Fendt Tractor 930NA Gen6 Parts Catalog F957105 06.2020
Brand: Fendt
Model: Fendt 930NA Gen6
Serial Number: WAM95724X00F00101-99999
Publication Date: 06.2020
Number of Pages: 1231 Pages
Engine H218pb1501xxx D1556le5xx
Engine - Mount
Crankcase
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve
Cylinder Head And Valves
Valve Cover
Air Intake
Exhaust Manifold
Turbo-Charger
Oil Pump And Sump
Oil Cooler And Filter
Coolant Piping
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management - Sensor
Electronic Engine Management - Wiring Harness
Electronic Engine Management - Support Bracket
Wiring Harness - Injector
Starter Motor
Belt - Belt Tensioner
Special Overhaul Parts
Engine Installation
Overview - Filters
Fuel Pre-Filter
Air Filter
Exhaust After-Treatment - Tank Adblue
Exhaust After-Treatment - Supply Unit
Axle Housings
Filters
Valve Block Assembly - Pressure Filter
Valve Block Assembly - Middle
Aeration - Rear
Aeration - Filter Retainer
Oil Tank - Exterior
Oil Tank - Interior
Oil Cooler - Fuel Pipings
Fuel Lines
Water Cooled Radiator
Coolant Piping - Expansion Tank
Coolant Piping - Tank Adblue
Air Filter - Retainer
Boost Intercooling
Silencer
Silencer - Console
Exhaust After-Treatment - Particel Filter
Exhaust Brake
Speed Control
Visco Fan
Visco Fan - Reversible Fan
Engine Pre-Heater
Axle
Filler
Propel
Bevel Drive
Planetary Drive
Planetary Drive - Tyre Pressure Control System
Joint Shafts
Joint Shafts - Tyre Pressure Control System
Joint Housing
Joint Housing - Tyre Pressure Control System
Cross Bar - Upper
Cross Bar - Lower Parts
Sensor - Swing Angle
Spring Cylinder
Brake Assembly
Steering Cylinders
Stop Disc
Tie Rod
Axle - Fixing Parts
Cover Assembly - Sensor
Drive Pinion
Tube - Comfort System
Tube - Spring Cylinder
Tubes Fr.Axle Spring - Middle
Tubes Fr.Axle Spring - Rear
Pipes Steering Cyl. - Front
Pipes Steering Cyl. - Rear
Valve Installation - Bracket
Valve Installation
Valve Installation - Fsc
Gear Box Lubrication
Gear Box Lubrication - Tyre Pressure Control System
Gear Box Lubrication - Gear Pump Group, Mt800
Pipes Trans Oil Cool - Front Axle
Steering Wheel
Steering Colmn
Steering Colmn - Mounting Unit
Steering Column - Mounting Unit
Steering Column - Reverse Driving Implement
Steering Unit
Steering Unit - Vario Guide
Clutch Housing
Transmission Gear Housing
Wheel Shaft Housing
Rear Axle Cover
Oil Level Indicator
Final Drive
Final Drive - Tyre Pressure Control System
Disc Brake
Foot Brake Actuating
Switches - Drivers Cab
Brake Valve
Actuating Cylinder
Pipes Brake System
Hand Brake Valve
Pipes Brake System - Park Brake
Valve Installation - Park Brake
Clutch Actuating
Drive Shaft
Suspension - Transmission
Gear
Duct Plate
Adjusting Device - Lever
Adjusting Device - Governor
Plumbing Assembly - Gear
Shifting
Engine P . T . O - Drive Pinion
Engine P . T . O - Output Drive
Engine P . T . O - Shifting
Pump Drive
Pump Drive - Cover
Gear Pump Group, Mt800 - Rear
Gear Pump - Front
Valve Block Assembly - Coupler
Pipe Diagnostics
Front P.T.O. - Propel
Front P.T.O. - Coupler
Front P.T.O. - Gear
Front P.T.O. - Case Assembly
Front P.T.O. - Valve Block Assembly
Front Wheel Drive
Compressed Air System
Compressed Air
Compressed Air - Tyre Pressure Control System
Suction Piping
Pressure Pipe
Air Drier
Air Drier - Tyre Pressure Control System
Air Tank
Brake-Armatures Inst - Retainer
Brake-Armatures Inst - Front
Brake-Armatures Inst - Reverse Driving Implement
Brake-Armatures Inst - Rear
Trailer Valve
Double Pipe Brake
Double Pipe Brake - Duomatic Clutch
Double Pipe Brake - Italy
Air Brake Single
Tyre Pressure Control System - Valve Components
Tyre Pressure Control System - Fuel Pipings
Tyre Pressure Control System - Valve - Mat
Tyre Pressure Control System - Baraxle
Joints And Gaskets - Plumbing Assembly
Pump Installation
Piston Pump
Piston Pump - 2nd Circuit Hydr.
Gear Pump
Pipes Basic Circuit - Main Drive
Pipes Basic Circuit - Control Pipe
Pipes Basic Circuit - 2nd Circuit Hydr.
Ext.Pless.Connection - 2nd Circuit Hydr.
Ext.Pless.Connection - 1nd Circuit Hydr.
Returflow Rear
Return Flow - Casedrain
Return Flow Front
Trailer Brake Valve
Pipes Hd.Trail.Brake
Hydr.Trailer Brake
Pipes Power-Lift - Single Acting
Pipes Power-Lift - Double Acting
Tube - Bottom Link
Valve Block Assembly - Bottom Link
Pipes Hydr. Steering
Pipes Hydr. Steering - Vario Guide
Pipes Hydr. Steering - Reverse Driving Implement
Rotary Leadthrough - Reverse Driving Implement
Valve Support - Basic Scope
Center Piece
Valve Installation - 1nd Circuit Hydr.
Valve Installation - 2nd Circuit Hydr.
Directional C. Valve - 120l Min
Directional C. Valve - 140l Min
Directional C. Valve - 170l Min
Directional C. Valve - Rear Power Lift
Spacer - Left Hand
Directional C. Valve - Hydr.Conn. D.A.Front
Directional C. Valve - Front Linkage
End Plate - Back And Left Side
Spacer - Right Hand
End Plate - Right Hand Rear
1 2 Coupling Sleeve - Lever Coupling
3 4 Coupling Sleeve - Lever Coupling
5 8 Ffc Coupler - Lever Coupling
Deck - 1 2 Coupling Sleeve
Deck - 3 4 Coupling Sleeve
Deck - 5 8 Ffc Coupler
Additional Parts - Lever Coupling
Additional Parts - 5 8 Ffc Coupler
Leak Oil Line
Leak Oil Line - Return Flow
Female Coupler - Connect Under Pressure (Cup) Coupling
Valve Installation - Middle
Bottle - Hydr.Conn. D.A.Front
Headlight
Headlight - Led
Lighting - Front
Rear Lighting
Rear Lighting - Led
Brake Light - Upper
Lights - Entry
License Plate Light
Central Electric System
Switches
Transmitter - Motor
Transmitter - Gear Box
Ignition Switch - Id-Module
Ignition Switch - Immobilizer System
Column Assemb.Switch
Cable Loom - Supply
Cable Loom - Engine
Cable Loom - Gear
Cable Loom - Operator Platform
Cable Loom - Reverse Driving Implement
Cable Loom - Cabin Roof
Cable Loom - Camera Engine Hood
Cable Loom - Terminal
Disconnection Points
Socket F. Implements
Cable Loom - External Counter
Reverse Beeper
Battery Disconnect Relay - Battery Shift
Socket - Front
Socket - Rear
Socket For Abs
El.Hd.Remote Control - Rear Power Lift
Additional Lighting
Additional Lighting - Led
Work Lights - Engine Hood
Work Lights - Cabin-Roof Front
Work Lights - Indicator Bracket
Work Lights - Cabin-Roof Rear
Work Lights - Rear Light Carrier
Signal Light
Signal Light - Led
Lighting - Extendet Vehicle Width
Combi-Instrument - Control Part
Terminal - 7
Terminal - 10,4
Arm Rest
Radar Sensor
Electronic Box
Control - Gear
Implement Control - Isobus
Cabin Frame
Clamping Parts - North America
Column Panelling
Body
Body - Reverse Driving Implement
Body - Rotary Leadthrough
Roof
Roof Hatch
Licence Plate Holder
Door
Door Lock
Windscreen - Side Pane
Rear Window Pane
Windshield Wiper - Front
Windshield Wiper - Right Hand
Windshield Wiper - Rear
Windscreen Wash-Inst
Rearview Mirror - North America
Floor Covering
Floor Covering - Reverse Driving Implement
Base
Base - Reverse Driving Implement
Coating
Coating - Reverse Driving Implement
Coating - Left Hand
Roof Panelling
Roof Panelling - Audio System
Roof Panelling - Clamping Parts
Interior Lighting
Sun-Shield Assy
Radio Installation Kit
Radio Installation Kit - Infotainment
Drivers-Cabin Outfit - Support Bracket
Drivers-Cabin Outfit - Mirror
Drivers-Cabin Outfit - Cool Box
Mobile Phone - Support Bracket
Tablet Holder
Aeration - Front
Aeration - Air Distributor
Aeration - Blower
Aeration - Air Conditioner And Heater
Aeration - Insulation
Tube - Heater
Tube - Driver Seat
Tube - Operator Seat
Arm Support
Armrest - Adjuster
Driver Seat
Operator Seat
Compressor
Seat Spring Assy
Service Package
Safety Belt - Operator Seat
Seat Belt - Instructor Seat
Instructor Seat
Compresser
Tubes F.Refrig.Fluid
Condenser
Logo
Hood Group - Front Grill
Hood Group - Side Panelling
Hood Group - Side Cover
Hood Bracket
Entry Left
Entry Right
Entry Right - Splash-Guard
Toolbox
Tool Set
Toolbox - Metal
Water Tank
Toolbox (Optional Equipment)
Frame Storage Front - Mechanical Suspension
Frame Storage Front - 3 Point Air Suspension
Frame Storage At The Back - Mechanical Suspension
Frame Storage At The Back - Air Suspension
Base For Frame - Fuel Pipings
Warning Plate - North America
Labeling - Cab
Labeling - Cab Interior
Labeling
Labeling - North America
Disc Wheels Rear - 23 X 38
Disc Wheels Rear - 25 X 38
Disc Wheels Rear - 27 X 38
Disc Wheels Rear - 20 X 42
Disc Wheels Rear - 23 X 42
Disc Wheels Rear - 25 X 42
Disc Wheels Rear - 28 X 42
Disc Wheels Rear - 25 X 44
Adjustab.Rear Wheels - 16 X 46
Adjustab.Rear Wheels - 15 X 50
Adjustab.Rear Wheels - 11 X 54
Front Disc Wheels - 23 X 30
Front Disc Wheels - 18 X 34
Front Disc Wheels - 23 X 34
Front Disc Wheels - 25 X 34
Front Disc Wheels - 23 X 38
Adjust. Front Wheels - 14 X 34
Adjust. Front Wheels - 11 X 38
Adjust. Front Wheels - 13 X 38
Mudguard Front - Cover Assembly
Mudguard Front - Basic Scope
Fendor Holder
Fendor Holder - Dual Wheels
Turning Bracket - Swivelling Mudguard
Intermediate Piece - Front
Wheel Hub - Baraxle
Spacer Ring - Wheel Hub
Mudguard Rear
Mudguard Rear - Splash-Guard
Mudguard Enlargement
Wheel Spacers - Rear
Wheel Spacers
Implement Lift System Front
Frame
Bottom Link
Cylinders - Front Linkage
Upper Link
Sensor - Comfort Power Lift
Tube - Basic Scope
Tube - Single Acting
Tube - Double Acting
3 Point Hitch Group - Cat 3
Upper Link - Cat 3
Link Holder - Cat 3
Upper Link - Cat 4
Link Holder - Cat 4
Hydr. Upper Link - 120mm
Hydr. Upper Link - Clamping Parts
Link Holder - Hydr. Upper Link
Bottom Link - Cat 3
Support
Power Lift - Clamping Parts
Power Lift
Lift Cylinder
Oil Tank - Inner
Sensor
Lift Arms
Support - Mechanical
Support - Hydraulically
Cylinder - Support
Link Holder
Hydr. Upper Link - 90mm
Bottom Link - Cat 4
Linkage
Tow Hitch - Front
Remote Control
Toolbar
Toolbar - North America
Pto Shaft Protection - North America
Ball Type Clevis - North America
Drawbar And Hitch - North America
Precision Farming Systems
Varioguide - Novatel
Varioguide - Trimble
Agco Connectivity Module (Acm)
Spacer Ring - Axle Shaft
Flange - Loading Weight
Loading Weight - Tail Wheel
Front Weight Carrier - Loading Weight
Loading Weight
Ball Sleeve - Upper Link
Ball Sleeve - Lower Links
First Aid Kit
Wheel Wedge Mounting
Ball Retainer - Cat 3
Ball Retainer - Cat 4
Ball Sleeve - Bottom Link
Extinguisher
Multi-Coupling - 5 8 Coupler Plug
