Fendt Tractor GT 380GT Parts Catalog F380000 09.2020
Brand: Fendt
Model: Fendt GT 380GT
Serial Number: 380/00001-99999
Publication Date: 09.2020
Number of Pages: 1747 Pages
V-Belt
Speed Control
Engine Stop
Fuel System
Shrink Hose
Air Filter
Pre-Cleaner
Exhaust To Bottom
Exhaust Upright
Cold Starting Aid
Crankcase
Front Cover
Breather Pipe
Tension Roller
Cylinder
Mass Balancer
Piston
Camshaft
Valve Drive
Oil Pan
Oil Pump
Lubric. Oil Cooler
Oil Filter Mounting
Supply Lines
Leak Oil Line
Fuel Pump
Injector Valve
Cooling Air Blower
Fan Panelling
Vibration Damper
Engine Overhaul Parts
Front Axle Bracket
Axle Carrier
Axle Body
Front Wheel Suspens.
Axle Bridge
Drive
Lock Differential
Joint Housing
Double Joint
Planetary Drive
Joint Shaft
Additional Weight
Tie Rod
Steering Cylinder
Pipes Steering Cyl.
Balance Truss
Steering Wheel
Steering Assy
Differential Lock
Hand-Brake
Brake
Foot Brake Actuating
Brake Master Cylinder
Brake Hydraulics
Hydraulic Brake
Caliper
Clutch Housing
Gearbox-Housing
Oil Level Indicator
Change-Speed Gearbox
Overdrive
Shifting
Mlt.Step Gear Change
Side Gear Shifting
Shift Lever
Gearlock
Clutch
Clutch Actuating
Clutch Hydraulic
Final Drive
P.T.O. Actuating
Engine P.T.O.
Front P.T.O.
Actuator
P.T.O. F. Implements
Front P.T.O. Gear
Front P.T.O. Operat.
Front Wheel Drive
Front Wheel Drive Constant
Constant Overdrive
Engine P.T.O. Const.
P.T.O. Indep. Const.
Bevel Drive
Compressed Air System
Compressor Installat
Defrosting Pump
Air Tank
Manometer
Trailer Valve
Air Brake Single
Pump Installation
Pipes Basic Circuit
Pipes Aux.Contr.Auto
Pipes For Top Valve
Pipes W O Top Valve
Pipes Hd.Trail.Brake
Pipes Conn.1st Circ.
Pipes Conn.2nd Circ.
Valve Installation
Joystick
Valve Supplement
Valve Protection
Hydr.Conn. S.A. Rear
Hydr.Conn. D.A. Rear
Returflow Rear
Hydr.Conn. S.A. Mid.
Hydr.Conn. D.A. Mid.
Returnflow Middle
Hydr.Conn. S.A.Front
Coupling Bracket
Screw Coupling
Alternator Assy
Headlight
Lights And Horn
Blinker Lamp
Dashboard
Timer
Cable Looms
Cable Loom
Rep.Set Cable Loom
Wiring And Fuses
Starter Motor
Starter Blocking
Socket F.Trail.Light
Socket F. Implements
Cigar Lighter
Work Lamp
Additional Lighting
Winter-Serv.Lighting
Lighting
Signal Light
Implement Lighting
Display
Transmitter
Board Computer
Support Leg
Hydr. Operation Rear
Cabin Frame
Cabin Roof High
Cabin Roof Low
Roof
Pane
Roof Hatch
Doors
Front Window
Limitation
Side Window
Slide Window
Rear Window
Folding Window
Floor Covering
Coating
Roof Panelling
Interior Cab. Outfit
Built-In Case
Heating Device
Heater
Hose Line
Electrical Equipment
Aeration
Rear View Mirror
Sun Visor
Windshield Wiper
Windscreen Wash-Inst
Interior Lighting
Radio Installation Kit
Cover Plate For Roof
Body
Operator Seat
Seat Suspension
Shift Gate
Compressor
Bellows
Back Part
Seat Plate
Spring Assembly
Spring Assy
Seat Spring Assy
Turning Bracket
Security Belt
Tool Box
Hitch
Trailer Hitch
Remote Control
Adjustable Drawbar
Tie Rod Connection
Body-Panelling
Entry
Base For Frame
Latching
Labeling
Base
Spring Susp. Assy
Silencing Box
Handle
Mudguard Seat
Front Disc Wheels
Adjust. Front Wheels
Adjustab.Rear Wheels
Fenders
Mud Guards Fix
Mud Guards Adjustab.
Mudguard Enlargement
Intermediate Piece
Track Adjustment
Intermediate Pieces
Dirt Scraper
Implement Lift System Front
Front Lift Ram
Pipelines
Diaphrag.Accumulator
Manometer Installat.
Top Link
Bottom Link
Front Power Lift
Front Weight Carrier
Power Lift
Hydr.Main Contr.Unit
Link Holder
Auxiliary Cylinder
Oil Tank
Lift Arms
Support
Mounting Unit
Front Rear Loaders
Mounting Frame
Hoist 3
Hoist 3s
Lift Cylinder
Kick-Out Device
Magnet
Piping Lift Arm
Spill-Valve
Hyd.Implem.Operation
Parallelogr.Mounting
Fast Coupl.Frame
Piping Parallelogr.3
Piping Parallelogr3s
Multi-Coupling
Hyd.Circuit 3 Cat.3
Hyd.Circ. 3 Cat 3s
Earth Scoop
Heavy Goods Bucket
Universal Scoop
Bulk Scoop
Manure Fork
Slotted Plug
Cutting Header - Suspension
Bar Holder
Finger Side Mower
Cutter Head Inside
Double-Knife Mower
Bar Adjusting Device
Lifting Device
Assembly Cart
Inner Swath Board
Tipping Platform
Auxiliary Frame
Modification Part
Wheel Wedge Mounting
Warning System
Brake Lever Support
Implement Frame
Lifting Cylinder
Depth Limiter
Mounting Parts
Steps Handle
Rear-Mirror
Special Painting
Snow Plough
Technical Documents
