702,019
Fiat Allis Motor Grader 100-C 150-C 200-C Service Manual 70697310
Brand: Fiat Allis
Type of Machine: Motor Grader
Model: Fiat Allis 100-C, 150-C, 200-C Motor Grader
Part Number: 70697310
Number of Pages: 893 Pages
70645121-1000, 11000, 11000 MKII, 685T Engines
Supplement No 6 Service Manual Form 70645121 10000, 11000, 11000 MKII, 685T Engines
Supplement No 5 Service Manual Form 70645121 10000, 11000, 11000 MKII Engines
Supplement No 4 Service Manual Form 70645121 10000, 11000, 11000 MKII Engines
Supplement No 3 Service Manual Form 0645121-5 (7-66) 10000, 11000 Engines Construction Machinery Division
Section 1 - Description and Specifications
Section 2 - Cooling System
Section 3 - Electrical System
Section 4 - Fuel System (With American Bosch Fuel Injection Pump)
Section 5 - Fuel System (With Roosa Master Fuel Injection Pump)
Section 5A - Fuel System (With Bosch (Germany) Fuel Injection Pump)
Section 6 - Air Cleaner and Intake Manifold
Section 7 - Exhaust Manifold and Turbocharger
Section 8 - Valves, Valve Operating Mechanism, and Cylinder Heads
Section 9 - Front End and Gear Train
Section 10 - Flywheel and Ring Gear; Flywheel Housing and Crankshaft Rear Oil Seal
Section 11 - Lubrication System
Section 12 - Camshaft and Camshaft Bearings
Section 13 - Pistons, Piston Rings, Connecting Rods, and Connecting Rod Bearings
Section 14 - Crankshaft and Crankshaft Gear, Main Bearings, and Main Bearing Caps
Section 15 - Cylinder Block and Cylinder Sleeves
Section 16 - Engine Removal and Installation
Section 17 - Engine Disassembly and Assembly
Section 18 - Fits and Tolerances; Bolt, Capscrew, and Nut Torque Wrench Specifications; Stud Gauge Heights
Section 19 - Troubleshooting
Section 20 - Service Tools
70687805-TurboCharger
Description and Operation
Maintenance
Removal and Disassembly
Cleaning and Insspection
Reassembly and Installation
Troubleshooting
Service Tools
70646138-Engine Clutch, and Clutch Brake
Topic 1 - General Description/ Topic 2 - Troubleshooting
Topic 3 - Engine Clutch Oiling System
Topic 4 - Clutch Brake
Topic 5 - Engine Clutch
Topic 6 - Engine Clutch, Clutch Brake, and Shifting Lock Mechanism Adjustments
Topic 7 - Fits and Tolerances
Conversion Tables
70693862-100C, 100B, M100, m70 Motor Grader Transmission
General Description/ Trouble Shooting
Lubricating System
Drive Shaft Universal Joint
Fits and Tolerances
Service Tools
70690696-150C, 200C Mortor Graders Transmission
Topic 1 - General Description and Oil Flow Schematics
Topic 2 - Lubricant Specifications, Capacity and Service
Topic 3 - Trouble-Shooting
Topic 4 - Pressure Checking
Topic 5 - Flow Checking
Topic 6 - Hydraulic System Components
Topic 7 - Engine Clutch
Topic 8 - Range Transmission
Topic 9 - Main Transmission
Topic 10 - Drive Shaft Universal Joint
Topic 11 - Fits and Tolerances
Topic 12 - Service Tools
Alphabetical Index
70641623-Tandems and Rear Axles
Supplement No 1 Service Manual Form 70641623 Tandems and Rear Axle M-100, 100-B, 100-C, 150-C, 200-C Motor Graders
Replacement Pages For 641623 (6-67) Service Manual for Tandems, Rear Axle M100 Motor Grader
Safety Rules
Topic 1 - General Description/ Topic 2 - Trouble Shooting/ Topic 3 - Lubricant Specifications, Capacity and Service
Topic 4 - Tandems
Topic 5 - Rear Axle
Topic 6 - General Inspection
Topic 8 - Service Tools
Topic 9 - Conversion Tables
70657712-Rear Wheels and Brakes
Notice of Change To Service Manual 657712 (10-66) Rear Wheels and Brakes M100 Motor Grader
Topic 1 - General Description, Fluid Specifications, and Operation
Topic 3 - Adjustments
Topic 4 - "Bleed" Brake Lines
Topic 5 - Rear Wheels
Topic 6 - Brakes
Topic 7 - Wheel Cylinders
Topic 8 - Master Cylinder
Topic 9 - Fits and Tolerances
Topic 10 - Service Tools
Conversion Tables
70693124-Front Wheels, Axle and Wheel Lean
Topic 1 - General Information
Topic 2 - Trouble-Shooting
Topic 3 - Lubricant Specifications and Service
Topic 4 - Procedure For Raising Wheels
Topic 5 - Steering Control
Topic 6 - Front Wheels and Tires
Topic 7 - Spindles and Drag Links
Topic 8 - Wheel Lean
Topic 9 - Front Axle
Topic 10 - Fits and Tolerances
Topic 11 - Service Tools
Alphabetical Index
70690857-Power Control Box, Vertical Drive and Power Take off
Supplement No 2 - Service Manual Form 70690857 Power Control Box, Vertical Drive & Power Take Off 100-C, 150-C, 200-C, Motor Graders
Supplement No 1 - Service Manual Form 70690857 Power Control Box, Vertical Drive & Power Take Off 100-C, 150-C, 200-C, Motor Graders
Topic 2 - Lubrication Specifications
Topic 4 - Power Take-Off
Topic 6 - Control Box Assembly With Mechanically Actuated Shifting Fork and Housing Assembly
Alphabetical Index
70693744-Moldboard
Topic 2 - Lubricant Specifications and Capacities
Topic 3 - Troubleshooting
Topic 4 - Moldboard Lift Gear Housing and Links
Topic 5 - Side Shift Gear Housing And Links
Topic 6 - Circle Turn Gear Housing
Topic 7 - Moldboard, Circle, and Drawbar
Topic 8 - Bevel Gear Housing Assemblies
Topic 9 - Circle Turn and Side Shift Controls
Topic 10 - Scarifier
Alphabetical Index
73146366-Electrical Systems
Safety Rules
General Description
Troubleshooting
Changing Circuit
Starting Circuit
Ignition Circuit
Accessory Ciruits
Batteries
Electrical System Schematics
