Fendt Tractor 939 S4 Parts Catalog F954000 10.2020
Brand: Fendt
Model: Fendt 939 S4
Serial Number: 954/00101-05000, WAM954XXX00F05001-99999
Publication Date: 10.2020
Number of Pages: 1674 Pages
Crankcase
Set Of Gaskets - Motor
Crankcase Breather
Front Cover
Gearcase
Impulsetransmitter
Adapter Housing
Engine Mounting
Valve Cover
Head Gasket
Rocker Arm Bracket
Valve Drive
Camshaft
Piston
Connecting Rod
Connect. Rod Bearing
Main Bearing
Vibration Damper
Flywheel
Oil Pan
Oil Dipstick
Oil Cooler Box
Oil Cooler Box - Fixing Parts
Oil Filter
Charged Air
Charged Air - Mounting Parts
Pressure Pipe
Charged Air - Heat Protection
Exhaust Bend
Exhaust Bend - Fixing Parts
Exhaust Bend - Heat Protection
Turbo-Supercharger
Connecting Pipe
Compensator
Manometer - Wire
Egr-Module
Egr-Module - Connector
Egr-Module - Cool.Water Piping
Egr-Module - Support Bracket
Egr-Module - Bracket
Heating-Flange
Electric Wiring
Electric Wiring - Shield Cap
Fuel Lines
Fuel Pump
High-Pressure Pump
High-Pressure Pump - Fixing Parts
Injector
Cable Loom
High-Pressure Accum.
Metering Unit
Fuel Line
Thermostat Housing
Console
V-Belt
Fan Support
Prefilter
Water Cooled Radiator - Low Temperature
Water Cooled Radiator - Seal
Expansion Tank
Cool. Water Piping - Water Cooled Radiator
Cool. Water Piping
Cool. Water Piping - Coolant Pump
Cool. Water Piping - Heating Connection
Cool. Water Piping - Tank Adblue
Air Filter
Boost Intercooling
Silencer
Silencer - Console
Exhaust Brake
Exhaust After-Treatment
Exhaust After-Treatment - Particle Filter
Exhaust After-Treatment - Tank Adblue
Exhaust After-Treatment - Supply Unit
Exhaust After-Treatment - Piping
Speed Control
Visco Fan
Visco Fan - Reversible Fan
Engine Pre-Heater
Oil Level Indicator - Single Circuit Brake
Oil Level Indicator - Dual Circuit Brake
Axle Housings - Single Circuit Brake
Axle Housings - Dual Circuit Brake
Gear Box Lubrication - Dual Circuit Brake
Drive - Single Circuit Brake
Drive - Dual Circuit Brake
Bevel Drive
Planetary Drive
Planetary Drive - Tyre Pressure Control System
Planetary Drive - Abs
Planetary Drive - Tyre Pressure Control System + Abs
Universal Joint
Universal Joint - Tyre Pressure Control System
Universal Joint - Tyre Pressure Control System + Abs
Joint Housing
Joint Housing - Tyre Pressure Control System
Joint Housing - Abs
Joint Housing - Tyre Pressure Control System + Abs
Cross Bar - Upper
Cross Bar - Lower Parts
Sensor - Swing Angle
Spring Cylinder
Tubes Fr.Axle Spring - Front
Tubes Fr.Axle Spring - Rear
Brake Assembly - Dual Circuit Brake
Steering Cylinder Assembly
Pipes Steering Cyl.
Stop Disc
Tie Rod
Drive Pinion
Valve Installation
Valve Installation - Fsc
Valve Installation - Support Bracket
Pump Installation - Gear Box Lubrication
Front Weight Carrier - Loading Weight
Hoop Guard
Steering Wheel
Steering Column
Mounting Unit
Steering Unit
Valve Unit
Clutch Housing
Gearbox-Housing
Rear Axle Housing
Oil Level Indicator
Final Drive
Disc Brake
Foot Brake Actuating
Brake Valve - Single Circuit Brake
Brake Valve - Dual Circuit Brake
Actuating Cylinder
Pipes Brake System
Clutch Actuating
Gear
Suspension
Suspension - Gear Box
Duct Plate - Valves
Adjusting Device
Pipelines - Transmission
Piping - Gear
Group Gear Shifting
Shifting - Implement
Engine P.T.O.
Pump Drive
Lube Oil Pump
Pump Installation
Gear Pump
Valve Syst.Comfort
Pipes Diff.Lock Fr.
Tubes System Comfort
Pipe Diagnostics
Front P.T.O.
Pipes Front Pto
Front Wheel Drive Constant
Front Wheel Drive - Coupler
Front Wheel Drive
Compressed Air System
Air Presser
Air Presser - Tyre Pressure Control System
Pressure Pipes
Pressure Pipes - Tyre Pressure Control System
Air Drier
Air Drier - Tyre Pressure Control System
Air Tank
Additional Container
Brake-Armatures Inst
Fittings
Double Pipe Brake
Double Pipe Brake - Additional Parts
Double Pipe Brake - Single Circuit Brake
Double Pipe Brake - Dual Circuit Brake
Air Brake Single
Hand Brake Valve
Tyre Pressure Control System - Valve Components
Tyre Pressure Control System - Lines
Tyre Pressure Control System - Valves
Tyre Pressure Control System - Pipelines
Tyre Pressure Control System - Piping
Joints And Gaskets - Plumbing Assembly
Piston Pump
Pipes Basic Circuit
Pipes Basic Circuit - Steering
Pipes Basic Circuit - Front
Pipes Basic Circuit - Filters
Pipes Basic Circuit - Control Pipe
Trailer Brake Valve
Pipes Hd.Trail.Brake
Hydr.Trailer Brake
Pipes Power-Lift - Double Acting
Pipes Power-Lift - Single Acting
Tube - Support
Pipes-With Oil Cool.
Pipes Hydr. Steering
Pipes Hydr. Steering - Reverse Driving Implement
Rotary Leadthrough - Reverse Driving Implement
Pipes El.Hydr.Steer.
Center Piece
Directional C. Valve - 100l Min
Directional C. Valve - 140l Min
Directional C. Valve - 170l Min
Control Valve - Double Acting
Control Valve - Single Acting
End Plate - Back And Left Side
End Plate - Right Hand
Coupling Sleeve - 1.1 1.4
1 2 Coupling Sleeve - 1.1 1.4
Coupling Sleeve - 1.2 1.5
1 2 Coupling Sleeve - 1.2 1.5
Coupling Sleeve - 1.3 1.6
1 2 Coupling Sleeve - 1.3 1.6
Cover Assembly - 1 2 Coupling Sleeve
3 4 Coupling Sleeve - 1.4
Cover Assembly - 3 4 Coupling Sleeve
5 8 Ffc Coupler - 1.1 1.4
5 8 Ffc Coupler - 1.2 1.5
5 8 Ffc Coupler - 1.3 1.6
Cover Assembly - 5 8 Ffc Coupler
Additional Parts - 5 8 Ffc Coupler
Multi-Coupling - 5 8 Coupler Plug
5 8 Coupler Plug
Additional Parts - Female Coupler
Leak Oil Line
Coupling Sleeve
Ext.Pless.Connection
Hydr. Connect.
Returflow Rear
Valve Installation - Center
Valve Unit - Center
End Plate - Middle
Control Valve - Front Power Lift
Directional C. Valve - Hydr.Conn. D.A.Front
Hydr.Conn. D.A.Front - 2.1
Hydr.Conn. D.A.Front - 2.2
Leak Oil Line - Front
Front Return Flow
Alternator - Left Hand
Alternator - Right Hand
Headlight
Headlight - Led
Lighting - Front
Lighting - Rear
Lighting
Lighting - Entry
Lighting - Catseye
Entry
Licence Plate Holder
Control Part
Central Electric System
Switch - Drivers Cab
Ignition Switch - Id-Module
Ignition Switch - Immobilizer System
Column Assemb.Switch
Switch - Motor
Transmitter - Motor
Transmitter - Exhaust After-Treatment
Switch
Transmitter - Gear
Cable Loom - Motor
Cable Loom - Gear
Cable Loom - Drivers Cab
Cable Loom - Cabin Roof
Cable Loom - Camera
Disconnection Points
Socket F. Implements
Cable Loom - External Counter
Reverse Beeper
Socket For Abs
Battery Disconnect Relay
Starter Installation
Starter Installation - Fixing Parts
Socket - Front
Socket - Rear
Additional Lighting
Work Lamp - Cabin-Roof Front
Work Lights - Cabin-Roof Front
Work Lamp - Indicator Bracket
Work Lamp - Cabin-Roof Rear
Signal Light
Signal Light - Led
Extendet Vehicle Width - Lighting
Extendet Vehicle Width - Lights
Extendet Vehicle Width - Signaling Panels
Display
Terminal - 7
Terminal - 10,4
Radar Sensor
Electronic Box
Control
Arm Rest
Comfort System - Isobus
Tachograph
Control Box - Motor
Control Unit
Cabin Frame
Handrail
Column Panelling
Roof
Roof - Coating
Roof Hatch
Coating
Door
Door Lock
Side Pane - Right Hand
Windscreen
Rear Window Pane
Flap
Floor Covering
Drivers-Cabin Outfit
Mobile Phone - Support Bracket
Rear View Mirror
Sun Visor
Windshield Wiper - Front
Windshield Wiper - Rear
Windscreen Wash-Inst - Front
Windscreen Wash-Inst - Rear
Interior Lighting
Radio Installation Kit
Hands-Free Speaking
Tubes Heating
Heater
Aeration
Filter Retainer
Housing
Insulation
Pipelines - Driver Seat
Piping - Driver Seat
Body
Body - Cladding
Seat Bracket
Turning Bracket
Passenger Seat
Arm Support
Driver Seat
Operator Seat
Compressor
Seat Spring Assy
Service Package
Safety Belt - Operator Seat
Tubes F.Refrig.Fluid
Condenser
Evaporator
Tractor Hood
Hood Support
Side Part
Front Grill
Side Cover
Side Covering
Locking Kit
Tool Box
Tool Set
Pto Guard
Base For Frame
Base For Frame - Lines
Labeling
Warning Plate
Base
Insulation - Base
Sound Insulation
Disc Wheels Rear - 23x 38
Disc Wheels Rear - 25 X 38
Disc Wheels Rear - 27 X 38
Disc Wheels Rear - 20 X 42
Disc Wheels Rear - 23 X 42
Disc Wheels Rear - 25 X 42
Disc Wheels Rear - 27 X 42
Disc Wheels Rear - 30 X 42
Disc Wheels Rear - Tyre Pressure Control System
Adjustab.Rear Wheels - 16 X 46
Adjustab.Rear Wheels - 16 X 50
Front Disc Wheels - 16 X 30
Front Disc Wheels - 20 X 30
Front Disc Wheels - 23 X 30
Front Disc Wheels - 16 X 34
Front Disc Wheels - 18 X 34
Front Disc Wheels - 23 X 34
Front Disc Wheels - 25 X 34
Front Disc Wheels - Tyre Pressure Control System
Adjust. Front Wheels - 13 X 34
Adjust. Front Wheels - 15 X 34
Adjust. Front Wheels - 15 X 38
Mudguard Front
Wheel Hub
Mudguard Rear - Carrier
Mudguard Rear
Mudguard Rear - Splash-Guard
Mudguard Enlargement
Implement Lift System Front
Sensor
Locking Ram - Front
Tube - Single Acting
Tube - Double Acting
Valve Unit - Double Acting
Top Link
Lower Links
Power Lift
Oil Tank - External
Oil Tank - Interior
Draft Pin
El.Hd.Remote Control
Lift Arms
Support
Support - Hydraulic
Upper Link
Hydr. Upper Link - 90mm
Hydr. Upper Link - 120mm
Hydr. Upper Link - Clamping Parts
Link Holder
Ball Retainer
Linkage
Toolbar
Wagon Hitch Kit
Trailer Hitch
Trailer Hitch - Cuna
Remote Control
Ball Type Clevis
Mount
Ball Type Clevis - Long
Forced Steering
Piton Fix
Piton Fix - Drawbar And Hitch
Spacer
Bottom Hitch Assy - Drawbar And Hitch
Drawbar And Hitch - Cat 4
Drawbar And Hitch - Cat 3
Drawbar And Hitch
Drawbar And Hitch - Cranked
Bottom Hitch Assy
Trailer Hitch - Front
Front Rear Loaders
Carrier - Console
Mounting Bracket
Hoist
Jack Assembly
Reversing Lever
Dumping Cylinder
Parallelogr.Mounting
Lift Cylinder
Fast Coupl.Frame
Fast Coupl.Frame - Hydraulic
Fast Coupl.Frame - Working Hydraulic
Cylinder - Latching
Valve Unit - Fast Coupl.Frame
Piping Lift Arm
Piping Parallelogrr.
Equipment
Multi-Coupling - Equipment
Damping
Solenoid Valve - Damping
Multi-Coupling
Multi-Coupling - Connecting Pipe
Multi-Coupling - Tractor Mounted
Electrical Equipment - Frontendloader Mounted
Electrical Equipment - Tractor Mounted
Electrical Equipment - Lighting
Pallet Fork
Universal Scoop
Heavy Goods Bucket
Light Goods Bucket
Silage Bucket 2200
Hydraulic Equipment - Silage Grapple
Hydr. Cylinder - Silage Grapple
Manure Fork
Bale Grab
Hydraulic Equipment - Bale Grab
Hydr. Cylinder - Bale Grab
Bale Fork
Precision Farming Systems
Cable Loom - Varioguide
Base Station
Data Transfer - Vario-Doc
Varioguide - Topcon
Varioguide - Novatel
Varioguide - Trimble
Agco Connectivity Module (Acm)
EmerGency Pack
Wheel Wedge Mounting
Spacer Ring - Rear Axle Shaft
Flange - Loading Weight
Loading Weight - Tail Wheel
Loading Weight
Carrier
Hitch - Loading Weight
Brand: Fendt
Model: Fendt 939 S4
Crankcase
Crankcase Breather
Front Cover
Gearcase
Impulsetransmitter
Adapter Housing
Engine Mounting
Valve Cover
Head Gasket
Rocker Arm Bracket
Valve Drive
Camshaft
Piston
Connecting Rod
Main Bearing
Vibration Damper
Flywheel
Oil Pan
Oil Dipstick
Oil Cooler Box
Oil Filter
Charged Air
Pressure Pipe
Exhaust Bend
Turbo-Supercharger
Connecting Pipe
Compensator
Manometer - Wire
Egr-Module
Heating-Flange
Electric Wiring
Fuel Lines
Fuel Pump
High-Pressure Pump
Injector
Cable Loom
Metering Unit
Fuel Line
Thermostat Housing
Console
V-Belt
Fan Support
Prefilter
Expansion Tank
Cool. Water Piping
Air Filter
Boost Intercooling
Silencer
Silencer - Console
Exhaust Brake
Speed Control
Visco Fan
Engine Pre-Heater
Bevel Drive
Planetary Drive
Universal Joint
Joint Housing
Joint Housing - Abs
Cross Bar - Upper
Spring Cylinder
Pipes Steering Cyl.
Stop Disc
Tie Rod
Drive Pinion
Valve Installation
Hoop Guard
Steering Wheel
Steering Column
Mounting Unit
Steering Unit
Valve Unit
Clutch Housing
Gearbox-Housing
Rear Axle Housing
Oil Level Indicator
Final Drive
Disc Brake
Actuating Cylinder
Pipes Brake System
Clutch Actuating
Gear
Suspension
Duct Plate - Valves
Adjusting Device
Piping - Gear
Group Gear Shifting
Engine P.T.O.
Pump Drive
Lube Oil Pump
Pump Installation
Gear Pump
Valve Syst.Comfort
Pipes Diff.Lock Fr.
Pipe Diagnostics
Front P.T.O.
Pipes Front Pto
Front Wheel Drive
Air Presser
Pressure Pipes
Air Drier
Air Tank
Fittings
Double Pipe Brake
Air Brake Single
Hand Brake Valve
Piston Pump
Pipes Basic Circuit
Trailer Brake Valve
Hydr.Trailer Brake
Tube - Support
Center Piece
5 8 Coupler Plug
Leak Oil Line
Coupling Sleeve
Hydr. Connect.
Returflow Rear
Valve Unit - Center
End Plate - Middle
Front Return Flow
Headlight
Headlight - Led
Lighting - Front
Lighting - Rear
Lighting
Lighting - Entry
Lighting - Catseye
Entry
Control Part
Switch - Motor
Transmitter - Motor
Switch
Transmitter - Gear
Cable Loom - Motor
Cable Loom - Gear
Cable Loom - Camera
Reverse Beeper
Socket For Abs
Socket - Front
Socket - Rear
Additional Lighting
Signal Light
Signal Light - Led
Display
Terminal - 7
Terminal - 10,4
Radar Sensor
Electronic Box
Control
Arm Rest
Tachograph
Control Box - Motor
Control Unit
Cabin Frame
Handrail
Column Panelling
Roof
Roof - Coating
Roof Hatch
Coating
Door
Door Lock
Windscreen
Rear Window Pane
Flap
Floor Covering
Rear View Mirror
Sun Visor
Interior Lighting
Hands-Free Speaking
Tubes Heating
Heater
Aeration
Filter Retainer
Housing
Insulation
Body
Body - Cladding
Seat Bracket
Turning Bracket
Passenger Seat
Arm Support
Driver Seat
Operator Seat
Compressor
Seat Spring Assy
Service Package
Condenser
Evaporator
Tractor Hood
Hood Support
Side Part
Front Grill
Side Cover
Side Covering
Locking Kit
Tool Box
Tool Set
Pto Guard
Base For Frame
Labeling
Warning Plate
Base
Insulation - Base
Sound Insulation
Mudguard Front
Wheel Hub
Mudguard Rear
Sensor
Locking Ram - Front
Top Link
Lower Links
Power Lift
Oil Tank - External
Oil Tank - Interior
Draft Pin
Lift Arms
Support
Support - Hydraulic
Upper Link
Link Holder
Ball Retainer
Linkage
Toolbar
Wagon Hitch Kit
Trailer Hitch
Remote Control
Ball Type Clevis
Mount
Forced Steering
Piton Fix
Spacer
Drawbar And Hitch
Bottom Hitch Assy
Front Rear Loaders
Carrier - Console
Mounting Bracket
Hoist
Jack Assembly
Reversing Lever
Dumping Cylinder
Lift Cylinder
Fast Coupl.Frame
Cylinder - Latching
Piping Lift Arm
Equipment
Damping
Multi-Coupling
Pallet Fork
Universal Scoop
Heavy Goods Bucket
Light Goods Bucket
Silage Bucket 2200
Manure Fork
Bale Grab
Bale Fork
Base Station
Varioguide - Topcon
EmerGency Pack
Loading Weight
Carrier
