjusting
Clamp Aperture Adjustment
Before Adjusting
After Adjusting
Clamp Closure Adjustment
Before Adjusting
Rod Drilling Center Position Adjustment
Before Adjusting
Magazine Rotation Speed Adjustment
Before Adjusting
Magazine Indexing Position Adjustment
Before Adjusting
Arm Slide Proximity Switch Adjustment
Before Adjusting
Swing Proximity Switch Adjustment
Before Adjusting
Swing (in) Timing Adjustment
Before Adjusting
Clamp Closure Timing Adjustment When Unscrewing
Before Adjusting
Automatic Screw Tightening Pressure Adjustment
Before Adjusting
Grease Nozzle Adjustment
Before Adjusting
Hydraulic and Pneumatic Circuit Diagrams
Hydraulic Circuit Diagram (1/2)
Hydraulic Circuit Diagram (2/2)
Rod Changer Hydraulic Circuit Diagram
