Fiat Allis Tractor 260-B 261-B Service Manual 73111173
Brand: Fiat Allis
Type of Machine: Elevating Tractor Scraper, Tractor Scraper
Type of Manual: Service Manual, Electrical Schematic
Model: Fiat Allis
260-B Tractor Scraper
261-B Elevating Tractor Scraper
Part Number: 73111173
Number of Pages: 1017 Pages
Index
70699853-16000 T, 17000 MKII, 19000 MKII, 21000 MKII, 25000 MKII, 6138 L, LT, I Engine
Supplement No 3 Service Manual Form 70699853 - 6138LT, 6138T, 613I Engines
Supplement No 2 Service Manual Form 70699853 - 16000T, 17000 Mark II, 19000 Mark II, 21000 Mark II, 25000 Mark II
Supplement No 1 Service Manual Form 70699853 - 16000T, 17000 Mark II, 19000 Mark II, 21000 Mark II, 25000 Mark II
Section 1 - Description and Specifications
Section 2 - Cooling System
Section 3 - Electrical System
Section 4 - Fuel System and Accessory Drive
Section 5 - Air Cleaner and Intake Manifold
Section 6 - Exhaust Manifold and Turbocharger
Section 7 - Valves, Valve Operating Mechanism and Cylinder Heads
Section 8 - Front End and Gear Train
Section 9 - Flywheel and Ring Gear; Flywheel Housing and Crankshaft Rear Oil Seal
Section 10 - Lubricating System
Section 11 - Camshaft and Camshaft Bearings
Section 12 - Pistons, Piston Rings, Connecting Rods and Connecting Rod Bearings
Section 13- Crankshaft and Crankshaft Gear, Main Bearings and Main Bearing Caps
Section 14 - Cylinder Block and Cylinder Sleeves
Section 15 - Engine Removal and Installation
Section 16 - Engine Disassembly and Assembly
Section 17 - Fits and Tolerances; Standard Torque Wrench Specifications and Stud Heights; Specific Application Torque Values
Section 18 - Troubleshooting
Section 19 - Fuel and Lubricant Specifications
70691332-Transmission Front
Supplement No 5 Form 70691332 - Front Transmission Service Manual 260-B, 261-B, 262-B, 263-B Tractor Scrapers
Supplement No 4 Form 70691332 - Front Transmission Service Manual 260-B, 261-B, 262-B, 263-B Tractor Scrapers
Supplement No 3 Form 70691332 - Front Transmission Service Manual 260-B, 261-B, Transmission , 262-B, 263-B Transmission (Front)
Supplement No 2 Form 70691332 - Front Transmission Service Manual 260-B, 261-B, 262-B, 263-B Tractor Scrapers
Supplement No 1 Form 70691332 - Front Transmission Service Manual 260-B, 261-B Tractor Scrapers
Safety Rules
Topic 1 - General Description
Topic 2 - Lubricant Specifications, Capacity, and Service
Topic 3 - Troubleshooting
Topic 4 - Pressure Checking
Topic 5 - Flow Checking
Topic 6 - Hydraulic System Components
Topic 7 - Torque Converter
Topic 8 - Transmission
Topic 8A - Automatic Shift
Topic 9 - Universal Joint
Topic 10 - Fits and Tolerances
Topic 11 - Service Tools
Alphabetical Index
73112420-Axle, Differential, And Brakes
Topic 2 - Lubricant Specifications and Capacity
Topic 3 - Trouble Shooting
Topic 4 - Tires
Topic 5 - Planetary Hub and Wheel Brakes
Topic 6 - Parking Brake
Topic 7 - Differential Carrier
Topic 8 - Differential (Tractor)
Topic 9 - Differential (262-B, 263-B Scraper)
Topic 10 - Adjustments
Topic 11 - Cleaning and Inspection
Topic 12 - and Tolerances
Topic 13 - Service Tools
Alphabetical Index
70694367-Hydraulic systems
Supplement No 1 Hydraulic Systems Service Manual
Topic 2 - Hydraulic System Specifications, Capacity, and Service
Topic 3 - Hydraulic System Operation and Component Functions
Topic 4 - Troubleshooting
Topic 5 - Hydraulic Pumps and Pump Drives
Topic 6 - Hydraulic Control Valves
Topic 7 - Hydraulic Cylinders
Topic 8 - 261-B,263-B Elevator Hydraulic Motor and Transmission
Topic 9 - Torque Values
Topic 10 - Service Tools
Alphabetical Index
70689739-Power Steering Hydrostatic
Topic 2 - Trouble-Shooting
Topic 3 - Steering Column Pump
Topic 4 - Steering Valve
Topic 5 - Steering Cylinders
Topic 6 - Adjustments
Alphabetical Index
73117273-Power Steering Hydraulic Follow-UP Type
Safety Rules
Topic 2 - Troubleshooting
Topic 3 - Steering Wheel Pump
Topic 5 - Feedback Cylinder
Topic 6 - Steering Cylinders
70698976-Air System
Topic 3 - Air Compressor
Topic 4 - Governor
Topic 5 - Air Lines and Reservoirs
Topic 6 - Air Reservoir Drain Cocks
Topic 7 - Relief and Check Valves
Topic 8 - Treadle Valve
Topic 9 - Scraper Brake Rotochamber, Air Lines and Reservoir (261-B)
Topic 10 - Scraper Service Brake Air Cylinder and Air Lines (260-B)
Topic 11 - Quick Release and Relay Emergency Valves
Topic 12 - Alcohol Injector (Special Equipment)
Topic 13 - Tractor Service Brake Air Cylinder
Topic 14 - Air Horn
Topic 15 - Hand Brake Valve (Special Equipment)
Topic 16 - Parking Brake Control
Topic 17 - Parking Brake Air Cylinder
Topic 18 - Parking Brake Valve
Topic 19 - Seat Shock Absorber
Topic 20 - Tests
Topic 21 - Miscellaneous
Alphabetical Index
73127732-Hitch
Safety Rules
Topic 1 - General
Topic 2 - Disassembly of Scraper From Tractor
Topic 3 - Hitch Removal and Disassembly
Topic 4 - Disassembly of Link or Steering Cylinders From Swing Arm
Topic 5 - Assembly of Link or Steering Cylinders to Swing Arm
Topic 6 - Hitch Assembly and Installation
Topic 7 - Assembly of Scraper-To-Tractor
Topic 8 - Checks and Adjustments
Topic 9 - Weldments
70698030-Scraper
General Description
Trouble-Shooting
Tires
Wheels and Axles
Brakes and Air Chamber
Ejector
Apron and Cylinder
Air Reservoir and Lines
Main Frame and Bowl
Lubrication Instructions
Torque Values
Index
73146366-Electrical Systems
Safety Rules
General Description
Troubleshooting
Changing Circuit
Starting Circuit
Ignition Circuit
Accessory Ciruits
Batteries
Electrical System Schematics
