Hyundai
86
176,684
FOTON Truck AUMARK E-1044 Service Manual
Brand: FOTON
Type of Manual: Service Manual, Electric Diagram
Model: FOTON AUMARK E-1044, Emission Standard IV Truck
(4J28TC Hydraulic brake)
Number of Pages: 1907 Pages
IN Introduction
How to use this manual?​
Applicable model​
Main technical parameters of complete vehicle​
General​
Identification information​
Vehicle identification number (VIN)​
Coding rules for vehicle identification number (VIN)​
Nameplate​
Serial number (SN)​
General maintenance and operation​
Precautions for operation​
Safety rules​
Safety rules​
Cleaning specifications​
Cleaning specification​
Method for vehicle fault detection​
General​
Analysis of the fault described by the customer​
Symptom simulation inspection​
Diagnosis trouble code (DTC) list​
Symptom table​
Circuit detection​
DI Diagnosis
Fault diagnosis of electrical and electronic components​
Fault diagnosis of electrical engine control​
Fault diagnosis of auto body electric control​
EG Engine section
Engine(4J28TC)​
Engine mechanical part​
Fuel system​
Lubrication system​
Cooling system​
Air intake system​
Exhaust system​
Starting and charging​
Engine control system​
Emission purification device​
EGR system​
POC system​
TR Speed change and control mechanism
Clutch​
Clutch system​
Air removal from clutch system​
Clutch pressure plate and driven plate​
Clutch oil reservoir​
Clutch components​
Clutch slave cylinder​
Clutch master cylinder​
Clutch pedal​
Clutch control system​
Manual gearbox​
Gearbox assembly​
AX Vehicle bridge and transmission shaft
Transmission shaft​
Transmission shaft assembly​
Transmission shaft​
Universal joint​
Sliding yoke​
Front axle/front drive axle​
Front axle​
Rear axle/rear shaft​
Rear axle​
FR Carframe, hanger bracket and wheel
Carframe​
Carframe assembly​
Carframe accessories​
Front suspension​
Front suspension assembly​
Front leaf spring assembly​
Front shock absorber assembly​
Front stabilizer bar​
Rear suspension​
Rear suspension assembly​
Rear plate spring assembly​
Rear shock absorber assembly​
Rear stabilizing rod assembly​
Wheel and tyre​
Wheel assembly​
Front wheel and tyre​
Rear wheel and tyre​
Spare wheel and installation mechanism​
ST Steering system
Steering mechanism​
Steering system​
Steering wheel​
Combination switch​
Steering column​
Steering track rod​
Steering knuckle​
Steering inner articulated shaft​
Power steering​
Power steering​
Steering gear assembly​
Steering oil pump​
Steering oil tank​
Steering oil pipe​
Steering oil liquid​
BR Braking system
Service braking (hydraulic)​
Service braking (hydraulic) system​
Vacuum booster and brake master pump (hydraulic)​
Brake system air removal​
Brake pedal​
Braking line (hydraulic)​
Front wheel brake​
Rear wheel brake​
ABS系统​
Vacuum tank​
Exhaust brake valve assembly​
Parking brake​
Parking braking system​
Parking brake handle​
Parking brake bracing wire​
Parking brake​
BW Auto body
Body assy​
Sheet metal​
Coating​
Plastic parts​
Driving cab overturn and locking device​
Cab turnover mechanism​
Cab fastening device​
Cab suspension, overturn and locking device​
Cab assembly​
Windshield, window glass, rear view mirror​
Glass and rear view mirror​
Door glass lifter​
Front windshield glass​
Rear windscreen glass​
Outside back mirror​
Inside rearview mirror​
Interior and exterior trimming​
Door inner shield​
Sunvisor​
Floor finishing component​
Front bumper​
Rear bumper​
Front face shield​
Wheel trimming (including fender, wheel eyebrow, wheel cover)​
Ceiling fender​
Side wall inner shield​
Rear wall inner shield​
Pedal​
Safety handle​
Instrument panel/Combination instrument/Ashtray​
Instrument panel​
Auxiliary instrument panel​
Combination instrument​
Instrument panel framework​
Ashtray​
Door and engine cover​
Front door​
Door outside handle​
Door lock​
Door lock​
Front door lock​
Seat​
Seat assembly​
Driver seat​
Assistant seat​
Seat belt​
Seat belt​
Seat belt warning system​
Driver/Assistant seat belt​
Driver/Assistant seat lock catch​
Retractor​
Belt adjustment device for height​
EL Electrical system
Electric parts​
Storage battery​
Lighting System​
Windscreen wiper and washer​
Audio System​
Information System​
Warm wind and air conditioning​
Vehicle control system​
Circuit​
Circuit introduction​
System circuit diagram​
Wire harness connector information​
Wire harness and electrical component connector clip location plan​
index
Vehicle schematic
Vehicle schematic(Ⅰ)​
Vehicle schematic(Ⅱ)​
Vehicle schematic(Ⅲ )​
Vehicle schematic(Ⅳ )​
Vehicle schematic(Ⅴ)​
Back cover
