Momed80
150
35,046
Foton Automotive Sauvana 2011 Workshop Manual FTSM-201110
Brand: Foton
Type of Machine: Automotive
Type of Manual: Workshop Manual
Model: Foton Sauvana 2011 Automotive
Part Number: FTSM-201110
Publication Date: 2011
Number of Pages: 884 Pages
11A ENGINE CONTROL SYSTEM
Engine Control System
Engine Control Module (ECM)
ECT Sensor
Throttle Valve Body
Idle Stepping Motor
TPS
Intake Manifold Pressure/Temperature Sensor
Knock Sensor
CKP Sensor
Front Oxygen Sensor
Rear Oxygen Sensor
Canister Solenoid Valve
Wheel Speed Sensor
Ignition Control Module
12A FUEL
Fuel System
Fuel Level Sensor Assembly
Fuel Filter Assembly
Fuel Pump Assembly
Fuel Injector Assembly
Fuel Tank Cap Sliding Door
12B FUEL
Fuel System
Fuel Tank Cap Cover
Fuel Tank Cap
13A EMISSION CONTROL
Fuel tank cap
Canister
Canister solenoid valve
Positive crankcase ventilation check valve (PVC valve)
14A INTAKE AIR
Intake Air System
Air Cleaner Assembly
Intake Line
Intake manifold
14B INTAKE AIR
INTAKE AIR SYSTEM
Air Filter Assembly
Aftercooler Assy
Intake Line
15A ENGINE MECHANICAL
Engine Mechanical System
Engine Assembly
Engine Accessory Belt
Toothed Timing Pulley Casing
Toothed Timing Belt
Rock Arm, Rock Arm Shaft, Hydraulic Tappet & Camshaft
Cylinder Head, Valve
Piston & Connecting Rod Assembly
Crankshaft, Cylinder Block & Flywheel
15B ENGINE MECHANICAL
Engine Assembly
16A EXHAUST
Exhaust system
Exhaust pipe
Exhaust manifold
16B EXHAUST
Exhaust System
Exhaust Pipe
17A COOLING
Coolant
Electronic Fan
Thermostat
Water pump
17B COOLING
Coolant
Electronic Fan
18A LUBRICATION
Lubrication System
Engine Oil
Oil Filter
Oil Pan
Oil Pump
19A IGNITION
Ignition System
Ignition Module, High Voltage Cable & Spark Plug
20A STARTING AND CHARGING
Start & Charge System
Starter
Battery
20B STARTING AND CHARGING
Start and Charge System
Generator
Starter
Battery
31 FRONT SUSPENSION
Front Suspension Assembly
Front Wheel Alignment
Front Shock Absorber
Upper Swing Arm
Lower Swing Arm
Stabilizer
32 REAR SUSPENSION
Rear Suspension Assembly
Rear Shock Absorber
Rear Leaf Spring
33 TIRE AND WHEEL
Wheel & Tire Assembly
Front Tire & Wheel
Rear Wheel & Tire
Spare Tire Mounting Mechanism
Tire Pressure Monitoring System Receiver Module
34 AXLE AND PROPELLER SHAFT
Front Axle Assembly
Front Main Reducer Assembly
Front Differential Assembly
Front Driving Gear
Front Axle Clutch Assembly
Front Axle Clutch Controller
Front Rim
Main Reducer Gear Oil
Steering Knuckle
Transmission Shaft Assembly
Intermediate Bearing
Cardin Joint
Front Half Axle
Rear Axle Assembly
Rear Half Axle
Rear Axle Housing Assembly
Rear Differential Assembly
Rear Driving Gear
35 BRAKE
Brake System Emission
Brake Pedal
Master Brake Cylinder & Vacuum Booster
Front Brake
Rear Brake
ABS Executor Assembly
Wheel Speed Sensor
Master Brake Cylinder & Vacuum Booster (RH)
36 PARKING BRAKE
Park Brake System
Park Brake Lever
Park Brake Cable
41A TRANSMISSION R5M21
Transmission Shifting System
Transmission Assembly
First Shaft & Reverse Shaft Assembly
Second Shaft Assembly
Intermediate Shaft Assembly
41B TRANSMISSION JC538
Transfer Case (4WD)
Transfer Case Control Unit
42 CLUTCH
Clutch System
Clutch System Air Discharge
Clutch Pedal
Master Clutch Cylinder
Clutch Cylinder
Clutch Module
Index
