BigBoss1
106
307,104
FENDT Tractor 207F VARIO S3 (WAM239XXX00F00101-99999) Part Book
Brand: FENDT
Type of Manual: Part Book
Model: FENDT 207F VARIO S3 (WAM239XXX00F00101-99999) Tractor
Publication Date: 2025
Number of Pages: 762 Pages
TABLE OF CONTENT PAG 00-TOC Tech Spec Notes Ref
GENERAL INFORMATION PAG 01-000-TOC Tech Spec Notes Ref
FILTERS GUIDE PAG 01-0001
ENGINE, FUEL AND EXHAUST SYSTEM PAG 02-000-TOC Tech Spec Notes Ref
ENGINE ASSEMBLIES - ENGINE SERIAL NUMBER RANGE D61038-KLD501019 PAG 02-0001
ENGINE - RETAINER PAG 02-0002
CYLINDER BLOCK PAG 02-0003
TIMING GEARS & HOUSING PAG 02-0004
FLYWHEEL & HOUSING PAG 02-0005
CRANKSHAFT & PISTONS PAG 02-0006
CAMSHAFT & VALVE MECHANISM PAG 02-0007
CYLINDER HEAD PAG 02-0008
VALVE ROCKER COVER PAG 02-0009
INTAKE MANIFOLD PAG 02-0010
TURBOCHARGER & EXHAUST MANIFOLD PAG 02-0011
EXHAUST GAS RECIRCULATION (EGR) PAG 02-0012
OIL PUMP & SUMP PAG 02-0013
OIL COOLER & OIL FILTER PAG 02-0014
CLOSED CRANKCASE VENTILATION (CCV) PAG 02-0015
COOLANT PUMP & THERMOSTAT PAG 02-0016
FUEL INJECTION SYSTEM PAG 02-0017
FUEL FILTERS PAG 02-0018
ELECTRONIC ENGINE MANAGEMENT PAG 02-0019
ALTERNATOR PAG 02-0020
STARTER MOTOR PAG 02-0021
ENGINE OVERHAUL PARTS PAG 02-0022
SPECIAL OVERHAUL PARTS PAG 02-0023
ENGINE AIR FILTER PAG 02-0024
WATER COOLER PAG 02-0025
EXPANSION TANK PAG 02-0026
CHARGE AIR COOLER PAG 02-0027
FUEL TANK PAG 02-0028
FUEL LINES PAG 02-0029
EXHAUST - EXHAUST AFTER-TREATMENT PAG 02-0030
EXHAUST - EXHAUST AFTER-TREATMENT PAG 02-0031
VISCOSTATIC FAN PAG 02-0032
VISCOSTATIC FAN - REVERSIBLE FAN PAG 02-0033
VALVE BLOCK (COMPONENTS) - REVERSIBLE FAN PAG 02-0034
SPEED CONTROL PAG 02-0035
SPEED CONTROL PAG 02-0036
ENGINE PRE-HEATER PAG 02-0037
AXLES PAG 03-000-TOC Tech Spec Notes Ref
FRONT AXLE SUPPORT PAG 03-0001
FRONT AXLE SUPPORT - MOUNTING UNIT PAG 03-0002
FRONT AXLE SUPPORT - INTERMEDIATE PIECE PAG 03-0003
FRONT AXLE SUPPORT - ANGLE PAG 03-0004
MOUNTING UNIT - FRONT PAG 03-0005
SUSPENSION CYLINDER PAG 03-0006
MOUNTING UNIT - REAR PAG 03-0007
SENSOR - ROTATION ANGLE PAG 03-0008
AXLE BRIDGE PAG 03-0009
DRIVE PAG 03-0010
JOINT HOUSING PAG 03-0011
DRIVE SHAFT PAG 03-0012
PLANETARY TRAIN PAG 03-0013
STEERING CYLINDER (COMPONENTS) PAG 03-0014
PIPES STEERING CYLINDER PAG 03-0015
TUBES FR.AXLE SPRING - FRONT PAG 03-0016
TUBES FR.AXLE SPRING - FRONT PAG 03-0017
TUBES FR.AXLE SPRING - BRACKET PAG 03-0018
TUBES FR.AXLE SPRING - REAR PAG 03-0019
TUBES FR.AXLE SPRING - REAR PAG 03-0020
TUBES FR.AXLE SPRING - REAR PAG 03-0021
TUBES FR.AXLE SPRING - VALVE INSTALLATION PAG 03-0022
DRIVE SHAFT PAG 03-0023
DRIVE SHAFT - FRONT AXLE WITH SUSPENSION PAG 03-0024
HITCH PAG 03-0025
FRONT AXLE WEIGHT PAG 03-0026
FRONT AXLE WEIGHT - ADDITIONAL WEIGHT PAG 03-0027
STEERING SYSTEM PAG 04-000-TOC Tech Spec Notes Ref
STEERING WHEEL PAG 04-0001
STEERING COLUMN PAG 04-0002
STEERING COLUMN - AUTOGUIDE PAG 04-0003
STEERING COLUMN - MOUNTING PARTS PAG 04-0004
STEERING UNIT PAG 04-0005
STEERING UNIT - AUTOGUIDE PAG 04-0006
DRIVETRAIN SYSTEM PAG 05-000-TOC Tech Spec Notes Ref
TRANSMISSION HOUSING PAG 05-0001
REAR AXLE HOUSINGS PAG 05-0002
OIL LEVEL INDICATOR PAG 05-0003
DIFFERENTIAL PAG 05-0004
FINAL DRIVE PAG 05-0005
FOOT BRAKE PAG 05-0006
FOOT BRAKE ACTUATING PAG 05-0007
BRAKE BOOSTER PAG 05-0008
PIPES BRAKE SYSTEM PAG 05-0009
PIPES BRAKE SYSTEM PAG 05-0010
HANDBRAKE LEVER PAG 05-0011
HANDBRAKE VALVE PAG 05-0012
HANDBRAKE PAG 05-0013
CLUTCH ACTUATING PAG 05-0014
CLUTCH DISC PAG 05-0015
GEARBOX PAG 05-0016
PIVOT - GEARBOX PAG 05-0017
GEARBOX - PIVOT PAG 05-0018
CHANNEL PLATE - VALVES PAG 05-0019
ADJUSTING DEVICE PAG 05-0020
ADJUSTING DEVICE - LEVER PAG 05-0021
TUBES SYSTEM COMFORT PAG 05-0022
BEVEL DRIVE PAG 05-0023
TRANSMISSION LUBRICATION PAG 05-0024
SHIFTING PAG 05-0025
PTO (POWER TAKE-OFF) CLUTCH PAG 05-0026
ENGINE P.T.O. PAG 05-0027
P.T.O.INDEP.PROPORT. PAG 05-0028
P.T.O. ACTUATING PAG 05-0029
PUMP INSTALLATION PAG 05-0030
GEAR PUMP PAG 05-0031
PUMP DRIVE PAG 05-0032
PUMP DRIVE PAG 05-0033
VALVE BLOCK (COMPONENTS) PAG 05-0034
FILTERS PAG 05-0035
OIL COOLER PAG 05-0036
VALVE BLOCK (COMPONENTS) PAG 05-0037
VALVE SYST.COMFORT PAG 05-0038
PIPES DIFF.LOCK FR. PAG 05-0039
FRONT PTO (POWER TAKE-OFF) - GEARSHIFT PAG 05-0040
FRONT PTO (POWER TAKE-OFF) - CLUTCH PAG 05-0041
FRONT PTO (POWER TAKE-OFF) - CLUTCH PAG 05-0042
FRONT PTO (POWER TAKE-OFF) - GEARBOX PAG 05-0043
FRONT PTO (POWER TAKE-OFF) - HOUSING PAG 05-0044
FRONT PTO (POWER TAKE-OFF) - HOUSING PAG 05-0045
FRONT PTO (POWER TAKE-OFF) - HYDRAULIC LINES PAG 05-0046
FRONT WHEEL DRIVE CONSTANT PAG 05-0047
FRONT WHEEL DRIVE PAG 05-0048
COMPRESSED AIR SYSTEM PAG 06-000-TOC Tech Spec Notes Ref
AIR COMPRESSOR & BELT PAG 06-0001
CLAMPING DEVICE PAG 06-0002
BRAKE-ARMATURES INST - RETAINER PAG 06-0003
BRAKE-ARMATURES INST PAG 06-0004
BRAKE-ARMATURES INST PAG 06-0005
SHUTTLE VALVE - PIPING PAG 06-0006
PRESSURE PIPES PAG 06-0007
AIR TANK PAG 06-0008
DOUBLE PIPE BRAKE PAG 06-0009
AIR DRYER PAG 06-0010
HYDRAULIC SYSTEM PAG 07-000-TOC Tech Spec Notes Ref
GASKETS - PIPE LINES PAG 07-0001
PUMP INSTALLATION PAG 07-0002
PISTON PUMP PAG 07-0003
GEAR PUMP PAG 07-0004
BASIC PIPES CIRCUIT - BASIC SCOPE PAG 07-0005
BASIC PIPES CIRCUIT PAG 07-0006
BASIC PIPES CIRCUIT PAG 07-0007
BASIC PIPES CIRCUIT PAG 07-0008
BASIC PIPES CIRCUIT PAG 07-0009
BASIC PIPES CIRCUIT PAG 07-0010
BASIC PIPES CIRCUIT PAG 07-0011
BASIC PIPES CIRCUIT PAG 07-0012
BASIC PIPES CIRCUIT PAG 07-0013
BASIC PIPES CIRCUIT PAG 07-0014
PIPES HYDRAULIC STEERING PAG 07-0015
ELECTRO-HYDRAULIC STEERING PIPES PAG 07-0016
PIPES HYDRAULIC TRAILER BRAKE - FRONT PAG 07-0017
PIPES HYDRAULIC TRAILER BRAKE - REAR PAG 07-0018
TRAILER BRAKE VALVE PAG 07-0019
TRAILER BRAKE VALVE PAG 07-0020
PIPES HYDRAULIC TRAILER BRAKE - FRONT PAG 07-0021
PIPES HYDRAULIC TRAILER BRAKE - REAR PAG 07-0022
PIPES HYDRAULIC TRAILER BRAKE - SHUTTLE VALVE PAG 07-0023
PIPES-WITH OIL COOL. PAG 07-0024
PIPES POWER-LIFT PAG 07-0025
STROKE LIMITER PAG 07-0026
PIPES POWER-LIFT - TILT ADJUSTMENT PAG 07-0027
PIPES POWER-LIFT - TILT ADJUSTMENT PAG 07-0028
VALVE INSTALLATION - RIGHT SIDE PAG 07-0029
VALVE INSTALLATION - RIGHT SIDE PAG 07-0030
VALVE INSTALLATION - RIGHT SIDE PAG 07-0031
VALVE INSTALLATION - RIGHT SIDE PAG 07-0032
VALVE INSTALLATION - LEFT SIDE PAG 07-0033
VALVE INSTALLATION - LEFT SIDE PAG 07-0034
VALVE - FRONT AXLE WITH SUSPENSION PAG 07-0035
HYDR.CONN. D.A. MID. - RIGHT SIDE PAG 07-0036
HYDR.CONN. D.A. MID. - RIGHT SIDE PAG 07-0037
HYDR.CONN. D.A. MID. - RIGHT SIDE PAG 07-0038
HYDR.CONN. D.A. MID. - RIGHT SIDE PAG 07-0039
HYDR.CONN. D.A. MID. - LEFT SIDE PAG 07-0040
HYDR.CONN. D.A. MID. - LEFT SIDE PAG 07-0041
CASEDRAIN - MIDDLE PAG 07-0042
CASEDRAIN - MIDDLE PAG 07-0043
RETURNFLOW MIDDLE - RIGHT SIDE PAG 07-0044
RETURNFLOW MIDDLE - LEFT SIDE PAG 07-0045
CROSS CONNECTION PAG 07-0046
HYDR.CONN. D.A. REAR - 1.1 PAG 07-0047
HYDR.CONN. D.A. REAR - 1.2 PAG 07-0048
HYDR.CONN. D.A. REAR - 1.3 PAG 07-0049
HYDR.CONN. D.A. REAR - 1.4 PAG 07-0050
HYDR.CONN. D.A. REAR - 1.5 PAG 07-0051
RETURFLOW REAR PAG 07-0052
COUPLING SLEEVE - CONNECT UNDER PRESSURE (CUP) COUPLING PAG 07-0053
COUPLING SLEEVE - CONNECT UNDER PRESSURE (CUP) COUPLING PAG 07-0054
ELECTRICAL SYSTEM PAG 08-000-TOC Tech Spec Notes Ref
HEADLIGHT PAG 08-0001
LIGHTING - A-PILLAR PAG 08-0002
LIGHTING - A-PILLAR PAG 08-0003
LIGHTING - REAR PAG 08-0004
LICENSE PLATE HOLDER - CABIN ROOF HIGH PAG 08-0005
LICENSE PLATE HOLDER - CABIN ROOF LOW PAG 08-0006
RELAIS MOUNTING PAG 08-0007
SWITCHES PAG 08-0008
SWITCH - CAB PAG 08-0009
SWITCH - CAB PAG 08-0010
STEERING COLUMN SWITCH PAG 08-0011
TRANSMITTER - TRANSMISSION PAG 08-0012
CABLE LOOM - SUPPLY PAG 08-0013
CABLE LOOM - ENGINE PAG 08-0014
CABLE LOOM - GEAR PAG 08-0015
CABLE LOOM - BASE PAG 08-0016
CABLE LOOM - CABIN ROOF HIGH PAG 08-0017
CABLE LOOM - CABIN ROOF LOW PAG 08-0018
DISCONNECTION POINTS PAG 08-0019
SOCKET FOR IMPLEMENTS PAG 08-0020
BATTERY DISCONNECT RELAY PAG 08-0021
BATTERY INSTALLATION PAG 08-0022
REAR POWER OUTLET PAG 08-0023
REVERSE BUZZER PAG 08-0024
ADDITIONAL LIGHTING PAG 08-0025
WORK LIGHTS - ROOF (FRONT) PAG 08-0026
WORK LIGHTS - ROOF (FRONT) PAG 08-0027
WORK LIGHTS - ROOF (FRONT) PAG 08-0028
WORK LIGHTS - A-PILLAR PAG 08-0029
WORK LIGHTS - A-PILLAR PAG 08-0030
WORK LIGHTS - REAR ROOF PAG 08-0031
WORK LIGHTS - REAR ROOF PAG 08-0032
ROTARY BEACON PAG 08-0033
ROTARY BEACON PAG 08-0034
COMBI-INSTRUMENT - CONTROL PART PAG 08-0035
ELECTRONIC BOX PAG 08-0036
GEARBOX - ADJUSTING DEVICE PAG 08-0037
ARMREST - POWER VERSION PAG 08-0038
ARMREST - PROFI VERSION PAG 08-0039
CONTROL PART PAG 08-0040
CAB PAG 09-000-TOC Tech Spec Notes Ref
CABIN FRAME PAG 09-0001
MOUNTING PARTS PAG 09-0002
ROOF - BOTTOM PAG 09-0003
ROOF - UPPER PART PAG 09-0004
ROOF HATCH PAG 09-0005
CABIN ROOF LOW PAG 09-0006
DOORS PAG 09-0007
DOOR LOCK PAG 09-0008
WINDSHIELD PAG 09-0009
REAR WINDOW PAG 09-0010
FLOOR COVERING PAG 09-0011
TRIM PAG 09-0012
TRIM PAG 09-0013
TRIM PAG 09-0014
TRIM PAG 09-0015
TRIM PAG 09-0016
TOOL BOX PAG 09-0017
HEATER PAG 09-0018
HEATER PAG 09-0019
HEATER PAG 09-0020
HEATER PAG 09-0021
TUBES HEATING PAG 09-0022
HEATING, VENTILATION PAG 09-0023
FUEL PUMP PAG 09-0024
HEATING DEVICE PAG 09-0025
AERATION PAG 09-0026
AERATION PAG 09-0027
REAR VIEW MIRROR PAG 09-0028
REAR VIEW MIRROR PAG 09-0029
SUN VISOR PAG 09-0030
SUN VISOR PAG 09-0031
WINDSHIELD WIPER PAG 09-0032
WIPER PAG 09-0033
WINDSHIELD WASH-INST PAG 09-0034
WINDSHIELD WASH-INST PAG 09-0035
INTERIOR LIGHT PAG 09-0036
INTERIOR LIGHT PAG 09-0037
COLUMN PANELLING PAG 09-0038
RADIO INSTALLATION KIT PAG 09-0039
RADIO INSTALLATION KIT PAG 09-0040
HANDS-FREE SYSTEM PAG 09-0041
CABIN EQUIPMENT PAG 09-0042
OPERATOR SEAT PAG 09-0043
SPRING ASSY PAG 09-0044
LOWER PART SUSPENSION PAG 09-0045
SUSPENSION UNIT PAG 09-0046
SECURITY BELT PAG 09-0047
AIR CONDITIONING AND HEATING SYSTEM PAG 10-000-TOC Tech Spec Notes Ref
COMPRESSOR PAG 10-0001
COMPRESSOR PAG 10-0002
REFRIGERANT LINES PAG 10-0003
EVAPORATOR PAG 10-0004
CONDENSER PAG 10-0005
ELECTRICAL EQUIPMENT PAG 10-0006
ELECTRICAL EQUIPMENT PAG 10-0007
MOUNTING PARTS PAG 10-0008
MOUNTING PARTS PAG 10-0009
CHASSIS PAG 11-000-TOC Tech Spec Notes Ref
FRONT CONSOLE FRAME PAG 11-0001
ENGINE HOOD PAG 11-0002
ENGINE HOOD - MOUNTING PARTS PAG 11-0003
SCREEN PAG 11-0004
SIDE WALL PAG 11-0005
ENTRY - CARRIER PAG 11-0006
ENTRY PAG 11-0007
ENTRY - CLADDING PAG 11-0008
BASE FOR FRAME PAG 11-0009
BASE PAG 11-0010
LABELING PAG 11-0011
LABELING PAG 11-0012
LABELING PAG 11-0013
LABELING PAG 11-0014
WHEELS PAG 12-000-TOC Tech Spec Notes Ref
DISC WHEELS REAR - 12 X 24 PAG 12-0001
DISC WHEELS REAR - 11 X 28 PAG 12-0002
ADJUSTABLE REAR WHEELS - 12 X 24 PAG 12-0003
ADJUSTABLE REAR WHEELS - 13 X 24 PAG 12-0004
ADJUSTABLE REAR WHEELS - 12 X 28 PAG 12-0005
FRONT DISC WHEELS - 8 X 16 PAG 12-0006
FRONT DISC WHEELS - 9 X 16 PAG 12-0007
FRONT DISC WHEELS - 9 X 18 PAG 12-0008
FRONT DISC WHEELS - 11 X 18 PAG 12-0009
FRONT DISC WHEELS - 9 X 20 PAG 12-0010
FRONT MUDGUARD - BOTTOM EXHAUST PAG 12-0011
FRONT MUDGUARD - EXHAUST UPRIGHT PAG 12-0012
FRONT MUDGUARD - EXHAUST UPRIGHT PAG 12-0013
WHEEL CAP PAG 12-0014
MUDGUARD ENLARGEMENT PAG 12-0015
MUDGUARD COVER PAG 12-0016
IMPLEMENT LIFT SYSTEM FRONT PAG 13-000-TOC Tech Spec Notes Ref
FRONT LINKAGE PAG 13-0001
FRONT LINKAGE - FRONT AXLE WITH SUSPENSION PAG 13-0002
HITCH - FRONT PAG 13-0003
DOUBLE ACTING HYDRAULIC CYLINDER - FRONT LINKAGE PAG 13-0004
PIPE LINES PAG 13-0005
UPPER LINK PAG 13-0006
UPPER LINK - SUPPORT PAG 13-0007
LOWER LINKS PAG 13-0008
WEIGHT CARRIER, FRONT PAG 13-0009
LOADING WEIGHT PAG 13-0010
LOADING WEIGHT PAG 13-0011
LOADING WEIGHT PAG 13-0012
IMPLEMENT LIFT SYSTEM REAR PAG 14-000-TOC Tech Spec Notes Ref
LIFTING MECHANISM PAG 14-0001
LIFTING MECHANISM PAG 14-0002
LIFTING MECHANISM - BRACE PAG 14-0003
DOUBLE ACTING HYDRAULIC CYLINDER PAG 14-0004
OIL TANK - OIL FILLER PAG 14-0005
OIL TANK - BREATHER PAG 14-0006
OIL TANK PAG 14-0007
OIL TANK - GEAR PUMP PAG 14-0008
OIL TANK - CONTROL PUMP PAG 14-0009
SUPPORT - MECHANICAL PAG 14-0010
SUPPORT - HYDRAULIC PAG 14-0011
SENSING PIN PAG 14-0012
PATH-MEASURE SYSTEM PAG 14-0013
LOWER LINKS - LONG PAG 14-0014
QUICK COUPLING - LOWER LINKS PAG 14-0015
QUICK COUPLING - LOWER LINKS PAG 14-0016
VALVE BLOCK (COMPONENTS) PAG 14-0017
LIFTING DEVICE PAG 14-0018
TOP LINK PAG 14-0019
UPPER LINK - BRACKET PAG 14-0020
TILT ADJUSTMENT - INDICATOR PAG 14-0021
LINKAGE PAG 15-000-TOC Tech Spec Notes Ref
SLIDE RAIL - TRAILER HITCH PAG 15-0001
LOCKING DEVICE PAG 15-0002
TRAILER HITCH PAG 15-0003
TRAILER HITCH PAG 15-0004
REAR PTO (POWER TAKE-OFF) GUARD PAG 15-0005
TRAILER HITCH PAG 15-0006
TRAILER HITCH PAG 15-0007
ACCESSORIES PAG 16-000-TOC Tech Spec Notes Ref
WHEEL WEIGHTS - REAR WHEEL PAG 16-0001
WARNING SYSTEM PAG 16-0002
IMPLEMENT FRAME PAG 16-0003
BRAKE LEVER SUPPORT PAG 16-0004
HOSE SUPPORT PAG 16-0005
HOSE SUPPORT PAG 16-0006
TOOL PAG 16-0007
UPPER LINK - ACCESSORIES PAG 16-0008
SLIDE RAIL - ACCESSORIES PAG 16-0009
