Fendt Tractor GT 395GT Parts Catalog F395000 09.2020
Brand: Fendt
Model: Fendt GT 395GT
Serial Number: 395/00101-99999
Publication Date: 09.2020
Number of Pages: 1188 Pages
V-Belt
Speed Control
Engine Stop
Fuel Lines
Suction Pipe
Air Filter
Exhaust Manifold
Exhaust Upright
Cold Starting Aid
Crankcase
Interm. Gear Wheel
Front Cover
Tension Roller
Cylinder
Piston
Camshaft
Valve Drive
Oil Pan
Oil Pump
Lubric. Oil Cooler
Oil Filter Mounting
Leak Oil Line
Supply Lines
Fuel Pump
Injector Valve
Cooling Air Blower
Fan Panelling
Engine Overhaul Parts
Front Axle Bracket
Axle Carrier
Axle Bridge
Drive
Lock Differential
Joint Housing
Double Joint
Planetary Drive
Joint Shaft
Additional Weight
Hitch
Tie Rod
Steering Cylinder
Pipes Steering Cyl.
Balance Truss
Steering Wheel
Steering Assy
Differential Lock
Hand-Brake
Hand Brake Actuating
Foot Brake
Foot Brake Actuating
Brake Master Cylinder
Brake Hydraulics
Caliper
Clutch Housing
Gearbox-Housing
Oil Level Indicator
Synchronizer Unit
Countershaft
Shifting
Overdrive
Mlt.Step Gear Change
Side Gear Shifting
Shift Lever
Gearlock
Dual Clutch
Clutch Actuating
Clutch Hydraulic
Final Drive
P.T.O. Actuating
Engine P.T.O.
Front P.T.O.
Front P.T.O. Operat.
Housing Front P.T.O.
Front P.T.O. Gear
Front P.T.O.Valve Un
Front P.T.O. G.Shift
Front Wheel Drive
Front Wheel Drive Constant
Constant Overdrive
Engine P.T.O. Const.
Bevel Drive
Gear Box Lubrication
Valve Syst.Comfort
Tubes System Comfort
Compressed Air System
Compressor Installat
Defrosting Pump
Pressure Pipe
Air Tank
Manometer
Trailer Valve
Coupler Head
Air Brake Single
Pump Installation
Pipes Basic Circuit
Pipes Hydr. Steering
Pipes Aux.Contr.Auto
Pipes For Top Valve
Pipes W O Top Valve
Pipes Hd.Trail.Brake
Pipes-W O H.Tr.Brake
Trailer Brake Valve
Pipes Power-Lift 2.C
Pressure Regulator
Pipes W O Power-L.2c
Valve Installation
Joystick
Single Valve Control
Valve Supplement
Valve Protection
Hydr.Conn. S.A. Rear
Hydr.Conn. D.A. Rear
Returflow Rear
Hydr.Conn. S.A. Mid.
Hydr.Conn. D.A. Mid.
Returnflow Middle
Coupling Bracket
Alternator Assy
Headlight
Lights And Horn
Flashing Side Light
Control Console
Relais Mounting
Timer
Cable Loom
Rep.Set Cable Loom
Starter Motor
Starter Blocking
Socket F.Trail.Light
Board
Socket
Work Lamp
Additional Lighting
Winter-Serv.Lighting
Lighting
Socket F. Implements
Signal Light
Display
Transmitter
Board Computer
Comfort System
Cabin Frame
Steps Handle
Roof
Pane
Roof Hatch
Doors
Front Window
Side Window
Rear Window
Folding Window
Floor Covering
Coating
Roof Panelling
Interior Cab. Outfit
Built-In Case
Heating Device
Heating, Ventilation
Heater
Hose Line
Electrical Equipment
Aeration
Rear View Mirror
Sun Visor
Windshield Wiper
Windscreen Wash-Inst
Interior Lighting
Radio Installation Kit
Cover Plate For Roof
Compressor Install.
Compressor
Tubes F.Refrig.Fluid
Closing Cap
Mounting Parts
Evaporator
Condenser
Cable Looms
Body
Operator Seat
Seat Suspension
Shift Gate
Bellows
Spring Assy
Seat Spring Assy
Security Belt
Tool Box
Tool Set
Trailer Hitch
Remote Control
Adjustable Drawbar
Piton Fix
Base Frame
Drawbar And Hitch
Cap
Cladding
Entry Left
Entry Right
Base For Frame
Labeling
Base
Extension
Spring Susp. Assy
Silencing Box
Absorber Mat Set
Mudguard Seat
Handle
Front Disc Wheels
Adjust. Front Wheels
Adjustab.Rear Wheels
Mud Guards Adjustab.
Fenders
Mudguard Enlargement
Track Adjustment
Intermediate Pieces
Implement Lift System Front
Pipelines
Diaphrag.Accumulator
Manometer Screwing
Top Link
Bottom Link
Front Power Lift
Intermediate Piece
Front Weight Carrier
Power Lift
Oil Tank
Control Part
Control Valve
Eltr.Cont.Power Lift
Electronic Box
El.Hd.Remote Control
Lift Arms
Support
Hydr. Upper Link
Link Holder
Front Rear Loaders
Mounting Frame
Hoist 3
Hoist 3s
Lift Cylinder
Kick-Out Device
Magnet
Latching
Piping Lift Arm
Parallelogr.Mounting
Fast Coupl.Frame
Piping Parallelogr.3
Piping Parallelogr3s
Spill-Valve
Multi-Coupling
Hyd.Circuit 3 Cat.3
Hyd.Circ. 3 Cat 3s
Earth Scoop
Heavy Goods Bucket
Universal Scoop
Bulk Scoop
Manure Fork
Wheel Wedge Mounting
Warning System
Brake Lever Support
Technical Documents
Brand: Fendt
V-Belt
Speed Control
Engine Stop
Fuel Lines
Suction Pipe
Air Filter
Exhaust Manifold
Exhaust Upright
Cold Starting Aid
Crankcase
Interm. Gear Wheel
Front Cover
Tension Roller
Cylinder
Piston
Camshaft
Valve Drive
Oil Pan
Oil Pump
Lubric. Oil Cooler
Oil Filter Mounting
Leak Oil Line
Supply Lines
Fuel Pump
Injector Valve
Cooling Air Blower
Fan Panelling
Front Axle Bracket
Axle Carrier
Axle Bridge
Drive
Lock Differential
Joint Housing
Double Joint
Planetary Drive
Joint Shaft
Additional Weight
Hitch
Tie Rod
Steering Cylinder
Pipes Steering Cyl.
Balance Truss
Steering Wheel
Steering Assy
Differential Lock
Hand-Brake
Foot Brake
Brake Hydraulics
Caliper
Clutch Housing
Gearbox-Housing
Oil Level Indicator
Synchronizer Unit
Countershaft
Shifting
Overdrive
Side Gear Shifting
Shift Lever
Gearlock
Dual Clutch
Clutch Actuating
Clutch Hydraulic
Final Drive
P.T.O. Actuating
Engine P.T.O.
Front P.T.O.
Front P.T.O. Gear
Front Wheel Drive
Constant Overdrive
Bevel Drive
Valve Syst.Comfort
Defrosting Pump
Pressure Pipe
Air Tank
Manometer
Trailer Valve
Coupler Head
Air Brake Single
Pump Installation
Pipes Basic Circuit
Pipes For Top Valve
Pipes W O Top Valve
Trailer Brake Valve
Pressure Regulator
Valve Installation
Joystick
Valve Supplement
Valve Protection
Returflow Rear
Returnflow Middle
Coupling Bracket
Alternator Assy
Headlight
Lights And Horn
Flashing Side Light
Control Console
Relais Mounting
Timer
Cable Loom
Rep.Set Cable Loom
Starter Motor
Starter Blocking
Board
Socket
Work Lamp
Additional Lighting
Lighting
Signal Light
Display
Transmitter
Board Computer
Comfort System
Cabin Frame
Steps Handle
Roof
Pane
Roof Hatch
Doors
Front Window
Side Window
Rear Window
Folding Window
Floor Covering
Coating
Roof Panelling
Built-In Case
Heating Device
Heater
Hose Line
Aeration
Rear View Mirror
Sun Visor
Windshield Wiper
Interior Lighting
Compressor Install.
Compressor
Closing Cap
Mounting Parts
Evaporator
Condenser
Cable Looms
Body
Operator Seat
Seat Suspension
Shift Gate
Bellows
Spring Assy
Seat Spring Assy
Security Belt
Tool Box
Tool Set
Trailer Hitch
Remote Control
Adjustable Drawbar
Piton Fix
Base Frame
Drawbar And Hitch
Cap
Cladding
Entry Left
Entry Right
Base For Frame
Labeling
Base
Extension
Spring Susp. Assy
Silencing Box
Absorber Mat Set
Mudguard Seat
Handle
Front Disc Wheels
Fenders
Track Adjustment
Intermediate Pieces
Pipelines
Manometer Screwing
Top Link
Bottom Link
Front Power Lift
Intermediate Piece
Power Lift
Oil Tank
Control Part
Control Valve
Electronic Box
Lift Arms
Support
Hydr. Upper Link
Link Holder
Front Rear Loaders
Mounting Frame
Hoist 3
Hoist 3s
Lift Cylinder
Kick-Out Device
Magnet
Latching
Piping Lift Arm
Fast Coupl.Frame
Spill-Valve
Multi-Coupling
Hyd.Circuit 3 Cat.3
Hyd.Circ. 3 Cat 3s
Earth Scoop
Heavy Goods Bucket
Universal Scoop
Bulk Scoop
Manure Fork
Warning System
Brake Lever Support
Technical Documents
