Fiat Allis Crawler Loader 8 8B Service Manual 60406223
Brand: Fiat Allis
Type of Machine: Crawler Loader
Model: Fiat Allis 8, 8B Crawler Loader
Part Number: 60406223
Number of Pages: 74 Pages
Section 1 - General
1.1 Specification
1.1.1 Identification Data
1.1.2 Engine
1.1.3 Power Train
1.1.4 Bevel Drive
1.1.5 Steering Clutches
1.1.6 Brakes
1.1.7 Steering Clutch Hydraulic System
1.1.8 Final Drives
1.1.9 Sprockets
1.1.10 Undercarriage
1.1.11 Suspensions'.
1.1.12 Attachments
1.1.13 Electric System
1.1.14 Weights
1.2 Spare Parts
1.3 General Fitting Notes
1.3.1 Floating Ring Seals
1.3.2 Rotary Shaft Seals
1.3.3 O—Rings
1.3.4 Face Seals
1.3.5 Notes On Installation And Removal
1.4 Capacities
1.4.1 Lubricants
Section 2 - Engine
2.1 General
2.1.1 Description
2.1.2 Removal
2.1.3 Overhaul
2.1.4 Installation
2.2 Cylinder Block
2.2.1 Cylinder Sleeves
2.3 Cylinder Head
2.3.1 Valve Seat Dressing And Seat Inserts
2.4 Valve Gear
2.4.1 Camshaft
2,4.2 Valves And Guides
2.4.3 Valve Lifters And Rockers
2.4.4 Valve Clearance Adjustment
2.4.5 Valve Timing
2.4.6 Hourmeter
2.5 Crank Gear
2.5.1 Crankshaft
2.5.2 Crankshaft Bearings
2.5.3 Pistons And Ring I
2.5.4 Connecting Rods
2.5.5 Engine Balancep
2.5.6 Balancer Timing
2.5.7 Flywheel
2.6 Fuel System
2.6.1 Fuel Tank Removal
2.6.2 Dry—Type Air Cleaner (Standard Equipment)
2.6.3 Oil Bath Air Cleaner (Optional)
2.6.4 Fuel Feed Pump.
2.6.5 Fuel Injection Pump And Speed Governor
2.6.6 Injection Pump Timing
2.6.7 Fuel Injectors
2.6.8 Injection Pump Calibration Data
2.7 Lubrication System
2.7.1 Oil Pump
2.7.2 Oil Pressure Gauge
2.7.3 Oil Cooler
2.8 Cooling System
2.8.1 Water Pump
2.8.2 Radiator
2.8.3 Thermostat
2.8.4 Water Temperature Gauge
2.8.5 Fan Belt Tightener
2.8.6 Fan And Alternator Drive Belt Removal
2.9 Tests
2.9.1 Engine Compression Test
2.9.2 Engine Bench Test
2.10 Specification And Data
2.11 Tightening Torque Figures
2.12 Service Tools
Brand: Fiat Allis
Section 1 - General
1.1 Specification
1.1.2 Engine
1.1.3 Power Train
1.1.4 Bevel Drive
1.1.6 Brakes
1.1.8 Final Drives
1.1.9 Sprockets
1.1.12 Attachments
1.1.14 Weights
1.2 Spare Parts
1.3.3 O—Rings
1.3.4 Face Seals
1.4 Capacities
1.4.1 Lubricants
Section 2 - Engine
2.1 General
2.1.1 Description
2.1.2 Removal
2.1.3 Overhaul
2.1.4 Installation
2.2 Cylinder Block
2.3 Cylinder Head
2.4 Valve Gear
2.4.1 Camshaft
2.4.5 Valve Timing
2.4.6 Hourmeter
2.5 Crank Gear
2.5.1 Crankshaft
2.5.7 Flywheel
2.6 Fuel System
2.7.1 Oil Pump
2.7.3 Oil Cooler
2.8 Cooling System
2.8.1 Water Pump
2.8.2 Radiator
2.8.3 Thermostat
2.9 Tests
2.12 Service Tools
- FIAT ALLIS BACKHOE LOADER FB7B PARTS MANUAL
- FIAT ALLIS 14C CRAWLER DOZER SERVICE MANUAL
- FIAT ALLIS FD20 CRAWLER DOZER SERVICE MANUAL
- Fiat Hitach EX135W Wheel Excavator service manual (with engine workshop manual)
- Fiat Allis FD14C Parts Catalog 050101-up
- Fiat allis Fiat Fl10 Fl10B Crwlr Ldr & 10 10B Dozer Service Manual
- Fiat Tractor 411R Wheel Tractor Service Manual
- FIAT ALLIS FR10B WHEEL LOADER SN 610101-UP PARTS MANUAL
- Fiat Allis 14C Crawler Tractor Parts Catalog
- FIAT ALLIS FD7 FL7 CRAWLER DOZER SERVICE MANUAL
- FIAT ALLIS FD5 FL5 FL5B CRAWLER DOZER SERVICE MANUAL
- FIAT ALLIS BACKHOE LOADER FB7B caracteristiques-mantenance
- FIAT Trattori 480,500,540,640_480,500,540,640-DT Workshop Manual
- FIAT ALLIS 10C CRAWLER DOZER SERVICE MANUAL
- FIAT ALLIS FR12B WHEEL LOADER PARTS MANUALS
