Fiat-Hitachi Excavator EX455 Operational Principle Technical Manual 60413001
Brand: Fiat-Hitachi
Type of Machine: Excavator
Type of Manual: Technical Manual
Model: Fiat-Hitachi EX455 Excavator
Part Number: 60413001
Number of Pages: 621 Pages
Section 1 Ex455 General
Group 1 - Specifications
Excavator Dimensions (Lch Version)
Excavator Dimensions (Beh Version)
Excavator Performance
Engine Accessory
Electrical Equipment
Group 2 - Component Layout
Main Components
Electrical System (1) (Overall System)
Electrical System (2) (Monitor And Switch Panels)
Electrical System (3) (Relays, Diodes, Etc) {
Electrical System (4) (Relays, Batteries, Fuses)
Electrical System (5) (Fuses)
Other Components Pump Device 1
Section 2 Ex455 System
Group 1 -
Control System
Outline
Engine Control
Pump Control
Valve Control
Other Control
Group 2 -
Outline
Main Circuit
Pilot Circuit
Group 3 -
Outline
Power Circuit
Bulb Check Circuit
Preheat Circuit
Engine Start Circuit
Charging Circuit
Accessory Circuit
Surge Voltage Prevention Circuit
Engine Stop Circuit
Section 3 Ex455 Component Operation
Group 1 - Pump Device
Outline
Main Pump
Regulator
Pilot Pump
N Sensor (Engine Speed Sensor)
P Sensor (Pump Delivery Pressure Sensor)
A Sensor (Pump Displacement Angle Sensor)
Group 2 - Swing Device
Outline
Swing Motor
Valve Unit
Swing Parking Brake
Swing Reduction Gear
Group 3 - Control Valve
Outline
Hydraulic Circuits
Flow Combiner Valve
Pump Control Valve
Main Relief Valve
Overload Relief Valve (With Make-Up Function)
Make-Up Valve
Holding Valve
Arm Regenerative Valve
Group 4 - Pilot Valve
Outline
Operation
Group 5 -Travel Device
Outline
Travel Reduction Gear
Travel Motor
Travel Brake Valve
Travel Motor Displacement Angle Shift
Group 6 - Other Components (Upperstructure)
Pilot Shut-Off Valve
Shockless Valves
Solenoid Valve
Accumulator
Ec Motor
Group 7 -Other Components (Undercarriage)
Swing Bearing
Center Joint
Track Adjuster
Brand: Fiat-Hitachi
Engine Accessory
Main Components
Group 1 -
Control System
Outline
Engine Control
Pump Control
Valve Control
Other Control
Group 2 -
Outline
Main Circuit
Pilot Circuit
Group 3 -
Outline
Power Circuit
Bulb Check Circuit
Preheat Circuit
Charging Circuit
Accessory Circuit
Engine Stop Circuit
Outline
Main Pump
Regulator
Pilot Pump
Outline
Swing Motor
Valve Unit
Swing Parking Brake
Outline
Hydraulic Circuits
Flow Combiner Valve
Pump Control Valve
Main Relief Valve
Make-Up Valve
Holding Valve
Outline
Operation
Outline
Travel Motor
Travel Brake Valve
Shockless Valves
Solenoid Valve
Accumulator
Ec Motor
Swing Bearing
Center Joint
Track Adjuster
- New Holland 8160 8260 83608560 Workshop Technical Manual
- NEW HOLLAND & CASE IH FAULT CODES
- New Holland TX66 COMBINE Parts Catalog
- New Holland Tractor TL70 TL80 TL90 TL100 Repair Manual
- NEW HOLLAND Series TM Tractors Workshop Manual
- New Holland TC56 COMBINE Parts Catalog
- New Holland TM Series TM120 TM130 TM140 TM155 TM175 TM190 Repair Manual 11-2006
- New Holland T7.270 Service Manual
- New Holland B110-B115 workshop manual
- Repair Manual for Iveco NEF Engine F4GE0454C-F4GE0484G
- New Holland Hydraulic Excavator City Plus MH5.6 Workshop Manual
- New Holland BackhoeLoader B110 - B115 Repair Manual
- New Holland FX30 SELF-PROPELLED FORAGE HARVESTER Parts Catalog
- New Holland L220 Service Manual
- New Holland LM5040,LM5060,LM5080 Repair Manual
