Fendt Tractor 938 Vario MT Parts Catalog 652365 2018 - 2020
Brand: Fendt
Model: Fendt 938 Vario MT Tractor (2018 - 2020)
Serial Number: JXXX1001 – LXXX9999
Year of Manufacture: 2018, 2019, 2020
Number of Pages: 1121 Pages
Engine Assemblies - Lrc
Cylinder Head - Lrc
Electronic Engine Management
Timing Gears And Housing, Lrc - Starting From Engine Serial Number E54640
Coolant Piping - Lrc
Engine Acw3398750 98 Awf-Hla
Engine Assemblies - Engine Serial Number Range Jld302200-Jld525201
Flywheel And Housing
Crankshaft And Pistons
Valve Rocker Cover
Intake Manifold
Exhaust Manifold - M12 Turbo Mounting Stud Bolts
High Pressure Turbocharger - M12 Turbo Mounting Stud Bolts
Low Pressure Turbocharger And Icac - M12 Turbo Mounting Stud Bolts
Oil Pump And Sump
Oil Cooler And Filter
Coolant Piping
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Fan Drive
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine Acx2447020 98 Lfvc
Parts Lists And Illustrations
Engine Identification
Engine Assemblies
Cylinder Block - Service Parts
Timing Gears And Housing - Service Parts
Valve Mechanism - Service Parts
Cylinder Head - Service Parts
Exhaust Manifold
High Pressure Turbocharger - Service Parts
Interstage Charge Air Cooler (Icac)
Oil Pump - Service Parts
Crankcase Ventilation - Service Parts
Coolant Pump - Service Parts
Fuel Injection Pump - Service Parts
Fuel Filters - Service Parts
Fan Drive - Service Parts
Exhaust Aftertreatment - Service Parts
Engine Gasket Kits
Engine Installation
Filters
Engine Mount Group
Accessory Drive Group
Coupler Assembly
Engine Oil Service Group
Deflector Group
Deflector Group - Engine Without Air Compressor
Fuel Tank Group - Fuel Sender-Tube Type
Fuel Tank Group - Mid Capacity
Fuel Tank Group - High Capacity
Fuel Decal - 2020
Fuel Lines Group
Fuel Lines Group - Fuel Pre-Filter
Diesel Exhaust Fluid Lines Tier 3 - 2018 - 2019
Diesel Exhaust Fluid Lines - Tier 4, Final Compliant
Intake Group
Closed Crankcase Ventilation (Ccv) - Lines
Cooling Group - 2018 - 2019
Support Group - Fan
Def Tank Group - Tier 3
Def Tank Group - Tier 4, Final Compliant
Def Tank Group - 2018 - 2019
Def Tank Group - 2020
Def Lines - Engine Stage 5
Exhaust Group Tier 3 - 2018 - 2019
Exhaust Group Tier 3 - 2020
Exhaust Group Tier 4 - 2018 - 2019
Exhaust Group - Tier 4, Final Compliant
Exhaust Group Tier 4 - 2020
Exhaust Assembly - Engine Stage 5
Electrical Emissions - Engine Stage 5
Exhaust Support Assembly-Frame - Engine Stage 5
Brake Group - Steering Motor
Service Parts - Steering Motor
Brake Group - Steering Arrangement
Brake Group - Steering Pump Group
Service Parts - Steering Pump
Steering Gear
88 Inch Track
Shaft Group
Wide Gage, 72 - 120 Inches
Gearbox Housing
Wheel Shaft Housing
Rear Axle Cover
Gear
Duct Plate
Adjusting Device - Governor
Adjusting Device - Lever
Plumbing Assembly - Gear
Shifting
Bevel Drive
Rear Axle Differential
Handbrake
Brake Assembly - Rear Suspension
Hub Reduction - Left Hand
Hub Reduction - Right Hand
Engine P . T . O
Engine P . T . O - Shifting
Valve Syst.Comfort
Pump Drive
Valve Block Assembly
Brake Hydraulic
Pipes And Heat Shields Cont'd - Differential Lock Mechanism
Gear Pump
Valve Block Assembly - Comfort System
Brake Group - Brake Bleeders
Brake Group - Brake Valve
Brake Valve
Brake Group - Front And Rear
Brake Group - Lines And Fittings
Parking Brake Assembly - Secondary
Parking Brake Assembly, Modulating - Secondary
Completing Lines With No Trailer Brakes
Trailer Brake Valve - Air
Trailer Brake Valve - Hydraulic
Trailer Brake Valve - Hydraulic - Air
Trailer Brake Valve - 2020
Compressed Air System
Air Tank And Lines Group
Hydraulic Fan Group
Engine Fan - Hydraulic
Hydraulic Pump Arrangement Implement, 58gpm - Single
Service Parts - Implement Pump Assembly
85cc Single - No Power Beyond
85cc Single - Low Pressure Return Arrangement
85cc Dual - Low Pressure Return Arrangement
Hydraulic Pump Arrangement Implement, 58gpm - Dual Pump, Csv
85cc Dual - No Power Beyond
Case Drain Completing Arrangement - No Drain
Case Drain Completing Arrangement - Single Implement
Case Drain Completing Arrangement - Double Implement
Completing Arrangement - No Power Beyond
Single Pump Power Beyond
Dual Pump Power Beyond
Ecology Drain Hydraulic Tank
4 Bank Valve Group - 1 2 Inch Power Beyond Coupler Group
1 2 Coupling Sleeve
6 Bank Valve Group - 1 2 Inch Power Beyond Coupler Group
4 Implement Valve Group
4 Implement Valve Group - 3 Point Hitch
Service Parts - Control Valve
Service Parts - End Plate
6 Implement Valve Group
6 Implement Valve Group - 3 Point Hitch
Electrical Group - Front Chassis
Electrical System - Stage 5
Fuse And Relay Panel Assembly
Electrical Switches - Rear Fender
Batteries & Cables - Rear Power
Engine Heater Arrangement, 120 Volt
Engine Heater Arrangement, 240 Volt
Oil Sump Heater Arrangement, 120 Volt - Row Crop Option
Oil Sump Heater Arrangement, 240 Volt - Eame
Lighting Group, Roading, Left Hand Traffic - Led
Lighting Group, Roading, Right Hand Traffic - Led
Lighting Group, Roading, Left Hand Traffic - Halogen
Lighting Group, Roading, Right Hand Traffic - Halogen
Light Installation-Work - Led
Light Installation-Work - Halogen
Electrical Group - Less Regulated Countries
Extremity Arm Group - Red
Extremity Arm Group - Amber
Extremity Arm Group - Wide
Extremity Arm Group - Narrow
Extremity Arm Group - 2018 - 2019
Extremity Arm Group - 2020
Extremity Arm Group Rear - 2020
Extremity Arm Group Plugs - 2020
Beacon Group - Rotating Beacon Light
Electrical Group - Trailer Harness Group
Electrical Group - 7 Pin Socket
Timing Gear - Transmission
Transmitter
Door
Window Assembly, Rear
Visor Assembly And Mount
Interior Trim - Hammer Kit
Interior Trim - Left And Lower
Seat Group, Basic
Seat Assembly - Basic
Seat Group, Deluxe - Cloth
Seat Assembly - Cloth
Suspension Kit
Seat Group, Deluxe - Leather
Seat Assembly - Leather
Arm Support - Adjustment
Steering Column - Service Parts
Console Group, Front - Accelerator Pedal
Wiper Assembly - Front And Rear
Sidemirrors, Electric
No Radio
Radio Wiring - Plug
Radio And Speaker Mounting - Basic
Radio And Speaker Mounting - Deluxe
Armrest
Terminal Support
Arm Rest
Branding Arrangement - Fendt
Hvac Ventilation - Basic
Hvac Ventilation - Deluxe
Hvac Lines Group - Cab
Hvac Lines Group - Engine
Air Conditioner - Service Parts
Kit
Air Conditioner - Service Kit
Frame Group - Guard Driveline
Frame Group - 2020
Component Support Group
Component Support Group - 2020
Powertrain Guard Group - Right Hand
Powertrain Guard Group - Left Hand
Platform
Step Arrangement, Standard
Step Arrangement, Pivoting
Hood Group - Top
Hood Group Sides - 2018 - 2019
Hood Group Sides - 2020
Prop Rod Group
Grill Assembly
Shield Group
Fender Group
Plate
Decal Group,938 Vario Mt
Decal Installation - Electrical
Decal Group - Hydraulic
Decal Group - Chassis
Decal Group - Engine
Decal Group - Ce
Track Belt System
Undercarriage Arrangement With Narrow Axles - Support
Undercarriage Arrangement, Ultra Wide Gage - Support
Tensioner
Track Frame Arrangement, Right Hand
Track Frame Arrangement, Left Hand
Bogie Group
Medium Width Rubber Midroller Wheel Installation
Wide Width Rubber Midroller Wheel Installation
Plug Group
Narrow Width Wheel Installation - Front And Rear
Medium Width Wheel Installation - Front And Rear
Wide Width Wheel Installation - Front And Rear
Ejector Assy - Medium Width Driver Wheel Group
Ejector Assy - Wide Width Driver Wheel Arrangement
Belt Conditioner
Replacement Tracks
Replacement Tracks - Fendt
Replacement Tracks - Service Parts
Implement Lift System
Hitch Sensitivity System - Decal Group, 3 Point Hitch, International
Linkage Group, 3 Point Hook - Category 4
Linkage 3-Point Hitch - Category 4
3 Point Hitch Group, Category 4 - Quick Attach
Implement Ball Group, Hook, Category 4 And 3
Drawbar Arrangement
Draw Bar Hitch - Less Slider
Draw Bar Hitch - Slider
Tow Hook Group, Rear, Auto Latch
Tow Hook Group, 43 Mm Pin
Tow Hook Group, 50 Mm Pin
Link Group, Upper
Link Group, Upper - Hydraulic Group
Precision Farming Systems
Speed Sensor And Mounting
Speed Sensor And Mounting - Uk
Receiver Installation, Trimble
Gyro, Gsm
Gyro, Lte
Receiver Group - Auto Guide
Guidance Ready
Gateway Group
Idler Counterweights
Counterweight Group, Front - 1230 Kg
Counterweight Group, Front - 1415 Kg
Counterweight Group, Front - 1690 Kg
Number Plate - Front
Tow Cable Group - Front
Tow Cable Arrangement - Front
Pin Group - Category 4 To Category 3 Conversion
Reflector Group
Slow Moving Vehicle Warning Group - Right Side
Slow Moving Vehicle Warning Group - Left Side
Warning Plate
Slow Moving Vehicle Warning Group - 40 Kph
Sis Group - 40 Kph
Gateway Group - Field Accessories
Field Accessories, Modem Satellite
Modem Group - Field Accessories
Trimble Ready Installation - Field Accessories
A-Post Mounting Bracket
Implement Control Group - Field Accessory
Camera (Agcam) - Field Accessory
Camera Adapter
Side Window - Wiper
Medium Width Rubber Midroller Wheel Installation - Kit
Wide Width Rubber Midroller Wheel Installation - Kit
Deflector Group, Mt700
Axle Tool Kit
Rubber Belt Repair Kit
Guide Block Kit
Wheel Wedge Group - Kit
Field Installation Kit - Steering Ball Assembly
Fire Extinguisher Kit - Fire Extinguisher Mounting Kit
Ejector Assy - Field Accessories
Fuel Tank Guards & Plug - Field Accessories
Fuel Tank - Mid Capacity
Fuel Tank - High Capacity
Hydraulic Trailer Brake Kit
4 To 5 Implement Valve Conversion Kit
4 To 6 Implement Valve Conversion Kit
5 To 6 Implement Valve Conversion Kit
Hydraulic Pump Arrangement Implement, 58gpm - Kit
Cover Group
Coupler Assembly - 3 4 Coupling Sleeve
Coupler Assembly - 3 4 Ffc Coupler
5 8 Ffc Coupler - Manifold
