Fendt Tractor 512 Vario SCR Parts Catalog F413000 09.2019
Brand: Fendt
Model: Fendt 512 Vario SCR
Serial Number: 413/00101-99999
Publication Date: 09.2019
Number of Pages: 1379 Pages
Crankcase
Enging Support
Mass Balancer Gear
Set Of Gaskets - Motor
Transmitter
Crankcase Breather
Front Cover
Gearcase
Adapter Housing
Female
Engine Mounting
Valve Cover
Rocker Arm
Head Gasket
Valve Drive
Camshaft
Piston
Connecting Rod
Main Bearing
Flywheel
Flywheel Cover
Oil Pan
Oil Filler
Filler Cap
Heating Connection
Exhaust Bend
Turbo-Supercharger
Heating-Flange
Relay - Heating-Flange
Electric Wiring
Relay
Fuel Lines
Fuel Pump
High-Pressure Pump
Injector
High-Pressure Accum.
Metering Unit
Fuel Pressure Lines
Charged Air
Sensor
Charge Air Elbow
Thermostat Housing
V-Belt
Tension Roller
Fan Support
Heat Protection
Prefilter
Cool. Water Piping - Water Cooled Radiator
Cool. Water Piping
Cool.Water Piping - Heating
Air Cleaner
Air Cleaner - Clean Air Tube
Bulkhead
Boost Intercooling
Exhaust End Pipe
Exhaust Brake
Exhaust After-Treatment
Exhaust After-Treatment - Tank Adblue
Exhaust After-Treatment - Supply Unit
Exhaust After-Treatment - Pipelines
Speed Control
Visco Fan
Engine Pre-Heater
Axle Bridge
Drive
Joint Shafts
Planetary Drive
Joint Housing
Steering Cylinder
Tie Rod
Steering Cyl.Guard
Pipes Steering Cyl.
Joint Shaft
Shaft Protection
Spring Assembly
Spring Cylinder
Tubes Fr.Axle Spring
Front Weight Carrier
Hoop Guard
Front Weight Carrier - Front Axle Weight
Front Ballast Weight
Steering Wheel
Steering Column
Mounting Unit
Steering Unit
Gearbox-Housing
Rear Axle Housing
Rear Axle Cover
Valve Syst.Comfort
Oil Level Indicator
Final Drive
Disc Brake
Foot Brake Actuating
Brake Booster
Pipes Brake System
Brake Pipe
Shuttle Valve - Trailer Brake Valve
Actuating Cylinder
Hand Brake Lever
Hand Brake Actuating
Hand Brake Valve
Pipes Brake System - Handbrake
Park Brake - Brake Cylinder
Clutch Actuating
Clutch Disc
Suspension El. - Gear
Gear
Cover
Bevel Drive
Duct Plate
Adjusting Device
Tubes System Comfort
Group Gear Shifting
P.T.O. Clutch
Engine P.T.O. - Brake Assembly
Engine P.T.O.
Flange - Engine P.T.O.
P.T.O. Actuating
Pump Drive
Pump Installation
Lube Oil Pump
Gear Box Lubrication
Valve Unit - Filter
Pipes General - Measuring Point
Pipes Oil Cooler
Valve Unit - Group Gear Shifting
Pipes Diff.Lock Fr.
Front P.T.O. - Propel
Front P.T.O. - Clutch
Front P.T.O. - Transmission
Front P.T.O. - Housing
Front P.T.O.
Front Wheel Drive Constant
Front Wheel Drive - Shaft
Front Wheel Drive - Coupler
Compressed Air System
Air Presser
Pressure Pipes
Defrosting Pump
Pressure Regulator - Spill-Valve
Air Tank
Brake-Armatures Inst
Double Pipe Brake
Double Pipe Brake - Duomatic Clutch
Double Pipe Brake - Italy
Air Brake Single
Pump Installation - Power Version
Pump Installation - Profi
Pipes Basic Circuit
Pipes Basic Circuit - Piston Pump
Trailer Brake Valve
Pipes Hd.Trail.Brake
Pipes Power-Lift - Single
Shift
Pipes Power-Lift - Double Acting
Press. Relief Valve - Double Acting
Pipes-With Oil Cool.
Pipes Hydr. Steering
Pipes El.Hydr.Steer.
Valve Installation - Profi
Valve Installation - Power Version
Valve Unit
Directional C. Valve - Profi
Directional C. Valve - Power Version
Control Valve - Single Acting
Control Valve - Double Acting
Spacer
End Plate - Lower
End Plate - Side
Hydr.Conn. D.A. Rear
Coupling Sleeve - Lever
Leak Oil Line
Ext.Pless.Connection
Return Flow
Returflow Rear
Hydr.Conn. D.A.Front - Profi
Hydr.Conn. D.A.Front - Power Version
Bottle
Return Flow Front
Dynamo
Headlight
Work Lamp
Lighting - Front
Lighting - Rear
Licence Plate Holder
Control Part
Central Electric System
Switch - Drivers Cab
Column Assemb.Switch
Switch - Motor
Transmitter - Motor
Transmitter - Exhaust After-Treatment
Switch
Transmitter - Gear
Cable Loom - Supply
Cable Loom - Valves
Cable Loom
Cable Loom - Drivers Cab
Cable Loom - Cabin Roof
Male
Cable Loom - Camera
Disconnection Points
Socket F. Implements
Cable Loom - External Counter
Reverse Beeper
Socket For Abs
Battery Disconnect Relay
Starter Installation
Socket F.Trail.Light
Socket - Front
Additional Lighting
Work Lamp - Cabin-Roof Front
Work Lamp - Indicator Bracket
Work Lamp - Cabin-Roof Rear
Work Lamp - Extendet Vehicle Width
Signal Light
Signal Light - Led
Extendet Vehicle Width - Lighting
Display
Terminal
Radar Sensor
Electronic Box
Control
Arm Rest
Comfort System
Tachograph
Control Box
Cabin Frame
Column Panelling
Mounting Parts
Roof
Roof Hatch
Coating - Roof
Coating
Left Hand Door
Door Lock
Right Hand Door
Windscreen
Side Pane
Rear Window Pane
Floor Covering
Drivers-Cabin Outfit
Mobile Phone - Support Bracket
Support Bracket - Terminal
Interior Lighting
Radio Installation Kit
Hands-Free Speaking
Rear View Mirror
Sun Visor
Windshield Wiper
Windscreen Wash-Inst
Tubes Heating
Aeration
Compressor Install.
Tubes F.Refrig.Fluid
Condenser
Body
Tractor Hood
Front Module
Side Part - Left Hand
Side Part - Right Hand
Hood Support
Operator Seat
Seat Spring Assy
Base Plate
Service Package
Security Belt
Instructor Seat
Passenger Seat - Grammer
Tools
Tool Box
Trailer Hitch
Trailer Hitch - Italy
Ball Type Clevis
Remote Control
Retainer
Forced Steering
Piton Fix
Bottom Hitch Assy
Entry Left
Entry Right
Entry Right - Splash-Guard
Base For Frame - Front
Base For Frame - Rear
Air Pipe - Rear
Labeling
Warning Plate
Base
Sound Insulation
Front Disc Wheels
Adjust. Front Wheels
Adjustab.Rear Wheels
Row Crop Wheels - Rear
Mud Guard - Rigid
Swivelling Mudguard
Track Adjustment
Mudguard Rear
Mudguard Enlargement
Implement Lift System Front
Tube
Top Link
Top Link - Support Bracket
Bottom Link
Directional C. Valve - Front Power Lift
Loading Weight
Additional Weight
Carrier
Hitch - Loading Weight
Power Lift
Oil Tank - Profi
Oil Tank - Baseline
Oil Tank - Mounting Parts
Draft Pin
El.Hd.Remote Control
Lift Arms
Support - Left Hand
Support - Right Hand
Link Holder - Top Link
Hydr. Upper Link
Hydr. Upper Link - 90mm
Hydr. Upper Link - Mounting Parts
Link Holder - Hydr. Upper Link
Ball Retainer
Front Rear Loaders
Mounting Frame
Hood Protection
Mounting Bracket
Hoist
Support Leg
Reversing Lever
Dumping Cylinder
Dumping Cylinder - Cargo Professional
Parallelogr.Mounting
Lift Cylinder
Fast Coupl.Frame
Fast Coupl.Frame - Hydraulic
Cylinder - Latching
Valve Unit - Fast Coupl.Frame
Piping Lift Arm
Piping Parallelogrr.
Valve Unit - 3rd Hydr. Circuit
Equipment - 3rd Hydr. Circuit
Equipment - 4th Hydr. Circuit
Multi-Coupling - Equipment
Damping
Solenoid Valve - Damping
Connecting Pipe
Multi-Coupling
Multi-Coupling - Tube
Electrical Equipment
Electrical Kit - Cargo Professional
Electrical Equipment - Cargo Professional
Pallet Fork
Universal Scoop
Light Goods Bucket
Heavy Goods Bucket
Silage Bucket 1800
Silage Bucket 2200
Hydraulic Equipment - Silage Grapple
Hydr. Cylinder - Silage Grapple
Manure Fork
Bale Grab
Hydraulic Equipment - Bale Grab
Hydr. Cylinder - Bale Grab
Bale Fork
Precision Farming Systems
Cable Loom - Varioguide
Base Station
Data Transfer - Vario-Doc
Wheel Wedge Mounting
EmerGency Pack
Warning System
Wheel Weights
Brand: Fendt
Crankcase
Enging Support
Mass Balancer Gear
Transmitter
Crankcase Breather
Front Cover
Gearcase
Adapter Housing
Female
Engine Mounting
Valve Cover
Rocker Arm
Head Gasket
Valve Drive
Camshaft
Piston
Connecting Rod
Main Bearing
Flywheel
Flywheel Cover
Oil Pan
Oil Filler
Filler Cap
Heating Connection
Exhaust Bend
Turbo-Supercharger
Heating-Flange
Electric Wiring
Relay
Fuel Lines
Fuel Pump
High-Pressure Pump
Injector
Metering Unit
Fuel Pressure Lines
Charged Air
Sensor
Charge Air Elbow
Thermostat Housing
V-Belt
Tension Roller
Fan Support
Heat Protection
Prefilter
Cool. Water Piping
Air Cleaner
Bulkhead
Boost Intercooling
Exhaust End Pipe
Exhaust Brake
Speed Control
Visco Fan
Engine Pre-Heater
Axle Bridge
Drive
Joint Shafts
Planetary Drive
Joint Housing
Steering Cylinder
Tie Rod
Steering Cyl.Guard
Pipes Steering Cyl.
Joint Shaft
Shaft Protection
Spring Assembly
Spring Cylinder
Hoop Guard
Steering Wheel
Steering Column
Mounting Unit
Steering Unit
Gearbox-Housing
Rear Axle Housing
Rear Axle Cover
Valve Syst.Comfort
Oil Level Indicator
Final Drive
Disc Brake
Brake Booster
Pipes Brake System
Brake Pipe
Actuating Cylinder
Hand Brake Lever
Hand Brake Valve
Clutch Actuating
Clutch Disc
Gear
Cover
Bevel Drive
Duct Plate
Adjusting Device
Group Gear Shifting
P.T.O. Clutch
Engine P.T.O.
P.T.O. Actuating
Pump Drive
Pump Installation
Lube Oil Pump
Valve Unit - Filter
Pipes Oil Cooler
Pipes Diff.Lock Fr.
Front P.T.O.
Air Presser
Pressure Pipes
Defrosting Pump
Air Tank
Double Pipe Brake
Air Brake Single
Pipes Basic Circuit
Trailer Brake Valve
Shift
Valve Unit
Spacer
End Plate - Lower
End Plate - Side
Leak Oil Line
Return Flow
Returflow Rear
Bottle
Return Flow Front
Dynamo
Headlight
Work Lamp
Lighting - Front
Lighting - Rear
Control Part
Switch - Motor
Transmitter - Motor
Switch
Transmitter - Gear
Cable Loom - Supply
Cable Loom - Valves
Cable Loom
Male
Cable Loom - Camera
Reverse Beeper
Socket For Abs
Socket - Front
Additional Lighting
Signal Light
Signal Light - Led
Display
Terminal
Radar Sensor
Electronic Box
Control
Arm Rest
Comfort System
Tachograph
Control Box
Cabin Frame
Column Panelling
Mounting Parts
Roof
Roof Hatch
Coating - Roof
Coating
Left Hand Door
Door Lock
Right Hand Door
Windscreen
Side Pane
Rear Window Pane
Floor Covering
Interior Lighting
Hands-Free Speaking
Rear View Mirror
Sun Visor
Windshield Wiper
Tubes Heating
Aeration
Compressor Install.
Condenser
Body
Tractor Hood
Front Module
Hood Support
Operator Seat
Seat Spring Assy
Base Plate
Service Package
Security Belt
Instructor Seat
Tools
Tool Box
Trailer Hitch
Ball Type Clevis
Remote Control
Retainer
Forced Steering
Piton Fix
Bottom Hitch Assy
Entry Left
Entry Right
Air Pipe - Rear
Labeling
Warning Plate
Base
Sound Insulation
Front Disc Wheels
Mud Guard - Rigid
Swivelling Mudguard
Track Adjustment
Mudguard Rear
Tube
Top Link
Bottom Link
Loading Weight
Additional Weight
Carrier
Power Lift
Oil Tank - Profi
Oil Tank - Baseline
Draft Pin
Lift Arms
Support - Left Hand
Hydr. Upper Link
Ball Retainer
Front Rear Loaders
Mounting Frame
Hood Protection
Mounting Bracket
Hoist
Support Leg
Reversing Lever
Dumping Cylinder
Lift Cylinder
Fast Coupl.Frame
Cylinder - Latching
Piping Lift Arm
Damping
Connecting Pipe
Multi-Coupling
Pallet Fork
Universal Scoop
Light Goods Bucket
Heavy Goods Bucket
Silage Bucket 1800
Silage Bucket 2200
Manure Fork
Bale Grab
Bale Fork
Base Station
EmerGency Pack
Warning System
Wheel Weights
