Ford Ecosport 2020 Electrical Wiring Diagram, Connector Viewer Pinout & Engine
Brand: Ford
Type of Machine: Automobile
Type of Document: Diagrams, Connector Viewer, PINOUT ECU, Engine Assembly, Engine Disassembly, Engine Installation, Engine Removal
Date: Updated 2020
Model: 2020 Ford
Content:
BCM-ABS
Diagram
Fuse & Relay
Pinout
Details:
* Diagram:
All Wheel Drive (AWD)
Audio System Navigation - SYNC
Automatic Climate Control System
Charging System
Cluster and Panel Illumination
Component Location Views
Cooling Fan
Cruise Control
Electronic Engine Controls - 1.5L Diesel
Electronic Engine Controls - 1.5L TIVCT -AT
Electronic Engine Controls - 1.5L TIVCT -MT
Electronic Engine Controls - 2.0L GDI
Fog Lamps
Fuse and Relay Information
Grounds
Headlamps Autolamps
Heated Window
Horn Cigar Lighter
Instrument Cluster
Interior Lamps
Manual Climate Control System
Module Communications Network
Parking Aid
Parking, Rear and License Lamps
Passive Anti-Theft System
Power Distribution
Power Mirrors
Power Steering Controls
Power Windows
Remote Keyless Entry and Alarm
Reversing Lamps
Roof Opening Panel
Shift Interlock
Starting System
Supplemental Restraint System
Trailer Camper Adapter
Transmission Controls -6F15-6F35
Turn Signal Stop Hazard Lamps
Vehicle Dynamic Systems
Vehicle Emergency Messaging System
Wipers and Washers
* Engine:
Engine - 1.0L EcoBoost (92kW-125PS).rar
Engine - 1.5L Duratec (90kW-120PS) - I3.rar
Engine - 2.0L Duratec-HE (129kW-175PS).rar
Engine - 2.0L EcoBoost (177kW-240PS) - MI4.rar
Engine - 2.5L Duratec (125kW-170PS).rar
Engine - 1.5L EcoBoost (132kW-180PS) - I4.rar
Engine - 1.5L Duratorq-TDCI(67KW-91PS).rar
Engine - 1.6L Duratec-16v (81KW-110PS).rar
Engine - 2.0L Duratec-HE(107KW-145PS).rar
Assembly
Disassembly
Disassembly and Assembly of Subassemblies
Engine - Component Location.pdf
Installation
Removal
Removal and Installation
Specifications.pdf
System Operation.pdf
* Transmission:
6-Speed Automatic Transmission – 6F15
6-Speed Automatic Transmission – 6F35
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Description and Operation
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Diagnosis and Testing
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\General Procedures
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Removal and Installation
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Description and Operation\Transmission Cooling - Component Location.pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Description and Operation\Transmission Cooling - Overview.pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Diagnosis and Testing\Transmission Cooling.pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\General Procedures\Transmission Fluid Cooler - Backflushing and Cleaning - 1.0L EcoBoost (92kW-125PS).pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\General Procedures\Transmission Fluid Cooler - Backflushing and Cleaning - 1.5L Duratec (90kW-120PS) - I3.pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Removal and Installation\Cooler Bypass Valve - 1.0L EcoBoost (92kW-125PS).pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Removal and Installation\Cooler Bypass Valve - 1.5L Duratec (90kW-120PS) - I3.pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Removal and Installation\Transmission Fluid Auxiliary Cooler.pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Removal and Installation\Transmission Fluid Cooler - 1.0L EcoBoost (92kW-125PS).pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Removal and Installation\Transmission Fluid Cooler - 1.5L Duratec (90kW-120PS) - I3.pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Removal and Installation\Transmission Fluid Cooler Tubes - 1.0L EcoBoost (92kW-125PS).pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Removal and Installation\Transmission Fluid Cooler Tubes - 1.5L Duratec (90kW-120PS) - I3.pdf
6F15\307-02A Transmission Cooling - 6-Speed Automatic Transmission - 6F15\Removal and Installation\Transmission Fluid Warmer.pdf
6F15\307-05 Automatic Transmission External Controls\Description and Operation
6F15\307-05 Automatic Transmission External Controls\Diagnosis and Testing
6F15\307-05 Automatic Transmission External Controls\General Procedures
6F15\307-05 Automatic Transmission External Controls\Removal and Installation
6F15\307-05 Automatic Transmission External Controls\Description and Operation\External Controls - Component Location.pdf
6F15\307-05 Automatic Transmission External Controls\Description and Operation\External Controls - Overview.pdf
6F15\307-05 Automatic Transmission External Controls\Description and Operation\External Controls - System Operation and Component Description.pdf
6F15\307-05 Automatic Transmission External Controls\Diagnosis and Testing\External Controls.pdf
6F15\307-05 Automatic Transmission External Controls\General Procedures\Brake Shift Interlock Actuator Manual Override.pdf
6F15\307-05 Automatic Transmission External Controls\General Procedures\Selector Lever Cable Adjustment - 6-Speed Automatic Transmission - 6F15.pdf
6F15\307-05 Automatic Transmission External Controls\General Procedures\Selector Lever Cable Adjustment - 6-Speed Automatic Transmission - 6F35.pdf
6F15\307-05 Automatic Transmission External Controls\Removal and Installation\Downshift Paddle Switch.pdf
6F15\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever Bezel.pdf
6F15\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever Cable - 6-Speed Automatic Transmission - 6F15.pdf
6F15\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever Cable - 6-Speed Automatic Transmission - 6F35.pdf
6F15\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever Knob.pdf
6F15\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever.pdf
6F15\307-05 Automatic Transmission External Controls\Removal and Installation\Upshift Paddle Switch.pdf
6F15\Transfer Case and Power Transfer Unit\Assembly
6F15\Transfer Case and Power Transfer Unit\Description and Operation
6F15\Transfer Case and Power Transfer Unit\Disassembly
6F15\Transfer Case and Power Transfer Unit\Disassembly and Assembly of Subassemblies
6F15\Transfer Case and Power Transfer Unit\General Procedures
6F15\Transfer Case and Power Transfer Unit\Installation
6F15\Transfer Case and Power Transfer Unit\Overhaul
6F15\Transfer Case and Power Transfer Unit\Removal
6F15\Transfer Case and Power Transfer Unit\Removal and Installation
6F15\Transfer Case and Power Transfer Unit\Specifications.pdf
6F15\Transfer Case and Power Transfer Unit\Assembly\Transmission.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Differential.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Direct Clutch Assembly.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Final Drive.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Forward Clutch Assembly.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Input Shaft.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Intermediate Clutch Assembly.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Low One-Way Clutch Assembly.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Low-Reverse Clutch Assembly.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Main Control Valve Body.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Overdrive Clutch Assembly.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Planetary Assembly.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Pump Assembly.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Torque Converter Clutch (TCC.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Transmission Description - Component Location.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Transmission Description - Overview.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Transmission Description.pdf
6F15\Transfer Case and Power Transfer Unit\Description and Operation\Transmission Fluid Auxiliary Pump.pdf
6F15\Transfer Case and Power Transfer Unit\Disassembly\Transmission.pdf
6F15\Transfer Case and Power Transfer Unit\Disassembly and Assembly of Subassemblies\Transmission Case.pdf
6F15\Transfer Case and Power Transfer Unit\General Procedures\Adaptive Learning Drive Cycle.pdf
6F15\Transfer Case and Power Transfer Unit\General Procedures\Transmission Case Reseal.pdf
6F15\Transfer Case and Power Transfer Unit\General Procedures\Transmission Fluid Drain and Refill.pdf
6F15\Transfer Case and Power Transfer Unit\General Procedures\Transmission Fluid Exchange.pdf
6F15\Transfer Case and Power Transfer Unit\General Procedures\Transmission Fluid Level Check.pdf
6F15\Transfer Case and Power Transfer Unit\General Procedures\Transmission Identification.pdf
6F15\Transfer Case and Power Transfer Unit\General Procedures\Transmission Strategy Download.pdf
6F15\Transfer Case and Power Transfer Unit\Installation\Transmission.pdf
6F15\Transfer Case and Power Transfer Unit\Overhaul\Main Control Valve Body.pdf
6F15\Transfer Case and Power Transfer Unit\Overhaul\Transmission - 1.0L EcoBoost (92kW-125PS).pdf
6F15\Transfer Case and Power Transfer Unit\Overhaul\Transmission.pdf
6F15\Transfer Case and Power Transfer Unit\Removal\Transmission.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Halfshaft Seal LH.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Halfshaft Seal RH.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Main Control Cover - 1.0L EcoBoost (92kW-125PS).pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Main Control Cover - 1.5L Duratec (90kW-120PS) - I3.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Main Control Valve Body.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Output Shaft Speed (OSS) Sensor.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Roll Restrictor RH - 1.0L EcoBoost (92kW-125PS).pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Roll Restrictor RH - 1.5L Duratec (90kW-120PS) - I3.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Selector Shaft Seal.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Solenoid Body.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Solenoid.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Transmission - 1.0L EcoBoost (92kW-125PS).pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Transmission - 1.5L Duratec (90kW-120PS) - I3.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Fluid Auxiliary Pump.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Internal Wiring Harness Frame.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Range (TR) Sensor.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Support Insulator - 1.0L EcoBoost (92kW-125PS).pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Support Insulator - 1.5L Duratec (90kW-120PS) - I3.pdf
6F15\Transfer Case and Power Transfer Unit\Removal and Installation\Turbine Shaft Speed (TSS) Sensor.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35
6F35\307-05 Automatic Transmission External Controls
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Assembly
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Disassembly
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Disassembly and Assembly of Subassemblies
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\General Procedures
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Installation
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Overhaul
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Specifications.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Assembly\Transmission.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Differential.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Direct Clutch Assembly.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Final Drive.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Forward Clutch Assembly3.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Input Shaft.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Intermediate Clutch Assembly.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Low One-Way Clutch Assembly.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Low-Reverse Clutch Assembly.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Main Control Valve Body.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Overdrive Clutch Assembly.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Planetary Assembly.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Pump Assembly.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Torque Converter Clutch (TCC).pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Transmission Description - Overview.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Transmission Description - System Operation and Component Description.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Transmission Description.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Description and Operation\Transmission Fluid Auxiliary Pump.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Disassembly and Assembly of Subassemblies\Transmission Case.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\General Procedures\Adaptive Learning Drive Cycle.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\General Procedures\Transmission Case Reseal.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\General Procedures\Transmission Fluid Drain and Refill.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\General Procedures\Transmission Fluid Exchange.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\General Procedures\Transmission Fluid Level Check.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\General Procedures\Transmission Identification.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\General Procedures\Transmission Strategy Download.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Installation\Transmission.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Overhaul\Main Control Valve Body.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Overhaul\Transmission.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Overhaul\Transmission3.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal\Transmission.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Halfshaft Seal LH.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Halfshaft Seal RH - AWD.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Halfshaft Seal RH - FWD.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Main Control Cover.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Main Control Valve Body.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Output Shaft Speed (OSS) Sensor.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Roll Restrictor RH.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Selector Shaft Seal.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Solenoid Body.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Solenoid.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Case Bushing.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Fluid Auxiliary Pump.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Internal Wiring Harness Frame.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Range (TR) Sensor.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Transmission Support Insulator.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Transmission.pdf
6F35\307-01B Automatic Transmission-Transfer Case and Power Transfer Unit\Removal and Installation\Turbine Shaft Speed (TSS) Sensor.pdf
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\Description and Operation
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\Diagnosis and Testing
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\General Procedures
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\Removal and Installation
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\Description and Operation\Transmission Cooling - Component Location.pdf
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\Description and Operation\Transmission Cooling - Overview.pdf
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\Diagnosis and Testing\Transmission Cooling.pdf
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\General Procedures\Transmission Fluid Cooler - Backflushing and Cleaning.pdf
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\Removal and Installation\Cooler Bypass Valve.pdf
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\Removal and Installation\Transmission Fluid Cooler Tubes.pdf
6F35\307-02B Transmission Cooling - 6-Speed Automatic Transmission - 6F35\Removal and Installation\Transmission Fluid Cooler.pdf
6F35\307-05 Automatic Transmission External Controls\Description and Operation
6F35\307-05 Automatic Transmission External Controls\Diagnosis and Testing
6F35\307-05 Automatic Transmission External Controls\General Procedures
6F35\307-05 Automatic Transmission External Controls\Removal and Installation
6F35\307-05 Automatic Transmission External Controls\Description and Operation\External Controls - Component Location.pdf
6F35\307-05 Automatic Transmission External Controls\Description and Operation\External Controls - Overview.pdf
6F35\307-05 Automatic Transmission External Controls\Description and Operation\External Controls - System Operation and Component Description.pdf
6F35\307-05 Automatic Transmission External Controls\Diagnosis and Testing\External Controls.pdf
6F35\307-05 Automatic Transmission External Controls\General Procedures\Brake Shift Interlock Actuator Manual Override.pdf
6F35\307-05 Automatic Transmission External Controls\General Procedures\Selector Lever Cable Adjustment - 6-Speed Automatic Transmission - 6F15.pdf
6F35\307-05 Automatic Transmission External Controls\General Procedures\Selector Lever Cable Adjustment - 6-Speed Automatic Transmission - 6F35.pdf
6F35\307-05 Automatic Transmission External Controls\Removal and Installation\Downshift Paddle Switch.pdf
6F35\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever Bezel.pdf
6F35\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever Cable - 6-Speed Automatic Transmission - 6F15.pdf
6F35\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever Cable - 6-Speed Automatic Transmission - 6F35.pdf
6F35\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever Knob.pdf
6F35\307-05 Automatic Transmission External Controls\Removal and Installation\Selector Lever.pdf
6F35\307-05 Automatic Transmission External Controls\Removal and Installation\Upshift Paddle Switch.pdf
* Pinout:
2013 PINOUT FORD ECOSPORT 1.5 DIESEL-2.pdf
2013 PINOUT FORD ECOSPORT 1.5 DIESEL-3.pdf
2013 PINOUT FORD ECOSPORT 1.5 DIESEL.pdf
2013 PINOUT FORD ECOSPORT 1.6L-.pdf
2013 PINOUT FORD ECOSPORT 1.6L-2.pdf
2013 PINOUT FORD ECOSPORT 2.0L T-A-.pdf
2013 PINOUT FORD ECOSPORT 2.0L T-A-2.pdf
2013 PINOUT FORD ECOSPORT 2.0L T-A-3.pdf
2013 PINOUT FORD ECOSPORT 2.0L T-M-.pdf
2013 PINOUT FORD ECOSPORT 2.0L T-M-2.pdf
2014 PINOUT FORD ECOSPORT 1.5 DIESEL-2.pdf
2014 PINOUT FORD ECOSPORT 1.5 DIESEL-3.pdf
2014 PINOUT FORD ECOSPORT 1.5 DIESEL.pdf
2014 PINOUT FORD ECOSPORT 1.6L-.pdf
2014 PINOUT FORD ECOSPORT 1.6L-2.pdf
2014 PINOUT FORD ECOSPORT 2.0L T-A-.pdf
2014 PINOUT FORD ECOSPORT 2.0L T-A-2.pdf
2014 PINOUT FORD ECOSPORT 2.0L T-A-3.pdf
2014 PINOUT FORD ECOSPORT 2.0L T-M-.pdf
2014 PINOUT FORD ECOSPORT 2.0L T-M-2.pdf
2015 PINOUT FORD ECOSPORT 1.5 DIESEL-2.pdf
2015 PINOUT FORD ECOSPORT 1.5 DIESEL-3.pdf
2015 PINOUT FORD ECOSPORT 1.5 DIESEL.pdf
2015 PINOUT FORD ECOSPORT 1.6L-.pdf
2015 PINOUT FORD ECOSPORT 1.6L-2.pdf
2015 PINOUT FORD ECOSPORT 2.0L T-A-.pdf
2015 PINOUT FORD ECOSPORT 2.0L T-A-2.pdf
2015 PINOUT FORD ECOSPORT 2.0L T-A-3.pdf
2015 PINOUT FORD ECOSPORT 2.0L T-M-.pdf
2015 PINOUT FORD ECOSPORT 2.0L T-M-2.pdf
2016 PINOUT FORD ECOSPORT 1.5 DIESEL-2.pdf
2016 PINOUT FORD ECOSPORT 1.5 DIESEL-3.pdf
2016 PINOUT FORD ECOSPORT 1.5 DIESEL.pdf
2016 PINOUT FORD ECOSPORT 1.6L-.pdf
2016 PINOUT FORD ECOSPORT 1.6L-2.pdf
2016 PINOUT FORD ECOSPORT 2.0L T-A-.pdf
2016 PINOUT FORD ECOSPORT 2.0L T-A-2.pdf
2016 PINOUT FORD ECOSPORT 2.0L T-A-3.pdf
2016 PINOUT FORD ECOSPORT 2.0L T-M-.pdf
2016 PINOUT FORD ECOSPORT 2.0L T-M-2.pdf
2017 PINOUT FORD ECOSPORT 1.5 DIESEL-2.pdf
2017 PINOUT FORD ECOSPORT 1.5 DIESEL-3.pdf
2017 PINOUT FORD ECOSPORT 1.5 DIESEL.pdf
2017 PINOUT FORD ECOSPORT 1.6L-.pdf
2017 PINOUT FORD ECOSPORT 1.6L-2.pdf
2017 PINOUT FORD ECOSPORT 2.0L T-A-.pdf
2017 PINOUT FORD ECOSPORT 2.0L T-A-2.pdf
2017 PINOUT FORD ECOSPORT 2.0L T-A-3.pdf
2017 PINOUT FORD ECOSPORT 2.0L T-M-.pdf
2017 PINOUT FORD ECOSPORT 2.0L T-M-2.pdf
2017 PINOUT FORD ECOSPORT 2.0L T-M-3.pdf
2018 PINOUT FORD ECOSPORT 1.5 DIESEL-2.pdf
2018 PINOUT FORD ECOSPORT 1.5 DIESEL-3.pdf
2018 PINOUT FORD ECOSPORT 1.5 DIESEL.pdf
2018 PINOUT FORD ECOSPORT 1.5L TIVCT A-T-2.pdf
2018 PINOUT FORD ECOSPORT 1.5L TIVCT A-T.pdf
2018 PINOUT FORD ECOSPORT 1.5L TIVCT M-T-2.pdf
2018 PINOUT FORD ECOSPORT 1.5L TIVCT M-T.pdf
2018 PINOUT FORD ECOSPORT 2.0L GDI-2.pdf
2018 PINOUT FORD ECOSPORT 2.0L GDI.pdf
2019 PINOUT FORD ECOSPORT 1.5 DIESEL-2.pdf
2019 PINOUT FORD ECOSPORT 1.5 DIESEL-3.pdf
2019 PINOUT FORD ECOSPORT 1.5 DIESEL.pdf
2019 PINOUT FORD ECOSPORT 1.5L TIVCT A-T-2.pdf
2019 PINOUT FORD ECOSPORT 1.5L TIVCT A-T.pdf
2019 PINOUT FORD ECOSPORT 1.5L TIVCT M-T-2.pdf
2019 PINOUT FORD ECOSPORT 1.5L TIVCT M-T.pdf
2019 PINOUT FORD ECOSPORT 2.0L GDI-2.pdf
2019 PINOUT FORD ECOSPORT 2.0L GDI.pdf
2020 PINOUT FORD ECOSPORT 1.5 DIESEL-2.pdf
2020 PINOUT FORD ECOSPORT 1.5 DIESEL-3.pdf
2020 PINOUT FORD ECOSPORT 1.5 DIESEL.pdf
2020 PINOUT FORD ECOSPORT 1.5L TIVCT A-T-2.pdf
2020 PINOUT FORD ECOSPORT 1.5L TIVCT A-T.pdf
2020 PINOUT FORD ECOSPORT 1.5L TIVCT M-T-2.pdf
2020 PINOUT FORD ECOSPORT 1.5L TIVCT M-T.pdf
2020 PINOUT FORD ECOSPORT 2.0L GDI-2.pdf
2020 PINOUT FORD ECOSPORT 2.0L GDI.pdf
PINOUT FORD ECOSPORT 2004-2012
PINOUT FORD ECOSPORT 1.0 08V 2003 FIC EEC-VI.pdf
PINOUT FORD ECOSPORT 1.5 2017 PINOUT.pdf
PINOUT FORD ECOSPORT 1.6 FLEX 2005 MARELLI IAW 4AFR OU IAW 4CFR.pdf
PINOUT FORD ECOSPORT 1.6 FLEX 2008 MARELLI IAW 4CFR C 2 SONDAS LAMBDA.pdf
PINOUT FORD ECOSPORT 1.6 ROCAM 2003 FIC EEC-VI.pdf
PINOUT FORD ECOSPORT 2.0 16V 2003-08 - FIC EEC-VI TRANS. MECANICA.pdf
PINOUT FORD ECOSPORT 2.0 16V 2003-08 - FIC EEC-VI TRANS. AUTOMATICA.pdf
PINOUT FORD ECOSPORT 2.0 16V FLEX 2009 - FOMOCO ECO FLEX.pdf
Brand: Ford
Date: Updated 2020
Model: 2020 Ford
Content:
BCM-ABS
Diagram
Fuse & Relay
Pinout
Details:
* Diagram:
Charging System
Cooling Fan
Cruise Control
Fog Lamps
Grounds
Headlamps Autolamps
Heated Window
Horn Cigar Lighter
Instrument Cluster
Interior Lamps
Parking Aid
Power Distribution
Power Mirrors
Power Windows
Reversing Lamps
Roof Opening Panel
Shift Interlock
Starting System
Wipers and Washers
* Engine:
Assembly
Disassembly
Installation
Removal
Specifications.pdf
* Transmission:
* Pinout:
- Ford Ranger 2012 Workshop Manual
- Ford Figo 2010 Workshop Repair Manual
- Ford Fiesta 2008-2017 Full Service Manuals
- Ford Everest Workshop Repair Manual [Update 2012]
- Ford Mondeo 2008-2009 Workshop Manual
- FORD TRANSIT 2016 - WIRING DIAGRAM MANUAL
- Ford Ecosport 2014 B515 Wiring Diagram
- FORD FUSION 2015 USA Workshop Manual
- Ford Fiesta 2011 Workshop Manual & Wiring Diagrams
- Ford Ranger 2015-2016 Wiring Diagrams Manual
- Ford Mondeo 2008-2009 ( EU) Wiring System Diagram
- Ford Transit 2007 Workshop Manual
- Ford - Transit Connect 1.8D TDCi Schematics
- Ford Focus 2013 Workshop Repair Manual
- Ford Kuga MK1 2011 Workshop Manual + Wiring Diagram
