Fiat Allis Wheel Loader 545-B 605-B Service Manual 73061032
Brand: Fiat Allis
Type of Machine: Wheel Loader
Model: Fiat Allis 545-B, 605-B Wheel Loader
Part Number: 73061032
Number of Pages: 975 Pages
Index
70687161- 2900 Mark II Engine
Description and Specifications
Fuel System
Air Cleaner and Intake Manifold
Exhaust Manifold and Turbocharger
Valves, Valve Operating Mechanism, and Cylinder Head
Front End and Gear Train
Flywheel and Ring Gear, Flywheel Housing and Crankshaft Rear Oil Seal
Lubricatig System
Camshaft, Valve Lifters, and Camshaft Bearings
Pistons, Piston Rings, Connecting Rods, and Connecting Rod Bearings
Crankshaft and Crankshaft Gear, Main Bearings, and Main Bearing Caps
Cylinder Block and Cylinder Sleeves
Engine Removal and installation
Engine Disassembly and Assembly
Fits and Tolerances, Torque Specifications, and Stud Gauge Heights
Trouble-Shooting
Service Tools
70687805-Turbocharger
Description and Operation
Maintenance
Removal and Disassembly
Cleaning and Inspection
Reassembly and Installation
Troubleshooting
Service Tools
73059226-Transmission
Preventive Maintenance
General Overhaul Information
Transmission Removal and Installation
Disassembly of Transmission into Subassemblies
Rebuild of Subassemblies
Assembly of Transmission from Subassemblies
TRT Transmission - Operation and Description
TRT Transmission - Disassembly and Assembly
Service Tools, Wear Limits and Spring Data
Alphabetical Index
73053547-Axles
Topic 1 - General Information and Description
Topic 2 - Trouble Shooting
Topic 3 - Removal and Installation of Axles
Topic 4 - Differential Removal and Disassembly
Topic 5 - Cleaning and Inspection
Topic 6 - Assemble Components
Topic 7 - Planetary Hubs
Topic 8 - Cleaning and Inspection
Topic 9 - Assembly and Installation
Topic 10 - Drive Shafts
Topic 11 - Torque Specifications
Topic 12 - Wheels and Tires
Topic 13 - No Spin Differential Removal and Disassembly (Special Equipment)
73059356-Brakes and Air System
Topic 1 - General Description
Topic 2 - Troubleshooting
Topic 3 - Air Compressor
Topic 4 - Governor
Topic 5 - Air Tanks
Topic 6 - Air Tank Drain Cocks
Topic 7 - Valves
Topic 8 - Air Application Valve
Topic 9 - Power Clusters
Topic 10 - Service Brakes
Topic 11 - Clutch Cut-Off Valve
Topic 12 - Alcohol Injector
Topic 13 - Air Pressure Gauge
Topic 14 - Air Horn
Topic 15 - Low Air Pressure Switch
Topic 16 - Parking Brakes
Topic 17 - Bleeding System
Topic 18 - Emergency Brake Control Valve
Topic 19 - Tests
Topic 20 - Miscellaneous
73068993-Power Steering
Topic 1 - Description and Operation
Topic 1A - Emergency Steering (Special Equipment)
Topic 2 - Service and Maintenance
Topic 3 - Troubleshooting
Topic 4 - Power Steering Cylinders
Topic 5 - Power Steering Pump
Topic 6 - Power Steering Gear Assembly
Topic 7 - Hydraulic Pump
Topic 8 - Demand Valve
Topic 9 - Test and Adjustment Procedures
Topic 10 - Pressure Line, Fittings, Hoses and Tubing
Topic 11 - Torque Values
Alphabetical Index
73124400-Bucket Hydraulic Systems
Safety Rules
General
Hydraulic System Specifications
Troubleshooting and Testing
Hydraulic Pump Repair
Hydraulic Control Valve Repair
Hydraulic Cylinder Repair
Hydraulic Fittings, Hoses and Tubing
Service Tools
Torque Values
73055458-Bucket and Chassis
General Description
Bucket and Linkage
Fenders, Ladder, Hood, Bonnet, and Hand Rail
Platform and Seat Assembly
Main Frame and Pivot Pins
Linkage Wear Limits
ROPS Cab
Index
Conversion Tables
73146366-Electrical Systems
General Description
Troubleshooting
Changing Circuit
Starting Circuit
Ignition Circuit
Accessory Circuit
Batteries
Electrical System Schematics
Brand: Fiat Allis
Index
Fuel System
Lubricatig System
Trouble-Shooting
Service Tools
Maintenance
Troubleshooting
Service Tools
Alphabetical Index
73053547-Axles
Topic 4 - Governor
Topic 5 - Air Tanks
Topic 7 - Valves
Topic 14 - Air Horn
Topic 19 - Tests
Alphabetical Index
Safety Rules
General
Service Tools
Torque Values
General Description
Bucket and Linkage
Linkage Wear Limits
ROPS Cab
Index
Conversion Tables
General Description
Troubleshooting
Changing Circuit
Starting Circuit
Ignition Circuit
Accessory Circuit
Batteries
- FIAT ALLIS BACKHOE LOADER FB7B PARTS MANUAL
- FIAT ALLIS 14C CRAWLER DOZER SERVICE MANUAL
- FIAT ALLIS FD20 CRAWLER DOZER SERVICE MANUAL
- Fiat Hitach EX135W Wheel Excavator service manual (with engine workshop manual)
- Fiat Allis FD14C Parts Catalog 050101-up
- Fiat allis Fiat Fl10 Fl10B Crwlr Ldr & 10 10B Dozer Service Manual
- Fiat Tractor 411R Wheel Tractor Service Manual
- FIAT ALLIS FR10B WHEEL LOADER SN 610101-UP PARTS MANUAL
- Fiat Allis 14C Crawler Tractor Parts Catalog
- FIAT ALLIS FD7 FL7 CRAWLER DOZER SERVICE MANUAL
- FIAT ALLIS FD5 FL5 FL5B CRAWLER DOZER SERVICE MANUAL
- FIAT ALLIS BACKHOE LOADER FB7B caracteristiques-mantenance
- FIAT Trattori 480,500,540,640_480,500,540,640-DT Workshop Manual
- FIAT ALLIS 10C CRAWLER DOZER SERVICE MANUAL
- FIAT ALLIS FR12B WHEEL LOADER PARTS MANUALS
