Fendt Tractor GT 380GT Parts Catalog F149000 09.2020
Brand: Fendt
Model: Fendt GT 380GT
Serial Number: 149/00101-99999
Publication Date: 09.2020
Number of Pages: 1077 Pages
V-Belt
Speed Control
Engine Stop
Fuel System
Reserve Tank
Fuel Lines
Air Filter
Intake Hose
Intake Manifold
Charged Air
Tube
Turbo-Supercharger
Manifold
Exhaust Upright
End Pipe
Cold Starting Aid
Crankcase
Front Cover
Set Of Gaskets
Engine Overhaul Parts
Cylinder
Piston
Breather Pipe
Tension Roller Cover
Tension Roller
Cylinder Head Cover
Temp. Transmitter
Mass Balancer Gear
Flywheel
Connecting Rod
Camshaft
Valve Drive
Oil Pan
Pressure Oil Pipe
Lube Oil Pump
Oil Suction Tube
Lubric. Oil Cooler
Oil Filter Mounting
Fuel Pressure Lines
Injection Line
Injector Valve
Leak Oil Line
Spill-Piping
Cooling Air Blower
Fan Panelling
Vibration Damper
Front Axle Bracket
Axle Carrier
Axle Bridge
Drive
Lock Differential
Joint Housing
Double Joint
Planetary Drive
Joint Shaft
Additional Weight
Tie Rod
Steering Cylinder
Pipes Steering Cyl.
Balance Truss
Steering Wheel
Steering Assy
Differential Lock
Hand-Brake
Brake
Foot Brake Actuating
Brake Master Cylinder
Brake Hydraulics
Caliper
Clutch Housing
Gearbox-Housing
Oil Level Indicator
Change-Speed Gearbox
Countershaft
Overdrive
Gear Shaft
Primary Shaft
Drive Pinion
Synchronizer Unit
Shifting
Mlt.Step Gear Change
Side Gear Shifting
Shift Lever
Reverse Gear Shift
P.T.O. Actuating
Final Drive
Dual Clutch
Clutch Actuating
Clutch Hydraulic
Engine P.T.O.
Front P.T.O.
Front P.T.O. Gear
Front P.T.O. Operat.
Front Wheel Drive
Front Wheel Drive Constant
Constant Overdrive
Engine P.T.O. Const.
Bevel Drive
Gear Box Lubrication
Compressed Air System
Compressor Installat
Pressure Pipe
Defrosting Pump
Pressure Regulator
Air Tank
3-Way Control Valve
Valve Stack
Trailer Valve
Double Pipe Brake
Air Brake Single
Pump Installation
Pipes Basic Circuit
Pipes Aux.Contr.Auto
Pipes For Top Valve
Pipes W O Top Valve
Pipes Hd.Trail.Brake
Valve Installation
Joystick
Valve Supplement
Hydr.Conn. S.A.Front
Hydr.Conn. S.A. Rear
Hydr.Conn. D.A. Rear
Returflow Rear
Hydr.Conn. S.A. Mid.
Hydr.Conn. D.A. Mid.
Returnflow Middle
Alternator Assy
Headlight
Lighting
Licence Plate Holder
Dashboard
Combi-Instrument
Relais Mounting
Switch
Cable Loom
Rep.Set Cable Loom
Socket F. Implements
Starter Blocking
Starter Motor
Socket F.Trail.Light
Socket
Additional Lighting
Work Lamp
Signal Light
Display
Transmitter
Cabin Frame
Column Panelling
Cabin Roof High
Roof Hatch
Cover Plate For Roof
Coating
Cabin Roof Low
Doors
Door Lock
Windscreen
Window
Rear Window Pane
Flap
Floor Covering
Drivers-Cabin Outfit
Tool Holder
Heating Device
Heater
Hose Line
Electrical Equipment
Aeration
Rear View Mirror
Sun Visor
Windshield Wiper
Windscreen Wash-Inst
Interior Lighting
Radio Installation Kit
Compressor Install.
Compressor
Tubes F.Refrig.Fluid
Condenser
Evaporator
Body
Operator Seat
Spring Assy
Seat Spring Assy
Bellows
Security Belt
Tool Box
Tools
Hitch
Trailer Hitch
Remote Control
Adjustable Drawbar
Tie Rod Connection
Body-Panelling
Entry
Base For Frame
Labeling
Base
Spring Susp. Assy
Silencing Box
Front Disc Wheels
Adjust. Front Wheels
Adjustab.Rear Wheels
Row Crop Wheels
Mud Guards Adjustab.
Mudguard Enlargement
Mudguard Cover
Track Adjustment
Implement Lift System Front
Front Lift Ram
Pipelines
Diaphrag.Accumulator
Manometer Installat.
Top Link
Bottom Link
Front Power Lift
Front Weight Carrier
Loading Weight
Carrier
Power Lift
Cylinder Cover
Hydr.Main Contr.Unit
Actuator
Link Holder
Hydr. Operation Rear
Auxiliary Cylinder
Oil Tank
Lift Arms
Support
Mounting Unit
Front Rear Loaders
Mounting Frame
Hoist 3
Hoist 3s
Lift Cylinder
Parallelogr.Mounting
Fast Coupl.Frame
Piping Lift Arm
Piping Parallelogr.3
Piping Parallelogr3s
Support Bracket
Damping
Valve Unit
Connecting Pipe
Multi-Coupling
Hyd.Circuit 3 Cat.3
Hyd.Circ. 3 Cat 3s
Hydr.Circuit 3
Heavy Goods Bucket
Universal Scoop
Bulk Scoop
Manure Fork
Pallet Fork
Wheel Wedge Mounting
Warning System
Special Painting
Brake Lever Support
Technical Documents
Brand: Fendt
V-Belt
Speed Control
Engine Stop
Fuel System
Reserve Tank
Fuel Lines
Air Filter
Intake Hose
Intake Manifold
Charged Air
Tube
Turbo-Supercharger
Manifold
Exhaust Upright
End Pipe
Cold Starting Aid
Crankcase
Front Cover
Set Of Gaskets
Cylinder
Piston
Breather Pipe
Tension Roller
Cylinder Head Cover
Temp. Transmitter
Mass Balancer Gear
Flywheel
Connecting Rod
Camshaft
Valve Drive
Oil Pan
Pressure Oil Pipe
Lube Oil Pump
Oil Suction Tube
Lubric. Oil Cooler
Oil Filter Mounting
Fuel Pressure Lines
Injection Line
Injector Valve
Leak Oil Line
Spill-Piping
Cooling Air Blower
Fan Panelling
Vibration Damper
Front Axle Bracket
Axle Carrier
Axle Bridge
Drive
Lock Differential
Joint Housing
Double Joint
Planetary Drive
Joint Shaft
Additional Weight
Tie Rod
Steering Cylinder
Pipes Steering Cyl.
Balance Truss
Steering Wheel
Steering Assy
Differential Lock
Hand-Brake
Brake
Brake Hydraulics
Caliper
Clutch Housing
Gearbox-Housing
Oil Level Indicator
Countershaft
Overdrive
Gear Shaft
Primary Shaft
Drive Pinion
Synchronizer Unit
Shifting
Side Gear Shifting
Shift Lever
Reverse Gear Shift
P.T.O. Actuating
Final Drive
Dual Clutch
Clutch Actuating
Clutch Hydraulic
Engine P.T.O.
Front P.T.O.
Front P.T.O. Gear
Front Wheel Drive
Constant Overdrive
Bevel Drive
Pressure Pipe
Defrosting Pump
Pressure Regulator
Air Tank
3-Way Control Valve
Valve Stack
Trailer Valve
Double Pipe Brake
Air Brake Single
Pump Installation
Pipes Basic Circuit
Pipes For Top Valve
Pipes W O Top Valve
Valve Installation
Joystick
Valve Supplement
Returflow Rear
Returnflow Middle
Alternator Assy
Headlight
Lighting
Dashboard
Combi-Instrument
Relais Mounting
Switch
Cable Loom
Rep.Set Cable Loom
Starter Blocking
Starter Motor
Socket
Additional Lighting
Work Lamp
Signal Light
Display
Transmitter
Cabin Frame
Column Panelling
Cabin Roof High
Roof Hatch
Coating
Cabin Roof Low
Doors
Door Lock
Windscreen
Window
Rear Window Pane
Flap
Floor Covering
Tool Holder
Heating Device
Heater
Hose Line
Aeration
Rear View Mirror
Sun Visor
Windshield Wiper
Interior Lighting
Compressor Install.
Compressor
Condenser
Evaporator
Body
Operator Seat
Spring Assy
Seat Spring Assy
Bellows
Security Belt
Tool Box
Tools
Hitch
Trailer Hitch
Remote Control
Adjustable Drawbar
Tie Rod Connection
Body-Panelling
Entry
Base For Frame
Labeling
Base
Spring Susp. Assy
Silencing Box
Front Disc Wheels
Row Crop Wheels
Mudguard Cover
Track Adjustment
Front Lift Ram
Pipelines
Top Link
Bottom Link
Front Power Lift
Loading Weight
Carrier
Power Lift
Cylinder Cover
Actuator
Link Holder
Auxiliary Cylinder
Oil Tank
Lift Arms
Support
Mounting Unit
Front Rear Loaders
Mounting Frame
Hoist 3
Hoist 3s
Lift Cylinder
Fast Coupl.Frame
Piping Lift Arm
Support Bracket
Damping
Valve Unit
Connecting Pipe
Multi-Coupling
Hyd.Circuit 3 Cat.3
Hyd.Circ. 3 Cat 3s
Hydr.Circuit 3
Heavy Goods Bucket
Universal Scoop
Bulk Scoop
Manure Fork
Pallet Fork
Warning System
Special Painting
Brake Lever Support
Technical Documents
