Fiat Allis Loader Tractor 6G to FR35 Electrical System Service Manual 73146366
Brand: Fiat Allis
Type of Machine: Wheel Loader, Crawler Loader, Crawler Tractor, Motor Grader, Pipelayer, Tractor Scraper
Type of Manual: Service Manual, Electrical Schematic
Model: Fiat Allis
Crawler Loader 7G, 7G-B, 12G, 12G-B, 12G-B, HD11G, HD16G, HD21G, FL14E
Crawler Tractor HD6, HD9, HD11, HD11-B, HD16, HD16-B, HD21, HD21-B, HD21-C, HD31, HD41, HD41-B, FD30, FD30B, FD40, FD50
Motor Graders D65, D65-B, DD65, DD65-B, M100, M100-B, M100-C, M150-C, M200-C, FG75, FG85, FG95
Pipelayer HD21, FP120
Tractor Scraper (Elevating) 161, 260E-A, 261-B, 263-B
Tractor Scraper (Conventional) 260-A, 260-B, 262-B, 460-C
Wheel Loader
345-B, 545, 545H, 645, 545-B, 605-B, 545G, 545B (Series 33A)
645, 645-B, 745, 745H, 745-B, 745H-B, 745-C
945, 945-B, FR10 (Series 46C, 78Y), FR10 (Series 58M)
FR12 (Series 79M), FR12 (Series 59U), FR10 (S/N 525395-up), FR12 (S/N 552081-up)
FR15 (Series 80U), FR15 (S/N 575403-up), FR20 (Series 80C, 81C), FR20 (Series 31U)
FR20 (S/N 500325-up), FR10B, FR11, FR12B, FR15B, FR20B, FR30, FR35
Part Number: 73146366
Number of Pages: 846 Pages
73146366-Electrical Systems
Safety Rules
General Description
Troubleshooting
Changing Circuit
Starting Circuit
Ignition Circuit
Accessory Circuit
Batteries
Electrical System Schematics
73147745-Bucket And Chassis
Safety Rules
Foreword
General Description
Bucket and Linkage
Fenders, Ladder, Hood, Side Panel and Handrail
Platform and Seat Assembly
Fuel Tanks
Main Frame and Pivot Pins, Fr30
Main Frame and Pivot Pins, Fr35
Linkage Wear Limits
ROPS Cab
73148347-Brakes and Air System
Safety Rules
Topic 1 - General Description
Topic 2 - Trouble Shooting
Topic 3 - Air Compressor (Cummins Engine)
Topic 4 - Air Compressor (Fiat Engine)
Topic 5 - Governor & Unloader Valve (General)
Topic 6 - Air Tanks
Topic 7 - Grain Cocks & Automatic Drain Valve
Topic 8 - Valves
Topic 9 - Air Application Valve
Topic 10 - Service Brake Air Cylinders
Topic 12 - Quick Release Valves
Topic 13 - Alcohol Injector
Topic 14 - Air Dryer
Topic 15 - Air Pressure Gauge
Topic 16 - Air Horn
Topic 17 - Low Air Pressure & Brake Light Switches
Topic 18 - Parking Brake
Topic 19 - Parking Brake Actuator
Topic 20 - Parking Brake Valve
Topic 21 - Clutch Cut-Off Cylinder
Topic 22 - Tests
Topic 23 - Unloader Valve & Schmatics
Topic 24 - Alcohol Injector & Air Dryer Schematics
73148532-Axles and Drive Shafts
Table of Contents
Topic 1: General Information and Description
Topic 2: Troubleshooting
Topic 3: Removal and Disassembly
Topic 4: Cleaning and Inspection
Topic 5: Axle Assembly and Installation
Topic 6: No Spin Differential
Topic 7: Wheels
Topic 8: Drive Shafts
Topic 9: Lubrication and Specifications
Topic 10: Service Tools
73148732-Implement and Steering System
Safety Rules
General Description
Lubrication Specifications
Performance Specifications
Troubleshooting and Testing Hydraulic Systems
Implement and Steering Pumps
Emergency Steering Pump and Valve Repair
Valve Repair
Hydraulic Cylinder Repair
Automatic Bucket Leveler & Boom Kickout adjustments
Steering Gear
73148892-FR35 Transmission
Table of Contents
Safety Rules
Foreword
Transmission Testing and Troubleshooting
Transmission Removal
Transmission Installation
Transmission Disassembly
Transmission Assembly
73149377- FR35 Engine Related Components
Table of Contents
Safety Rules
Foreword
General Description
Hood and Side Panels
Muffler
Air Cleaner
Engine Controls
Cold Weather Starting Aid
Starter and Alternator
By-Pass Oil Filter
Engine Protection System
Radiator, Radiator Support and Fan Drive
Service Tools
73150208-8285 Engine
Table of Contents
Description and Operation
Engine Disassembly
Cylinder Bloc and Sleeves
Pistons, Connecting Rods, And Bearings
Crankshaft Pulley, Damper, and Balance Weights
Crankshaft, Main Bearings, Flywheel & Housing, Ring Gear & Rear Oil Seal
Cylinder Heads, Valves, Valve Guides, and Springs
Camshaft, Bushings, Lifters, Push Rods, and Rocker Assemblies
Timing Gear Train
Lubrication System
Air Intake and Exhaust System
Fuel Injection System
Troubleshooting
Service Tools
