Fiat Allis Wheel Loader 745 745H Service Manual 73058628
Brand: Fiat Allis
Type of Machine: Wheel Loader
Model: Fiat Allis 745, 745H Wheel Loader
Part Number: 73058628
Number of Pages: 808 Pages
Index
70645121-10000, 11000, 11000 MKII, 685T
Section 1 - Description and Specifications
Section 2 - Cooling System
Section 3 - Electrical System
Section 4 - Fuel System (With American Bosch Fuel Injection Pump)
Section 5 - Fuel System (With Roosa Master Fuel Injection Pump)
Section 5A - Fuel System (With Bosch (Germany) Fuel Injection Pump)
Section 6 - Air Cleaner and Intake Manifold
Section 7 - Exhaust Manifold and Turbocharger
Section 8 - Valves, Valve Operating Mechanism, and Cylinder Heads
Section 9 - Front End and Gear Train
Section 10 - Flywheel and Ring Gear; Flywheel Housing and Crankshaft Rear Oil Seal
Section 11 - Lubrication System
Section 12 - Camshaft and Camshaft Bearings
Section 13 - Pistons, Piston Rings, Connecting Rods, and Connecting Rod Bearings
Section 14 - Crankshaft and Crankshaft Gear, Main Bearings, and Main Bearing Caps
Section 15 - Cylinder Block and Cylinder Sleeves
Section 16 - Engine Removal and Installation
Section 17 - Engine Disassembly and Assembly
Section 18 - Fits and Tolerances; Bolt, Capscrew, and Nut Torque Wrench Specifications; Stud Gauge Heights
Section 19 - Troubleshooting
Section 20 - Service Tools
70677064-Turbocharger
Topic 1 - Description and Operation
Topic 2 - Maintenance
Topic 3 - Removal and Disassembly
Topic 4 - Cleaning and Inspestion
Topic 5 - Assembly and Installation
Topic 6 - Trouble Shooting
Topic 7 - Service Tools
Alphabetical Index
73050386-Transmission
Topic I - General
Topic II - General Description
Topic III - Description of Operation
Topic IV - Preventive Maintenance
Topic V - Trouble Shooting
Topic VI - General Overhaul
Topic VII - Transmission Removal and Installation (TT & TRT)
Topic VIII - Disassembly
Topic IX - Rebuild of Subassemblies
Topic X - Assembly of Transmission From Subassemblies
Topic XI - TT - Wear Limits and Spring Data
Topic XII - Transmission Control Valve (TT & TRT)
Topic XIII - TRT Transmission (TRT Only) Operation Description
Topic XIV - Disassembly TRT
Topic XV - Assembly of Transmission From Subassemblies
Topic XVI - TRT - Wear Limits and Spring Data
XVII - Decimal and Metric Equivalents of Fractions of an inch
73067178-Brakes and Air System
Topic 1 - General Description
Topic 2 - Air Compressor and Governor
Topic 3 - Air Compressor and Governor (Second Type)
General Description
Topic 4 - Air Storage Reservoirs
General Description
Topic 5 - Dual Air Application Valve
General Description
Topic 6 - Power Clusters
Topic 7 - Service Brakes
Topic 8 - Bleeding The Hydraulic System
Topic 9 - Parking Brake
Topic 10 - Clutch Cut-Off System
Topic 11 - Alcohol Injector (Special Equipment)
Topic 12 - Trouble Shooting
Topic 13 - Tests
Topic 14 - Emergency Brake Control Valve
Topic 15 - Miscellaneous
Alphabetical Index
73055601-Power Steering
Topic 2 - Hydraulic Tank and Components
Topic 3 - Trouble Shooting
Topic 4 - Power Steering Cylinders
Topic 5 - Power Steering Pump Assembly (FIRST Type)
Topic 6 - Power Steering Pump Assembly (Second Type)
Topic 7 - Steering Gear Assembly
Topic 8 - General Care of Hydraulic System
Topic 9 - Hydraulic Pump Assembly
Topic 10 - Demand Valve Assembly (First Type)
Topic 11 - Demand Valve Assembly (Second Type)
Topic 12 - Steering Valve Assembly (First Type)
Topic 13 - Steering Valve Assembly (Second Type)
Topic 14 - Adjustment Cross-Over Lever, Pitman Arm, and Tie Rod Assembly
Topic 15 - Pressure Lines, Fittings, Hoses and Tubing
Topic 16 - Test and Adjustment Procedures
Index
73124400-Bucket Hydraulic System
Safety Rules
General
Hydraulic System Specifications
Troubleshooting and Testing
Hydraulic Pump Repair
Hydraulic Control Valve Repair
Hydraulic Cylinder Repair
Hydraulic Fittings, Hoses and Tubing
Service Tools
Torque Values
73055458-Bucket and Chassis
General Description
Bucket and Linkage
Fenders, Ladder, Hood, Bonnet, and Hand Rail
Platform and Seat Assembly
Main Frame and Pivot Pins
Torque Specifications
Linkage Wear Limits
ROPS Cab
Index
Conversion Tables
73056512-Electrical Systems
Topic 1 - System Description
Topic 2 - Trouble Shooting
Topic 3 - Wiring Circuits
Topic 4 - Batteries
Topic 5 - Charging System
Topic 6 - The Cranking System
Topic 7 - Accessory System
Index
Conversion Tables
