Fendt Tractors Rubber Tracked 938 VARIO MT (2021-2025) (MXXX1001-PXXX9999) Part Book
Brand: Fendt
Type of Machine: Tractors Rubber Tracked
Type of Manual: Part Book
Model: Fendt 938 VARIO MT (2021-2025) (MXXX1001-PXXX9999) Tractors Rubber Tracked
Publication Date: 2025
Number of Pages: 1129 Pages
TABLE OF CONTENT PAG 00-TOC Tech Spec Notes Ref
GENERAL INFORMATION PAG 01-000-TOC Tech Spec Notes Ref
FILTERS GUIDE PAG 01-0001
BELTS GUIDE PAG 01-0002
SENSORS GUIDE PAG 01-0003
SENSORS GUIDE PAG 01-0004
ENGINE ACW3398750 98 AWF-HLA PAG 02-000-TOC Tech Spec Notes Ref
ENGINE ASSEMBLIES - ENGINE SERIAL NUMBER RANGE JLD302200-JLD525201 PAG 02-0001
CYLINDER BLOCK - HYDRAULIC LASH ADJUSTMENT PAG 02-0002
TIMING GEARS & HOUSING PAG 02-0003
FLYWHEEL & HOUSING PAG 02-0004
CRANKSHAFT & PISTONS PAG 02-0005
CAMSHAFT & VALVE MECHANISM - HYDRAULIC LASH ADJUSTMENT PAG 02-0006
CYLINDER HEAD PAG 02-0007
VALVE ROCKER COVER PAG 02-0008
INTAKE MANIFOLD PAG 02-0009
EXHAUST MANIFOLD - M12 TURBO MOUNTING STUD BOLTS PAG 02-0010
HIGH PRESSURE TURBOCHARGER - M12 TURBO MOUNTING STUD BOLTS PAG 02-0011
LOW PRESSURE TURBOCHARGER & ICAC - M12 TURBO MOUNTING STUD BOLTS PAG 02-0012
EXHAUST GAS RECIRCULATION (EGR) PAG 02-0013
OIL PUMP & SUMP PAG 02-0014
OIL COOLER & OIL FILTER PAG 02-0015
CLOSED CRANKCASE VENTILATION (CCV) PAG 02-0016
COOLANT PIPING PAG 02-0017
COOLANT PUMP & THERMOSTAT PAG 02-0018
FUEL INJECTION SYSTEM PAG 02-0019
FUEL FILTERS PAG 02-0020
ELECTRONIC ENGINE MANAGEMENT PAG 02-0021
FAN DRIVE PAG 02-0022
EXHAUST AFTER-TREATMENT PAG 02-0023
ENGINE OVERHAUL PARTS PAG 02-0024
SPECIAL OVERHAUL PARTS PAG 02-0025
ENGINE ACX2447020 98 LFVC PAG 03-000-TOC Tech Spec Notes Ref
INSTRUCTIONS - PARTS LISTS AND ILLUSTRATIONS PAG 03-0001
ENGINE IDENTIFICATION PAG 03-0002
ENGINE ASSEMBLIES PAG 03-0003
CYLINDER BLOCK - HYDRAULIC LASH ADJUSTMENT PAG 03-0004
CYLINDER BLOCK - SERVICE PARTS PAG 03-0005
TIMING GEARS & HOUSING PAG 03-0006
TIMING GEARS & HOUSING - SERVICE PARTS PAG 03-0007
FLYWHEEL & HOUSING PAG 03-0008
CRANKSHAFT & PISTONS PAG 03-0009
CAMSHAFT & VALVE MECHANISM - HYDRAULIC LASH ADJUSTMENT PAG 03-0010
VALVE MECHANISM - SERVICE PARTS PAG 03-0011
VALVE MECHANISM - SERVICE PARTS PAG 03-0012
CYLINDER HEAD PAG 03-0013
CYLINDER HEAD - SERVICE PARTS PAG 03-0014
CYLINDER HEAD - SERVICE PARTS PAG 03-0015
VALVE ROCKER COVER PAG 03-0016
INTAKE MANIFOLD PAG 03-0017
EXHAUST MANIFOLD PAG 03-0018
HIGH PRESSURE TURBOCHARGER PAG 03-0019
HIGH PRESSURE TURBOCHARGER - SERVICE PARTS PAG 03-0020
LOW PRESSURE TURBOCHARGER PAG 03-0021
INTERSTAGE CHARGE AIR COOLER (ICAC) PAG 03-0022
EXHAUST GAS RECIRCULATION (EGR) PAG 03-0023
OIL PUMP & SUMP PAG 03-0024
OIL PUMP - SERVICE PARTS PAG 03-0025
OIL COOLER & OIL FILTER PAG 03-0026
CLOSED CRANKCASE VENTILATION (CCV) PAG 03-0027
CRANKCASE VENTILATION - SERVICE PARTS PAG 03-0028
COOLANT PUMP & THERMOSTAT PAG 03-0029
COOLANT PUMP - SERVICE PARTS PAG 03-0030
FUEL INJECTION SYSTEM PAG 03-0031
FUEL INJECTION PUMP - SERVICE PARTS PAG 03-0032
FUEL FILTERS PAG 03-0033
FUEL FILTERS - SERVICE PARTS PAG 03-0034
ELECTRONIC ENGINE MANAGEMENT PAG 03-0035
FAN DRIVE PAG 03-0036
FAN DRIVE - SERVICE PARTS PAG 03-0037
EXHAUST AFTER-TREATMENT - SERVICE PARTS PAG 03-0038
ENGINE GASKET KITS PAG 03-0039
ENGINE OVERHAUL PARTS PAG 03-0040
SPECIAL OVERHAUL PARTS PAG 03-0041
ENGINE PAG 04-000-TOC Tech Spec Notes Ref
ENGINE ASSEMBLIES PAG 04-0001
CYLINDER HEAD PAG 04-0002
TIMING GEARS & HOUSING - FROM ENGINE S_N E54640 PAG 04-0003
COOLANT PIPING PAG 04-0004
ENGINE INSTALLATION PAG 05-000-TOC Tech Spec Notes Ref
ENGINE BRACKET PAG 05-0001
ENGINE - ACCESSORIES PAG 05-0002
ENGINE - GRID HEATER PAG 05-0003
ENGINE - OIL MAINTENANCE PAG 05-0004
ENGINE BLOCK HEATER - 120V PAG 05-0005
ENGINE BLOCK HEATER - 240V PAG 05-0006
HYDRAULIC FAN PAG 05-0007
HYDRAULIC FAN - SUPPORT PAG 05-0008
HYDRAULIC FAN - LINES PAG 05-0009
COOLING - AIR HOSE INSTALLATION PAG 05-0010
COOLING - RADIATOR PAG 05-0011
COOLING - RADIATOR (COMPONENTS) PAG 05-0012
COOLING - EXPANSION TANK & HOSES PAG 05-0013
COOLING - EXPANSION TANK PAG 05-0014
COOLING - EXPANSION TANK PAG 05-0015
COOLING - HYDRAULIC LINES PAG 05-0016
ENGINE AIR FILTER PAG 05-0017
EXHAUST - PLUGS PAG 05-0018
EXHAUST PAG 05-0019
EXHAUST PAG 05-0020
EXHAUST - SCR (SELECTIVE CATALYST REDUCTION) PAG 05-0021
EXHAUST PAG 05-0022
EXHAUST PAG 05-0023
EXHAUST - DEF TANK PAG 05-0024
EXHAUST - DEF LINES PAG 05-0025
EXHAUST - DEF LINES PAG 05-0026
EXHAUST - DEF LINES PAG 05-0027
EXHAUST - DEF LINES PAG 05-0028
FUEL - TANK PAG 05-0029
FUEL - TANK PAG 05-0030
FUEL - ADDITIONAL TANK PAG 05-0031
FUEL - LINES PAG 05-0032
FUEL - LINES PAG 05-0033
STEERING SYSTEM PAG 06-000-TOC Tech Spec Notes Ref
STEERING WHEEL & COLUMN PAG 06-0001
STEERING COLUMN (COMPONENTS) PAG 06-0002
STEERING PUMP & LINES PAG 06-0003
STEERING PUMP (COMPONENTS) PAG 06-0004
STEERING MOTOR (COMPONENTS) PAG 06-0005
STEERING GEAR PAG 06-0006
DRIVETRAIN SYSTEM PAG 07-000-TOC Tech Spec Notes Ref
DRIVELINE - VOITH COUPLER PAG 07-0001
DRIVELINE PAG 07-0002
TRANSMISSION OIL HEATER - 120V PAG 07-0003
TRANSMISSION OIL HEATER - 240V PAG 07-0004
ADJUSTING DEVICE - GOVERNOR PAG 07-0005
ADJUSTING DEVICE - LEVER PAG 07-0006
BEVEL DRIVE PAG 07-0007
BRAKE (COMPONENTS) - REAR AXLE PAG 07-0008
BRAKE (COMPONENTS) - REAR AXLE PAG 07-0009
BRAKE HYDRAULICS PAG 07-0010
GEARBOX - ADJUSTING DEVICE PAG 07-0011
CHANNEL PLATE - VALVES PAG 07-0012
FILTER PAG 07-0013
TRANSMISSION PAG 07-0014
TRANSMISSION - PIVOT PAG 07-0015
GEAR PUMP PAG 07-0016
TRANSMISSION HOUSING PAG 07-0017
HANDBRAKE PAG 07-0018
FINAL DRIVE - RIGHT SIDE PAG 07-0019
FINAL DRIVE - LEFT SIDE PAG 07-0020
VALVE BLOCK - PRESSURE FILTER PAG 07-0021
OIL COOLER PAG 07-0022
PIPES - DIFFERENTIAL LOCK MECHANISM PAG 07-0023
TRANSMISSION - PIPE LINES PAG 07-0024
PUMP DRIVE PAG 07-0025
PUMP DRIVE PAG 07-0026
REAR AXLE COVER PAG 07-0027
REAR AXLE DIFFERENTIAL PAG 07-0028
REAR AXLE DIFFERENTIAL PAG 07-0029
REAR AXLE DIFFERENTIAL PAG 07-0030
TRANSMITTER - TRANSMISSION PAG 07-0031
VALVE SYST.COMFORT PAG 07-0032
VALVE BLOCK (COMPONENTS) - COMFORT SYSTEM PAG 07-0033
WHEEL SHAFT HOUSING PAG 07-0034
TRANSMISSION - 72-88_ PAG 07-0035
TRANSMISSION - 72-120_ PAG 07-0036
BRAKE SYSTEM PAG 08-000-TOC Tech Spec Notes Ref
BRAKE PEDAL PAG 08-0001
BRAKE VALVE & ACCUMULATOR PAG 08-0002
BRAKE VALVE (COMPONENTS) PAG 08-0003
BRAKE LINES PAG 08-0004
BRAKE BLEEDERS - LINES PAG 08-0005
BRAKE LINES - BRAKE BLEEDERS PAG 08-0006
STEERING VALVE & LINES PAG 08-0007
PARKING BRAKE LEVER - STANDARD PAG 08-0008
PARKING BRAKE PAG 08-0009
PARKING BRAKE LEVER - MODULATING PAG 08-0010
PARKING BRAKE LINES - MODULATING PAG 08-0011
AIR BRAKE - BRAKE VALVE PAG 08-0012
AIR BRAKE - LINES PAG 08-0013
AIR BRAKE - LINES PAG 08-0014
AIR BRAKE - LINES PAG 08-0015
AIR TRAILER BRAKE PAG 08-0016
AIR TRAILER BRAKE PAG 08-0017
HYDRAULIC TRAILER BRAKE - VALVE & LINES PAG 08-0018
HYDRAULIC TRAILER BRAKE - VALVE & LINES PAG 08-0019
HYDRAULIC TRAILER BRAKE - VALVE & LINES PAG 08-0020
HYDRAULIC TRAILER BRAKE - VALVE & LINES PAG 08-0021
HYDRAULIC TRAILER BRAKE - VALVE & LINES PAG 08-0022
HYDRAULIC TRAILER BRAKE - LINES PAG 08-0023
HYDRAULIC TRAILER BRAKE - LINES PAG 08-0024
COMPRESSED AIR SYSTEM PAG 09-000-TOC Tech Spec Notes Ref
WITHOUT AIR COMPRESSOR - DEFLECTOR PAG 09-0001
AIR COMPRESSOR & LINES PAG 09-0002
AIR TANK & LINES PAG 09-0003
AIR TANK & LINES PAG 09-0004
AIR TANK & LINES PAG 09-0005
HYDRAULIC SYSTEM PAG 10-000-TOC Tech Spec Notes Ref
DRAIN (ECOLOGY) PAG 10-0001
HYDRAULIC TANK PAG 10-0002
HYDRAULIC TANK PAG 10-0003
HYDRAULIC TANK - SINGLE FILTER PAG 10-0004
HYDRAULIC TANK - DUAL FILTER PAG 10-0005
HYDRAULIC TANK - WITHOUT CASE DRAIN PAG 10-0006
HYDRAULIC LINES PAG 10-0007
HYDRAULIC LINES PAG 10-0008
GEAR PUMP - SINGLE PUMP PAG 10-0009
GEAR PUMP - DUAL PUMP PAG 10-0010
HYDRAULIC PUMP & LINES - SINGLE PUMP PAG 10-0011
HYDRAULIC PUMP & LINES - SINGLE PUMP PAG 10-0012
HYDRAULIC PUMP & LINES - DUAL PUMP PAG 10-0013
HYDRAULIC PUMP & LINES - DUAL PUMP PAG 10-0014
HYDRAULIC PUMP & LINES - DUAL PUMP PAG 10-0015
HYDRAULIC PUMP & LINES - DUAL PUMP PAG 10-0016
HYDRAULIC PUMP & LINES - DUAL PUMP PAG 10-0017
CASE DRAIN - SINGLE PAG 10-0018
CASE DRAIN - SINGLE PAG 10-0019
CASE DRAIN - DOUBLE PAG 10-0020
CASE DRAIN - DOUBLE PAG 10-0021
LOW PRESSURE RETURN - SINGLE PUMP PAG 10-0022
LOW PRESSURE RETURN - SINGLE PUMP PAG 10-0023
LOW PRESSURE RETURN - SINGLE PUMP PAG 10-0024
LOW PRESSURE RETURN - SINGLE PUMP PAG 10-0025
LOW PRESSURE RETURN - DUAL PUMP PAG 10-0026
LOW PRESSURE RETURN - DUAL PUMP PAG 10-0027
LOW PRESSURE RETURN - DUAL PUMP PAG 10-0028
LOW PRESSURE RETURN - DUAL PUMP PAG 10-0029
LOW PRESSURE RETURN - SINGLE & DUAL PUMP PAG 10-0030
LOW PRESSURE RETURN - SINGLE & DUAL PUMP PAG 10-0031
WITHOUT POWER BEYOND - SINGLE PUMP PAG 10-0032
POWER BEYOND - SINGLE PUMP PAG 10-0033
POWER BEYOND - DUAL PUMP PAG 10-0034
POWER BEYOND - ¾ FEMALE PRESSURE WITH ¼ FEMALE LOAD PAG 10-0035
POWER BEYOND - ¾ FEMALE PRESSURE WITH 3_8 FEMALE LOAD SENSE PAG 10-0036
POWER BEYOND - SINGLE & DUAL PUMP PAG 10-0037
1_2_ COUPLING SLEEVE - 4 DISTRIBUTORS PAG 10-0038
1_2_ COUPLING SLEEVE - 6 DISTRIBUTORS PAG 10-0039
1_2_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0040
1_2_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0041
1_2_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0042
1_2_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0043
3_4_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0044
3_4_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0045
3_4_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0046
3_4_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0047
3_4_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0048
3_4_ COUPLING SLEEVE - (COMPONENTS) PAG 10-0049
3_4_ FFC COUPLER - (COMPONENTS) PAG 10-0050
3_4_ FFC COUPLER - (COMPONENTS) PAG 10-0051
3_4_ FFC COUPLER - (COMPONENTS) PAG 10-0052
3_4_ FFC COUPLER - (COMPONENTS) PAG 10-0053
3_4_ FFC COUPLER - (COMPONENTS) PAG 10-0054
3_4_ FFC COUPLER - (COMPONENTS) PAG 10-0055
DISTRIBUTOR - COVER PAG 10-0056
AUXILIARY VALVE PAG 10-0057
AUXILIARY VALVE PAG 10-0058
AUXILIARY VALVE - 4 DISTRIBUTORS PAG 10-0059
AUXILIARY VALVE - 4 DISTRIBUTORS PAG 10-0060
AUXILIARY VALVE - 6 DISTRIBUTORS PAG 10-0061
AUXILIARY VALVE - 6 DISTRIBUTORS PAG 10-0062
AUXILIARY VALVE - 7 DISTRIBUTORS PAG 10-0063
AUXILIARY VALVE - 8 DISTRIBUTORS PAG 10-0064
DISTRIBUTOR (COMPONENTS) PAG 10-0065
DISTRIBUTOR (COMPONENTS) - END PLATE PAG 10-0066
ELECTRICAL SYSTEM PAG 11-000-TOC Tech Spec Notes Ref
LIGHTING - ROAD LIGHTS PAG 11-0001
LIGHTING - ROAD LIGHTS PAG 11-0002
LIGHTING - ROAD LIGHTS PAG 11-0003
LIGHTING - SIDE MARKER LIGHT PAG 11-0004
LIGHTING - WIDE LOAD WARNING PAG 11-0005
LIGHTING - WIDE LOAD WARNING PAG 11-0006
LIGHTING - SIGNAL LIGHT PAG 11-0007
LIGHTING - ROOF PAG 11-0008
LIGHTING - ROOF PAG 11-0009
LIGHTING - ROTARY BEACON PAG 11-0010
LIGHTING - ROTARY BEACON PAG 11-0011
LIGHTING - REFLECTORS PAG 11-0012
LIGHTING - WARNING PLATE PAG 11-0013
LIGHTING - SAFETY TRIANGLE PAG 11-0014
WORK LIGHTS PAG 11-0015
WORK LIGHTS PAG 11-0016
WORK LIGHTS PAG 11-0017
BATTERIES & CABLES PAG 11-0018
BATTERIES & CABLES PAG 11-0019
WIRING HARNESS - EXHAUST PAG 11-0020
WIRING HARNESS - EXHAUST PAG 11-0021
WIRING HARNESS - CHASSIS PAG 11-0022
WIRING HARNESS - CHASSIS PAG 11-0023
WIRING HARNESS - CHASSIS PAG 11-0024
WIRING HARNESS - CHASSIS PAG 11-0025
WIRING HARNESS - CHASSIS PAG 11-0026
WIRING HARNESS - CHASSIS PAG 11-0027
WIRING HARNESS - CHASSIS PAG 11-0028
WIRING HARNESS - CHASSIS PAG 11-0029
WIRING HARNESS - CHASSIS PAG 11-0030
WIRING HARNESS - CHASSIS PAG 11-0031
WIRING HARNESS - CHASSIS PAG 11-0032
WIRING HARNESS - CHASSIS PAG 11-0033
WIRING HARNESS - CHASSIS PAG 11-0034
WIRING HARNESS - CHASSIS PAG 11-0035
WIRING HARNESS - CHASSIS PAG 11-0036
WIRING HARNESS - CHASSIS PAG 11-0037
WIRING HARNESS - CHASSIS PAG 11-0038
WIRING HARNESS - CHASSIS PAG 11-0039
WIRING HARNESS - CHASSIS PAG 11-0040
WIRING HARNESS - FRONT CONSOLE PAG 11-0041
WIRING HARNESS - FRONT CONSOLE PAG 11-0042
WIRING HARNESS - CAB PAG 11-0043
WIRING HARNESS - CAB PAG 11-0044
WIRING HARNESS - ROOF PAG 11-0045
WIRING HARNESS - ROOF PAG 11-0046
WIRING HARNESS - ROOF PAG 11-0047
WIRING HARNESS - ROOF PAG 11-0048
WIRING HARNESS - TRAILER PAG 11-0049
WIRING HARNESS - TRAILER PAG 11-0050
WIRING HARNESS - TRAILER PAG 11-0051
WIRING HARNESS - TRAILER PAG 11-0052
WIRING HARNESS - REAR POWER OUTLET PAG 11-0053
WIRING HARNESS - REAR POWER OUTLET PAG 11-0054
WIRING HARNESS - REAR POWER OUTLET PAG 11-0055
FUSE PANEL PAG 11-0056
FUSE PANEL - FUSES & RELAYS PAG 11-0057
ARMREST PAG 11-0058
ARMREST (COMPONENTS) PAG 11-0059
ARMREST PAG 11-0060
ARMREST (COMPONENTS) PAG 11-0061
ARMREST PAG 11-0062
ARMREST - MONITORING DISPLAY PAG 11-0063
NT01 - MOUNTING BRACKET PAG 11-0064
NT01 KIT PAG 11-0065
MOUNTING BRACKET PAG 11-0066
MONITOR MOUNTING - VERTICAL & HORIZONTAL PAG 11-0067
CAB PAG 12-000-TOC Tech Spec Notes Ref
CAB SUPPORT - BASIC PAG 12-0001
CAB SUPPORT - DELUXE PAG 12-0002
CAB FRAME PAG 12-0003
CAB GLASS - WINDSHIELD & RIGHT SIDE PAG 12-0004
CAB GLASS - REAR WINDOW PAG 12-0005
DOOR PAG 12-0006
ROOF - OUTER PAG 12-0007
ROOF - INNER PAG 12-0008
ROOF - INNER PAG 12-0009
WASHER & WIPER PAG 12-0010
WASHER & WIPER PAG 12-0011
WASHER & WIPER PAG 12-0012
TRIM - ROOF PAG 12-0013
TRIM - RIGHT SIDE PAG 12-0014
TRIM - LEFT SIDE PAG 12-0015
TRIM - STORAGE BOX PAG 12-0016
TRIM - INSTRUMENT PANEL PAG 12-0017
TRIM - STEERING COLUMN PAG 12-0018
INSULATION PAG 12-0019
FOOTREST PAG 12-0020
OPERATOR SEAT - BASIC PAG 12-0021
OPERATOR SEAT (COMPONENTS) - BASIC PAG 12-0022
OPERATOR SEAT (COMPONENTS) - BASIC PAG 12-0023
OPERATOR SEAT - MID SPEC PAG 12-0024
OPERATOR SEAT (COMPONENTS) - MID SPEC PAG 12-0025
OPERATOR SEAT (COMPONENTS) - MID SPEC PAG 12-0026
OPERATOR SEAT - DELUXE PAG 12-0027
OPERATOR SEAT (COMPONENTS) - DELUXE PAG 12-0028
OPERATOR SEAT (COMPONENTS) - DELUXE PAG 12-0029
PEDALS PAG 12-0030
RADIO PAG 12-0031
RADIO - REMOTE CONTROL PAG 12-0032
RADIO - REMOTE CONTROL PAG 12-0033
RADIO - WIRING HARNESS PAG 12-0034
RADIO - WIRING HARNESS PAG 12-0035
RADIO - SPEAKERS PAG 12-0036
RADIO - SPEAKERS PAG 12-0037
REAR VIEW MIRROR PAG 12-0038
REAR VIEW MIRROR PAG 12-0039
FENDERS PAG 12-0040
SUN VISOR PAG 12-0041
ACCESSORIES PAG 12-0042
LICENSE PLATE HOLDER - WEIGHT CARRIER, FRONT PAG 12-0043
LICENSE PLATE HOLDER - FRONT PAG 12-0044
AIR CONDITIONING AND HEATING SYSTEM PAG 13-000-TOC Tech Spec Notes Ref
CONDENSER PAG 13-0001
CONDENSER (COMPONENTS) PAG 13-0002
COMPRESSOR PAG 13-0003
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) - FILTERS PAG 13-0004
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) PAG 13-0005
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) - KIT PAG 13-0006
HVAC SYSTEM (HEATING, VENTILATION & AIR CONDITIONING) - VENTILATION PAG 13-0007
REFRIGERANT LINES PAG 13-0008
CHASSIS PAG 14-000-TOC Tech Spec Notes Ref
CHASSIS PAG 14-0001
HOOD - LATCH PAG 14-0002
HOOD - LATCH PAG 14-0003
HOOD - FRONT GRILLE PAG 14-0004
HOOD - ENGINE HOOD PAG 14-0005
HOOD - SIDE PANELS PAG 14-0006
HOOD - SIDE PANELS PAG 14-0007
HOOD - FRAME PAG 14-0008
FIRE EXTINGUISHER - BRACKET PAG 14-0009
RIGHT SIDE PLATFORM & ROOF HANDRAIL PAG 14-0010
PLATFORM & HANDRAIL PAG 14-0011
ENTRY LADDER - STANDARD PAG 14-0012
ENTRY LADDER - PIVOTING PAG 14-0013
BOTTOM PLATE PAG 14-0014
SUPPORTING STRUCTURE - FUEL TANK PAG 14-0015
SUPPORTING STRUCTURE - FUEL TANK PAG 14-0016
SUPPORTING STRUCTURE - FUEL TANK PAG 14-0017
SUPPORTING STRUCTURE - FUEL TANK PAG 14-0018
GUARDS - TRANSMISSION PAG 14-0019
GUARDS - TRANSMISSION PAG 14-0020
GUARDS - ADDITIONAL FUEL TANK PAG 14-0021
GUARDS - ADDITIONAL FUEL TANK PAG 14-0022
DECALS PAG 15-000-TOC Tech Spec Notes Ref
EMBLEMS PAG 15-0001
SAFETY & WARNING - FUEL PAG 15-0002
SAFETY & WARNING - ENGINE PAG 15-0003
SAFETY & WARNING - ENGINE PAG 15-0004
SAFETY & WARNING - CHASSIS PAG 15-0005
SAFETY & WARNING - CAB PAG 15-0006
SAFETY & WARNING - CAB PAG 15-0007
SAFETY & WARNING - CAB PAG 15-0008
SAFETY & WARNING - HYDRAULIC PAG 15-0009
SAFETY & WARNING - ELECTRICAL PAG 15-0010
SPEED SIGN PAG 15-0011
PLATE PAG 15-0012
PLATE - FALLING-OBJECT PROTECTIVE STRUCTURE (FOPS) PAG 15-0013
TRACK BELT SYSTEM PAG 16-000-TOC Tech Spec Notes Ref
UNDERCARRIAGE SUPPORT PAG 16-0001
UNDERCARRIAGE - SHOCK ABSORBER PAG 16-0002
UNDERCARRIAGE - WIRING HARNESS & GUARDS PAG 16-0003
UNDERCARRIAGE - WIRING HARNESS & GUARDS PAG 16-0004
UNDERCARRIAGE PAG 16-0005
UNDERCARRIAGE PAG 16-0006
TENSION CYLINDER PAG 16-0007
TENSION CYLINDER PAG 16-0008
TENSIONER CHARGE HOSE PAG 16-0009
IDLER WHEEL PAG 16-0010
IDLER WHEEL & WHEEL DRIVE PAG 16-0011
IDLER WHEEL & WHEEL DRIVE PAG 16-0012
IDLER WHEEL & WHEEL DRIVE PAG 16-0013
EJECTOR WIDE PAG 16-0014
MIDWHEEL - BOGIE PAG 16-0015
MIDWHEEL - RUBBER PAG 16-0016
MIDWHEEL - POLY PAG 16-0017
MIDWHEEL - POLY PAG 16-0018
TRACKS PAG 16-0019
TRACKS PAG 16-0020
TRACKS PAG 16-0021
TRACKS PAG 16-0022
TRACKS PAG 16-0023
TRACKS PAG 16-0024
TRACKS PAG 16-0025
TRACKS PAG 16-0026
DEBRIS DEFLECTOR - INNER & OUTER PAG 16-0027
WHEEL CHOCKS PAG 16-0028
IMPLEMENT DRIVE SYSTEM PAG 17-000-TOC Tech Spec Notes Ref
PTO (POWER TAKE-OFF) PAG 17-0001
PTO (POWER TAKE-OFF) - SHIFTING PAG 17-0002
IMPLEMENT LIFT SYSTEM REAR PAG 18-000-TOC Tech Spec Notes Ref
3 POINT HITCH - LIFT ARM PAG 18-0001
3 POINT HITCH - LIFT CYLINDERS PAG 18-0002
3 POINT HITCH - TOP LINK LOCK PAG 18-0003
3 POINT HITCH - TOP LINK PAG 18-0004
3 POINT HITCH - TOP LINK PAG 18-0005
3 POINT HITCH - TOP LINK PAG 18-0006
3 POINT HITCH - LIFT LINKS PAG 18-0007
3 POINT HITCH - LOWER LINKS WITH BALL JOINT PAG 18-0008
3 POINT HITCH - LOWER LINKS WITH HOOK PAG 18-0009
3 POINT HITCH - QUICK HITCH PAG 18-0010
3 POINT HITCH - HITCH SENSITIVITY SYSTEM PAG 18-0011
DRAWBAR HITCH - WITHOUT SLIDER PAG 18-0012
DRAWBAR HITCH - WITH SLIDER PAG 18-0013
DRAWBAR HITCH - PIVOTING PAG 18-0014
DRAWBAR PAG 18-0015
DRAWBAR PAG 18-0016
DRAWBAR - PIN PAG 18-0017
TRAILER HITCH - AUTO LATCH PAG 18-0018
TRAILER HITCH PAG 18-0019
TRAILER HITCH PAG 18-0020
HITCH BALL PAG 18-0021
HITCH BALL - STEERING PAG 18-0022
PRECISION FARMING SYSTEMS PAG 19-000-TOC Tech Spec Notes Ref
GROUND SPEED SENSOR PAG 19-0001
GUIDANCE BRACKET PAG 19-0002
GUIDANCE READY PAG 19-0003
GUIDANCE READY PAG 19-0004
AUTO-GUIDE - RECEIVER PAG 19-0005
AUTO-GUIDE - RECEIVER PAG 19-0006
AUTO-GUIDE - RADIO PAG 19-0007
GYROSCOPE PAG 19-0008
TRIMBLE - RECEIVER PAG 19-0009
TRIMBLE - ANTENNA PAG 19-0010
TRIMBLE - ANTENNA PAG 19-0011
GATEWAY PAG 19-0012
GATEWAY - COMBINED GSM_LTE MODEM PAG 19-0013
GATEWAY - PLUGS PAG 19-0014
ATTACHMENTS PAG 20-000-TOC Tech Spec Notes Ref
TOW CABLE - FRONT PAG 20-0001
TOWING SYSTEM, FRONT PAG 20-0002
WITHOUT FRONT WEIGHTS - PLUGS PAG 20-0003
WEIGHT CARRIER, FRONT - 925LBS (420KG) PAG 20-0004
FRONT WEIGHT - 1785LBS (810KG) PAG 20-0005
FRONT WEIGHTS - 2190LBS (993KG) PAG 20-0006
FRONT WEIGHTS - 2800LBS (1270KG) PAG 20-0007
IDLER WHEEL COUNTERWEIGHT - HARDWARE PAG 20-0008
IDLER WHEEL COUNTERWEIGHT - 1000LBS (454KG) PAG 20-0009
IDLER WHEEL COUNTERWEIGHT - 2000LBS (907KG) PAG 20-0010
IDLER WHEEL COUNTERWEIGHT - 3000LBS (1360KG) PAG 20-0011
IDLER WHEEL COUNTERWEIGHT - 3500LBS (1588KG) PAG 20-0012
ACCESSORIES PAG 21-000-TOC Tech Spec Notes Ref
FIRE EXTINGUISHER KIT PAG 21-0001
ADDITIONAL FUEL TANK KIT PAG 21-0002
ADDITIONAL FUEL TANK KIT PAG 21-0003
FUEL TANK GUARDS KIT PAG 21-0004
HYDRAULIC TRAILER BRAKE KIT PAG 21-0005
CASE DRAIN KIT - DAUL 3_8” FEMALE FLAT FACE COUPLERS PAG 21-0006
HYDRAULIC FILTER (COMPONENTS) - 32 MICRON PAG 21-0007
POWER BEYOND KIT - SINGLE 85CC SINGLE 3_4 FEMALE PRESSURE 3_8 FEMALE LOAD PAG 21-0008
POWER BEYOND KIT - SINGLE 85CC 3_4 FEMALE PRESSURE 1_4 FEMALE LOAD PAG 21-0009
POWER BEYOND KIT - DUAL 85CC 3_4 FEMALE PRESSURE 3_8 FEMALE LOAD PAG 21-0010
POWER BEYOND KIT - DUAL 85CC 3_4 FEMALE PRESSURE 1_4 FEMALE LOAD PAG 21-0011
LOW PRESSURE RETURN KIT - 85CC DUAL 3_4 FEMALE FLAT FACE RETURN PAG 21-0012
LOW PRESSURE RETURN KIT - DUAL 85CC DUAL 3_4 FEMALE FLAT FACE RETURN PAG 21-0013
CONVERSION KIT - DUAL PUMP PAG 21-0014
CONVERSION KIT - DUAL PUMP PAG 21-0015
CONVERSION KIT - DUAL PUMP PAG 21-0016
5_8_ FFC COUPLER KIT PAG 21-0017
CONVERSION KIT - 4 =_ 5 DISTRIBUTORS PAG 21-0018
CONVERSION KIT - 4 =_ 6 DISTRIBUTORS PAG 21-0019
CONVERSION KIT - 5 =_ 6 DISTRIBUTORS PAG 21-0020
LIGHTING KIT - WARNING PLATE PAG 21-0021
EXTRA KEY KIT PAG 21-0022
CAB SUSPENSION KIT PAG 21-0023
SIDE WINDOW WIPER KIT PAG 21-0024
MONITOR MOUNTING KIT PAG 21-0025
PIVOTING ENTRY LADDER KIT PAG 21-0026
UNDERCARRIAGE SUPPORT KIT - ULTRA WIDE PAG 21-0027
AXLE TOOL KIT PAG 21-0028
GUIDE BLOCK KIT PAG 21-0029
RUBBER BELT REPAIR KIT PAG 21-0030
DEBRIS DEFLECTOR KIT PAG 21-0031
DRAWBAR KIT PAG 21-0032
PIN KIT - DRAWBAR PAG 21-0033
GATEWAY KIT PAG 21-0034
GATEWAY KIT PAG 21-0035
NT01 KIT PAG 21-0036
IMPLEMENT CONTROL KIT PAG 21-0037
CAMERA KIT (AGCAM) PAG 21-0038
CAMERA ADAPTER KIT - MOTEC PAG 21-0039
MODEM KIT PAG 21-0040
MODEM SATELLITE KIT PAG 21-0041
MODEM READY BRACKET, 4G DIGIFARM KIT PAG 21-0042
TRIMBLE KIT - 400MHZ PAG 21-0043
TRIMBLE KIT - 900MHZ PAG 21-0044
LEGACY GUIDANCE KIT PAG 21-0045
LEGACY GUIDANCE KIT PAG 21-0046
MONITOR MOUNTING - TOP PAG 21-0047
MONITOR MOUNTING - BOTTOM PAG 21-0048
Brand: Fendt
EXHAUST PAG 05-0019
EXHAUST PAG 05-0020
EXHAUST PAG 05-0022
EXHAUST PAG 05-0023
FILTER PAG 07-0013
ARMREST PAG 11-0058
ARMREST PAG 11-0060
ARMREST PAG 11-0062
DOOR PAG 12-0006
PEDALS PAG 12-0030
RADIO PAG 12-0031
FENDERS PAG 12-0040
CHASSIS PAG 14-0001
EMBLEMS PAG 15-0001
PLATE PAG 15-0012
TRACKS PAG 16-0019
TRACKS PAG 16-0020
TRACKS PAG 16-0021
TRACKS PAG 16-0022
TRACKS PAG 16-0023
TRACKS PAG 16-0024
TRACKS PAG 16-0025
TRACKS PAG 16-0026
DRAWBAR PAG 18-0015
DRAWBAR PAG 18-0016
GATEWAY PAG 19-0012
